Author Topic: [GB][FINISHED] Plates, PCBs and stabilisers - LeandreN Round 3  (Read 270918 times)
Offline faxe
Re: [GB][OPEN] Plates, PCBs and stabilisers - LeandreN Round 3
« Reply #200 on: Sat, 28 November 2015, 10:17:01 »
Ok, 3/3 on LeandreN GB's. 60% final try. :eek:
ISO Clueboard V2 Zealio 78g -ISO Clueboard V1 MX Clear - ISO 60% MX Clear - ISO Filco MJ 2 MX Brown - ISO is life
Offline Tunz
« Reply #201 on: Sat, 28 November 2015, 17:07:13 »
Placed my order.  Really excited to do my first build!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #202 on: Sat, 28 November 2015, 18:05:12 »
Strike!
Awesome! Thanks a lot dude :)
Offline chancellorr
« Reply #203 on: Sat, 28 November 2015, 23:04:14 »
What would be a good case that plays well with the underglow of the PCB?
Offline nmur
  • ಠ_ಠ
« Reply #204 on: Sat, 28 November 2015, 23:19:37 »
frosted acrylic cases, such as the TEX one
Offline cjhard
  • Claudia the Magnificent
« Reply #205 on: Sat, 28 November 2015, 23:26:11 »
TEX cases will require a modification. The horizontal supports between each row of switches will need to be removed where the RGB LED's are.
Check out the clear 3d printed case at 1UP Keyboards (supports Poker-style plates), or the BBB Acrylic case from winkeyless.kr (case includes plate)
Offline Latin00032
« Reply #206 on: Sun, 29 November 2015, 00:05:25 »
I thought I could use the rgb version with the tex case.
What if I got the tier 2 version without the rgb lights?
Could I then use most poker compatible cases?
What about other poker cases?
Offline cjhard
« Reply #207 on: Sun, 29 November 2015, 00:15:36 »
If the case doesn't have those funny ridges, you can use it even with the RGB LED's. I've seen a few nice looking aluminium cases that are just standoffs the PCB sits on top of.
If you got without RGB LED's, the components wouldn't interfere with the ridges in the case and you should be able to use any case you want.
A lot of the appeal of this PCB over the FaceW Sprit and mechanicalkeyboards.com sells is that RGB back lighting. You'll still have it as an option later if you wanted to solder in some LED's at least.
That said, the Acrylic TEX case can totally still be used, just dremel out slits to give clearance for the RGB LED's.
Offline longcat
« Reply #208 on: Sun, 29 November 2015, 01:29:41 »
Count me in! This will be my first custom board. Now to find an acrylic case...
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #209 on: Sun, 29 November 2015, 03:45:51 »
Last chance to order now!
Offline nmur
  • ಠ_ಠ
« Reply #210 on: Sun, 29 November 2015, 04:32:54 »
Thanks dude. I've just received a TEX acrylic case for this build so this is good to know.
Offline chancellorr
« Reply #211 on: Sun, 29 November 2015, 06:34:40 »
Thank you. Good thing I have a dremel.
Offline wodan
« Reply #212 on: Sun, 29 November 2015, 07:24:56 »
Just ordered a small set, hopefully not too late !!!
Love the layout ...
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #213 on: Sun, 29 November 2015, 07:41:31 »
Love the layout ...
You are in!
Offline Vimto
« Reply #214 on: Sun, 29 November 2015, 09:36:39 »
I'm going to be getting this group buy case
https://geekhack.org/index.php?topic=71551.0
Would the pcb / switches from this group buy work with this case?
Would I need a plate with the afore mentioned case?
HHKB Pro 2    HHKB Pro 2   Realforce 87U       WhiteFox        Keyboardio
   BT Hasu                              55g 10th      The True Fox        Model 01
  Controller                        Anniversary Ed.     On Order         On Order
Offline wodan
« Reply #215 on: Sun, 29 November 2015, 09:49:55 »
Awesome !!! Can I haz invoice please ?
Haven't gotten anything yet :(
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #216 on: Sun, 29 November 2015, 10:17:29 »
Starting invoicing tonight! Some will not get it before the middle of this week. It takes a lot of time.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #217 on: Sun, 29 November 2015, 10:19:11 »
Yes it will work. You will not need a plate.
Offline f1xedgear
« Reply #218 on: Sun, 29 November 2015, 10:26:23 »
Sounds like a good opportunity for some scripting!  ;D
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #219 on: Sun, 29 November 2015, 10:46:53 »
Yeah haha. That takes time too though...
Offline TalkingTree
    • My projects
« Reply #220 on: Sun, 29 November 2015, 11:21:04 »
Don't miss out guys.
Join the fun.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #221 on: Sun, 29 November 2015, 11:57:12 »
Join the fun.
Awesome! And thanks for your fast payment !
Offline cjhard
« Reply #222 on: Sun, 29 November 2015, 12:39:21 »
Got the invoice
Checked the total
"Oh jeez, what did I just do?"
"Better click Pay Now before I reconsider!"
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #223 on: Sun, 29 November 2015, 12:42:11 »
Got the invoice
Checked the total
haha !
You should double check though, as everything is manually entered!
Offline cjhard
« Reply #224 on: Sun, 29 November 2015, 12:56:19 »
I did look at the itemized, it looks like what I remembered asking for at least :)
Offline Vimto
« Reply #225 on: Sun, 29 November 2015, 13:37:49 »
Just filled in my order.
Going for a Tier 3, which i'm hoping will look good with the Carbon Fiber case.
Hopefully soldering the switches will be easy (never soldered before, so any tips welcome)
Thanks for the awesome groupbuy
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #226 on: Sun, 29 November 2015, 13:44:11 »
Thanks for the order! Let me know if you have any questions !
You can follow the progress of your order here:
https://docs.google.com/spreadsheets/d/1eHTkuk4TNCe5ozR7Rt_awH0E57Wb8s3zvJ1oc2uC3Eg/edit#gid=0&vpid=A1
Offline Sisric
« Reply #227 on: Sun, 29 November 2015, 13:53:39 »
Just put my order in. Hopefully I wasn't too late! Gonna be getting a TEX Acrylic case for this... Hopefully I can find a dremel to take what I need off!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #228 on: Sun, 29 November 2015, 14:00:27 »
You are in !
Offline bloodl1n3
« Reply #229 on: Sun, 29 November 2015, 14:07:30 »
LeandreN, I sent you a PM. Looks like there was some confusion with my order. Once we fix it, I'll be ready to pay! :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #230 on: Sun, 29 November 2015, 14:24:08 »
Not a confusion, just me not doing my job.
Updated it :)
Offline bloodl1n3
« Reply #231 on: Sun, 29 November 2015, 14:29:57 »
Perfect! Thanks LeandreN!
Offline lashiel
« Reply #232 on: Sun, 29 November 2015, 14:32:54 »
Entered for PCB and stabs. Hopefully not too late!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #233 on: Sun, 29 November 2015, 14:36:22 »
Not to late, but you will get an invoice a little later probably.
Offline lashiel
« Reply #234 on: Sun, 29 November 2015, 15:10:32 »
All good. Thanks LeandreN!
Offline nmur
  • ಠ_ಠ
« Reply #235 on: Sun, 29 November 2015, 16:58:52 »
paid invoice 001!
I feel special :3
Offline trenzafeeds
  • **** off
« Reply #236 on: Mon, 30 November 2015, 01:41:44 »
I'm excited for everyone who's gotten in on this, as it's probably your first custom build for a lot of you! Have fun everyone, it's an adventure.  :thumb:
demik will never leave.
Unless he gets banned.
Offline Vimto
« Reply #237 on: Mon, 30 November 2015, 01:58:56 »
Hi,
Apologies some more newbie question? Do i need to tell you the layout i want if i'm getting the tier 3 pcb with presoldered diodes / led's?
Does this PC support the Happy Layout as mentioned on the carbon fiber case I'm getting in the other group buy? I'm not sure which layout i'm going for yet.
Offline trenzafeeds
  • **** off
« Reply #238 on: Mon, 30 November 2015, 02:03:23 »
Hi,
You do not need to tell the layout ahead of time, you will determine that when you solder the switches, and this plate supports just about any 60%-based layout you can imagine, so yes, it supports happy. It should work just fine with hwood's cf cases.
Offline Sisric
« Reply #239 on: Mon, 30 November 2015, 05:57:51 »
It's going to be my first... I'm both scared that I will mess something up and very excited :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #240 on: Mon, 30 November 2015, 06:52:50 »
URGENT - URGENT - URGENT
Those who ordered a tier 2 PCB. Would it be a problem for you if RGB parts were added, for free? IF NOT, you have to tell me now.
I know this seems unfair to those who ordered a fully soldered PCB. I will be refunding what i can at the end.
This makes the process much faster and simpler for Winkeyless. I am already loosing money on the sales, so please let me know your ideas.
Offline Crossfire
« Reply #241 on: Mon, 30 November 2015, 07:36:08 »
I wouldn't dare to speak in behalf of all the tier 2 buyers, but as far as I'm concerned, YES, please, add them! :D
Offline faxe
« Reply #242 on: Mon, 30 November 2015, 07:57:22 »
As long as Tier 3 is still all soldered fine by me  :cool:
Offline skarhead
« Reply #243 on: Mon, 30 November 2015, 08:04:18 »
Not a problem for me
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #244 on: Mon, 30 November 2015, 08:18:27 »
Although I don't order PCB, but I think everyone 'll like this :)
Offline reddragon394
« Reply #245 on: Mon, 30 November 2015, 09:22:10 »
I ordered 3rd Tier, but i wouldn't mind. How would that go down though? everybody pays 2nd Tier and everyone gets 3rd Tier?
any way to prevent you from losing money? dont think anyone wants you to have disadvantages!
Offline dae1
« Reply #246 on: Mon, 30 November 2015, 09:34:53 »
I emailed LeandreN about this and the response was that we will get the refund of the cost of the rgb leds.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #247 on: Mon, 30 November 2015, 09:40:12 »
I will look at this at the end. 19$ refund per PCB tier 3. A lot of people have offered to not get a refund, which is amazing.
Thanks for all the positive response, I will make a update tonight and we can get this GB going !
Offline f1xedgear
« Reply #248 on: Mon, 30 November 2015, 09:59:10 »
I hope that more people end up doing this and that the tier2 buyers could also upgrade to tier3. There is only a $19 difference between the two tiers which is relatively small for the individual GB participant, but if this cost gets unloaded on the organizer, it would be a significant burden. LeandreN already puts a significant amount of work into the buy and I'd like there to be future rounds of his buys!
I realize that it is probably also unfair to GB participants to have sudden price changes, but then again, this isn't a store, so some hiccups should be expected (see the stickied posts).
I realize that I am quite new here, and hope I don't offend anyone by saying this. LeandreN and the other participants are free to make their own choices, of course! :)
« Reply #249 on: Mon, 30 November 2015, 10:06:37 »
Quote from: LeandreN
i havent gotten my invoice yet (i know it will come, dont feel rushed!) but i suggest putting both prices in there, so people can decide :D i would not want you to lose money and i surely will consider paying the normal price too :)
