Author Topic: [GB][FINISHED] Plates, PCBs and stabilisers - LeandreN Round 3  (Read 270914 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB][OPEN] Plates, PCBs and stabilisers - LeandreN Round 3
« Reply #250 on: Mon, 30 November 2015, 10:17:17 »
Quote from: LeandreN
A lot of people have offered to not get a refund, which is amazing.
i havent gotten my invoice yet (i know it will come, dont feel rushed!) but i suggest putting both prices in there, so people can decide :D i would not want you to lose money and i surely will consider paying the normal price too :)
I will have everyone pay 100% now and refund when the GB is over.
Offline axtran
« Reply #251 on: Mon, 30 November 2015, 10:43:09 »
Sounds good to me. :) Only issue I see is around whether or not the case that everyone will end up using can fit in the RGB LEDs (mine can!). :)
MX Silent > MX Vintage Black > Everything Else
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #252 on: Mon, 30 November 2015, 10:47:20 »
Do you have a list or something of those who can or cannot support the RGB LEDs?
Offline reddragon394
« Reply #253 on: Mon, 30 November 2015, 10:51:25 »
@LeandreN: Alright then :thumb:
if all fails i would think desoldering an SMD should be way easier then soldering them on :D (if one wants to do that)
Offline cjhard
  • Claudia the Magnificent
« Reply #254 on: Mon, 30 November 2015, 11:02:23 »
Just pick up a dremel, check out Youtube on how to operate it, and fix your case so that there's plenty of clearance :)
Offline eksuen
  • Ambassador of explosions.
« Reply #255 on: Mon, 30 November 2015, 11:16:36 »
I would prefer not to have the RGB parts, lest they cause clearance issues in my case (aluminum case so modding it would be a little more difficult). The case is opaque anyway so the RGB lighting would never be seen.
However, if I am in the minority and adding RGB parts to every PCB is easier, then that's fine with me.
Offline f1xedgear
« Reply #256 on: Mon, 30 November 2015, 11:22:32 »
Based on my research for my B.face build:
  • Anything Tex would have to be modified
  • Stock pok3r cases may also need modding?
  • Basically anything with the horizontal stiffener ridges would need modification
  • I've been told that this case will work (at least I hope so, since thats what i bought)
  • Cases from Ziptyze (the 3d printed ones) should not need modding
  • Winkeyless acrylic cases would obviously not need modifications
« Reply #257 on: Mon, 30 November 2015, 11:28:41 »
Bought the Lambo for the B.face too. Should be coming in today. Also got an acrylic case from TB that has those ridges. It's not a Tex case, but we'll see if it needs modification.
If I don't have a Dremel, is there any other way to modify the case without hassle?
Offline lashiel
« Reply #258 on: Mon, 30 November 2015, 11:31:40 »
I'm okay with it.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #259 on: Mon, 30 November 2015, 12:02:11 »
Thanks! It is decided. This is the best way.
Now please fill out this.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #260 on: Mon, 30 November 2015, 12:14:34 »
That will be many "thank you notes". This community is FANTASTIC!
Better get started on those. Haha  :D
Offline TalkingTree
    • My projects
« Reply #261 on: Mon, 30 November 2015, 12:52:48 »
By haste (I'm still at work), I forgot to leave my thank you note there so I'll drop one here.
Thanks a lot for all you've done in these three rounds. It's always been great.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #262 on: Mon, 30 November 2015, 12:56:49 »
It is my job to deliver "thank you" notes, haha ;)
Thanks though!
Offline chancellorr
« Reply #263 on: Mon, 30 November 2015, 13:06:30 »
Hey, will I have to clip and lube the stabs like in your video LeandreN?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #264 on: Mon, 30 November 2015, 13:35:00 »
No, but you can for better feels :)
Offline chancellorr
« Reply #265 on: Mon, 30 November 2015, 13:45:13 »
Hmmm. I do like better feels.
Offline Vimto
« Reply #266 on: Mon, 30 November 2015, 13:56:35 »
I've ordered a Tier 3 PCB, and just filled in the form to say I will continue to pay the Tier 3 price.
Thanks for the awesome groupbuy
My question is, i'm in the other group buy to get the carbon fibre case I mentioned earlier, and now I'm getting worried that the LED's might not fit.
How easy will it be to remove the LED's if necessary?
You mentioned you could do the soldering of the switches for a fee, but I guess that would require you to have the plate. Is that right?
Sorry building this keyboard is all new to me.
HHKB Pro 2    HHKB Pro 2   Realforce 87U       WhiteFox        Keyboardio
   BT Hasu                              55g 10th      The True Fox        Model 01
  Controller                        Anniversary Ed.     On Order         On Order
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #267 on: Mon, 30 November 2015, 14:00:08 »
Thank you !
The RGB LEDs are under, and i am 99% sure they will fit. They are pretty easy to remove with a soldering iron and a tweezer. I can solder the switches for you, but then i need the plate...
Offline Vimto
« Reply #268 on: Mon, 30 November 2015, 14:02:50 »
Thanks for the info. Just paid the invoice, thanks for all your effort
Will probably be asking more stupid questions when I actually have to build it. Apologies in advance.   ;D
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #269 on: Mon, 30 November 2015, 14:06:56 »
No problem, just fire the questions !
Offline Jumie
« Reply #270 on: Mon, 30 November 2015, 18:43:43 »
paid just now
Offline Zealousy
    • Twitter
« Reply #271 on: Mon, 30 November 2015, 22:06:10 »
I plan on putting this in an aluminum TEX case, would the RGB soldering etc. get in the way of mounting the PCB inside? If so, then I'll respond to leave mine tier 2. Otherwise, free upgrade is free!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #272 on: Mon, 30 November 2015, 23:41:14 »
It might be a problem. Respond to the form accordingly.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #273 on: Tue, 01 December 2015, 01:16:51 »
Just sent the payment to Winkeyless. They are starting the production now.
Still 15 unpaid invoices. I would like to see these paid by the weeks end so I can order the plates :)
Gaterons are also ordered, but not paid.
Offline wodan
« Reply #274 on: Tue, 01 December 2015, 01:34:58 »
Thread title still says "[OPEN]"
Offline Jumie
« Reply #275 on: Tue, 01 December 2015, 01:43:27 »
I have paid, but the google docs still not updated yet.
Offline Numpy
  • The feels man
« Reply #276 on: Tue, 01 December 2015, 01:59:55 »
I'm still a little confused. As I am going to use a TEX aluminium case, am I still able to have a PCB without the RGB soldering if I select Tier 2 on this survey?
Custom 60%: Cherry MX blues with 62g gold springs and PBT Black on Black dyesub keycaps.
Other Keyboards: Deck Hassium Pro (MX Browns), the underated Leopold FC660M (MX Browns)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #277 on: Tue, 01 December 2015, 02:05:13 »
The tier 2 choice on the survey does not guarantee you a tier 2 PCB. It is only a few tier 2s available. I am sorry. You can refund the order, or keep the tier 3 and sell it(recommended).
Offline Numpy
  • The feels man
« Reply #278 on: Tue, 01 December 2015, 02:11:27 »
 :( Ahh... I do understand that this will make it an easier GB overall and do thank you for being a responsive GB leader.
How difficult is it to de-solder these components? (no past experience soldering but am going to solder on my switches)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB][closed] Plates, PCBs and stabilisers - LeandreN Round 3
« Reply #279 on: Tue, 01 December 2015, 02:14:40 »
Fill out the form either way.
Desoldering should be okay with a tweezer and soldering iron, however I am sure some people will trade a RGB board for a non RGB board on mechmarket :)
Offline Numpy
  • The feels man
« Reply #280 on: Tue, 01 December 2015, 02:19:23 »
Yep, filled out the form. Could you perharps reference a source you think is particularly good at instructing how to solder/de-solder?
Offline TalkingTree
    • My projects
« Reply #281 on: Tue, 01 December 2015, 02:46:52 »
There's no particular instruction to follow, just some advices.
Use a small tip, the smaller the better.
Desolder one end at time.
Hold the component with the tweezers and either pull it up or twist it a bit while desoldering. It will come off the PCB.
If you are careful, you can desolder without damaging the components themselves.
Offline Numpy
  • The feels man
« Reply #282 on: Tue, 01 December 2015, 02:54:59 »
Thanks for this, hopefully this will come in handy  :)
Offline trees
  • I like bagels.
« Reply #283 on: Tue, 01 December 2015, 09:07:28 »
Get it without the RGB. It took some very serious modification to get my B.face + RGB in a TEX case.
B.Face HHKB - B.mini - Black/Purple Custom
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #284 on: Tue, 01 December 2015, 09:10:29 »
Thanks for the confirmation!
Offline chancellorr
« Reply #285 on: Tue, 01 December 2015, 09:23:19 »
I will be paying later today when I get home from work.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #286 on: Tue, 01 December 2015, 09:28:50 »
Update
I have got a lot of payments, still about 10 remaining for Paypal and a couple SEPA/bank transfers i haven't invoiced.
Why did you remove the tier 2 PCB?
The PCB orders suprised me, a lot more RGB boards than anticipated. Winkeyless is going to factory solder all the PCBs. To reduce time, and cost for them, and me, they asked me to remove the tier 2 options and give them tier 3 for free.
2 problems:
1.RGB parts doesn't fit some cases, like the TEX acrylic one. It requires modificaton of the case. It is because of the ridges inside the case.
2. Tier 3 PCB buyers are paying more for the same product as the tier 2 buyers.
Solutions fot tier 2 users
1. They will still send me 10 tier 2 PCBs. Those will go to the people that filled the form and REALLY couldn't settle with the tier 3 PCB. I had to really beg them for this, i really appericate Winkeyless' work!
2. Trade the PCB on classifieds or /r/mechmarket. I am sure some people will trade their non-RGB boards for a RGB one.
3. Refund the PCB (not ideal for me, but i want people to be satisfied)
Solutions fot tier 3 users
1. Keep the tier 3 as it is
2. Refund 19$ to match the tier 2 price (not ideal for me, but i want people to be satisfied)
The GB will hopefully ship faster, and will reduce the massive cost of these PCBs for me.
Thanks for your consideration!
Offline nmur
  • ಠ_ಠ
« Reply #287 on: Tue, 01 December 2015, 09:45:47 »
does anyone have images of the TEX case modified to fit the RGB strips of the pcb?
« Reply #288 on: Tue, 01 December 2015, 09:52:03 »
It's not a Tex, but I ordered this one off TaoBao and my B.face fits nicely in it. Not sure whether other RGB boards have the LED strips in the same spots.
http://world.taobao.com/item/45583909127.htm?fromSite=main&spm=2014.21146508.0.0
There are ridges, and they do seem to align with the RGB strips, but I can't tell if they touch because of the height of the screw holes and the angle of the board. Some of the ridges have notches in them as if to accommodate RGB LEDs, but in other areas they don't. If they do touch, they must not touch very much because I'm still to work the LEDs without issue and they don't seem to be bothered by the ridges.
It's not the world's sturdiest case, but it does the job and, for less than $10, I just threw it with the rest of my TB proxy order.
Offline f1xedgear
« Reply #289 on: Tue, 01 December 2015, 09:53:55 »
Just as another data point, You will be more likely to:
  • have or know someone who has a dremel tool to grind down the case ridges
than to have:
  • The proper skills to desolder the RGB LEDs with a soldering pencil
  • A soldering tweezers
Desoldering the LEDs with a regular soldering pencil will be difficult because the LEDs have 2 pins on each side which have to be heated at as close to the same time as possible so you don't lift pads/traces off the PCB or burn the PCB while trying to heat the opposite side of the LED through the LED itself.
Pictures of the LEDs for reference:
Given the choice between disfiguring the inside of the case (which won't be visible when the keyboard is assembled) or potentially damaging the PCB (and rendering it unusable), I'd definitely choose modding the case.  That way you will also still have the RGBs available should you ever want an acrylic case instead.
Offline nmur
  • ಠ_ಠ
« Reply #290 on: Tue, 01 December 2015, 09:59:59 »
thanks dudes.
I actually have a TEX case here awaiting the pcb, so I think I'm gonna try and just mod the case. tbh though I am surprised to see the size of the RGB components, as that don't look too large, so it must be a close fit even without them.
EDIT I guess those horizontal supports are literally meant to hold up the pcb between the rows of switches, which would indeed make it a tight fit
Offline tominabox1
« Reply #291 on: Tue, 01 December 2015, 10:05:00 »
Nevermind.
« Last Edit: Tue, 01 December 2015, 10:17:13 by tominabox1 »
Offline bloodl1n3
« Reply #292 on: Tue, 01 December 2015, 10:28:13 »
Same here. Just want to confirm that payment was received.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #293 on: Tue, 01 December 2015, 10:36:02 »
Updating now !
Offline trees
  • I like bagels.
« Reply #294 on: Tue, 01 December 2015, 11:18:15 »
Nmur, my boards at home but remind me in a few hours ill take some pics.
You also have to think about the lines shorting out your board, it took 2 layers of electrical tape for mine to stop.
Offline axtran
« Reply #295 on: Tue, 01 December 2015, 13:55:29 »
I was looking at pictures of the Tex Acrylic currently on MassDrop and it looks like some of the ridges have been reduced to accomodate backlit PCBs? I have to check to see if my current case (an older Tex Acrylic) has this same type of layout... it might work without modification.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #296 on: Tue, 01 December 2015, 13:59:36 »
Hey ! Updated the status form and sent all the invoices!
Please check your status here.
Thanks.
Offline braidn
« Reply #297 on: Tue, 01 December 2015, 21:51:24 »
For the folks who are on the fence with cases. Ziptyze cases are really solid for 3d printing, he is super flexible, and as described above, they fit without any mods. In addition if you are buying a steel plate with this drop, this alone will add weight and rigidity to the board overall if you are worried about that type of thing.
Offline ideus
  • Björkö.
« Reply #298 on: Tue, 01 December 2015, 22:12:07 »
Thanks.
is there any chance to still get in for a blue aluminum plate?
« Reply #299 on: Wed, 02 December 2015, 21:49:22 »
Oh well, apparently our whole last page and the IC thread is gone :(
