Author Topic: paint acrylic?  (Read 2906 times)
Offline Eszett
paint acrylic?
« on: Sun, 01 May 2016, 10:12:20 »
Any ideas how to paint acrylic to get a durable result? I have a transparent acrylic case, which is rather ugly.
Re: paint acrylic?
« Reply #1 on: Sun, 01 May 2016, 11:36:16 »
If it is transparent, then paint the back side.
That way, the actual paint surface is always protected.
- Oliver Willis 2026-08-01
Offline Eszett
Re: paint acrylic?
« Reply #2 on: Sun, 01 May 2016, 12:34:17 »
+1 for intelligence :-) Anyway, I'd like to paint the side parts as well. So I'm curious if there is a method of painting the surface of transparent acrylic layers in a durable manner?
« Last Edit: Sun, 01 May 2016, 21:01:43 by Eszett »
Offline SKD
Re: paint acrylic?
« Reply #3 on: Mon, 02 May 2016, 15:58:57 »
If you plan on painting the outside you need to sand and prime then paint (spray can?). Acrylic can be fairly durable if you do it right. PM me if you want more details, I need to go to sleep lol
Offline exitfire401
  • The Force is Re/\l
Re: paint acrylic?
« Reply #4 on: Mon, 02 May 2016, 15:59:58 »
I've also had very good luck with acrylic based spray paints.
Offline absyrd
  • CPT HYPE PADAWAN
Re: paint acrylic?
« Reply #5 on: Mon, 02 May 2016, 16:03:26 »
Krylon Fusion. Be patient and follow the directions.
Offline Eszett
Re: paint acrylic?
« Reply #6 on: Mon, 02 May 2016, 16:20:03 »
Thanks for your posts. Especially Krylon Fusion sounds interesting, as it's description says it's made for plastic surfaces, and, no sanding or priming is necessary as well! I hope it is sold in Europe somewhere ...
Offline SKD
Re: paint acrylic?
« Reply #7 on: Tue, 03 May 2016, 06:47:05 »
I would at least sand it slightly, paint adheres better than a perfectly smooth surface.
Offline absyrd
  • CPT HYPE PADAWAN
Re: paint acrylic?
« Reply #8 on: Tue, 03 May 2016, 06:53:16 »
Same. Quick sand will help.
Offline Eszett
Re: paint acrylic?
« Reply #9 on: Wed, 04 May 2016, 16:12:12 »
Thanks for suggestions!
