Author Topic: Does stacking o-rings provide the same result as using a thicker o-ring?  (Read 3901 times)
Offline Franck Dernoncourt
    • website
I plan to add o-rings in my mechanical keyboard. Does stacking o-rings provide the same result as using a thicker o-ring, from the standpoint of the keyboard user?
For example, I could use two o-rings stacked on top of each other (1.5mm + 2.5mm), or directly use a 4mm o-ring.
Offline ddot
  • Master of Suspense
Send Lpwl that question.  He has his own vendor sub forum:
https://geekhack.org/index.php?board=189.0
Before that he was just operating out of the classifies, but he talked about stacking a bit in this post:
https://geekhack.org/index.php?topic=62935.msg1652742#msg1652742
Offline Malenky
Assuming you're talking about adding them to Cherry MX keys, then I'd imagine they feel pretty similar. Potentially stacked o-rings might feel *slightly* softer because I'd imagine they would allow for slightly more compression when compared to a single o-ring of equivalent thickness. Be careful though, Cherry MX switches have 4mm of travel, so 4mm of o-ring will make your keyboard unusable, unless you're using SA profile keycaps, which are really tall (in which case, you'd basically be stacking o-rings to pad the distance until they actually had any sort of effect).
Offline Lpwl
  • lpwl.bigcartel.com
    • My O-ring Store
I wasn't home last week-end, so I answered Franck's question directly via e-mail but I guess a few words here might also help a few wanderers ...
The answer is both yes and no.
It depends on what keycaps you are using !
For example, if you are using SP DSA profile caps then 4mm ≠ 1.5mm + 2.5mm.
And from my testing, anything thicker than 3mm will stop you from being able to actuate every switch comfortably.
Further reading :
[1]  O rings for DSA Caps
[2]  Lpwl O-Rings - FAQ & HELP
[3]  hjc1710's comment from my older sale thread
Thank you again ddot for referring him to me  :thumb:
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Further reading :
Out of curiosity, is it because the 4mm has a larger OD compared to the the 1.5mm and 2.5mm rings?
Offline Lpwl
    • My O-ring Store
Yup, you're right - though I think this has more to do with SignaturePlastics keycaps lacking cross-shaped supports.
