Author Topic: [Oddforge] VE.A  (Read 338154 times)
Offline alienman82
Re: [Oddforge] VE.A
« Reply #400 on: Thu, 13 October 2016, 16:53:56 »
removed.
« Last Edit: Thu, 01 March 2018, 13:57:39 by alienman82 »
Offline jal
  • I can't believe it's not gravy!
Re: [Oddforge] VE.A
« Reply #401 on: Thu, 13 October 2016, 16:58:58 »
possibly.. the thing is the layout will determine MOQ.  every layout would have a separate one.  plus it's a small pool of people to deal with as well.  [...]
Yeah. I don't know how many were sold in the first drop, but Massdrop sold 102 VE.As. (At least that's what it said on the page that list my purchases.)
Not sure how to estimate how many of those would take part at all, let alone per-type, but this is probably a job for lasergist.
Offline adamski07
  • adamskimodz|fudorekz12
Re: [Oddforge] VE.A
« Reply #402 on: Thu, 13 October 2016, 21:54:30 »
Love this board. My new daily!  :thumb:
Offline clappingcactus
Re: [Oddforge] VE.A
« Reply #403 on: Thu, 13 October 2016, 22:13:07 »
BUMP
Quick Question About Price for B-stock.
- We will mark with small intentional dent on inside (totally invisible when assembled)
- Our MSRP is 450 USD, we will discount over 20% for B-stock. which will be around 350USD for Basic Kit + misc
---- Case, PCB, Plate
---- SATA cable, 3Lock LEDs with matching resistors (will not be pre-soldered) for your convenience.
- We will charge paypal fee to you.
- We will use EMS with tracking number. package weight is under 2.5kg (those who uses pounds, do your math by yourself)
----You can check your shipping cost at following link.
----http://ems.epost.go.kr/front.EmsDeliveryDelivery09.postal
- We will not accept any undervalue request.
How's this sounds?
Any good?
Can we buy plate + pcb only?
I don't see why not at this point.
But as always, nothing set firmly yet.
Whether I buy one of the B-stocks or just a backup pcb/plate depends on the price. Any idea how much spare PCB+Plates would cost?
I wasn't in the massdrop so I don't know what the retail for those was.
Offline alienman82
Re: [Oddforge] VE.A
« Reply #404 on: Thu, 13 October 2016, 22:14:24 »
removed.
« Last Edit: Thu, 01 March 2018, 13:57:33 by alienman82 »
Offline juahenza
  • DoSmallThingswithGreatLove
Re: [Oddforge] VE.A
« Reply #405 on: Thu, 13 October 2016, 22:22:34 »
very nice picture  :thumb:
456GT | TGR Jane CE | Dolphin v2 | Whale | 360c | LZ FE | LZ IRON | TX-CP | Varmilo VA87M | HHKB P2 | IBM SSK P.1397681| IBM Industrial SSK P.1395682 | VE.A | Realforce 87u | Datamancer Streamline TKL | Datamancer Mechinist TKL | TANK v1 | RAMA M-4 | Realforce 108UW-HIPRO
Offline adamski07
Re: [Oddforge] VE.A
« Reply #406 on: Thu, 13 October 2016, 22:42:30 »
looks like that livestream one?  I like the clear housing on it.  I'm building mine right now actually just taking a break :)
Correct. too lazy to setup the livestream again so I decided to finish the build without livestreaming it again.  :p
thanks! Here's another one.
Offline alienman82
Re: [Oddforge] VE.A
« Reply #407 on: Thu, 13 October 2016, 22:47:46 »
removed.
« Last Edit: Thu, 01 March 2018, 13:57:30 by alienman82 »
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #408 on: Thu, 13 October 2016, 23:37:33 »
BUMP
How's this sounds?
Any good?
We have rough plan for releasing PCB and Plate at Massdrop price. which is 55USD for PCB and 35USD for plate.
ZeFyr "Vermillion" J.
Vergo type.T / alpetit / alpetit II / VE.A with Vergo type.T-II
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #409 on: Thu, 13 October 2016, 23:38:25 »
OMG...
Offline alienman82
[Oddforge] VE.A
« Reply #410 on: Fri, 14 October 2016, 08:50:34 »
removed.
« Last Edit: Thu, 01 March 2018, 13:57:22 by alienman82 »
Offline RobotMalcolmX
  • hackerman
Re: [Oddforge] VE.A
« Reply #411 on: Fri, 14 October 2016, 13:37:56 »
How many switches are required for a normal ansi layout on this? I counted but want to make sure I was correct, I came up with 97.
Offline alienman82
Re: [Oddforge] VE.A
« Reply #412 on: Fri, 14 October 2016, 13:54:44 »
removed.
« Last Edit: Thu, 01 March 2018, 13:57:14 by alienman82 »
  • hackerman
Re: [Oddforge] VE.A
« Reply #413 on: Fri, 14 October 2016, 14:10:39 »
that's how many massdrop gives you.  I had what I thought was 98 switches, but I had two extra.  I probably counted wrong.  100 is definitely save
Thanks friendo.
Offline Data
Re: [Oddforge] VE.A
« Reply #414 on: Fri, 14 October 2016, 14:17:39 »
Every bag of switches has those 1 or 2 mangled switches, where that one pin is smashed up against the switch housing and you're like, man... do I even want to try fixing that?
So I'd get an even 100.   ;)
Offline Jaceun
Re: [Oddforge] VE.A
« Reply #415 on: Fri, 14 October 2016, 15:19:34 »
Anyone have an idea as to why my Macro keys, 1 and 2 are not powering in switch LEDs? Everything else works, including those keys when pressed.
Checked for the obvious stuff and now I need a little help. Known good LEDs, correct polarity and powered USB port on my PC if that matters.
I don't see any bad soldering or poor connections but maybe you all have better eyes.
Leopold FC660M | MX Blues
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #416 on: Fri, 14 October 2016, 16:54:13 »
Read assembly guide please :)
http://oddforge.com/product/vea_assembly
Offline alienman82
Re: [Oddforge] VE.A
« Reply #417 on: Fri, 14 October 2016, 16:58:06 »
removed.
« Last Edit: Thu, 01 March 2018, 13:57:06 by alienman82 »
Offline Jaceun
Re: [Oddforge] VE.A
« Reply #418 on: Fri, 14 October 2016, 17:01:53 »
I feel a little silly, I see the F _ _ L pattern now. That part was confusing me before, but now it all makes sense. I just thought I had to have messed something up haha. Thank you zefyr.
Offline alienman82
Re: [Oddforge] VE.A
« Reply #419 on: Fri, 14 October 2016, 18:50:53 »
removed.
« Last Edit: Thu, 01 March 2018, 13:57:03 by alienman82 »
Offline HouseofSuffering
Re: [Oddforge] VE.A
« Reply #420 on: Fri, 14 October 2016, 19:46:02 »
Looking forward to getting a second, "B" stock Ve.A!! :thumb:
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
Re: [Oddforge] VE.A
« Reply #421 on: Fri, 14 October 2016, 19:59:58 »
Sad I will only be able to have a "B" stock VE.A =( these pictures are amazing though
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
Re: [Oddforge] VE.A
« Reply #422 on: Sat, 15 October 2016, 12:18:22 »
Missed out on the GB for this, so I'm definitely going to keep my eyes open for the B-stock.
  • hackerman
Re: [Oddforge] VE.A
« Reply #423 on: Mon, 17 October 2016, 08:05:30 »
Is there any information as to when you'll open up selling the b-stock parts/kits?
Offline Fictiouz
  • That "White" Guy
Re: [Oddforge] VE.A
« Reply #424 on: Mon, 17 October 2016, 09:05:42 »
what he said ^
Offline LDobler
Re: [Oddforge] VE.A
« Reply #425 on: Tue, 18 October 2016, 18:14:45 »
I need one of those b-stock VE.As in my life!  :eek:
Offline Goranth
Re: [Oddforge] VE.A
« Reply #426 on: Tue, 18 October 2016, 18:18:49 »
I'm going to have to watch this like a hawk.
Re: [Oddforge] VE.A
« Reply #427 on: Tue, 18 October 2016, 18:22:58 »
At this point I will take any VE.A in my life at all.
Offline litster
  • rare caps?! THAT'S A SMILIN
Re: [Oddforge] VE.A
« Reply #428 on: Tue, 18 October 2016, 19:41:52 »
Life is good with VE.A
Offline commandlinedesign
Re: [Oddforge] VE.A
« Reply #429 on: Wed, 19 October 2016, 06:18:06 »
Wanted to show off my VE.A!
Album: http://imgur.com/a/yTssL
  • hackerman
Re: [Oddforge] VE.A
« Reply #430 on: Wed, 19 October 2016, 08:48:38 »
This is where I would post my VE.A
Offline aaron6301
  • Pixel Pusher
Re: [Oddforge] VE.A
« Reply #431 on: Wed, 19 October 2016, 10:26:47 »
Received my replacement plates for Zefyr which means I can finally get around to building this thing :thumb:
Planned build:
  • Silver VE.A w/Black Plate
  • 62g - Gateron Linear Clears, Lubed
  • Transparent stabs, Lubed & Clipped
  • GMK Classic Retro
  • KK Miso Snackey or HWS Copper/Red Keythulu
Just waiting on resistors for the indicator cluster but I think I could manage without them for the time being. I'll post potato quality pics when I get around to building it this weekend.
Offline kawasaki161
Re: [Oddforge] VE.A
« Reply #432 on: Wed, 19 October 2016, 11:54:29 »
Are there any transparent stabs that need to be clipped? The only ones I've seen thus far were Vintage style, meaning they don't need to be clipped.
Offline aaron6301
  • Pixel Pusher
Re: [Oddforge] VE.A
« Reply #433 on: Wed, 19 October 2016, 12:49:01 »
Not entirely sure tbh. I've clipped the old fashioned black ones and assumed the transparent variant needed the same treatment. They should be arriving this Friday so can't really confirm till I have them in my possession.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #434 on: Thu, 20 October 2016, 01:26:25 »
Announcement from oddforge
We set a mailing list for B-stock GB.
Subscribe it if you need to be notified at important events.
http://eepurl.com/ckXnGD
* We will announce here, GH, as always *
« Last Edit: Thu, 20 October 2016, 02:15:43 by zefyr »
Re: [Oddforge] VE.A
« Reply #435 on: Thu, 20 October 2016, 08:16:50 »
That's great! Thanks for the mailing list, now I can relax a little.
  • hackerman
Re: [Oddforge] VE.A
« Reply #436 on: Thu, 20 October 2016, 08:40:48 »
Leaving the country for a few days next week, never have I been so torn.
Won't have access to email most likely RIP me.
Offline Norman_the_Owl
Re: [Oddforge] VE.A
« Reply #437 on: Thu, 20 October 2016, 11:03:00 »
How much stock do you have?
Will i be able to buy parts individually, or only as an entire keyboard? I'm only interested in the PCB, and ideally whatever parts it takes to assemble the PCB.
Offline MandrewDavis
  • Chasin' That Neon Rainbow
Re: [Oddforge] VE.A
« Reply #438 on: Thu, 20 October 2016, 13:47:30 »
Why only the PCB? Building your own case?
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Re: [Oddforge] VE.A
« Reply #439 on: Thu, 20 October 2016, 14:13:43 »
I don't want a plate because I'm going alps, and i need to make my own anyways. I don't want the case because I don't want to spend 350 dollars right now. 55 for the PCB (plus shipping of course) is a much more swallowable price. I'll make a sandwich case out of acrylic when i have the cash
Offline Niomosy
Re: [Oddforge] VE.A
« Reply #440 on: Thu, 20 October 2016, 18:05:13 »
The case is rather cost-prohitibitive for many of us.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #441 on: Fri, 21 October 2016, 00:58:03 »
We have around 20 B-stock.
And for indv parts, I don't see why not by now.
We have stock PCB and plates.
Re: [Oddforge] VE.A
« Reply #442 on: Fri, 21 October 2016, 05:44:58 »
Awesome, thanks Zefyr. You've created a killer product, I hope i can get my hands on a PCB.
Offline Niomosy
Re: [Oddforge] VE.A
« Reply #443 on: Fri, 21 October 2016, 13:10:48 »
Wondering what the PCB crowd are looking at in terms of cases for this as I'm tempted to go that route as well.
This could probably become a solid mass-produced keyboard were it to have a less expensive case.
Re: [Oddforge] VE.A
« Reply #444 on: Fri, 21 October 2016, 13:33:16 »
I'm going to go for an acrylic sandwich case, the top layer will probably be a different material though, as an acrylic alps plate is apparently easier said than done
Re: [Oddforge] VE.A
« Reply #445 on: Fri, 21 October 2016, 14:07:56 »
Here is the problem with acrylic - it cracks. Just from looking at the alps plate DXF file, anyone wanting to build a case where the halves fit together like the VE.A, there is only a 1.65mm (2.4mm for cherry without switchtop opening) cap between the switch-holes and the outside of the case. That isn't going to last long and is probably among other reasons Zefyr went with poly-carb.
For cherry, using 1.5mm acrylic for the plate and 3mm underneath for support similar to what winkeyless does. Anything alps needs a metal plate, assuming nobody wants to hotglue their precious switches in.
Just my thoughts, maybe someone else is thinking outside the box.
Offline E3E
Re: [Oddforge] VE.A
« Reply #446 on: Fri, 21 October 2016, 14:31:43 »
There have been Alps boards with plastic plates before though. My APC TH-5539 has a plastic place that's pretty solid, though I think it has a lot of ribbing and thickened areas to reinforce it. Acrylic is too brittle, I'd say. Maybe 3D printed and reinforced plastic would work.
Also, in regards to an acrylic case, the VE.A'S predecessor was all acrylic.
Re: [Oddforge] VE.A
« Reply #447 on: Fri, 21 October 2016, 15:05:27 »
I'm worried I am not going to be able to even afford the B-stock on these, let alone put it together with the 0 experience I have at this point being brand new to Mechanical Keyboards, and without any electronic component or soldering experience. But I am going to sure take my best shot at it because I am absolutely in love with the design of these. Really obsessed with what I imagine is an older version in a bronze/copper case with blue/teal lighting that haunts me it's so beautiful! Can't wait to get more info
Offline Data
Re: [Oddforge] VE.A
« Reply #448 on: Fri, 21 October 2016, 20:45:02 »
The gold case was a one-off by the way.
Re: [Oddforge] VE.A
« Reply #449 on: Fri, 21 October 2016, 20:46:23 »
Thanks for the heads up, I suspected it might be, if I can get one of the cases I'm pretty experienced with industrial coatings/paint, I think I can make it work
