Author Topic: What do you use for your Keyboard dust cover?  (Read 10435 times)
Offline dwk396
  • asdf1234
« on: Sun, 12 July 2015, 22:57:46 »
Here is my dust cover for hhkb.
Re: What do you use for your Keyboard dust cover?
« Reply #1 on: Sun, 12 July 2015, 23:36:06 »
Tea towel.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2 on: Mon, 13 July 2015, 00:28:32 »
Life is too short to worry about dust
Offline skuko
« Reply #3 on: Mon, 13 July 2015, 01:04:20 »
default filco dust cover :)
Offline dwk396
  • asdf1234
« Reply #4 on: Mon, 13 July 2015, 01:08:44 »
Life is too short so I want to keep things nice and neat....
« Reply #5 on: Mon, 13 July 2015, 01:52:07 »
Yeah, life is too short to spend time dusting keyboards all the time :p
Offline fanpeople
« Reply #6 on: Mon, 13 July 2015, 02:03:18 »
That is one expensive dust cover. I use a pillow case to throw over.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #7 on: Mon, 13 July 2015, 02:08:47 »
I don't use one at the moment, but I really should. I can go pick up one on elitekeyboards for like $15.
I'll probably order the one for the HHKB when I order my landing pads...
Offline seville57
« Reply #8 on: Mon, 13 July 2015, 06:58:18 »
Duckys own dust cover.
Offline Magna224
« Reply #9 on: Mon, 13 July 2015, 08:18:39 »
My focus 2001 has a stock dust cover ;)
« Reply #10 on: Mon, 13 July 2015, 08:30:19 »
I use that little rubber sheet that comes with some stock boards like Leopolds.
Offline Giorgio
« Reply #11 on: Mon, 13 July 2015, 09:24:52 »
I had the same keyboard for five years and I did never cover it. Maybe I work in a clean environment, or maybe I type so fast that it cleans itself with the turbulence  :thumb:
The simple idea of a dust cover makes me cringe. I'm not my granma.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #12 on: Mon, 13 July 2015, 09:28:03 »
My 5161 came with one, I made one for my KB-101A, and my FK-2001 has a built-in one. That's about it xD .
Offline Data
« Reply #13 on: Mon, 13 July 2015, 09:32:22 »
Dust cover?
They're called "hands".
Offline Giorgio
« Reply #14 on: Mon, 13 July 2015, 09:32:34 »
Well, dust happens also when you use it. An unused keyboard needs to be cleaned less that a keyboard used for many hours a day. Today you worry about the dust, tomorrow you'll worry about the shiny keycaps, the day after tomorrow you won't use your keyboard to preserve it spotless.  :))
Offline Giorgio
« Reply #15 on: Mon, 13 July 2015, 09:33:25 »
Good one.  :thumb:
Dust cover?
Offline davkol
  •  Post Editing Timeout
« Reply #16 on: Mon, 13 July 2015, 10:30:32 »
I put my QFR in a dust-free closet, whenever I'm not using it (99 % of time).
My TypeMatrix 2030 is always dressed in a silicone skin that prevents dust, hairs, spills,… from getting under the scissor switches and protects keycaps from sweat.
The ErgoDox usually sits on the tray, but I put a neoprene case (that I use to store the keyboard for traveling) or a mousepad upside down (because I don't want dust grinding between the mousepad or mouse feet) on it.
Offline animal
« Reply #17 on: Mon, 13 July 2015, 10:44:43 »
I use a small towel I got from a bar :)
Real men do it with a keyboard.
Offline EscapeVelocity
  • Antiquarian
« Reply #18 on: Mon, 13 July 2015, 15:40:08 »
Velour Cloth
« Reply #19 on: Mon, 13 July 2015, 15:43:05 »
Another entry for the stock ducky plastic cover.
I bought a piece of acrylic with intentions of making a cover but never got around to it.
  • Antiquarian
« Reply #20 on: Mon, 13 July 2015, 15:46:17 »
Most of the time, I dont bother.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #21 on: Mon, 13 July 2015, 16:30:48 »
I use my desk.  My keyboard tray slides under and has a front that flips up.
If my keyboard sat on my desk, I wouldn't bother as my hands are rarely "office" clean anyway due to work.
Offline dwk396
  • asdf1234
« Reply #22 on: Mon, 13 July 2015, 16:41:23 »
Ah...Okay....man... everytime I see some dirt/dust or some particles between keycaps, I am like "FUUUDDGEE I HAVE TO GET THAT OUT OF THERE"
Maybe I should just worry less about it.
I used to put a towel on top of my keyboards but I saw more dusts or whatyoumacallit that fell from the towel.
Offline Leslieann
« Reply #23 on: Mon, 13 July 2015, 17:37:14 »
My keyboard is such a b*dass, it repels dust.
(Just don't look under the keycaps.)
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #24 on: Mon, 13 July 2015, 19:27:35 »
you seem to have broken your spacebar by putting that ****ty leopold on top of it
Offline CaplockJack
« Reply #25 on: Mon, 13 July 2015, 19:37:42 »
None
Offline dwk396
  • asdf1234
« Reply #26 on: Mon, 13 July 2015, 21:23:54 »
lol maybe
Offline Macsmasher
« Reply #27 on: Wed, 15 July 2015, 00:23:46 »
I use the keyboard roofs from EK. Great for keeping out the dust, dog hair, etc. You don't realize just how much crap gets in there until you pull the keycaps. I have better things to do than clean out my keyboards.
Offline ynrozturk
« Reply #28 on: Wed, 15 July 2015, 20:04:51 »
The covers that I got from Elite Keyboards. Looks and works great.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline dwk396
  • asdf1234
« Reply #29 on: Wed, 15 July 2015, 20:12:04 »
maybe I should do that....
Offline SquawkVFR
« Reply #30 on: Wed, 15 July 2015, 22:47:25 »
You guys must live in much dustier places than me, I don't cover mine and never really had a dust problem...
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #31 on: Thu, 16 July 2015, 05:44:43 »
Same mine doesn't get dusty. No cover.
Offline dwk396
  • asdf1234
« Reply #32 on: Thu, 16 July 2015, 06:41:04 »
I live in a place where the land became so deserted like the movie interstellar.
Offline Shaussman
« Reply #33 on: Thu, 16 July 2015, 07:45:57 »
Most of that crap is my hair that gets in there when I'm using it or a couple of crumbs from when I have to eat at my keyboard or that sort of thing.
I don't bother covering my keyboard, dust really isn't an issue even in my dusty as hell dorm room.
MX Brown Quickfire XT | MX Clear WASD VP3 | MX Blue Ducky Zero
Offline quake4mhg
« Reply #34 on: Fri, 17 July 2015, 00:19:15 »
We gotta be creative ;D
Offline Doyniish
  • Good you
    • Power Hour Playlists
« Reply #35 on: Fri, 17 July 2015, 12:14:40 »
Same with me. My grandma had a serious problem with that type of thing  :eek:
