Author Topic: will Cherry ever make an ergoclear switch?  (Read 10016 times)
Offline Special K
« on: Thu, 22 October 2015, 12:36:31 »
Will Cherry ever make an ergoclear switch (i.e. strong tactile bump with a relatively light spring), or if I want something like this are my only options pretty much:
1. Use an alps board
2. Individually mod cherry MX clear switches by removing the springs and swapping them with MX brown springs
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
Offline bcredbottle
Re: will Cherry ever make an ergoclear switch?
« Reply #1 on: Thu, 22 October 2015, 12:37:17 »
https://geekhack.org/index.php?topic=74807.0
Offline jonathanyu
« Reply #2 on: Thu, 22 October 2015, 12:40:14 »
op is asking for Cherry made switches, not gateron.
Offline bcredbottle
« Reply #3 on: Thu, 22 October 2015, 12:56:27 »
Is this true OP? Have I failed you?
Offline Special K
« Reply #4 on: Thu, 22 October 2015, 13:02:48 »
No, your information was helpful as well.  Having said that, I assume no large keyboard manufacturer is ever going to make a board with these switches (or ones from Cherry, should they ever make them) in it, correct?  Meaning I would be on my own in acquiring a case and PCB to attach the switches to?  Does anyone sell a full-size Filco OEM case and PCB?
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline jerue
  • (Whenever that happens :P)
« Reply #5 on: Thu, 22 October 2015, 13:52:30 »
Take the Cherry Corp engineers and some execs to Oktoberfest 2016 and maybe you'll get your Cherry branded ergo-clear. ;)
Offline bcredbottle
« Reply #6 on: Thu, 22 October 2015, 13:56:26 »
AFAIK Cherry has no plans to make ergo clears. Even if they do roll it out weeks or months from now, it would be a bit before you start seeing a wide selection of boards carrying them. Your best option is to buy Zealios and solder them onto an existing board or a new build.
Offline Special K
« Reply #7 on: Thu, 22 October 2015, 14:04:01 »
Where can I buy a full-size case + PCB?
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
« Reply #8 on: Thu, 22 October 2015, 14:06:22 »
He means buy a keyboard, take it apart and put it back together with the parts you want.
 Depending on your keycap/stabilizer preference, I am a big fan of the Leopold FC900R with thick pbt caps for ~$119.99 from www.mechanicalkeyboards.com
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #9 on: Thu, 22 October 2015, 17:11:34 »
lol, expecting Cherry to innovate...
Offline trizkut
« Reply #10 on: Thu, 22 October 2015, 17:26:08 »
Didn't Cherry once say they would make them, but only if it reached 750k MOQ?  :)) :))
Offline azhdar
  • Praise the AZERTY god
« Reply #11 on: Thu, 22 October 2015, 17:27:37 »
Dude have you not seen QMX clip? So innovative.
yep : http://deskthority.net/wiki/Cherry_MX_Ergo_Clear#Availability
Azerty Propagandiste
Offline jonathanyu
« Reply #12 on: Thu, 22 October 2015, 17:32:39 »
how much is 750k switches?
Offline azhdar
« Reply #13 on: Thu, 22 October 2015, 17:34:05 »
750.000 so about 750.000$
« Reply #14 on: Thu, 22 October 2015, 17:40:14 »
I would think something like $200K if buying that many.
Offline SamirD
« Reply #15 on: Thu, 22 October 2015, 20:17:17 »
If 750k is retail on 750k switches, then wholesale will be easily half of that for 375k.  Factor in a discount for the quantity and it would probably be around 300-310k + freight.
« Last Edit: Thu, 22 October 2015, 21:25:01 by SamirD »
Offline Saimeidae
« Reply #16 on: Thu, 22 October 2015, 20:28:38 »
You may be interested in a Clueboard from skullydazed and Zealios then, if you don't want to salvage from a board. Less work and likely cheaper.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #17 on: Thu, 22 October 2015, 22:29:57 »
Assuming a company is interested in selling those.  750,000 switches will be 7,211 keyboards (assuming 104 key).
If you sell it on a global scale, it's actually not that much.
I wonder why no one has attempted it yet.  I feel like CM Storm, Ducky, Vortex or even Corsair can probably pull it off........ maybe.....  :P
Offline Oobly
« Reply #18 on: Fri, 23 October 2015, 01:01:33 »
Or you could get Zealios, GoN NerD108 PCB and case and go for a full Korean custom. Expensive, but worth it, IMHO.
As a matter of interest, 2x3x4 LED's can fit INSIDE Zealio cases and they're compatible with 4-lead RGB LED's, too.
I don't see Cherry making anything like these any time soon. IMO, they made a mistake going for the damped slider solution by copying Alps quiet switches. They should have put dampers in the case instead (inside the tube and mounted in the "shoulders" of the top case). That way you make two new molds and ALL your switch types can be damped... Also would allow them to make a tighter top case for the damped switches and the new cases could be clear, too. Then rearrange the switch product line like this:
1. Linear 65g
2. Linear "Silent" 65g
3. Tactile 65g (Clear stem shape)
4. Tactile "Silent" 65g
5. Clicky 65g
6. Clicky "Silent" 65g
The "silent" clicky switches would still have the normal click from the white part of the slider, the blue part would be damped by the case.
Job done. One spring, two case types, three slider types.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #19 on: Fri, 23 October 2015, 06:13:09 »
Retail is around $0.50/switch for existing switches, at least from www.mechanicalkeyboards.com
Offline SamirD
« Reply #20 on: Fri, 23 October 2015, 08:45:48 »
Even better.  So full retail for 750k switches would be at 375k and half of that would be only 187.5k.  So then we're closer to about $170k + freight.
And depending on how much of a break they give for such large production runs, it could get into the sub $150k range, plug freight.
Offline bcredbottle
« Reply #21 on: Fri, 23 October 2015, 08:59:21 »
This whole thread is derailing into ridiculous territory but I'm intrigued by the remote possibility of someone actually arranging the financing for a 750k switch GB.
Offline SamirD
« Reply #22 on: Fri, 23 October 2015, 09:47:40 »
What are the gross/net revenues for some of these keyboard companies?  That would give us an idea of where the financial feasibility may lie.
Offline bcredbottle
« Reply #23 on: Fri, 23 October 2015, 09:52:25 »
Not sure but IIRC even the Zealios GB didn't hit MOQ. Not sure it would be worth it for anyone to invest six figures in such a niche area. It would be one thing if we were talking about boards w/ Ergo Clears b/c the market is much bigger for that.
Offline SamirD
« Reply #24 on: Fri, 23 October 2015, 10:31:39 »
That's probably why the MOQ is so high.  There just isn't enough demand.  Which makes sense since we're talking about a small niche inside another very small niche.
Offline Special K
« Reply #25 on: Fri, 23 October 2015, 10:43:17 »
1. Linear 65g
5. Clicky 65g
Are you talking about these:
http://www.gonskeyboardworks.com/custom-kbds-w-assembly/77-gon-ns-nerd-108-w-tuningassembly.html
It looks like Zealios switches aren't an option, and neither is "no switches".  Are you saying I would have to buy the keyboard with some type of Cherry MX switch, then de-solder all of them and solder in the Zealios?
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
« Reply #26 on: Fri, 23 October 2015, 11:01:52 »
1. Linear 65g
5. Clicky 65g
Currently zelios can only be purchased from Zealpc.net
The GON board is one of the only full size customs out there if that is what you are looking for. You could probably contact GON and ask to get only the PCB and plate but he is months behind on building boards so you probably want to avoid having him build it.
Again my solution for what you want is buy a well built full size board and swap out the switches. Whether you swap stems and springs or buy zelios is really personal choice between how much work you want to do on switches versus spending a little more money.
Offline CaplockJack
« Reply #27 on: Fri, 23 October 2015, 11:06:52 »
If they do it will be a Corsair exclusive.
Offline SamirD
« Reply #28 on: Fri, 23 October 2015, 11:27:12 »
Corsair seems like they'd have large enough pockets to try something like this.
« Reply #29 on: Fri, 23 October 2015, 11:32:49 »
And it would almost be guaranteed they'd screw it up somehow.  :))
Offline SamirD
« Reply #30 on: Fri, 23 October 2015, 11:52:43 »
hahaha, then their 'exclusive' switches would be dumped on the market for 1/10th the cost to other suppliers who would gobble them up and make cheap boards with them.
Offline Oobly
« Reply #31 on: Fri, 23 October 2015, 12:24:22 »
Nope, this: http://zealpc.net/collections/switches/products/zealio
This: http://www.gonskeyboardworks.com/pcbs-and-controllers/78-nerd-108-pcb-ver15.html
And this: http://www.gonskeyboardworks.com/housings-and-related-parts/79-gon-ns-nerd-108-housing-only.html
Unfortunately the introductory price on the Zealios is over, but they're still worth getting. A full size board is expensive, though, since it uses the most switches, largest PCB, largest case with most cutouts, etc.
Offline swimmingbird
  • keyset hoarder
« Reply #32 on: Sun, 25 October 2015, 08:06:59 »
I don't know why you would want Cherry to make them anyway with their crappy QC and factory lubing.
Cherry are innovating but not in a way that actually makes a difference to real keyboard enthusiasts - they would rather sell rgb lit switches to Corsair in bulk than bother making a product that sells to a incredibly small niche
Offline ideus
  • Björkö.
« Reply #33 on: Sun, 25 October 2015, 10:15:37 »
Mechanical keyboard stuff is already at premium prices within small niche markets, there is no much reasons to invest in it; GMK, for example is profiting on very old molds that once were own by Cherry itself.
Offline SamirD
« Reply #34 on: Sun, 25 October 2015, 18:37:25 »
Because that makes business sense!  High quality and high margins are mutually exclusive unless you want to charge a lot for each item (which doesn't usually fly).
  • keyset hoarder
« Reply #35 on: Sun, 25 October 2015, 19:06:45 »
Yep it does make business sense as Corsair are actually a customer that can provide Cherry with the kind of volumes that make innovation cost effective
Still when a smaller company like GMK can innovate more than you with something like the QMX clips they really need to step up their game
Offline SamirD
« Reply #36 on: Sun, 25 October 2015, 20:01:41 »
But only if Corsair can sell them will they place the order.  It's a supply and demand thing.  Sometimes smaller companies are better for the niches so it explains why GMK is able to do it.
Remember, Cherry sells more keyboards via CDW than they ever will through a retail or gaming channel.  It's just not a big enough niche.
Offline Kola93
« Reply #37 on: Sun, 25 October 2015, 21:12:20 »
I think it is more important to realize that Cherry no longer holds the patent for MX switches and the market now has many suitable alternatives that will take over Cherry's offerings in a few years if they don't ramp up production.
Offline SamirD
« Reply #38 on: Sun, 25 October 2015, 21:27:27 »
Ah, I forgot about that point.  They'll need to invent the next switch that puts them back on top.  Or they'll need to figure out how to produce what they do for cheaper.  Hmmm...sounds like they're doing the latter from what I've read on here. :(
Offline Kola93
« Reply #39 on: Sun, 25 October 2015, 21:31:34 »
My manufacturing contacts tell me Kailh is positioned to take over Cherry's market share, so there is no more hope for Cherry.
Offline ideus
  • Björkö.
« Reply #40 on: Sun, 25 October 2015, 21:33:13 »
Naive question: Are you serious?
Offline Kola93
« Reply #41 on: Sun, 25 October 2015, 21:34:29 »
Yes. My brother and I have looked into manufacturing keyboards.
  • keyset hoarder
« Reply #42 on: Mon, 26 October 2015, 06:10:52 »
Don't pay attention to those just trying to get above the 100 post threshold  :))
Offline ideus
  • Björkö.
« Reply #43 on: Mon, 26 October 2015, 08:34:41 »
When I was young, I loved those small cakes that he is using as avatar, that was the only reason I replied him.  :p
Offline CaplockJack
« Reply #44 on: Mon, 26 October 2015, 08:50:59 »
Twinkies.
Offline ideus
  • Björkö.
« Reply #45 on: Mon, 26 October 2015, 08:54:27 »
Twinkies.
Right, my early years were full of them, vanilla was my overall favorite, but I also can take chocolate, or strawberry. Those summer afternoons with clear sky and warm weather were not be the same without a bag of them.
Offline Special K
« Reply #46 on: Mon, 26 October 2015, 09:00:48 »
I remember reading elsewhere on here that a very small percentage of Cherry's revenue comes from keyboard switches, so maybe they really don't care one way or the other.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
  • keyset hoarder
« Reply #47 on: Mon, 26 October 2015, 09:42:46 »
Yeah I imagine that a lot of Cherry's revenue comes from the industrial side of things but I would still think that key switches would be a significant chunk otherwise they probably would have spun off that division already
Offline Oobly
« Reply #48 on: Mon, 26 October 2015, 09:42:58 »
Cherry will keep on chugging along regardless. Some companies will still make boards with "genuine Cherry MX" switches and people will buy them. Also, they make a lot more money from the rest of their product range than selling MX switches to manufacturers. IMO, Gateron and Kailh will take a good chunk of that market from them, but from what I can tell, they won't really care. It's too much work and investment for them to chase that market, when they'd have to make new molds for the sliders and cases just to make their stock switches as good as the current competition (or at the very least, repolish the slider molds). And it's still a niche market, although it's growing.
Zealios are the ErgoClears Cherry will not make. They're available right now, are better than genuine Cherry in every signifant area and there's a chance the prices will eventually drop when enough have been manufactured and sold (and if companies start making agreements with Zeal to use them).
Offline KaminKevCrew
« Reply #49 on: Mon, 26 October 2015, 10:18:06 »
According to the deskthority wiki,
"On request, Cherry has stated that they will actually produce Ergo Clears in a slider-colour of choice, with a minimum order of at least 750,000 switches."
(this is from their page on cherry ergo clear switches.)
