Author Topic: Looking to buy a second keyboard  (Read 3078 times)
Offline Agarito
« on: Sat, 03 October 2015, 20:18:32 »
Hey guys,
Been using a filco majestouch (brown switch) since 2010 but haven't really looked into getting a second keyboard until now. I've been recently looking at keyboards that don't have a space between the number keys and the f keys. Looks like this: http://www.amazon.ca/Noppoo-Mechanical-Gaming-Keyboard-Switches/dp/B0091QOCNA
I've been having a difficult time finding keyboards that have this feature as I don't really know what the layout is called (have to check pictures of each keyboard, manually). Anyone happen to know what type of keyboard this is?
Thanks
Offline njbair
    • nickbair.net
Re: Looking to buy a second keyboard
« Reply #1 on: Sat, 03 October 2015, 20:20:37 »
It doesn't really have a name, but maybe the keyword "compact" would be helpful for your search.
My boards:
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #2 on: Sat, 03 October 2015, 20:22:05 »
Do you want the numpad as well?
A lot of 75% boards have the F keys next to the numbers. Otherwise, I don't think there is a name for it, its not very standard to have them close together really, and you will probably have to just look at the pictures if you don't go 75%
Offline Agarito
« Reply #3 on: Sat, 03 October 2015, 20:24:24 »
Thanks for the replies. I should have mentioned that I am not looking for a numpad.
Unfortunately, it  seems as though a lot of tenkeyless (which im guessing is the 75%?) has the space between the numbers and f keys.
Offline njbair
    • nickbair.net
« Reply #4 on: Sat, 03 October 2015, 20:38:45 »
A Tenkeyless is actually an 87%. This is a 75:
My boards:
Offline Agarito
« Reply #5 on: Sun, 04 October 2015, 08:53:13 »
Looks like the 75 configuration is exactly what I am looking for, thanks!
Offline julayyy
« Reply #6 on: Sun, 04 October 2015, 17:02:21 »
Looks like MechanicalKeyboard.com is making their own variation of that type of keyboard using Gateron Keyswitches.
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1371
It's going to be out in 4 days
QuickfireTK MX Reds         v60 mini MX Clears
Offline Latin00032
« Reply #7 on: Sun, 04 October 2015, 17:18:46 »
Brown only?
Offline julayyy
« Reply #8 on: Sun, 04 October 2015, 17:45:01 »
Brown only?
There's other switches as well but only gateron and greetech https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=243
Offline Agarito
« Reply #9 on: Sun, 04 October 2015, 18:35:56 »
Thanks for the recommendation. Do you know if this company's keyboards are on par with the build quality of filco?
Offline julayyy
« Reply #10 on: Mon, 05 October 2015, 15:58:49 »
As of right now, nothing have been said about the build quality of the keyboard.  You can check out this thread https://geekhack.org/index.php?topic=74857.0 for more info but it seems that since the keyboard haven't been released yet, they're still keeping quiet on the manufacture.
