Author Topic: [Oddforge] VE.A  (Read 332192 times)
Offline Azzures
  • ༼ つ ಥ_ಥ ༽つ PRAISE HELIX ༼ つ ಥ_ಥ ༽つ
Re: [Oddforge] VE.A
« Reply #250 on: Mon, 26 September 2016, 15:14:46 »
Yeah, similar issue here.
Well least Im not the only one, thought I was going to have to unsolder the entire board of the switches and try again. Maybe one of the chips doesnt have enough clearance to rest on the acrylic layer? Going to take another look tonight. Also, does anyone know where I can buy more of these plastic screws for the case? They strip very easily >.>
was having the same issue. Re-tighten all 4 of those rubbers screws on the back to about the same tightness. If one screw is looser than the other 3 it'll wobble a little. Re-tightened mine, solid as a rock now.
Problem with mine is one wont screw in all the way now, tried rethreading it, but I think theres something wrong with the screw hole now. But the problem is negligible now, just added a thin layer of take to one of the rubber feet. works fine now. Im so happy with it ^.^
Offline Data
Re: [Oddforge] VE.A
« Reply #251 on: Mon, 26 September 2016, 18:53:07 »
Are resistors required for the lock indicator LEDs?
I see solder pads for them on the bottom of the PCB, but they aren't mentioned in the build guide.  Would appreciate any feedback from those who've built theirs already.  :)
Offline hkf
  • your #1 fan
Re: [Oddforge] VE.A
« Reply #252 on: Mon, 26 September 2016, 19:05:26 »
I assume yes because there is room for them.
I built mine from r1 of the kr gb with the translated instructions.
Offline Data
Re: [Oddforge] VE.A
« Reply #253 on: Mon, 26 September 2016, 20:07:53 »
Did they cover resistors for the lock indicators in those instructions?
Offline hkf
  • your #1 fan
Re: [Oddforge] VE.A
« Reply #254 on: Mon, 26 September 2016, 20:25:00 »
http://kbdlab.co.kr/index.php?document_srl=3152205&mid=board_tune&document_srl=3216765
Offline exitfire401
  • The Force is Re/\l
Re: [Oddforge] VE.A
« Reply #255 on: Mon, 26 September 2016, 20:54:41 »
Not sure if i missed, but were there instructions for assembling the tented stand? I feel like I'm trying to put legos together without documentation haha. Also, same question with the lock leds. Any suggestions for resistors for the locks?
Offline Data
Re: [Oddforge] VE.A
« Reply #256 on: Mon, 26 September 2016, 21:15:12 »
Thanks. Much better photos there. I can clearly see the resistors.
I didn't have SMD resistors for my chosen LEDs so I just cut the legs short on a few thru-hole resistors and everything is working fine. The lock indicators are incredibly bright. :P
Offline Vypr
Re: [Oddforge] VE.A
« Reply #257 on: Mon, 26 September 2016, 21:29:06 »
Thank you, those pics will be helpful
current keyboard: VE.A (home) WhiteFox TrueFox (home)  MD1 Infinity (Home)  Infinity Ergodox (work)
future keyboards:
Offline hkf
  • your #1 fan
Re: [Oddforge] VE.A
« Reply #258 on: Mon, 26 September 2016, 21:45:58 »
depends on colour but I'd just go 1k
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #259 on: Mon, 26 September 2016, 23:18:51 »
We apologize that didn't describe SMT option specific.
Our recommended resistor is over 330ohm~910ohm depending what LED you use and what bright you prefer :)
It's your choice
ZeFyr "Vermillion" J.
Vergo type.T / alpetit / alpetit II / VE.A with Vergo type.T-II
Offline litster
  • rare caps?! THAT'S A SMILIN
Re: [Oddforge] VE.A
« Reply #260 on: Tue, 27 September 2016, 01:27:44 »
Finally received my kit.  Now I need to look for instructions on assembling it.  What LED and resistors are you all getting?
Offline briannnn
Re: [Oddforge] VE.A
« Reply #261 on: Tue, 27 September 2016, 02:32:40 »
Just got mine too!  I was going to do white/blue lock LEDs with 820/910 resistors respectively.
Offline exitfire401
Re: [Oddforge] VE.A
« Reply #262 on: Tue, 27 September 2016, 02:40:50 »
So, I just spent an embarrassingly long amount of time (though admittedly, I was trying to do it in between matches of Rocket League) just getting the first half of my tent stand completed. If anyone else needs the instructions, I found them here http://kbdlab.co.kr/index.php?document_srl=3286770&mid=board_etc (Btw, I only found them after being ridiculously frustrated and not comprehending that there are two end pieces for the brace for the feet.) Happy Building to all! I'll be finishing the last half of the tent stand tomorrow and then it's time to work on the Zealios while I wait for the clear stabs!
Offline krisst
Re: [Oddforge] VE.A
« Reply #263 on: Tue, 27 September 2016, 04:03:53 »
I looked up aliexpress for 910ohm smd resistors. There seems to have more than 1 type.
  • 0603 910 ohm SMD Resistor 5% 1/10W 910R 910ohm Chip Surface Mount Resistor ROHS
  • 0402 910 ohm SMD Resistor 1% 1/16W 910R 910ohm Chip Surface Mount Resistor ROHS
  • 0805 910 ohm SMD Resistor 1% 1/8W
Might have more type than what I listed. Any idea which percentage and wattage rating to get?
Thanks
Offline Data
Re: [Oddforge] VE.A
« Reply #264 on: Tue, 27 September 2016, 06:54:28 »
It's your choice
Too late!   :P  Using 100-200 ohm resistors on my lock indicators and they're fine.  There are only 3 of them so they're pulling a negligible current - maybe 50mA total and only when all 3 are lit.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #265 on: Tue, 27 September 2016, 12:14:19 »
It's your choice
You are right :)
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #266 on: Tue, 27 September 2016, 12:16:22 »
Thanks
0805 is what Vergo type.T-II uses. 1%/5% means precision which is not a big deal for LED.
Offline litster
Re: [Oddforge] VE.A
« Reply #267 on: Tue, 27 September 2016, 12:26:37 »
Should we start a separate thread to centralize all the information and discussion on putting a VE.A together?  E.g. assembly instructions, links to wrist rest, LED and resistor selections, etc?
Offline Data
Re: [Oddforge] VE.A
« Reply #268 on: Tue, 27 September 2016, 13:21:42 »
Cross-posting from Massdrop comments...
Sorry for potato quality.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #269 on: Tue, 27 September 2016, 13:25:22 »
BUMP
Added resource page on website.
http://oddforge.com/product/vea_resource
You can download Alps switch mounting plate example.
Note,
We cannot offer mounting plate layout design service. It's almost impossible.
If you are familiar with Alps, you know that already :)
We can offer basic layout only, which is in the example design file.
It uses one Apple Ext (M0115 or M3501) and one Standard (M0116) keysets.
So, please use it only you are familiar with Alps and CAD.
Offline alienman82
Re: [Oddforge] VE.A
« Reply #270 on: Tue, 27 September 2016, 13:30:07 »
removed.
« Last Edit: Thu, 01 March 2018, 14:07:46 by alienman82 »
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #271 on: Tue, 27 September 2016, 13:31:38 »
Hey you did it very nicely :)
Hope you enjoy VE.A.
Thanks for your support buddy.
Offline krisst
Re: [Oddforge] VE.A
« Reply #272 on: Tue, 27 September 2016, 13:35:09 »
Thanks
Alright, will order that. Thank you!
I need a set of sky dolch... Looks great!
Offline Data
Re: [Oddforge] VE.A
« Reply #273 on: Tue, 27 September 2016, 13:36:43 »
 :thumb:  I'm really enjoying it a lot so far.  It wouldn't be possible without your and your team's tireless dedication and attention to detail.  Congrats on an amazing first group buy.  I look forward to seeing what you come up with next.  ;)
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
Re: [Oddforge] VE.A
« Reply #274 on: Tue, 27 September 2016, 14:55:17 »
I cannot get enough of what I am seeing of the VE.A, I so profoundly hope we will see a round 2 of these, exactly the same design, they are perfect. You created an amazing design that was so well realized with a wonderful attention to detail and didn't have to sacrifice style or functionality to any critical level. Love it! Keep the pictures coming guys!!!
Offline MandrewDavis
  • Chasin' That Neon Rainbow
Re: [Oddforge] VE.A
« Reply #275 on: Tue, 27 September 2016, 17:03:34 »
I am hoping for something a little different if OddForge looks to make more projects in the future. There should be extras for sale in the coming weeks.
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline redbanshee
  • actually Dade Murphy
Re: [Oddforge] VE.A
« Reply #276 on: Tue, 27 September 2016, 18:05:32 »
Where did you score those grey blanks for the spacebar, etc? Are they GMK?
Offline briannnn
Re: [Oddforge] VE.A
« Reply #277 on: Tue, 27 September 2016, 18:50:05 »
Not sure what he's using, but I have the dark gray blank PBT Gateron set and it matches Sky Dolch pretty perfectly.  Also sorry for potato.
Offline Data
Re: [Oddforge] VE.A
« Reply #278 on: Wed, 28 September 2016, 08:25:23 »
Same as briannnn above.  They're part of a blank PBT set from Shadovved's group buy.  They match the GMK Sky Dolch set perfectly - row profile, sculpt, color, even material thickness and underside support structure are a perfect match.  The ONLY difference is the side texture.  GMK is smooth/glossy where Gateron/EnjoyPBT is textured/matte.  But you have to get super close to notice.  And of course GMK is ABS vs PBT.  :D
Offline litster
Re: [Oddforge] VE.A
« Reply #279 on: Fri, 30 September 2016, 01:08:04 »
Hi everyone.  Need some help here.  I got the left half one done and it is working fine.  Just finished the right half.  All the keys are working except
H  J  K L :
5 keys in a row are not working.  Maybe a line is disconnected somewhere?
Offline hkf
  • your #1 fan
Re: [Oddforge] VE.A
« Reply #280 on: Fri, 30 September 2016, 01:26:54 »
H  J  K L :
I've had a similar issue, F7-F11 weren't registering. Cleaned my PCB and it was all fine.
No idea as to the real cause, though. HTH
Offline litster
Re: [Oddforge] VE.A
« Reply #281 on: Fri, 30 September 2016, 01:28:21 »
How did you clean it?
Offline JDragon
Re: [Oddforge] VE.A
« Reply #282 on: Fri, 30 September 2016, 01:33:05 »
Looks like I won't be able to build mine until November since I'm waiting on some Zeal parts :(
Yup. Same for me too. Ordered some stabs. Hopefully VE.A package will arrive safely and everything is perfect, PCB is working, etc. Would be good to make sure to test the PCB, check the casing even if you are not building it yet. I think by Nov, any spare VE.A from zefyr might be put up for sale for any interested buyers, not confirm, just my thought.
That is a good point, I'll be sure to do that.
Good point :)
We will save spares for unexpected accident.
And put them on sale after 2~3 weeks later.
Is there an ETA for extras? I missed the GB and I can't get over how beautiful the board looks. I've got to have one! You guys did an amazing job with this.
Offline litster
Re: [Oddforge] VE.A
« Reply #283 on: Sat, 01 October 2016, 00:29:29 »
H  J  K L :
Anyone?  Something is wrong with Column 3, 9 to 13.
H Col:3 Row:9
J Col:3 Row:10
K Col:3 Row:11
L Col:3 Row:12
: Col:3 Row:13
Anyone?  Zefyr?
Offline exitfire401
Re: [Oddforge] VE.A
« Reply #284 on: Sat, 01 October 2016, 00:35:33 »
H  J  K L :
H Col:3 Row:9
J Col:3 Row:10
K Col:3 Row:11
L Col:3 Row:12
: Col:3 Row:13
Anyone?  Zefyr?
I've got nothing =( Haven't assembled mine yet
Offline litster
Re: [Oddforge] VE.A
« Reply #285 on: Sat, 01 October 2016, 02:15:09 »
Holy ****!  I found a defect on the PCB and fixed it.  I need Oddforge or Zefyr to confirm this is a good fix.
I spent the whole night using a multi-meter to see if I could figure anything out.  I noticed that on most rows, the bottom end of the diodes on the same row connects to each other, except the HJKL; row.  And I checked that they do connect between ; L K J H, but not between " and ;.
At first I thought the via was plugged and causing the problem, but when I looked closer, the trace is actually disconnected (at the red rectangle).  I jumped and connected these points and looks like all the keys are working now.
I am glad I fixed it.  But I am mad that the PCB is defective, and caused me so much grief...
Can I get a replacement PCB?
Offline krisst
Re: [Oddforge] VE.A
« Reply #286 on: Sat, 01 October 2016, 09:14:08 »
I have not build my kb yet and checked the area marked in red. There is indeed a connection. I guess the PCB you received do have defects. Does it work now though, with the jumper?
Hope you get replacement if possible.
Offline exitfire401
Re: [Oddforge] VE.A
« Reply #287 on: Sat, 01 October 2016, 09:21:27 »
I'd shoot the oddforge team an email. Email address is on the site and zefyr has posted it a page back on the thread as well.
Offline exitfire401
Re: [Oddforge] VE.A
« Reply #288 on: Sat, 01 October 2016, 12:39:43 »
Just spent about 35 minutes shorting out each of my leads. Everything's good on my board currently.
Offline alienman82
Re: [Oddforge] VE.A
« Reply #289 on: Sat, 01 October 2016, 13:24:45 »
removed.
« Last Edit: Thu, 01 March 2018, 14:07:11 by alienman82 »
Offline alienman82
Re: [Oddforge] VE.A
« Reply #290 on: Sat, 01 October 2016, 14:44:24 »
removed.
« Last Edit: Thu, 01 March 2018, 14:07:07 by alienman82 »
Offline litster
Re: [Oddforge] VE.A
« Reply #291 on: Sat, 01 October 2016, 17:24:48 »
Thanks for checking this on your PCB.  I definitely have a defective PCB.  With jumper it is working.  But the jumper shouldn't be there.  I wonder if there are more defective PCBs shipped to buyers.
I will give that a try.  Thanks.
BTW, anyone knows where I can find the keymapper user guide?  The link [http://oddforge.com/product/vea_userguide] on oddforge.com is broken.
Re: [Oddforge] VE.A
« Reply #292 on: Sat, 01 October 2016, 23:18:55 »
BTW, anyone knows where I can find the keymapper user guide?  The link http://oddforge.com/product/vea_userguide on oddforge.com is broken.
Link to the Bootmapper programming guide created by XX7.
Offline litster
Re: [Oddforge] VE.A
« Reply #293 on: Sun, 02 October 2016, 01:23:01 »
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #294 on: Sun, 02 October 2016, 03:10:12 »
Sorry for late response!
I'm gonna check your picture and test it with stock PCB.
And reply as soon as possible!
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #295 on: Sun, 02 October 2016, 03:27:07 »
Your fix is correct.
I sent you a PM. :) We can talk about aftercare there.
PS :
Oddforge team is very surprised that you found that disconnection and fixed it by yourself.
We heard about that can happen very rarely, but seen it first time.
We finally know that why this forum is named "geekhack".
Four thumbs up mate-geek.
« Last Edit: Sun, 02 October 2016, 23:05:28 by zefyr »
Offline litster
Re: [Oddforge] VE.A
« Reply #296 on: Mon, 03 October 2016, 19:33:41 »
Got in touch with zefyr.  He is going to take care of it.  Thanks zefyr!
Meanwhile, I need a good short spacebar (2.75x?).  That long shift key is hurting my thumb.  I flipped it upside down and it doesn't hurt as much, but it is still a little weird.
Best ergo keyboard ever IMO.  And I have a lot of ergo keyboards.  Love the acrylic tent.  Really well designed.  It is made of acrylic but there is no flex!
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #297 on: Tue, 04 October 2016, 00:16:47 »
I have tried SP's DSA with space (mixing with DCS) and that worked for me :)
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #298 on: Tue, 04 October 2016, 01:02:50 »
Recently I heard something about aftermarket.
That VE.A is traded very high prices.
In ROK, overprice trading is a kind of taboo.
So we didn't expect something like this.
Is there somebody who can give the information of that tradings for us?
We wanted to people actually typing with VE.A... not for aftermatket profits...
Maybe this is something we should accept as culture difference. Hmm...
Offline renzpwns
  • I didn't like money in my wallet anyways.
Re: [Oddforge] VE.A
« Reply #299 on: Tue, 04 October 2016, 04:32:28 »
Yeah, happens quite a bit in this hobby. Korean kustoms, artisans, keysets etc.
