Author Topic: [GB][DONE] ROUND 2 LeandreN plate(designed by JDcarpe) + SPRiT PCB  (Read 254464 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB][Taking orders] LeandreN plate(designed by JDcarpe) + SPRiT PCB
« Reply #100 on: Sat, 08 August 2015, 01:00:52 »
Layouts supported by the PCB
"- Supports : Standard Winkey layout, 1.5x 1x 1.5x 7x Winkeyless, 1x 1.5x 7x 1.5x 1 HHKB, 1x1 Backspace
- Supports : most of currently available Keycaps : centered & off-centerd Capslock, 6x 6.25x 7x Spacebars, 1x1 Backspace, ANSI+ISO Shift & Enter"
Offline eeymiel
« Reply #101 on: Sat, 08 August 2015, 04:43:59 »
This is going to be my first custom build :)
Can I change the colour, after you post pictures? I think I'm going with a silver / white build, but if other colours look real nice I might want to change it.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #102 on: Sat, 08 August 2015, 07:27:26 »
Yes you can :)
Offline chalks
« Reply #103 on: Sat, 08 August 2015, 08:26:14 »
Does the PCB and plate support a short right shift, so I can put a function key next to it?
Offline cinnamoncider
  • Thorpies are snappy
  • No clack; no life.
« Reply #104 on: Sat, 08 August 2015, 09:41:41 »
Is it possible to lower the declared value?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #105 on: Sat, 08 August 2015, 09:48:16 »
Yes!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #106 on: Sat, 08 August 2015, 09:49:13 »
I'll check it up, but I think not.
Offline wlhlm
« Reply #107 on: Sat, 08 August 2015, 09:59:46 »
It does:
(picture by rpeterclark)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #108 on: Sat, 08 August 2015, 10:00:35 »
It does:
Thanks wlhlm!
Offline nmur
  • ಠ_ಠ
« Reply #109 on: Sat, 08 August 2015, 10:05:40 »
This photo from sprit's thread shows two boards with a short right shift with fn
Offline rpeterclark
  • RPTR ❌
« Reply #110 on: Sat, 08 August 2015, 13:27:28 »
Look at those sexy boards!  ;) Yes, SPRiT's PCBs support a short right shift.
Order placed! Not sure that I really need a 3rd SPRiT board, but I can't pass up the purple plate option. I may have to sell one once this comes in...
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #111 on: Sat, 08 August 2015, 13:31:28 »
« Reply #112 on: Sat, 08 August 2015, 15:44:57 »
Maybe I'm blind, but I don't see a deadline in the OP.
Offline wlhlm
« Reply #113 on: Sat, 08 August 2015, 15:48:54 »
What's the timeline for this buy?
I don't know yet. At least two weeks. Will update later
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #114 on: Sun, 09 August 2015, 01:34:54 »
Keep the orders coming!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #115 on: Mon, 10 August 2015, 01:40:02 »
28 plates ordered! thanks.
To those who just ordered a PCB, i would appericate if you could order a plate too. This was meant to be a comboprice, but since i forgot to mention, i'll let it go.
Anyway, keep orders coming, tell everyone!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #116 on: Mon, 10 August 2015, 02:35:06 »
Samples are being sent firday this week!
I also have some color samples!
I start it off with purple:
The picture has nothing to do with the actual plate and is just to give a picture of how it may look.
Offline TalkingTree
    • My projects
« Reply #117 on: Mon, 10 August 2015, 07:03:48 »
What do you mean by comboprice?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #118 on: Mon, 10 August 2015, 07:24:52 »
It was meant that the price of the PCB should be 45$ only if you bought the plate, but its just a few orders so I'll let it go. You bought a plate from me last time didn't you?
Offline Applet
« Reply #119 on: Mon, 10 August 2015, 07:30:58 »
Any updates on the deadline? And when will the invoicing be done? I'd really like to join, but I have to check my economy :)
Is it possible to run TMK-firmware on these boards? (not a deal breaker, but I use it for everything else)
« Last Edit: Mon, 10 August 2015, 07:38:56 by Applet »
Offline inde
« Reply #120 on: Mon, 10 August 2015, 08:10:13 »
could you explain a bit (or link something) so I can figure out how much else I'll need after buying plate + PCB + case?
Interested noob here :/
« Reply #121 on: Mon, 10 August 2015, 08:18:56 »
In addition to the PCB, plate, and case, you would need around 63 switches and a set of PCB mount stabilizers to build a complete keyboard. Well, keycaps also, but I assumed you know that. :)
Offline TalkingTree
    • My projects
« Reply #122 on: Mon, 10 August 2015, 09:00:55 »
Actually, two. I ordered three then gave up one ANSI to make room to another user who was interested.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #123 on: Mon, 10 August 2015, 09:01:34 »
Then its fine :)
Offline rpeterclark
  • RPTR ❌
« Reply #124 on: Mon, 10 August 2015, 09:01:58 »
I contacted the seller of the case that was suggested and he confirmed that he has the clear version of that as well even though it is not listed.
It's a $20 case so expectations are low, but these seem like a good cheap option that can be used until something nicer comes along!
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« Reply #125 on: Mon, 10 August 2015, 09:14:10 »
Actually it looks quite nice I think, I prefer the stock poker cases so if its anything like those its good for taking and carrying around daily!
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #126 on: Mon, 10 August 2015, 10:01:02 »
Awesome do you think it is possible to sand it down to get an acrylic led thingy?
« Reply #127 on: Mon, 10 August 2015, 10:02:49 »
Maybe an acetone vapor bath?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #128 on: Mon, 10 August 2015, 10:05:41 »
Okay, for this case.
Ways to customize it the way you want:
Buy the transparent version, sand it down to get the forsted acrylic look. Face the leds down and get an awesome look.
Vinyl wrap it in any pattern, texture and color you want.
« Reply #129 on: Mon, 10 August 2015, 10:09:39 »
I just want to add that my plate design should be compatible with any 60% PCB available. From a Poker to the GH60 to the GON NerD 60 to the Sprit 60% PCB, et cetera.
No need to worry if this plate will work with your PCB...it will! Just order!!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #130 on: Mon, 10 August 2015, 10:11:03 »
Yes, just because I have it in the order form doesn't mean that the SPRiT PCBs are the only alternative, they're just really cheap :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #131 on: Mon, 10 August 2015, 11:17:38 »
10 days :)
Offline aeonblack
« Reply #132 on: Mon, 10 August 2015, 12:05:00 »
Put me down for a dark red plate, black pcb, 135g springs and red led's.
Offline trenzafeeds
  • **** off
demik will never leave.
Unless he gets banned.
Offline zenless
« Reply #134 on: Mon, 10 August 2015, 12:20:48 »
I have my order in for one set of plate/pcb.
Now the question is does the order end before funds become available and i decide i should pick up more?
Offline aeonblack
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #137 on: Mon, 10 August 2015, 12:27:57 »
10 days, but i can delay payment a little :)
Offline trenzafeeds
  • **** off
« Reply #138 on: Mon, 10 August 2015, 12:44:13 »
I promise I'm going to order like tomorrow, I'm so glad that this gb is happening. How close are we to the desired number of orders?
Offline theanyday
  • love love love
« Reply #139 on: Mon, 10 August 2015, 12:48:06 »
Looks like the purple plate is a hit? Maybe I should have ordered two of them lol  :-X :p
MIRA SE | White Fox w/ 67g Zealios | POK3R w/ Blues | K70 w/ Browns | Planck w/ Greens | NovaTouch TKL
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #140 on: Mon, 10 August 2015, 12:53:54 »
30 plates, i really want 50, that would make my life so much simpler.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #141 on: Mon, 10 August 2015, 12:54:40 »
Yes, a lot of purple orders.
Tell me if you want one more ! :)
http://i.imgur.com/fQ89RTe.png
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #142 on: Mon, 10 August 2015, 13:12:37 »
I want to add to my order, how do you prefer to have that done? :D
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #143 on: Mon, 10 August 2015, 13:13:09 »
Click on the Order Here button in the OP.
Offline theanyday
  • love love love
« Reply #144 on: Mon, 10 August 2015, 13:18:11 »
I've never purchased from Aliexpress before, anyone mind informing me how to go about it? Particularly ordering a part that isn't technically listed? Do I buy the case then add a note to the effect of wanting the clear version?
« Last Edit: Mon, 10 August 2015, 14:10:02 by theanyday »
Offline rpeterclark
  • RPTR ❌
« Reply #145 on: Mon, 10 August 2015, 13:48:48 »
For sure it's not as nice and tidy as Amazon. It sometimes even feels a little sketchy, but so far I have not yet been burned. You'll have an opportunity to add notes to your order, be as specific as possible and don't hesitate to message the seller directly before, or after to make sure they got and understand your order. Pay with a credit card or something that offers a bit of protection. Also remember to be patient, these things are shipping super slow from China.
Offline TalkingTree
    • My projects
« Reply #146 on: Mon, 10 August 2015, 14:24:42 »
I bought electronics there once. Air shipping, perfect packaging and no customs fee as the reseller declared the goods as a gift (which, mind you, as far as I know is illegal in most countries).
« Last Edit: Mon, 10 August 2015, 14:27:18 by TalkingTree »
Offline andysun
« Reply #147 on: Mon, 10 August 2015, 16:03:22 »
Ordered!
Also, first post here on GH, have been mostly a lurker :P
This is my first custom board, where do you guys usually go about ordering switches? (especially you european geekhackers out there :) )
Offline Applet
« Reply #148 on: Mon, 10 August 2015, 16:06:10 »
Ordered!
I'd say 7bit over at deskthority is a great source: http://deskthority.net/group-buys-f50/cherry-mx-taking-pre-orders-t2760.html
Or here in the classifieds. And welcome out into the light ;)
Offline aeonblack
« Reply #149 on: Mon, 10 August 2015, 16:35:11 »
Ordered!
I'm fairly new to this as well, just finished building on a GON 60% PCB (which is similar to this one), and I ended up ordering my switches from mechanicalkeyboards.com. I like MX Green switches, and they were one of the few places I could find them in stock at the time. I also really liked the orange aluminum TEX case they had....
