Author Topic: [GB][FINISHED] Plates, PCBs and stabilisers - LeandreN Round 3  (Read 270918 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB][Taking orders] LeandreN GB round 3 - plates, PCBs and stabilisers.
« Reply #100 on: Mon, 16 November 2015, 01:13:45 »
Entered for one PCB and stabs and 80 Gat blues. I've said it before and I'll say it again, LeandreN is the king!
Offline bloodl1n3
« Reply #101 on: Mon, 16 November 2015, 11:24:49 »
Awesome, I'm in!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #103 on: Mon, 16 November 2015, 15:01:32 »
A lot of orders already, but there is always a place for more orders! Keep 'em coming!
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #104 on: Mon, 16 November 2015, 18:54:56 »
I'm back after a long time. I can't follow your GB sorry :(
Now I want steel plate for Sprit 60 PCB. Is plates in this GB support my PCB?
« Reply #105 on: Mon, 16 November 2015, 19:17:39 »
Yes, they work great with the Sprit 60% PCB. That's the same PCB he's selling in this GB. :)
Offline cjhard
  • Claudia the Magnificent
« Reply #106 on: Mon, 16 November 2015, 19:33:28 »
I thought Sprit's PCB was the FaceW? It looks like this GB is for the b.face X2, no?
Should fit regardless.
Offline HesterDW
« Reply #107 on: Mon, 16 November 2015, 20:25:37 »
I have been looking into buying a GON PCB and was was thinking of fitting some underglow LED's. Then sticking the whole thing in a TEX acrylic case I have lying around. Since this one is RGB seems to me that this one is the better option. Can I change the color to whatever I want or will it constantly show a rainbow of colors? Follow up question. If you can change the color of the LED's, how do you do that?
I'm still a noob when it comes to this stuff, someone would have to back me up. I'm pretty sure you program the PCB (with software or in bios?) on how to switch colors. Whichever LEDs you buy would have a set number of colors and by programming the keyboard you're basically able tell the LEDs to do what you want when a certain key combination is pressed.
So I'd imagine you could program the keyboard to cycle through LED colors or rainbow depending on what you want.
  • Frenzy Classic.
« Reply #108 on: Mon, 16 November 2015, 22:48:27 »
Sound great! Thanks! Can I order only plate?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #109 on: Mon, 16 November 2015, 23:39:39 »
Yes you can. This time you will get it in a cardboard box, so no worries about a bent plate ;-)
Please note that the plates only support PCB mounted stabilisers.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #110 on: Tue, 17 November 2015, 00:10:35 »
Here is a message regarding RGB underglow + TEX cases:
Early PCBs had an LED strip. You can kind of adjust those. Now the RGB LEDs get soldered directly to the PCB.
If you look inside the TEX case, there are ridges that are inside the body of the case. On acrylic Tex builds using the b.face with RGB, people use a rotary tool to cut space to fit the LEDs!
Ziptyze cases (z-cases) have the ridges purposely removed. They are best case for price...
Offline Numpy
  • The feels man
« Reply #111 on: Tue, 17 November 2015, 01:35:28 »
Awesome group buy, hoping to make my first keyboard  ;D
Thanks for this  :-*
Custom 60%: Cherry MX blues with 62g gold springs and PBT Black on Black dyesub keycaps.
Other Keyboards: Deck Hassium Pro (MX Browns), the underated Leopold FC660M (MX Browns)
  • Frenzy Classic.
« Reply #112 on: Tue, 17 November 2015, 01:35:39 »
Yes, thanks for your remind. Do you have some pics about cardboard box?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #113 on: Tue, 17 November 2015, 07:19:54 »
I can get a excact picture for you, but this is the only picture i could find:
http://www.anyboxdirect.com/products/shirt_knitwear_a4_box.jpg
It is basically this without the "white paint". Together with some bubblewrap, it will be safe.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #114 on: Tue, 17 November 2015, 07:20:39 »
Thanks for this  :-*
Offline t8c
« Reply #115 on: Tue, 17 November 2015, 07:51:43 »
LeandreN rocks, always easy to deal with! I hope you run a 75 % or Mini EX GB in the future :cool:
Offline chancellorr
« Reply #116 on: Tue, 17 November 2015, 08:56:01 »
When is this GB going to end? I'd like to get in but I don't get paid until next week.
EDIT: Says 29th on Reddit. Perfect.
« Last Edit: Tue, 17 November 2015, 09:47:23 by chancellorr »
  • Frenzy Classic.
« Reply #117 on: Tue, 17 November 2015, 08:56:21 »
Ok. Thanks! You're seems professional this round.
Offline QuickDelat
« Reply #118 on: Tue, 17 November 2015, 09:30:32 »
the box should look like this if he's still using the same as last round. Cannot say enough how much I recommend this guy!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #119 on: Tue, 17 November 2015, 09:37:11 »
I am actually not using the Posten boxes anymore as they are very expensive. I have someone that is very similar though ;-)
Thanks QuickDelat!
« Reply #120 on: Tue, 17 November 2015, 11:24:18 »
Regular or gold stabs?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #122 on: Tue, 17 November 2015, 13:27:54 »
Here are some interesting information.
This is a pie chart of all the plates that is ordered. Seems like people want plain colors, or purple, red or blue.
Cool to see that many orders of steel plates.
Keep the orders coming ! :D
Offline Cindori
    • My Blog
« Reply #123 on: Wed, 18 November 2015, 08:52:46 »
"underlow led" = No in-switch LED?
How does programmability work? I would want this layout, it's possible?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #124 on: Wed, 18 November 2015, 09:40:51 »
You can have both at the same time if you want.
That layout would be possible. And i really like it actually. You use the Winkeyless bootloader when you program. That is a GUI so it should work easy.
Offline Cindori
    • My Blog
« Reply #125 on: Wed, 18 November 2015, 10:08:28 »
Sounds very nice but how is OS X compatibility? Once it's programmed in the bootloader (i'm assuming windows .exe) it persists across reboots and other OS?
What is LED control like? Brightness/on-off?
Expected ship time?
This plate fits?
« Last Edit: Wed, 18 November 2015, 10:11:40 by Cindori »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #126 on: Wed, 18 November 2015, 10:41:10 »
Expected ship time?
This plate fits?
Yes i think they even have a program for OSX(i am not 100% sure).
I think breathe effect and typing(vibrant leds) not typing(leds off) is a feature.
Expected shipping time is 2  months after GB close.(29th of November)
Offline tDr1v3r
« Reply #127 on: Wed, 18 November 2015, 12:51:33 »
I've joined too.
Just for curiosity, how hard is it to write a working layout to the PCB? I want to use a mix of ISO and ANSI - long Enter and the 1.25 Shift with the extra 1u key, and the same fn layer I know and love on my Pok3r.
razer blackwidow tournament edition w/ mx blues, vortex pok3r w/ mx browns, b.face x2 - wip w/ tex acrylic case, silver plate and 65g tactile zealios
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #128 on: Wed, 18 November 2015, 12:58:49 »
I've joined too.
This is an excellent post explaining how the keymapping works on the Winkeyless boards. It is fairly straight forward guide, i am sure you can make the layout you are asking for.
Offline trenzafeeds
  • **** off
« Reply #129 on: Wed, 18 November 2015, 13:07:31 »
Works with OSX just like a pok3r does. The control, windows, etc. just function as their mac equivalents.
demik will never leave.
Unless he gets banned.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #130 on: Fri, 20 November 2015, 14:02:08 »
Thank you so much for the orders. I really think that people have starting trusting my GBs, and that is fantastic. Thanks to all the orders, i can drop the price of the Tier 2 PCB to 59$. This is 3$ cheaper per PCB.
Tier 1 PCB (diodes +  controller parts) = 49$
Tier 2 PCB (diodes, controller parts and resistors) = 59$
Tier 3 PCB (diodes, controller parts, resistors and RGB underglow parts) = 78$
I have also removed the (+2$) on the steel plates. They are now just 30$, like the aluminium plates.
I hope this helps even more people joining the GB. Please invite your family, friends and colleagues to join!
PS: The expected shipping time is reduced from 2 months after invoicing to 1,5 months :)
Offline MarkRobbo
Re: [GB][OPEN] Plates, PCBs and stabilisers - LeandreN Round 3
« Reply #131 on: Fri, 20 November 2015, 15:22:45 »
Nice :D Would certainly recommend this buy especially with that steel plate and PCB cost reduction.
Good experience with Leandren last round.
Offline cryptokey
  • [°°▄°] luser-friendly
« Reply #132 on: Fri, 20 November 2015, 15:46:08 »
So since it uses FaceW firmware, then it's not Linux compatible? I'm very interested in this buy, however I primarily use Linux so I want to make sure everything will work.  Also, is there a picture of the gunmetal plate anywhere?
« Last Edit: Fri, 20 November 2015, 15:49:45 by cryptokey »
[WTB] HHKB Black
Offline priyadi
« Reply #133 on: Fri, 20 November 2015, 17:04:23 »
From my understanding, the keyboard will work under Linux. But in order to reprogram it, it will be necessary to use Windows.
Boards: Filco TKL+HID Liberation, Infinity 60%, Sentraq S60-X, Whitefox, Ergodox, Planck.
Member of the flat keyboard society.
Keycap manifesto: "Key sets without vendor neutral Super key are worthless"
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #134 on: Fri, 20 November 2015, 17:05:48 »
Offline MarkRobbo
« Reply #135 on: Fri, 20 November 2015, 17:10:53 »
Correct, as far as I know. If anyone finds a way to flash on Linux that would be helpful for me.
But, of course, it would work fine under linux. It's sending the same key codes
Offline cjhard
« Reply #136 on: Fri, 20 November 2015, 17:30:12 »
Would not dfu-programmer work?
Offline priyadi
« Reply #137 on: Sat, 21 November 2015, 00:23:24 »
Someone will need to work on this: https://github.com/showjean/ps2avrU . This also might be helpful: https://github.com/tmk/tmk_keyboard/issues/186
Unfortunately I'm not familiar enough with these stuff. And the FaceW firmware also doesn't support SpaceFn which I  require, so I've given up and will only get a board supported by TMK for now.
Offline priyadi
« Reply #138 on: Sat, 21 November 2015, 00:27:49 »
No it won't. dfu programmer requires chip with integrated USB. CMIIW.
Offline flabbergast
« Reply #139 on: Sat, 21 November 2015, 11:35:46 »
It is possible to (re-)program faceW PCBs both in linux and on mac os x. First, to get a hex file with your preferred keymap, just use the online flash thingy here: http://winkeyless.kr/bootMapper/
Once you have the hex file:
1) Put the board into the bootloader mode (hold Q and plug in the board). It enumerates as "bootloadHID" - that's the bootloader these boards use.
2) Use the bootloadHID command line program to upload the hex to the board.
You can either compile bootloadHID yourself from sources; or for mac os x I've already uploaded once a binary (compiled on my machine) that you can just unpack and use here. (I can probably also make linux binaries if someone needs.)
« Last Edit: Sat, 21 November 2015, 11:37:44 by flabbergast »
Offline Latin00032
« Reply #140 on: Sat, 21 November 2015, 21:39:12 »
I'm surprised no one ordered orange?
I'm thinking of joining this gb. If most likely go for orange.
Offline kakakowie
  • Make Love not War
« Reply #141 on: Sat, 21 November 2015, 21:50:56 »
Hmm. Are those layouts the only possible ones? Are there any other possible layouts?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #142 on: Sun, 22 November 2015, 01:52:25 »
Yeah I have some orders for orange now.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #143 on: Sun, 22 November 2015, 01:52:46 »
Only the ones pictured
Offline TalkingTree
    • My projects
« Reply #144 on: Sun, 22 November 2015, 03:27:53 »
Should be plenty.
Offline beltet
« Reply #145 on: Mon, 23 November 2015, 04:58:44 »
Made a order.
Looking forward to it!
Offline TalkingTree
    • My projects
« Reply #147 on: Mon, 23 November 2015, 07:16:53 »
Would this fit into this case?
It does. I own one.
Offline ekx
« Reply #148 on: Mon, 23 November 2015, 07:19:59 »
Great  :) Thanks
Offline braidn
« Reply #149 on: Mon, 23 November 2015, 21:40:43 »
Very interesting. This does open up things to the Linux folks. Nice!
