Author Topic: Key a little wobbly. Is there a solution?  (Read 1616 times)
Offline maroder
« on: Wed, 22 July 2015, 15:28:22 »
Hi,
the ISO Return/Enter key of my Poker II (MX Black) seems to wobbly a little more than on my Pok3r III (MX Clear).
Does anyone know if this is because of difference regarding the switches?  :-X
The switches themselves are seated tight in place on both keyboards so I guess it has to do with the space between stem and switch. Can something be done to reduce this wobble a little?
Thanks for any suggestions.
Cheers,
Maroder
Offline absyrd
  • CPT HYPE PADAWAN
Re: Key a little wobbly. Is there a solution?
« Reply #1 on: Wed, 22 July 2015, 15:39:55 »
Cling wrap
« Reply #3 on: Wed, 22 July 2015, 15:48:19 »
Offline maroder
« Reply #4 on: Wed, 22 July 2015, 15:58:49 »
Hey, thanks for the near instant replies! I'll have a go then with the cling wraps.
