Author Topic: Happy Hacking Professional Bluetooth  (Read 149371 times)
Offline ZestMyu
« on: Mon, 11 April 2016, 21:00:31 »
PFU is finally releasing a Happy Hacking keyboard with built in bluetooth:
http://www.pfu.fujitsu.com/direct/shop/hhkb/btpre.html
Offline appleonama
  • Trollo en USA
Re: Happy Hacking Professional Bluetooth
« Reply #1 on: Mon, 11 April 2016, 21:02:53 »
that crappy design choice  :'( and micro b connector  :'(
I'd rather buy a hasu controller
« Last Edit: Mon, 11 April 2016, 21:04:58 by appleonama »
Offline FrostyToast
  • Litshoard
« Reply #2 on: Mon, 11 April 2016, 21:06:55 »
The only thing that would make this remotely compelling versus the Hasu controller is battery life.
Quote from: elton5354
« Reply #3 on: Mon, 11 April 2016, 21:07:24 »
Well that's pretty sweet.
Offline fknraiden
« Reply #4 on: Mon, 11 April 2016, 21:11:31 »
Any english articles? or what specs and version availability?
Offline thatsmrdoctortoyou
  • Dingo babies
    • IG
« Reply #5 on: Mon, 11 April 2016, 21:12:20 »
Agreed, mini USB would have made this more desireable.
What is the battery life with the Hasu controller?
Offline pr0ximity
« Reply #6 on: Mon, 11 April 2016, 21:14:19 »
I see they still haven't figured out how to put a key in either of the bottom corners.
Offline FrostyToast
  • Litshoard
« Reply #7 on: Mon, 11 April 2016, 21:33:58 »
I see you still haven't figured out that there is another JP model.
Offline Coreda
« Reply #8 on: Mon, 11 April 2016, 21:34:02 »
You'd think there would be space enough for a flatter battery and BT adapter to fit inside the existing case. From the looks of it they went with replaceable AA batteries, though it's unclear if they can be recharged from the unit itself. Maybe someone who understands Japanese can shed some light.
Offline pr0ximity
« Reply #9 on: Mon, 11 April 2016, 21:51:01 »
Ah right, always forget about that thing. Tiny spacebars before tiny spacebars were cool.
Offline yomammary
« Reply #10 on: Mon, 11 April 2016, 22:28:43 »
That's underwhelming...
RF 87u 55g | Leeku 1800
Offline clacktalk
  • circa 2015
« Reply #11 on: Mon, 11 April 2016, 22:30:48 »
not programmable
jutting AA battery compartment
where is the innovation
diary of a clacktalk
radio_killah: too much frank
« Reply #12 on: Mon, 11 April 2016, 22:32:07 »
I still would rather get the hasu controller so I can program keys as well as have Bluetooth.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #13 on: Mon, 11 April 2016, 22:45:25 »
PFU, just release a HHKB 3, that's all you need to do and the HHKB master race will be lining up for one, as long as it's not ****e.
Offline jerue
  • (Whenever that happens :P)
« Reply #14 on: Mon, 11 April 2016, 23:21:32 »
  • No type-s
  • finally a black HHKB Pro JP option
  • dat bootay though
Maybe this is just to tide us over for the next...eon or so...then again, why fix something if it isn't broken?
Offline Belfong
« Reply #15 on: Mon, 11 April 2016, 23:44:57 »
I thought it's not that bad looking. Hmm, I have been looking for a BT mech keyboard for the iPad and this came at the right time. I wonder if they are discontinuing the non BT models, since this one can be cable driven as well.
Offline Belfong
« Reply #16 on: Mon, 11 April 2016, 23:57:28 »
oh look, finally a rubber stopper in the BT edition:
Offline appleonama
  • Trollo en USA
« Reply #17 on: Tue, 12 April 2016, 00:11:28 »
AMAZING!
Offline adhoc
« Reply #18 on: Tue, 12 April 2016, 01:07:48 »
Heh, I wrote I'd expect a new HHKB on GH IRC channel 2 weeks ago, everyone mocked me. It's an iteration, not innovation, which is perfectly fine in my eyes. I wanted wireless, no usb hub and stock pbt space bar from the update. So far this rings all the bells (except for the space bar - or?), but I'll wait for type s bt, which will inevitably come.
Offline funderburker
« Reply #19 on: Tue, 12 April 2016, 01:49:06 »
Well, I don't understand why they went with a AA battery solution because it looks... out-dated. I think that their design team is stuck in 2005.
They could've taken example from Hasu and just made a official Bluetooth controller with built-in battery but instead they made the classical design a bit rough and I don't like it. But that's just my opinion. I'll be happy with my newly bought HHKB Pro 2 & will probably buy the Hasu controller instead of this.
Could this mean that the HHKB Pro 2 price will drop? This could possibly happen, right?
Keyboard design by Skepur
Offline FrostyToast
  • Litshoard
« Reply #20 on: Tue, 12 April 2016, 01:58:23 »
I like AA because lithium ion dies over time and you cannot replace the batteries like you can with traditional methods.
Offline Belfong
« Reply #21 on: Tue, 12 April 2016, 01:58:59 »
Apple Wireless Keyboard and Trackpad also use AA battery. I think it make sense. It's easy to replace and they are cheap. I don't mind this decision. The design, though, is a bit weird with that row of thing jutting at the back. I tell myself that if it works for Matias, surely it will look good in a HHKB.
Offline nmur
  • ಠ_ಠ
« Reply #22 on: Tue, 12 April 2016, 03:08:52 »
apparently the battery can last for 3 months? if so, that's pretty long
Offline Belfong
« Reply #23 on: Tue, 12 April 2016, 03:25:15 »
exciting huh! finally the iPad has a worthy keyboard.
« Reply #24 on: Tue, 12 April 2016, 03:40:21 »
  • No type-s
  • dat bootay though
There has always been a black jp tho
Offline beehatch
  • baehatch
« Reply #25 on: Tue, 12 April 2016, 03:51:35 »
fug
Offline rurushu
« Reply #26 on: Tue, 12 April 2016, 04:28:36 »
uhh.... the design... in my humblly humble opinion, is fugly.
The non- BT ones are nicer in design.
Offline MJ45
  • HHKB Pro
« Reply #27 on: Tue, 12 April 2016, 05:12:30 »
If they made a white HHKB Pro BT it would look like a Apple approved HID device.134157-0
Offline yomammary
« Reply #28 on: Tue, 12 April 2016, 08:50:19 »
Offline joric
« Reply #29 on: Tue, 12 April 2016, 09:20:02 »
Made a somewhat shocking discovery.
http://www.pfu.fujitsu.com/hhkeyboard/bt/spec.html
"Power supply   AA batteries (two), the power supply from the Micro USB port (cable not included)"
"Interface : Bluetooth Ver3.0 Class2 (Bluetooth HID 1.0 profile)" No USB here.
http://www.amazon.co.jp/dp/B01DVH7C0O/?m=A2JB8E672LPES7&tag=pfdi-22
"Power to adopt a readily available AA batteries. About three months operating with two AA alkaline batteries. Also equipped with a USB micro-B connector for power supply"
Also this picture:
Top: LED indicator. The LED's color and blinking/non-blinking indicate the connection status
Bottom left: Power switch
Bottom center: Battery compartment, AA battery x 2
Bottom right: USB micro-B connector (for power supply)
Seems pretty straightforward that USB is for power only.
« Last Edit: Wed, 13 April 2016, 10:56:51 by joric »
Offline Latin00032
« Reply #30 on: Tue, 12 April 2016, 15:02:43 »
"Power supplyAA batteries (two), the power supply from the Micro USB port (cable not included)"
Also this picture:
I want to like this but I'd rather install a hasu controller so I can customize the layout.
Offline robbles
« Reply #31 on: Tue, 12 April 2016, 15:27:51 »
I wonder how long it will be before these are ready to purchase in the USA. With the relative scarcity of Hasu's BT controller, if Amazon US gets these I might bite. I told myself my second HHKB would be a blank white though. The lack of color options is disappointing.
How does one become so interested in a thing like keyboards? When you realize you use a keyboard more than any other tool in your life.
Offline breaker9691
« Reply #32 on: Tue, 12 April 2016, 21:05:24 »
i'm not sure that i will buy this version but i think when i got it i will make  quick review and typing sound for anyone who considering about buy this version
i'm loving the type-s with the "thock thock" sound and i owning both pro2 type-s and pro2, this version adding more "rubber dome" so it's will surely doesn't scratch your glass table and more stable when using on surface like glass and something like that
but typing is different each version of hhkb, hope that still can keep HHKB like a legend of 60% keyboard.
Offline Rad
« Reply #33 on: Tue, 12 April 2016, 21:14:26 »
That girl got an ass on her.
Offline raymogi
« Reply #34 on: Tue, 12 April 2016, 21:51:01 »
Might get this just because.
Please feed my addiction.
Offline joric
« Reply #35 on: Wed, 13 April 2016, 10:07:49 »
DIP switches migrated to the bottom, covered with a special lid.
Offline FoC_Tow
  • Brokehlicious
« Reply #36 on: Wed, 13 April 2016, 11:19:08 »
Yeah... No
Offline iLLucionist
  • Topre is Love.
« Reply #37 on: Wed, 13 April 2016, 11:34:05 »
Nope. The newest series have built-in batteries and charging over... thought micro or mini USB.
Offline iLLucionist
  • Topre is Love.
« Reply #38 on: Wed, 13 April 2016, 11:37:32 »
Seriously... lack of innovation and vision here. WTF. That bulge at the back looks disgusting. It made my eyes puke.
Why not steel case, plate mounted, 55g option, other color combo's, reversible / cherry compatible stems, pbt spacebar.
So many sane options that most topre lovers would immediately buy. Even at 100$ more. Why this? WHY?
Also, this makes topre look bad in my opinion, the lack of direction.
"HHKB is supreme."
> "Yeahh... but have you seen that fugly bluetooth HHKB? Nahh... I'll buy a Razer instead. Laaataahh loooossssaaaahhhs"
Offline beehatch
  • baehatch
« Reply #39 on: Wed, 13 April 2016, 18:36:24 »
Offline kekman
  • quit life
« Reply #40 on: Wed, 13 April 2016, 19:44:35 »
"HHKB is supreme."
i think pfu wants the protect the hhkbs image as a 'purist' topre typing board, but they kinda ****ed up every opportunity with this.
Offline derb2k2
  • Something of a Topre ****..
« Reply #41 on: Wed, 13 April 2016, 19:48:48 »
even though bluetooth is attractive, big negative on this. Don't like that part jutting out.
I'll be on the lookout for a slimmer version without the bump though.
edit: ahah, reading earlier comments. Yea that design isn't too good.
« Last Edit: Wed, 13 April 2016, 19:50:48 by derb2k2 »
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
Offline Polymer
« Reply #42 on: Wed, 13 April 2016, 20:14:08 »
MOST Topre lovers?  Why would they want it plate mounted?  That would completely kill the feel you get with a HHKB.  Some people may want a RF in the shape of a HHKB...but the HHKB is different and it should be..all that extra thock?  Lost..  That isn't innovation and is probably going in the WRONG direction.  55g is a niche weight and not the one they've determined is the best.  It might have a following here but it is a niche weight. Even check out the others that have made Topre keyboards (660c, Novatouch), they're not 55g.  Why would they make these MX compatible when they sell Topre Keycaps?  Maybe at some point if they're never making anymore keycaps (I would love more colors but the market is too small for that) they'll do us all a favor and switch but I just don't see it happening.    PBT Spacebar would be nice..but if you have any experience with these you know people have had to get their hair dryers out and straighten them a bit..not an issue any company wants to deal with...An Aluminum case would be interesting but for the same reason as the plate, you'd lose the feel and that's not something I'm interested in having with the HHKB.  I think one thing that wouldn't have changed the keyboard from a normal user standpoint but allowed for more options is programmable.
I do agree that the bulge probably could've been handled differently (although I'm sure they looked into it)...Normal batteries are so much better than chargeable ones though.  What happens when your chargeable battery dies?  You have a bluetooth keyboard that you need to have plugged in...You only have a built in battery because of size or because you want the keyboard to be obsolete in the 3-5 years it'll take for the battery to no longer charge very well...and if they had a replaceable battery, how long will that be available?  Pretty nice market to begin with...AA batteries that last 3 months is pretty good..more than happy to deal with that..and the usb as a backup in case it dies is great.  Maybe having a way to charge rechargeable AA's if it was plugged in might've been interesting....
Offline joric
« Reply #43 on: Wed, 13 April 2016, 21:27:15 »
You probably just never had a wireless keyboard. Try it, this is ****ing sweet (not the hasu controller that just makes it a huge PITA). Ordering this one right now.
Offline cryptokey
  • [°°▄°] luser-friendly
« Reply #44 on: Wed, 13 April 2016, 22:04:42 »
Been looking around at getting my first HHKB, but this bluetooth HHKB is too fugly for me.  Bluetooth and micro usb isn't a plus for me so I'll pass.
[WTB] HHKB Black
Offline joric
« Reply #46 on: Thu, 14 April 2016, 00:44:19 »
Just got an official reply to my inquiry from hhkb@pfu.fujitsu.com:
USB is for power only.There is no I/F.
It can't charge battery.
Best Reg,
今後とも弊社製品の変わらぬご愛顧の程、心よりお願い申し上げます。敬具
【ご質問/ご連絡 内容】
Title : USB connector Inquiry :
This is about HHKB Professional BT.
1) Is USB for power only? Will it work via USB cable if there's no Bluetooth on the host?
2) Does it have a built in charger for AA-sized accumulators?
Product Name: HHKB全般
Offline iLLucionist
  • Topre is Love.
« Reply #47 on: Thu, 14 April 2016, 03:40:25 »
"HHKB is supreme."
I don't think pfu is gonna recover from this.. topre bragging rights down the drain
Offline henz
  • What?
« Reply #48 on: Thu, 14 April 2016, 06:04:40 »
its like we need to hype because they have released a new model.
Offline joric
« Reply #49 on: Thu, 14 April 2016, 07:23:05 »
