Author Topic: Happy Hacking Professional Bluetooth  (Read 149376 times)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Happy Hacking Professional Bluetooth
« Reply #100 on: Mon, 18 April 2016, 19:16:46 »
Hehe, the Amazon links on that site the OP listed are affiliate links. I'm guessing that pfdi-22 is PFU's affiliate link :))
AA cell is an odd choice. Why no use LiPo?
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« Reply #101 on: Mon, 18 April 2016, 19:27:25 »
Easier to replace, cheaper to replace...and should they fail unlike a Lipo which would likely be inside the keyboard as opposed to an external bump..the failing AA"s won't damage the keyboard the Lipo most likely will.
Honestly this is one of the biggest things i applauded about the Logitech G602 was the switch to AA's.
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
« Reply #102 on: Mon, 18 April 2016, 19:27:51 »
Honestly this is one of the biggest things i applauded about the Logitech G602 was the switch to AA's.  If they went with a rechargeable pack i likely would not be as interested as i am now.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #103 on: Mon, 18 April 2016, 20:09:54 »
LiPo may have problems with temperature but honestly, who is going to leave their HHKB out in a hot car or outside in the snow?
Offline Polymer
« Reply #104 on: Mon, 18 April 2016, 20:19:55 »
It isn't just that, it is replacing it when it is no longer delivering the lifetime it should.  Where would you get it?  How much would that be?  How long would it keep a charge for?
I like the idea of AAs..although LiPO would've given them a greater chance to add it to the current internals of the case...
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #105 on: Mon, 18 April 2016, 20:45:09 »
There are common LiPo packs in use for Drones/RC stuff but I get where you're coming from. Those Drone LiPo packs are probably too big to fit in a HHKB anyway
Offline iLLucionist
  • Topre is Love.
« Reply #106 on: Tue, 19 April 2016, 04:35:24 »
They traded away aesthetic for the return of functionality.
How is this objectively bad?
I'm a man who values looks before functionality but even then I have to say that I can approve of this. AA batteries will always be more functional than lithium ion in the event that bulk and weight are of no concern.
Well... like I've pointed out with the new Apple wireless keyboard, aesthetics didn't need to be traded for functionality. At least that's the way I look at it.
How are AA batteries more functional? A Li-Ion will last longer, you don't have it sticking out, and you don't have to replace the batteries. Saves a lot of hassle if you ask me.
Offline intelli78
« Reply #107 on: Tue, 19 April 2016, 04:45:29 »
Hmm, this isn't the HHKB update I was hoping for.
« Reply #108 on: Tue, 19 April 2016, 05:27:07 »
li-Ion will eventually die (and if it does so in a poor fashion it could cause a good amount of damage)  Rechargeable AA's are cheap simple to replace.   When in smaller tech like this i always prefer an easily removable battery source hence as i mentioned earlier loved when Logitech moved the G602 to AA's.  Given when the run time on batteries is so long when you can use 2 AA's i don't see the real advantage of a li-ion.
THe Li-Ion if inside the board could end up damaging it should anything bad happen with the battery
An internal L-ion is much harder to replace then two AA's and whom is to know if they would use a proprietary size/battery cable etc
If it happens to die when i am not near a charging source or i don't have time to connect it and let it sit and charge i can swap out AA's easily on a whim or even buy some should i not have rechargables with me.
Short of a major case redesign i'm not sure they could fit a battery big enough inside the case to provide longer lasting power than 2 AA's can?  I mean panasonic eneloops are 2550 mAh /AA Do they make safe li-ions small enough that could fit inside the case to compete with that these days?
It's all subjective of course but personally with devices such as this i tend to move toward AA's over rechargeable internal cells.
Offline iLLucionist
  • Topre is Love.
« Reply #109 on: Tue, 19 April 2016, 05:51:15 »
I can see that. I had the original macbook air and I literally had to throw it away because to top and bottom shell started to separate because the battery was expanding.
Offline Belfong
« Reply #110 on: Tue, 19 April 2016, 09:08:39 »
So why can they built it like the old Nokia feature phone? Flat Li Ion battery that's easily replaceable.
Offline iLLucionist
  • Topre is Love.
« Reply #111 on: Tue, 19 April 2016, 09:18:58 »
I'm thinking... it should be possible to built in custom BT controller with a Li-Ion and just mod a regular HHKB. Such a battery should fit in nicely, there is plenty of room in HHKB case.
Offline funderburker
« Reply #112 on: Tue, 19 April 2016, 09:34:02 »
A quick question - does AA batteries hold more power or they are just using it more effectively?
Keyboard design by Skepur
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #113 on: Tue, 19 April 2016, 09:44:20 »
Depends on the AA cell. Most non-rechargeables are +/- 800 mAh but one could get rechargeables with much more capacity.
PFU is pretty big. I don't see why they couldn't find a producer of a safe battery for tablets or cell phones that would fit the HHKB case. Their customers are obviously well informed of the products, why couldn't they do this and offer a replacement battery on the website?
My thought is AA is the easiest to access without opening the case. I guess PFU hates it when people open the HHKB :confused:
« Reply #114 on: Tue, 19 April 2016, 09:48:01 »
But they could've made a pocket in the case for AA batteries. Or AAA batteries. Well, will never know for sure. Still voting for Hasu to become PFU HHKB team director. :D
Offline iLLucionist
  • Topre is Love.
« Reply #115 on: Tue, 19 April 2016, 09:49:56 »
I really don't understand it either. It seems sloppy. Like typical PC laptop designs.
« Reply #116 on: Tue, 19 April 2016, 11:06:40 »
I can't really argue that point, much as i prefer AA or AAA batteries one has to wonder if they could not have incorporated them into the casing a little better.
Offline joric
« Reply #117 on: Sat, 23 April 2016, 05:58:32 »
First review:
« Reply #118 on: Sat, 23 April 2016, 06:39:22 »
First review:
Can't wait till some reviews in English come out...especially ones that delve very specifically into how good the bluetooth connection itself is.  Most specifically with iOS hopefully.
Offline joric
« Reply #119 on: Sat, 23 April 2016, 07:02:21 »
Someone speaking japanese could submit subtitles for it: https://www.youtube.com/timedtext_video?ref=player&v=s6BmoR18lfQ
Offline joric
« Reply #120 on: Sat, 23 April 2016, 07:10:16 »
Here's a text version in japanese http://japanese.engadget.com/2016/04/11/hhkb-happy-hacking-keyboard-profess/
Upd: "HHKB Professional BT" is automatically power if there is no 30-minute character input has become the specifications turned off. The power will turn on the power button long press, but then re-connect automatically to the terminal which has been pairing just before"
Sorry for Google Translate, but it seems that they've used a dedicated wakeup button to switch keyboard on after 30 minutes of inactivity. This is really ****ty. I  bet they didn't change the keyswitch board at all, and it's the same 5V-only power hog TP16834 capsense controller. Hasu could've done the same a long while ago, I already wrote about a separate wakeup button here https://geekhack.org/index.php?topic=12047.msg2107950#msg2107950
« Last Edit: Sat, 23 April 2016, 09:22:22 by joric »
Offline iLLucionist
  • Topre is Love.
« Reply #121 on: Sat, 23 April 2016, 08:34:14 »
Soo... wtf is with those arrow keys cluster and the spacebar? I thought this was a HHKB with HHKB layout?? I must say that the bulge looks less ugly than I anticipated. This looks more like they put a fc660 in a HHKB form factor.
« Reply #122 on: Sat, 23 April 2016, 09:59:54 »
That's the Japanese layout as is with the normal JP HHKB layout, i'd venture to guess the American version will look more like the normal HHKB Pro 2 we are used to.
Offline iLLucionist
  • Topre is Love.
« Reply #123 on: Sat, 23 April 2016, 10:15:14 »
Ah, that makes sense. I hope somebody will get the American HHKB and post a review of that.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #124 on: Sat, 23 April 2016, 12:06:09 »
RIP the screens on those devices! He stacked them on top of each other.. oh the humanity :'(
Edit - If the Hasu controller gets an update for the HHKB2 JP layout, I would totally buy that board/controller and open the case up :cool:
« Last Edit: Sat, 23 April 2016, 12:09:45 by csmertx »
Offline iLLucionist
  • Topre is Love.
« Reply #125 on: Sat, 23 April 2016, 12:11:10 »
I'd probably try that as well. I'm curious if it would be possible to buy a Li-Ion accu for a smartphone or something and hook that up to hasu controller. There should be plenty of room to build that into HHKB.
Offline joric
« Reply #126 on: Mon, 25 April 2016, 00:03:27 »
Got HHKB from Amazon to the shipping service, supposedly there's one more week till it gets to me. Hasu already got one from the local store, promised to post pics later.
Upd: That "empty space" is actually a large ferrite bead (as you can see there's no USB interface, just USB power supply):
The main board has quite changed. The main controller is ultra-low power MSP430, the bluetooth chip is BCM20730.
Looks like there's no proprietary topre chip (TP16834) anymore. And it still has analog mux, but LW051A instead of HC4051.
Uses a small 20pin PCB-PCB connector, no more JST-13, no more wires (only a few that go to the batteries).
« Last Edit: Mon, 25 April 2016, 18:15:07 by joric »
Offline Belfong
« Reply #127 on: Mon, 25 April 2016, 02:11:01 »
Upd: That "empty space" is actually a large ferrite bead:
The main board is quite changed. The main controller is ultra-low power MSP430, the bluetooth chip is BCM20730:
awesome shot of the internals.
I'd really like to know, does it sleep after 30 min of inactivity and you need to wake it up by pressing the on switch? Is that really true?!
Offline joric
« Reply #128 on: Mon, 25 April 2016, 04:42:14 »
Another unboxing (shows that "smart case" that goes to preorderers).
Status LED turns off after a while (as on bluetooth Filco's).
The smartness of the case wasn't really shown.
« Last Edit: Mon, 25 April 2016, 05:10:31 by joric »
Offline iLLucionist
  • Topre is Love.
« Reply #129 on: Mon, 25 April 2016, 05:16:01 »
Very nice pictures and internals. I'm not a PCB designer, but it looks like they actually put some effort into the design.
Offline iLLucionist
  • Topre is Love.
« Reply #130 on: Mon, 25 April 2016, 05:19:13 »
Actually, that bulge looks WAY smaller like this. It's also very to the lower end of the board. Don't think I find it that ugly anymore.
Offline Belfong
« Reply #131 on: Mon, 25 April 2016, 05:23:22 »
That's my thought as well. And it looked to be pretty solidly built. My only concern is not aesthetic but whether I need to press the start button to wake the keyboard up.
Offline iLLucionist
  • Topre is Love.
« Reply #132 on: Mon, 25 April 2016, 06:18:12 »
The way I read it, is that you need just to start typing again and it'll establish a connection again real quick.
I am actually thinking of buying this one now.. damm..
Offline joric
« Reply #133 on: Mon, 25 April 2016, 06:19:11 »
Paid for the last mile. Shipping weight is 1095g, dimensions are 34x17x14 cm, probably includes that really smart smart case for the first 1000 of buyers. Paid 3250 JPY for shipping to Europe (EMS, 7 days, fully insured, http://www.amazon.co.jp/dp/B01DVH7C0O/ + http://zenmarket.jp). Now I wait.
Offline iLLucionist
  • Topre is Love.
« Reply #134 on: Mon, 25 April 2016, 06:38:07 »
What is that really smart smart case, seriously?
Offline Belfong
« Reply #135 on: Mon, 25 April 2016, 06:39:37 »
I think they meant smart as in nice to look at, pleasant to the eye. Not smart as in intelligence.
Offline joric
« Reply #136 on: Mon, 25 April 2016, 06:50:13 »
Might be. It was just a google translate after all. Can't even find that page anymore.
Upd: It's there in the description to the unboxing video. Looks like it's just a cheap cloth pocket:
There are three BT models: PD-KB600B (US layout), PD-KB600BN (US layout, blank keys) and PD-KB620B (JP layout). Mine shown here is the blank one - PD-KB600BN. The fact that the keyboard came with a soft keyboard case -- or "HHKB smart case" as PFU calls it -- confirms I was indeed one of the fastest (≤ 1000th) to preorder the keyboard. There is nothing "smart" about the case by the way; it's just a name.
« Last Edit: Mon, 25 April 2016, 07:42:49 by joric »
Offline iLLucionist
  • Topre is Love.
« Reply #137 on: Mon, 25 April 2016, 07:36:58 »
But what IS a soft keyboard case? How does it differ from the regular keyboard? I'm confused... is it the keyboard case ITSELF or is it a carrying cloth bag?
Offline joric
« Reply #138 on: Mon, 25 April 2016, 07:43:32 »
A cloth sleeve. I coudn't find exact model but it clearly says "BIRD" on the label, looks like there's no PFU branding at all. Looks pretty generic.
« Last Edit: Mon, 25 April 2016, 07:55:59 by joric »
Offline losing_ctrl
« Reply #139 on: Mon, 25 April 2016, 07:45:11 »
I must agree. My initial judgement was too harsh on the bulge, now I'm thinking it's no big deal, and would like to get one of these. Ha!  I'll await further testimonials as to how good the BT works with regards to latency and connecting, staying connected, and reconnecting after going to sleep.
Offline Polymer
« Reply #140 on: Mon, 25 April 2016, 09:00:19 »
It is in the pictures...It is just a cloth/neoprene cover for the keyboard...Carrying case, sleeve, cache, cover, whatever you want to call it..
Offline iLLucionist
  • Topre is Love.
« Reply #141 on: Mon, 25 April 2016, 09:13:37 »
Doesn't particularly look like a MUST HAVE or something.
Offline the_marsbar
« Reply #142 on: Mon, 25 April 2016, 16:18:52 »
I agree - that is actually quite nice. The PFU marketing guys made a poor choice with the angles of the photos on their website IMO.
If I hadn't recently bought two HHKBs I'd have gotten the BT one instead of my regular black board.
Offline hasu
  • @tmk
« Reply #143 on: Mon, 25 April 2016, 22:05:45 »
I got it and took some pics of internal.
http://imgur.com/a/YfcYt/all
I'll add info(of internals) in this thread.
https://geekhack.org/index.php?topic=12047.msg2152474#msg2152474
Offline adhoc
« Reply #144 on: Tue, 26 April 2016, 01:25:21 »
We're getting a better version of bluetooth connectivity than stock confirmed. :D
Offline iLLucionist
  • Topre is Love.
« Reply #145 on: Tue, 26 April 2016, 04:51:53 »
Very nice pics of the internals, this looks promising.
Offline joric
« Reply #146 on: Tue, 26 April 2016, 05:35:06 »
Seems like it sells for 27500 JPY (248 USD) rather than 29700 JPY (267 USD) directly at PFU:
http://www.pfu.fujitsu.com/direct/hhkb/detail_hhkb-pro-bt.html "27,500 ¥ (excluding tax) (tax-included price: ¥ 29,700)"
Does tax always apply?
« Last Edit: Tue, 26 April 2016, 05:36:41 by joric »
Offline iLLucionist
  • Topre is Love.
« Reply #147 on: Tue, 26 April 2016, 06:23:30 »
Do they ship to Europe directly?
Offline adhoc
« Reply #148 on: Tue, 26 April 2016, 08:55:55 »
Is there a usb dongle with bluetooth receiver included, or do you have to have a bluetooth receiver already available on your device?
Offline TopreFan333
« Reply #149 on: Tue, 26 April 2016, 11:08:21 »
Same here -- I'd happily make this upgrade if it turns out to be usable.
« Last Edit: Tue, 26 April 2016, 19:39:18 by dchadwick »
