Author Topic: I'm looking for an aluminum keyboard for my friend (or just a durable one)  (Read 3853 times)
Offline ANightOnCloudNine
He has gamer rage so he needs a durable keyboard to endure his wrath, I need suggestions
Offline rm-rf
Re: I'm looking for an aluminum keyboard for my friend (or just a durable one)
« Reply #1 on: Tue, 03 November 2015, 02:03:04 »
a heavier keyboard wielded by rage might not be a good thing..
Offline Bartlebum
  • Addict.
« Reply #2 on: Tue, 03 November 2015, 02:18:14 »
Pok3r has a pretty decently beefy build. It's small, but mighty!
Razer | HHKB | Pok3r | GON
Offline dutC4
« Reply #3 on: Tue, 03 November 2015, 02:19:26 »
 :blank:
« Last Edit: Thu, 22 December 2016, 15:05:58 by dutC4 »
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Tue, 03 November 2015, 02:30:24 »
Don't make the mistake of thinking that just because Apple makes keyboards out of aluminium that that is a durable material :P (or a good keyboard).
Offline squishygnomes
« Reply #5 on: Tue, 03 November 2015, 02:34:35 »
Probably not the answer you are looking for but rather than looking for a durable keyboard he should learn to control his "gamer rage" and not break his stuff.
That being said, anything with a metal case is pretty hard to damage beyond repair. I'd recommend a Pok3r as an excellently built keyboard with a metal case, the programmability is nice too if you play indie games that don't let you rebind controls.
Offline clochette
« Reply #6 on: Tue, 03 November 2015, 04:58:35 »
an aluminium keyboard will not solve the issue here
the switches are more prone to spoiling should your friend abuse it
perhaps its better to get a board that can get switches replaced easily
Offline Leslieann
« Reply #8 on: Wed, 04 November 2015, 04:47:24 »
Get him a Model M, seriously you can pound your fists on it and not hurt it. Otherwise, Vortex/Filco, it should be considered a lethal weapon/zombie assault keyboard. Mine is close to 5 pounds, and like the Model M, you can pound on it and not hurt it. On the bad side, that same aluminum can fall and break a foot, or your desk. The Model M, likely won't. The Model M($50) also won't break your wallet like a Vortex/Filco (about $300) will do.
I'm not sure handing a raging moron a 5 pound weapon to sling around is such a good idea.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline chyros
  • a.k.a. Thomas
« Reply #9 on: Wed, 04 November 2015, 09:11:33 »
Good point. This is why I also think for instance the Acer 6311 is more robust than its moderately flimsy frame and hammers-over-membrane construction would suggest. Sure, it's prone to dusting up, but servicing it is as simple as screwing off the back panel and the entire mechanism including the insides of all the switches are instantly exposed, ready to be cleaned. Moreover, the switches are case-mount and can be replaced by clipping out a switch and putting in a new one, no soldering ir anything needed. Tough? No. But highly serviceable, and that goes a long way.
Offline SamirD
« Reply #10 on: Wed, 04 November 2015, 12:26:02 »
He should have one of those industrial models designed for kiosks.  They even have metal keys!
http://www.oitkeypad.com/keyboards.htm
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #11 on: Wed, 04 November 2015, 12:34:07 »
If he can't control his "gamer rage", then my suggestion would be a stack of cheap rubber domes from Walmart or like store.
If he goes into a fit and smashes his fists on a mech, replacement caps and switches will most likely be in order.  For the cost of very cheap after market caps,o e could probably buy 5 or 6 cheap rubber dome switches.
Not to mention if it is a pcb mount board or the plate doesn't screw to the case, then the reality of a damaged pcb is very real.  Granted one could possibly fix broken traces with soldered in jumpers, it could possibly feel horrible depending on where the break occurs in relation to mount screws.  Most only have a few mount points.  This would be in addition to having to desoldered all the switches.
Offline crayzieap
« Reply #12 on: Wed, 04 November 2015, 12:38:53 »
This maybe a crazy idea... but he should get the most expensive custom board possible.... that way when he breaks it he may have buyers remorse and learn to control the rage over a "game" :D
« Reply #13 on: Thu, 05 November 2015, 02:01:19 »
lol he just smashes his hands on him, when we move in we're getting a punching bag in the gaming room.
Offline chyros
  • a.k.a. Thomas
« Reply #14 on: Thu, 05 November 2015, 02:33:40 »
In that case, get a vile and cheap rubber dome board for nothing. That way he can smash as many as he wants and it won't matter.
« Reply #15 on: Thu, 05 November 2015, 13:32:42 »
hes gonna do that so yay  :thumb:
Offline MagicSauce
« Reply #16 on: Thu, 05 November 2015, 19:28:15 »
Was thinking the same thing.
Go ahead and smash all the rubber domes you like but be kind to your mechs!
Offline FrostyToast
  • Litshoard
« Reply #17 on: Thu, 05 November 2015, 19:36:34 »
If he has uncontrollable "gamer rage" then your friend has bigger problems.
This might help him more.
Quote from: elton5354
Offline SamirD
« Reply #18 on: Thu, 05 November 2015, 19:41:13 »
Does it help?  I've actually rage hit my M a few times.  :-[  The phone usually takes more punishment (so I keep a spare charged and ready to go).
