Author Topic: [GB][FINISHED] Plates, PCBs and stabilisers - LeandreN Round 3  (Read 268838 times)
Offline reddragon394
Re: [GB][closed] Plates, PCBs and stabilisers - LeandreN Round 3
« Reply #300 on: Wed, 02 December 2015, 22:43:05 »
Still had both open on my phone, PDFs attached, hope it helps :)
Offline f1xedgear
« Reply #301 on: Wed, 02 December 2015, 22:49:16 »
Oh well, apparently our whole last page and the IC thread is gone :(
Site was down earlier today, they probably had to restore the database from a backup or something.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #302 on: Wed, 02 December 2015, 23:34:38 »
You're a life saver! Thanks :)
EDIT: can't seem to be able to open the PDF for this thread though, random unreadable characters.
« Last Edit: Wed, 02 December 2015, 23:58:33 by LeandreN »
Offline rabs
« Reply #303 on: Thu, 03 December 2015, 02:39:02 »
Hey Guys,
Thanks again LeandreN for the awesome group buy, made me pull the trigger on making my first custom! Sorry if my questions have already been answered, I can't seem to open the backup PDF of the thread.
I just wanted to check whether the PCB supports split backspace/split right shift/split left shift layouts - I know it does on the WKL store, but I'm not sure if the pre-soldering will preclude these layouts.
Cheers :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #304 on: Thu, 03 December 2015, 02:44:42 »
Hey Guys,
Cheers :)
It will support all the layouts you mentioned. All the information is still in the OP on page 1.
Offline rabs
« Reply #305 on: Thu, 03 December 2015, 02:53:24 »
Ahh awesome thanks.
Offline trenzafeeds
  • **** off
demik will never leave.
Unless he gets banned.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #308 on: Thu, 03 December 2015, 06:15:21 »
Shoot me offers!
Interested in keycaps and random stuff.
« Reply #309 on: Thu, 03 December 2015, 06:39:28 »
Shoot me offers!
Sadly have almost nothing to trade, since I just started sourcing stuff in the keyboard realm :(
I got a a vpro v700 for crazily cheap, just to play around with and maybe harvest for parts if that's something for you  :p
I'll attach the PDF once more, for good measure. This thread wasn't too interesting to have saved, I'm happy I got the ic though :D
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #310 on: Thu, 03 December 2015, 07:27:06 »
Shoot me offers!
Thanks, still can't open the PDF properly though. It is not that important now :) shoot me an offer in PM if you want the case
Offline assumed_bivalve
« Reply #311 on: Thu, 03 December 2015, 09:56:19 »
I'm looking at this case as a potential alternative to the Tex aluminum case.  It just has stand-offs and doesn't have the ridges that would be an issue with the RGB LEDs.
Does anybody have one of these?  It looks like it would probably work without modification.
Offline trenzafeeds
  • **** off
« Reply #312 on: Thu, 03 December 2015, 10:38:40 »
Oh yes, thank you for this by the way. I had most of the info backed up anyways, but I appreciate it!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #313 on: Thu, 03 December 2015, 10:55:08 »
Looks like it should work.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #314 on: Thu, 03 December 2015, 11:07:42 »
Click here for timer
Plates and PCBs ordered. gaterons will be ordered this week.
Offline TalkingTree
    • My projects
« Reply #315 on: Thu, 03 December 2015, 13:58:24 »
Is it the first of February already?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #316 on: Thu, 03 December 2015, 14:04:34 »
Soon™
Will maybe ship sooner, depending on a lot of stuff. I like to set the timeframe a little more than i expect :D
« Reply #317 on: Thu, 03 December 2015, 17:57:55 »
Sooo does anybody know how WKL manages it to put RGB underlighting + in switch lighting in even their full size boards, still running under 500 mA? i imagine the in switch LEDS are PWM regulated, but what about the RGB ones? :D
Oh, and since we get the 60%'s and their website says 810 Ohm resistors work for all colors at that size, does anyone know whats up with that? how can that work, just one value working for all colors, and why is this size sensitive? :D
Offline rddm
« Reply #318 on: Fri, 04 December 2015, 07:14:40 »
If you use 810 Ohm resistors for all colors, the risk of dead leds is low. The only problem, is that some colors can have more light.
RGB leds on wkl have 4 pins, 1 for "color code" , 2 for power, and the last I don't know (didn't saw the datasheet), but maybe for on/off.
Offline ekx
« Reply #319 on: Fri, 04 December 2015, 08:04:29 »
The color a RGB led produces is always controlled through PWM afaik. You can think of them as 3 single leds (Red, Green and Blue) that are PWM regulated, grouped together in a very small space.
« Last Edit: Fri, 04 December 2015, 08:06:53 by ekx »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #320 on: Fri, 04 December 2015, 08:10:49 »
Updated status sheet.
Please check it :D
Offline rddm
« Reply #321 on: Fri, 04 December 2015, 08:16:01 »
The wkl pcb uses a WS2812B as rgb led.
Specifications
 Power Supply Voltage: +3.5V+5.3V
 Input Voltage: -0.5VDD+0.5V
 Red Vf: 1.8~2.2V
 Green Vf: 3.0~3.2V
 Blue Vf: 3.2~3.4V
 Red Wavelength: 620~630 nm
 Green Wavelength: 515~530 nm
 Blue Wavelength: 465~475 nm
 Red luminous intensity(20mA): 550~700 mcd
 Green luminous intensity(20mA): 1100~1400mcd
 Blue luminous intensity(20mA): 200~400 mcd
Product Description
WS2812 is an intelligent control LED light source that the control circuit and RGB chip are integrated in a package of 5050 components. It includes intelligent digital port data latch and signal reshaping amplification drive circuit. Also include a precision internal oscillator and a 12V voltage programmable constant current control part, effectively ensuring the pixel point light color height consistent.
LED with low driving voltage, environmental protection and energy saving, high brightness, scattering angle is large, good consistency, low power, long life and other advantages. The control chip integrated in LED above becoming more simple circuit, small volume, and convenient installation.
You are right, the pwm control the color
« Reply #322 on: Fri, 04 December 2015, 13:06:21 »
thanks for the info you two :thumb:
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB][CLOSED] Plates, PCBs and stabilisers - LeandreN Round 3
« Reply #323 on: Sat, 05 December 2015, 10:49:30 »
Need a RGB case that will fit your tier 3 PCB?
Look no further.
https://geekhack.org/index.php?topic=77618
Offline donpark
« Reply #324 on: Sun, 06 December 2015, 04:54:20 »
Since the PCB is from Wkl, I assume I can order a translucent housing/casing from Wkl right?
Ordered a tier 3 PCB.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #325 on: Sun, 06 December 2015, 04:54:59 »
yes you can.
Offline xondat
  • i'm not a star
« Reply #326 on: Mon, 07 December 2015, 12:14:22 »
Probably going to be designing and ordering my own case for this; is there anywhere where I can find measurements for the plate size and where the screws go?
Offline FoC_Tow
  • Brokehlicious
« Reply #327 on: Mon, 07 December 2015, 13:38:17 »
Looks like I missed out unfortunately...
Missing sales on GH is the worst part about being so busy recently! xD
+1 for the next Round tho!
The PCB looks awesome LeandreN!! <3 :-*
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #328 on: Tue, 08 December 2015, 06:14:38 »
Okay ladies and gentlemen.
Gateron's are shipped from gateron themselves to Corus KB. I will then proceed to pay them. PCB mounted gateron blues. Plates are in production and will ship to me before christmas, same with PCBs. (atleast the tier 3 ones.)
Offline TalkingTree
    • My projects
« Reply #329 on: Tue, 08 December 2015, 06:29:21 »
So, good chances to get plates and PCBs before the end of the year?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #330 on: Tue, 08 December 2015, 07:25:47 »
There is a chance they are shipped before the end of the year at least.
Offline TalkingTree
    • My projects
« Reply #331 on: Tue, 08 December 2015, 08:06:24 »
Great. That's what you are.
Offline axtran
« Reply #332 on: Tue, 08 December 2015, 08:13:14 »
LeandreN is the best! :)
MX Silent > MX Vintage Black > Everything Else
Offline chancellorr
« Reply #333 on: Tue, 08 December 2015, 08:29:40 »
So far this has been the best group buy I have been a part of. Thank you LeandreN!
Offline dae1
« Reply #334 on: Tue, 08 December 2015, 08:51:02 »
Seriously?!  This is so much better than the KC60 (which I haven't received yet) that I ordered from MassCrap.  You're the best!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #335 on: Tue, 08 December 2015, 09:06:58 »
Thanks a lot guys. Here is an insider picture.
~10kg of overpriced cardboard boxes. Should be enough!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #336 on: Mon, 14 December 2015, 05:16:07 »
I need some money right now, so i will sell some of the canceled orders in my GB. Dibs to those who want to buy the whole order.
100% of the money will go to:
Fund refunds for those who wanted a refund AFTER the deadline.
Fund refunds to those who bought the tier 3 PCB and wanted partial refund because all the tier 2s were upgraded to tier 3.
Order ID | Stabilisers | PCB| Plate | Price| Available|Other|
Order 1| 1 set | Tier 3| Alu, purple| 117$| NO
Order 2| 2 sets| 2x tier 1| 1x blue alu, 1x purple alu| 176$| Yes
Order 3| none| none| 1x carbon fiber| 75$| Yes
Order 4| 1 set| 2x Tier 3 | Steel| 216$| Yes| 90 gateron blues
PM me if you are interested.
Offline FoC_Tow
  • Brokehlicious
« Reply #337 on: Sat, 19 December 2015, 07:47:20 »
OMG PMed  :thumb:
Dibs on Order 4!  ;)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #338 on: Sat, 19 December 2015, 08:49:29 »
Hey guys!
Still waiting on information from Corus regarding the Gaterons.
The plates have not shipped yet, but they are very close to shipment.
Hojin is working as hard as i can to get the PCBs finished. They will not ship until after Christmas.
« Last Edit: Sat, 19 December 2015, 13:48:31 by LeandreN »
Offline TalkingTree
    • My projects
« Reply #339 on: Sat, 19 December 2015, 13:46:11 »
They will not ship before after Christmas.
Come again?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #340 on: Sat, 19 December 2015, 13:48:39 »
Offline TalkingTree
    • My projects
« Reply #341 on: Sat, 19 December 2015, 13:52:32 »
For a second I thought you were trolling.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #342 on: Sat, 19 December 2015, 13:56:44 »
Ha! Could definitely have been the case ;)
Offline chancellorr
« Reply #343 on: Sat, 19 December 2015, 14:24:46 »
Come again?
Welcome to the world of Group Buys.
Edit: I'm dumb. Carry on.
Offline lashiel
« Reply #344 on: Sat, 19 December 2015, 15:18:30 »
Come again?
Fixed, thanks !
Huh. It actually kinda makes sense though, if you think about it. Funny error.
Offline toneman77
« Reply #345 on: Tue, 22 December 2015, 11:11:42 »
I regret not being on this GB on so many levels....
Offline TalkingTree
    • My projects
« Reply #346 on: Tue, 22 December 2015, 12:39:34 »
Read a few posts back, LeandreN has some unpaid orders he's willing to sell.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #347 on: Tue, 22 December 2015, 12:43:06 »
Not anymore right now. They sold pretty quickly. More later.
Offline chancellorr
« Reply #348 on: Tue, 22 December 2015, 12:43:54 »
I ordered a silver plate but won't be needing it if anyone is interested same with stabs.
Offline TalkingTree
    • My projects
« Reply #349 on: Tue, 22 December 2015, 13:01:59 »
I'm glad.
