Author Topic: HHKB cleaning  (Read 7263 times)
Offline bocahgundul
  • a seal
HHKB cleaning
« on: Sat, 19 December 2015, 21:52:20 »
I know it kind of stupid but I want to hear how you guys clean your hhkb  :thumb:
Offline livingspeedbump
    • KeyChatter
Re: HHKB cleaning
« Reply #1 on: Sat, 19 December 2015, 22:52:30 »
It depends on what you need cleaning. Because the top half of the keyboard is all one piece, dust doesnt really get very far. I usually just pop off the caps, swap it out with some q-tips, caps on, done.
<- My Collection (so far)
Offline bocahgundul
  • a seal
Re: HHKB cleaning
« Reply #2 on: Sat, 19 December 2015, 23:34:08 »
just q tip no alcohol?
    • KeyChatter
Re: HHKB cleaning
« Reply #3 on: Sat, 19 December 2015, 23:35:02 »
I use the acrylic cover on mine and slide it under my desk when not in use. My HHKB's never get dirty enough to need alcohol   :rolleyes:
Offline bocahgundul
  • a seal
Re: HHKB cleaning
« Reply #4 on: Sat, 19 December 2015, 23:54:44 »
Thx for the reply alcohol is safe right for hhkb?
Offline steve.v
Re: HHKB cleaning
« Reply #5 on: Sun, 20 December 2015, 00:27:46 »
do not use a blow dryer to dry the keyboard. Deformed my spacebar; luckily matto's spacebar came in.
Offline bocahgundul
  • a seal
Re: HHKB cleaning
« Reply #6 on: Sun, 20 December 2015, 00:36:29 »
thx for the info man
Offline jcoffin1981
Re: HHKB cleaning
« Reply #7 on: Sun, 20 December 2015, 00:39:03 »
I keep a dust cover on the board when not in use.  I periodically wipe it down with a diluted windex type solution.
Offline GenKaan
  • Mer caps, mindre käbbel
Re: HHKB cleaning
« Reply #8 on: Sun, 20 December 2015, 04:11:28 »
If its not super dirty: Take a slightly damp toothbrush and rub the keys and then a dry cloth to get it super dry
If its dirty: remove caps, put in hot water with soap, rinse under water, put on a dry cloth for a few hours, rub them individually when I place them back on the keyboard
If its super mega mega dirty:
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline absyrd
  • CPT HYPE PADAWAN
Re: HHKB cleaning
« Reply #9 on: Sun, 20 December 2015, 04:30:48 »
Yep. I just take caps off and 70% alcohol and qtips. Doesn't hurt case.
Re: HHKB cleaning
« Reply #10 on: Sun, 20 December 2015, 07:36:55 »
OXO Good Grips Electronics Cleaning Brush https://www.amazon.com/dp/B0050B6CYW/ref=cm_sw_r_other_awd_y7QDwb49T5DM7
I use this.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
Re: HHKB cleaning
« Reply #11 on: Sun, 20 December 2015, 07:49:04 »
Take it apart and take off the housing. Take the housing to some hot water and soap.
Takes less time then taking a small q tip and trying to get the small nooks.
When I put it back together I put a small amount of lube on my fingers when I insert the sliders.
It's about the perfect amount of lube needed.
Offline bocahgundul
  • a seal
Re: HHKB cleaning
« Reply #12 on: Sun, 20 December 2015, 08:13:42 »
thx for all the reply man appreciate it  :thumb:
Offline Bucake
Re: HHKB cleaning
« Reply #13 on: Sun, 20 December 2015, 11:20:29 »
how do you even remove the sliders? do you have to push them out with force..?
they have tiny hooks that keep'em in place and i'm hesitant to try and force them out. i'd hate to damage my topre boards
also, anyone ever used that funny cleaning gel stuff?
because i have a few keyboards that aren't necessarily filthy, but they do have a bit of dust and tiny hairs lying around..
i've tried some vacuuming, but not everything's coming out
Offline Bromono
  • Wanabe Cicerone
Re: HHKB cleaning
« Reply #14 on: Sun, 20 December 2015, 11:26:41 »
I just take a plastic screw driver and pop them off. You will see tiny residue from the sliders, but it doesn't hurt the slider or board.
For boards that are not that dirty, a qtip will work.
If it looked like my first HHKB when I first got it (It was disgusting), then dissembling the case is your best bet.
Offline RoastPotatoes
    • RoastPotatoes Keyboard Blog
Re: HHKB cleaning
« Reply #15 on: Sun, 20 December 2015, 12:02:10 »
Offline bocahgundul
  • a seal
Re: HHKB cleaning
« Reply #16 on: Sun, 20 December 2015, 17:23:55 »
Offline crj3012
Re: HHKB cleaning
« Reply #17 on: Wed, 30 December 2015, 13:49:48 »
Electric duster weekly on all my keyboards and wipe them down with simple green cleaner as needed.
Re: HHKB cleaning
« Reply #18 on: Wed, 30 December 2015, 16:50:17 »
Clean them with the tears of cherry users
Offline bocahgundul
  • a seal
Re: HHKB cleaning
« Reply #19 on: Wed, 30 December 2015, 17:13:25 »
lol thats the best cleaning solution for topre board
