Author Topic: [TMK] Keyboard Protocol Converter  (Read 369053 times)
Offline Drag0nFly
Re: [TMK] Keyboard Protocol Converter
« Reply #200 on: Thu, 03 August 2023, 00:25:49 »
Here are some pictures of the Acorn Archimedes A300 kybd–
Offline hasu
  •  Moderator
  • @tmk
« Reply #201 on: Thu, 03 August 2023, 09:04:16 »
With reading this article Convergent/Unisys/Burroughs B25-K5 is not compatible with AT apparently.
https://www.smbaker.com/restoring-a-convergent-technologies-ngen-pc-workstation-burroughs-b25-unisys
Let me have some time to reseach Acorn keyboard protocol. I'll PM later.
Offline Drag0nFly
« Reply #202 on: Thu, 03 August 2023, 16:54:33 »
 :thumb: – looking forward to what you find. Thanks also for the information on the Unisys–too bad it's not AT compatible (although I was aware that might be a bit optimistic...)
Offline Drag0nFly
« Reply #203 on: Thu, 03 August 2023, 18:24:28 »
Man, was that page on the Convergent/Unisys detailed, with schematics and all. Did not come up during any of my web searches earlier.
The guy also built a Convergent to PS2 keyboard converter, with the 8-pin SDL plug.
He also has the same/similar small form-factor keyboard as me used for testing. That one is extremely practical (although mine is USB)
Offline Drag0nFly
« Reply #204 on: Thu, 07 September 2023, 18:30:30 »
Hi @hasu,
Just wondering if you had time to research this yet, and how feasible it would be to create firmware for the Acorn keyboards with the KART protocol. I can be of assistance wrt. sending a keyboard for this, if required. :)
Offline cavilio
« Reply #205 on: Fri, 22 September 2023, 03:08:55 »
Hi @hasu,
I am willing to purchase 2 of your USB to USB converters, in order to add programmability to a Ducky mecha mini and a Pok3r. Do you still sell those? How to proceed to order them (I live in France)?
« Last Edit: Fri, 22 September 2023, 07:20:38 by cavilio »
Offline hasu
  •  Moderator
  • @tmk
« Reply #206 on: Fri, 22 September 2023, 20:12:04 »
Hi,
Yes, it is still available in stock.
Check the first post of this thread to place an order.
How to order
Please check this notes on shipping under COVID-2019 pandemic before ordering. 2020-04-02
Email me to let me know which converter you want and your country. I'll send you Paypal invoice soon.
My email is: hasu@tmk-kbd.com
Offline cavilio
« Reply #207 on: Sun, 01 October 2023, 04:12:37 »
Hi,
Thanks, I will send you an email right now!
Offline Akarui
« Reply #208 on: Sat, 27 April 2024, 05:44:41 »
Greeting
I'm wondering if the NEC 9800 converter would slightly work with NEC 8801 if the NEC is plugged in with a 5 pin to 8 pin mini din?
Offline hasu
  •  Moderator
  • @tmk
« Reply #209 on: Sat, 27 April 2024, 07:56:25 »
Hi,
Converter for PC-9801 does not work with PC-8801. The two keyboards are different in terms of their protocol and signals.
Greeting
Offline ermilokss
« Reply #210 on: Sat, 11 May 2024, 11:05:53 »
Hello. I soldered adb-usb converter based on Arduino Pro Micro for Apple Extended Keyboard II.  Works good, its what i wanted to say, but keyboard randomly stop to respond while gaming. Num pad light is shiny which means keyboard is powered, but no button reacts to press. Tried with 1kOhm resistor and 2 parallel 1kOhm (500 Ohm), keyboard behaviour dont change. To fix this behaviour need to unplug-plug keyboard and its works until next random stop. Which solution for my situation can be?
Offline hasu
  •  Moderator
  • @tmk
« Reply #211 on: Sun, 12 May 2024, 19:20:10 »
Check open post of this thread, DEBUG section particularly.
https://geekhack.org/index.php?topic=14290.0
Post in the thread if you need further question.
Offline iereegha
« Reply #212 on: Mon, 24 June 2024, 18:18:40 »
Hi @hasu,
I would like to use several of those usb-usb-converters to port "sane" keyboard layouts to Windows without admin privileges.
The target Windows system only supports German layout as input method. The keyboards shall emulate (1) Neo2 and (2) US-International.
After reviewing
     http://www.tmk-kbd.com/tmk_keyboard/editor/unimap/?usb_usb
and
    https://github.com/tmk/tmk_keyboard/blob/master/converter/usb_usb/keymap.c
it is not clear to me how special German accentuated characters (äöüß) are encoded; How do I encode them in firmware?
Windows claims each attached keyboard is a ISO-layout with German keycaps. What characters can and cannot be encoded by sequences?
Additional links: Target layout (excluding the greek characters)
https://neo-layout.org/
https://de.wikipedia.org/wiki/Tastaturbelegung_US-International#/media/Datei:KB_US-International.svg
Offline hasu
  •  Moderator
  • @tmk
« Reply #213 on: Mon, 24 June 2024, 22:10:26 »
USB keyboards includes the converter send just a key code when the key is typed.
They don't send characters technically and won't work as what you are anticipating.
To input the characters(äöüß) converter firmware have to emulate how you are doing on the target Windows system.
To emulate the layout in firmware is very difficult if this is not impossible and you will have to write quite a bit of code yourself.
This may give you an idea on this topic.
https://github.com/tmk/tmk_keyboard/wiki/FAQ-Keymap#input-special-charactors-other-than-ascii-like-c%C3%A9dille-%C3%A7
Offline nicoverduin
« Reply #214 on: Tue, 25 June 2024, 07:05:17 »
No dounbt my ignorance but I have the following problem of which I hope somen can help me further.
I have an IBM keyboard type 1399625 of which I understand is a so-called terminal keyboard with character code set 3. I have tried al kinds of commercial adaptors with the same result that when I type a character it will be repeated endlessly. To my understanding it means that the adaptor does not receive a break code for the key pressed.
Does the soarer converter (PS/2 to USB) solve this problem?
Do I need to modify anything?
Can I set the codeset 3 into codeset 2? How?
kindest regards
Nico Verduin
Netherlands
Offline hasu
  •  Moderator
  • @tmk
« Reply #215 on: Tue, 25 June 2024, 20:33:03 »
I think you are right about the inference.
- Yes, both Soarer's and my TMK converter can support it.
- No. you don't need.
- The two converters should recognize its code set automatically.
There is a thread for Soarer's converter on this forum, you can get more specific help there.
https://geekhack.org/index.php?topic=17458.0
Offline nicoverduin
« Reply #216 on: Wed, 26 June 2024, 09:40:55 »
It Works !!!!!!
For now I just installed the 32U4 teensy 2.0 firmware on a leonardo
Cut my mini din connector with cable off my chinese adaptor (which didn't work anyway).
Connect it to the Leonardo and tried it with Word. Works like a charm.
I have to do some remapping (numlock and scroll lock leds do not turn on...yest)
But now I know the keyboard is fine making me happy!!!!
thank for the getting started help!!!
Nico
Offline hasu
  •  Moderator
  • @tmk
« Reply #217 on: Sun, 13 October 2024, 07:43:03 »
Rewrote NeXT conveter firmware and added mouse support.
https://github.com/tmk/tmk_keyboard/tree/master/converter/next_usb_ng
Mouse support is preliminary but it should work somewhat. I don't have NeXT mouse to test this feature and mouse movement direction is still unclear to me especially. Let me know your result if you have one.
https://github.com/tmk/tmk_keyboard/wiki/NeXT#tmk-prebuilt-converter
Thank you
Offline peterro
« Reply #218 on: Sun, 17 November 2024, 15:10:21 »
Hi,
I've been trying to get a Wyse 50 keyboard working using the soarer FW but have run into a dead end. It partially works but seems to have noise in the signal but what do I know about that. The full detail of what I've done is here: https://geekhack.org/index.php?topic=123803.0
Perhaps you either have some input or maybe I start over and you have a converter that would work. Any recommendations would be appreciated.
Thanks.
Offline DirtyGingy
« Reply #219 on: Sat, 31 May 2025, 16:51:38 »
I recently managed to pickup an FM Towns FMT-KB101A. It hasn't arrived yet, but I believe it uses the Hirose HR12 connector and the protocol is not the usual AT or XT a lot of boards I normally encounter use. Someone managed to point me toward this, but I'm at a loss so far. https://archive.org/details/3FmTowns/page/230/mode/2up
