Author Topic: Keyboards with built-in capslock+ctrl swapping?  (Read 10670 times)
Offline hitaki
« on: Thu, 28 May 2015, 01:08:24 »
I've become accustomed to having capslock and ctrl switched, by use of the hardware dipswitches on my keyboard.
I know you can swap capslock+ctrl  in software, but (I frequently switch desktops, keyboards, and operating systems) it's annoying to have to keep this setting in-synch..
The question is, which models offer hardware-based switches to swap capslock and ctrl? Alternatively, which keyboards offer firmware-based programming to do the equivalent? So far, I've seen capslock+ctrl swapping on the Ducky Shine 3, Leopold FC900R, Leopold FC660C, Leopold FC660M, Realforce 87UB and 87 10AE. What other vendors / models offer this functionality?
RF 87ub, RF 10th Anniversary Edition, Leopold FC660C, KUL ES-87, KBP v60
Offline MellowFellow
Re: Keyboards with built-in capslock+ctrl swapping?
« Reply #1 on: Thu, 28 May 2015, 01:10:49 »
if you already know the answers.... why bother asking...
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #2 on: Thu, 28 May 2015, 01:15:17 »
He asked what OTHER models have it. Jesus.
Offline user 18
« Reply #3 on: Thu, 28 May 2015, 01:19:44 »
Because the list isn't complete, and hitaki is looking for boards not on their list already :)
Off the top of my head, the KUL ES-87 has this functionality. I'm not sure how key remapping works on the poker series of boards, but it's possible that they could be remapped in the same way.
HHKB has control in that spot by default, not sure where caps is hidden in that layout though.
Avatar by ashdenej
Offline hitaki
« Reply #4 on: Thu, 28 May 2015, 04:00:28 »
I've looked at the Pok3r which doesn't seem to have it via hardware switch, but I think you can program it into one of the layers.
The V60 mini has dipswitches, and seems like one option lets you configure capslock to ctrl, and ctrl to fn key.
As you pointed out, I'm interested in what other models have this feature - as I have one TKL keyboard I quite like, except it doesn't have this built in.
Offline henz
  • What?
« Reply #5 on: Thu, 28 May 2015, 04:31:33 »
get a custom, then you can program it however you feel.
for example a nerd from gon.
Offline Bogus Bill
« Reply #6 on: Thu, 28 May 2015, 05:17:53 »
The Noppoo Choc Mini has a Caps/Left-Ctrl swap function, Fn+F9 does the trick. No aditional software/firmware required, simply plug and swap.
I think the Nano also has this function, but I'm not sure.
Offline Ludovician
« Reply #7 on: Thu, 28 May 2015, 05:29:28 »
Fn+Tab
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline bueller
  • MX baller
« Reply #8 on: Thu, 28 May 2015, 07:07:36 »
The KBT pure has it, not sure about the pro.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #9 on: Thu, 28 May 2015, 07:52:03 »
nice try
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #10 on: Thu, 28 May 2015, 13:48:17 »
IIRC the Northgate Omnikey has this. It's a DIP switch setting.
Offline strict
  • TKL Zealot
« Reply #11 on: Thu, 28 May 2015, 13:51:41 »
I have my Phantom remapped. Not through hardware of course but when you build the firmware you just tweak the keymap in the TMK config or using EasyAVR.
Offline Neo.X
« Reply #12 on: Thu, 28 May 2015, 14:42:05 »
Filco Minila
All those keyboards will be lost in time....
Offline FuriousGeorge
« Reply #13 on: Thu, 28 May 2015, 18:29:06 »
Tex Beetle has a dip switch setting.
« Reply #14 on: Fri, 29 May 2015, 03:04:48 »
The great thing about the KUL is that just doesn't swap which codes the keys send but that it also comes with additional keycaps with these legends and has a LED for the Caps Lock key in the lower left corner.
I have my Phantom mapped to have two left Control keys. This did require that I wrote code in the firmware especially to handle this case. If you happen to press both keys then you want the "key up" event to occur when you release the last pressed key, not the first pressed key.
Offline vvp
« Reply #15 on: Fri, 29 May 2015, 03:34:37 »
Kinesis Advantage allows you to remap any key to any other location with a few keystrokes.
E.g. sappping LCtrl/CapsL would be something like: Prog+F12 LCtrl CapsL CapsL Ctrl Prog+F12
Offline Nai_Calus
  • CLACK
« Reply #16 on: Fri, 29 May 2015, 04:51:37 »
WASD Code has this functionality via dipswitch.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline oscillik
    • music podcasts
« Reply #17 on: Fri, 29 May 2015, 04:54:14 »
indeed all WASD v2 keyboards have this
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline seville57
« Reply #18 on: Thu, 18 June 2015, 06:38:15 »
Ducky Shine 4 dipswitch.
« Last Edit: Thu, 18 June 2015, 06:40:26 by seville57 »
Offline opensecret
  • 公开的秘密
« Reply #19 on: Sun, 21 June 2015, 22:05:38 »
Your recall is correct.  Northgate sometimes made feature changes and produced some keyboards without the dip switches, but most Omnikeys have dip switches that allow switching Caps, Ctrl and Alt (and include replacement key caps), not to mention changing to other keyboard layouts, such as Dvorak.  A manual that explains all this is on-line at: http://deskthority.net/w/images/3/38/Northgate_OmniKey_Users_Guide_Apr92.pdf
IBM Model M |Matias Mini Quiet Pro|Plum 84EC-S|RealForce 103U-UW & 87U-UW|Omnikey Ultra T| 2 Omnikey Ultras| WASD V2| Xmit Hall Effect|
