Author Topic: Ergodox print to check out if my thumbs are ok for it  (Read 6427 times)
Offline Phenix
« on: Thu, 18 February 2016, 03:22:23 »
Hello
Is there a
Ergodox print to check out if my thumbs are ok for it??
Would prefer it in A4 if not A3. Just want to make sure my hands are big enough :thumb:
Winter is coming.
Offline hoggy
  • * Moderator
Re: Ergodox print to check out if my thumbs are ok for it
« Reply #2 on: Thu, 18 February 2016, 04:00:07 »
If we were to come up with a library of such files (preferably pdfs?), what would be the best way to go about it?
I think it would be handy to have a bunch of files covering the most popular (and available) ergo boards.
Offline vvp
« Reply #3 on: Thu, 18 February 2016, 04:09:53 »
Actually, dxf files would be better since users can modify them more easily than pdf. And they are also suitable as a design files (e.g. to derive CAD models from them for 3dPrinting or laser cutting). Not sure what programs are best for dxf on windows. On linux, qcad works very well. Linux version of qcad is free. I do not know about windows version.
Yep.
Offline Phenix
« Reply #4 on: Thu, 18 February 2016, 07:38:10 »
Sounds in general good. But I just need a plain piece of paper with just the design x(so the case in cm .. To check out if my thumb fits
Winter is coming.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #7 on: Thu, 18 February 2016, 17:24:50 »
Here is a two-page PDF I made a few years ago from litster's CAD files. Should be A4 format: if you have a US printer then make sure that your settings are set to crop and not to scale the file before printing.
« Last Edit: Thu, 18 February 2016, 17:26:45 by Findecanor »
Offline Phenix
« Reply #8 on: Fri, 19 February 2016, 07:22:59 »
I already printed it out (from above the link :thumb:)
Thanks anyway.
Now I only have to deal with the questions
Which layout
Which layers
      Going to be fun ;D
Winter is coming.
