Author Topic: [GB][DONE] ROUND 2 LeandreN plate(designed by JDcarpe) + SPRiT PCB  (Read 252755 times)
Offline dav1k
Re: [GB][IN PRODUCTION] LeandreN plate(designed by JDcarpe) + SPRiT PCB
« Reply #350 on: Fri, 21 August 2015, 17:53:57 »
Gold stabs?
I don't remember seeing that on the order page? Is that still available?
Or was that only for the cool kids?
Offline theginginator
« Reply #351 on: Fri, 21 August 2015, 23:32:30 »
Was too late to order, will there be any exra of the purple plates/white pcb's after everything is complet, thanks
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #352 on: Sat, 22 August 2015, 01:17:06 »
Gold stabs?
If you really want, you can PM me and I'll add it to your order. It was just extras and not originally a part of the GB :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #353 on: Sat, 22 August 2015, 01:17:38 »
If you want, I can add you to the list of leftovers?
« Reply #354 on: Sat, 22 August 2015, 01:50:32 »
Yes that would be great thanks
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #355 on: Sat, 22 August 2015, 01:55:41 »
Done!
Offline bigDave
  • The biggest
« Reply #356 on: Sat, 22 August 2015, 05:10:45 »
Is a sepa payment the same as a normal bank transfer? If so and you are in the Uk it would be preferred as we wouldn't need to worry about exchange rates and commission.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #357 on: Sat, 22 August 2015, 05:53:55 »
Yeah it is the same as normal bank transfer, but it only benfits if you are paying in EUROs. I am also in Norway, not UK.
Offline bigDave
  • The biggest
« Reply #358 on: Sat, 22 August 2015, 06:59:32 »
So am I able to make a sepa payment despite being in the UK?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #359 on: Sat, 22 August 2015, 07:21:05 »
As long as you can pay in Euros, you can use SEPA as payment in this GB.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #360 on: Sat, 22 August 2015, 08:05:40 »
http://leandren.blogspot.no/p/group-buy.html
take a look. Still working on this site.
Offline zenless
« Reply #361 on: Sat, 22 August 2015, 08:27:48 »
LeandreN is putting a ton of good work into this, even though it's not complete yet i'm appreciative!
Offline trenzafeeds
  • **** off
« Reply #362 on: Sat, 22 August 2015, 09:17:11 »
Awesome! It'll be nice to see updating info about the groupbuy. On a different note, I totally forgot how many similarities Norwegian has to German, it's kinda weird.
demik will never leave.
Unless he gets banned.
Offline 3K
« Reply #363 on: Sat, 22 August 2015, 09:28:05 »
There really are similarities!
Also the pictures show an AUNK PCB, not a SPRIT one - is this for demonstration only?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #364 on: Sat, 22 August 2015, 10:10:00 »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #365 on: Sat, 22 August 2015, 11:23:56 »
Unfortunately, i had to swith it to English...
Thanks for the words, updated a little there now, more will come !
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #366 on: Sat, 22 August 2015, 11:25:32 »
Yes, only to show how i plan to package these parts!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline a-c
« Reply #368 on: Sat, 22 August 2015, 15:21:57 »
Those cheap plastic cases seem to be on sale for $13.99.
http://www.aliexpress.com/store/product/Mini-Keyboard-GH60-plastic-Case-for-60-Mechanical-Keyboard-Compatoble-PBT-Keycaps-Poker2-Pok3r-Faceu-60/1555390_32311183273.html
You have to purchase them using the Android or IOS app. Not sure how that works, never used the app.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #369 on: Sat, 22 August 2015, 15:33:25 »
https://www.massdrop.com/buy/60-aluminum-plate
If you missed out, you can buy one of these ;)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #371 on: Sat, 22 August 2015, 15:48:05 »
Hahahahaha
It's certainly not your design, but it is an alternative! Haha.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #372 on: Sat, 22 August 2015, 15:50:39 »
This is the "Silver" color for anyone wondering!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #373 on: Sat, 22 August 2015, 16:14:17 »
Offline joey
« Reply #375 on: Sat, 22 August 2015, 19:46:42 »
Did these support stepped caps-lock too?
Edit: Yes it does, thanks FreeChemicals!
LeandreN: left me know if there are any spares too, thanks!
« Last Edit: Sat, 22 August 2015, 20:17:58 by joey »
Offline wlhlm
« Reply #376 on: Sat, 22 August 2015, 21:24:19 »
Got these at the post office today :)
http://leandren.blogspot.no/2015/08/this-is-what-100-custom-clearance-notes.html
Do you have to fill them all out by hand? Is there no way you could just print them out or order already filled-out stickers?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #377 on: Sun, 23 August 2015, 00:15:42 »
There are no way as I can see it...
It's a lot of work, but i t goes pretty fast :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #378 on: Sun, 23 August 2015, 00:16:38 »
Okey!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #379 on: Sun, 23 August 2015, 03:10:21 »
The rest of the invoices will most probably go out next week.
Offline rpeterclark
  • RPTR ❌
« Reply #380 on: Sun, 23 August 2015, 06:55:51 »
Are you guys sure about the off center caps lock? The plate cutout for that switch looks centered only in the OP photos.
Offline flabbergast
« Reply #381 on: Sun, 23 August 2015, 07:09:14 »
To me it looks like the cutout for the caps lock is much wider than for a normal switch and goes all the way to the side of the plate, which is where the off-center caps switch would be.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #382 on: Sun, 23 August 2015, 08:25:47 »
Yeah it is wider and support offset caps lock
« Reply #383 on: Sun, 23 August 2015, 09:01:05 »
Yep, I'm sure. ;)
Offline rpeterclark
  • RPTR ❌
« Reply #384 on: Sun, 23 August 2015, 09:39:50 »
Yep, I'm sure. ;)
Great! :-D
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #385 on: Sun, 23 August 2015, 12:35:23 »
Invoicing PayPal for some of the orders.
Offline DanielT
« Reply #386 on: Mon, 24 August 2015, 14:43:16 »
I must say I really like how this GB is handled so far  :thumb: nice updates, you found a solution for the dreaded PayPal problem, really smooth, keep up the good work ;)
Offline trenzafeeds
  • **** off
« Reply #387 on: Mon, 24 August 2015, 14:53:01 »
Couldn't agree more.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #388 on: Mon, 24 August 2015, 15:02:55 »
Thanks for the support !
Offline ika
« Reply #389 on: Mon, 24 August 2015, 23:16:23 »
Hahahahaha
excuse the ignorance, but what is the joke here?
Offline trenzafeeds
  • **** off
« Reply #390 on: Mon, 24 August 2015, 23:20:56 »
Hahahahaha
Those plates are just way worse
Offline ika
« Reply #391 on: Mon, 24 August 2015, 23:33:14 »
Given the price difference, I figured that was the case. But I'm assuming they're the same thickness, so aside from anodizing, how much worse can plate be? Is the H-style plate design that much worse than the "four inverse  corners" design? Apologies if this is not the place to ask.
Offline trenzafeeds
  • **** off
« Reply #392 on: Mon, 24 August 2015, 23:40:04 »
I'll let JD himself handle this if he shows up, he'd explain the quality of his plates much better than I. There's really a number of big differences.
Offline DanielT
« Reply #393 on: Tue, 25 August 2015, 01:31:07 »
It's not just the quality, but JD's design brings support for a lot of layouts, this is the main point. This plate can acomodate both standard boring layouts but also very exotic ones, and this can not be done with the other one :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #394 on: Tue, 25 August 2015, 02:13:34 »
They are actually sourced be me and my friend SentrantPC, but it has way less features than the the JD plates. In addition, they are from another factory.
Offline Defying
  • (suffer on)
« Reply #395 on: Tue, 25 August 2015, 09:58:55 »
just got invoiced by SPRiT, but I'm not on the list to be invoiced by him.
edit: saw your email, will ignore the invoice.
« Last Edit: Tue, 25 August 2015, 10:05:28 by Defying »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #396 on: Tue, 25 August 2015, 10:10:38 »
Yeah you have paid and everything is okay.
Please ignore the invoice if you get one by SPRiT AND you have already paid. Also let me know!
Offline TalkingTree
    • My projects
« Reply #397 on: Tue, 25 August 2015, 10:40:35 »
I read in the email that some had their orders cancelled. What's left unsold?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #398 on: Tue, 25 August 2015, 10:45:28 »
I will have to see when we are done.
Offline MarkRobbo
« Reply #399 on: Tue, 25 August 2015, 11:08:33 »
Paid invoice :) Thanks LeadreN
