Author Topic: [Oddforge] VE.A  (Read 338164 times)
Offline Data
Re: [Oddforge] VE.A
« Reply #450 on: Fri, 21 October 2016, 20:48:45 »
That I'd like to see.
Offline alienman82
Re: [Oddforge] VE.A
« Reply #451 on: Sun, 23 October 2016, 17:22:46 »
removed.
« Last Edit: Thu, 01 March 2018, 13:52:36 by alienman82 »
Offline alienman82
Re: [Oddforge] VE.A
« Reply #452 on: Sun, 23 October 2016, 21:29:06 »
removed.
« Last Edit: Thu, 01 March 2018, 13:52:31 by alienman82 »
Offline Delirious
Re: [Oddforge] VE.A
« Reply #453 on: Sun, 23 October 2016, 21:55:28 »
Does anyone know the spec for the plastic screws? They are too filmsy for my taste so I'm definitely replacing them with some stainless steel screws.
Offline aaron6301
  • Pixel Pusher
Re: [Oddforge] VE.A
« Reply #454 on: Sun, 23 October 2016, 22:04:24 »
I ordered some M3 15mm flat head hex screws and they work perfectly. If you pay for postage, I can send you some as I ordered 100.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Offline krisst
Re: [Oddforge] VE.A
« Reply #455 on: Sun, 23 October 2016, 22:23:29 »
I bought some titanium screws instead. M3 x 15mm. Pack of 10.
Ebay link below
http://www.ebay.com/itm/222220208667
Offline alienman82
Re: [Oddforge] VE.A
« Reply #456 on: Sun, 23 October 2016, 22:24:09 »
removed.
« Last Edit: Thu, 01 March 2018, 13:52:29 by alienman82 »
Offline krisst
Re: [Oddforge] VE.A
« Reply #457 on: Mon, 24 October 2016, 00:30:58 »
Ebay link below
gross china.
Item seems to be shipping from Hong Kong. Colour of these screws matches dark grey case well enough.
Either way, still better than those plastic screws provided. They strip too easily.
Re: [Oddforge] VE.A
« Reply #458 on: Mon, 24 October 2016, 00:47:56 »
Ebay link below
Not gonna hound you over buying 10 screws buhhh..
let's understand titanium alloy for a moment.
Its advantage is , more strength to weight ratio..  vs steel.
However, the strongest steel is stronger than the strongest titanium.
If you got high tensile steel screws, it is cheaper AND stronger than steel,  but it will be heavier..
So,  on a KEYBOARD,  where it doesn't have to be light,  and most of the weight is NOT the screws,     it makes more sense to use steel instead of titanium..
Offline Data
Re: [Oddforge] VE.A
« Reply #459 on: Mon, 24 October 2016, 08:02:21 »
Ebay link below
They're screwing directly into polycarbonate so strength is meaningless.  You'll strip the threads in the PC before anything else comes close to failing.
Plus, titanium...
Offline alienman82
Re: [Oddforge] VE.A
« Reply #460 on: Mon, 24 October 2016, 09:40:04 »
removed.
« Last Edit: Thu, 01 March 2018, 13:52:26 by alienman82 »
Offline krisst
Re: [Oddforge] VE.A
« Reply #461 on: Mon, 24 October 2016, 09:45:38 »
Ebay link below
They are just screws that I chose to replace those plastic ones... Don't have to be so serious, right? As long as it doesn't rust, doesn't strip, I don't care as much.
All these talks about screws and I am still here waiting for those stabs from Zeal before assembling my VE.A... probably looking at early Dec
Offline Data
Re: [Oddforge] VE.A
« Reply #462 on: Mon, 24 October 2016, 13:43:44 »
Ebay link below
Brutal.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #463 on: Mon, 24 October 2016, 22:06:52 »
Ebay link below
Hmm, we choose PC bolts instead of STS because they looks better when assembled.
You can see some features that we choose quality over price.
like...
PC bolts for transparent effect. instead of STS bolts.
Diamond sanding at backside of black mounting plate. (funny, that side is not even visible.)
910 resistors for all in-switch LEDs for your convenience.
ZeFyr "Vermillion" J.
Vergo type.T / alpetit / alpetit II / VE.A with Vergo type.T-II
Offline aaron6301
  • Pixel Pusher
Re: [Oddforge] VE.A
« Reply #464 on: Tue, 25 October 2016, 13:45:03 »
Finally got the chance to put it together.
  • VE.A Silver w/Black Plate
  • GMK Retro
  • KK Miso Soup
  • 62g Gateron Linear Clears - Lubed
  • Trans Stabs - Lubed
  • Sip Scoketed - White In Switch
« Last Edit: Tue, 25 October 2016, 13:49:08 by aaron6301 »
Offline MajorKoos
  • 1 life please. Extra large.
Re: [Oddforge] VE.A
« Reply #465 on: Tue, 25 October 2016, 20:09:16 »
Ebay link below
like...
+1 for the diamond sanding.
A very unique finish indeed - both in looks and touch.
I'd love to see more of that in future designs.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #466 on: Wed, 26 October 2016, 03:28:32 »
  • GMK Retro
  • KK Miso Soup
Finally :)
Hope you like it!
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [Oddforge] VE.A
« Reply #467 on: Thu, 27 October 2016, 01:54:58 »
Potato picture, finished this bad boy tonight:
Offline seblove
Re: [Oddforge] VE.A
« Reply #468 on: Thu, 27 October 2016, 02:31:57 »
  • GMK Retro
  • KK Miso Soup
Eyyy you went with the white cable. Hope you're loving it man, looks super clean.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #469 on: Thu, 27 October 2016, 02:54:11 »
I posted VE (Vergo) making story.
https://geekhack.org/index.php?topic=85476.0
Hope you like it.
Re: [Oddforge] VE.A
« Reply #470 on: Thu, 03 November 2016, 11:46:01 »
Love this board. My new daily!  :thumb:
looks like that livestream one?  I like the clear housing on it.  I'm building mine right now actually just taking a break :)
Correct. too lazy to setup the livestream again so I decided to finish the build without livestreaming it again.  :p
very nice picture  :thumb:
thanks! Here's another one.
Dude, I just saw this in the keyboard nominations. Are you using tactile grays? I don't see too many boards with those; I just happened to have my Jane installed with them, lubed with 72g SPRiT springs and Gateron clear tops.
Offline RobotMalcolmX
  • hackerman
Re: [Oddforge] VE.A
« Reply #471 on: Thu, 03 November 2016, 17:16:52 »
So I'm guessing we still have no clue when b-stock will be available?
Offline alienman82
Re: [Oddforge] VE.A
« Reply #472 on: Thu, 03 November 2016, 17:38:20 »
removed.
« Last Edit: Thu, 01 March 2018, 13:46:22 by alienman82 »
  • hackerman
Re: [Oddforge] VE.A
« Reply #473 on: Thu, 03 November 2016, 17:43:55 »
seems you didn't see the email sign up.  put email in.  forget.
I did see it and I did sign up, but it's still nice to know some information without just "soon".
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
Re: [Oddforge] VE.A
« Reply #474 on: Thu, 03 November 2016, 18:07:36 »
I would offer that some of us don't have the financial liberty to just forget about something that costs over $200, that's something I need to budget for, or set small amounts of money aside incrementally, where having a tentative date could ease that a little for lots of people
Offline MandrewDavis
  • Chasin' That Neon Rainbow
Re: [Oddforge] VE.A
« Reply #475 on: Thu, 03 November 2016, 22:36:37 »
Try $500 with shipping.
Zefyr is still recovering from the OG groupbuy. Based on your posts, you are certainly desperate for a VE.A, but don't seem to have the funds. I am working (very slowly) on an acrylic case for the VE.A and will try to share on here once I confirm my design is A-OK.
« Last Edit: Thu, 03 November 2016, 22:38:19 by MandrewDavis »
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #476 on: Fri, 04 November 2016, 00:33:13 »
Hey guys!
Sorry to keep you waiting so long.
B-stock is ready :)
We carefully checked quality again.
About 35 sets passed our B-class quality line.
(18 black, 8 grey, 6 silver)
Price will be 350USD, including black-titan-coated mounting plate.
No bare STS mounting plate option.
But we have no experience of direct GB.
Problem is money collecting.
So, quick question.
When attended in a GB, you got paypal e-mail invoice? or just sending budget?
And also, we are preparing special version of VE.A. without anodizing.
We are considering run a field test in early-adopter-like form.
Keep your interests on us, please :)
« Last Edit: Fri, 04 November 2016, 00:36:49 by zefyr »
Offline DormantLemon
Re: [Oddforge] VE.A
« Reply #477 on: Fri, 04 November 2016, 02:46:40 »
I would imagine a PayPal invoice would work for most here, most artisan giveaways/sales do that.
Sent from my SM-G928F using Tapatalk
VE.A Silver | GMK Hyperfuse Origins
TGR Alice Pink | GMK Laser
Offline JDragon
Re: [Oddforge] VE.A
« Reply #478 on: Fri, 04 November 2016, 03:57:37 »
I would prefer PayPal invoice.
Offline yuktsi
  • Colour my life with the chaos of trouble
Re: [Oddforge] VE.A
« Reply #479 on: Fri, 04 November 2016, 04:27:28 »
Does anyone know where I can get a nice sata cable?
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline kawasaki161
Re: [Oddforge] VE.A
« Reply #480 on: Fri, 04 November 2016, 07:27:33 »
You could just get any cable you like from a computer store and then buy some sleeve to customize it. I really like the MDPC-X sleeve, but there probably are others that also offer Sata sized sleeve.
If you don't want to make your own I'm sure Pexon offers a lot of options.
Offline yuktsi
Re: [Oddforge] VE.A
« Reply #481 on: Fri, 04 November 2016, 07:43:41 »
Gonna get some sleeve and try it myself. Seems easy from seeing how people did it on youtube. Thansk bro
My collection
  • hackerman
Re: [Oddforge] VE.A
« Reply #482 on: Fri, 04 November 2016, 08:17:14 »
Paypal invoices work great for me!
Offline Saiph
Re: [Oddforge] VE.A
« Reply #483 on: Fri, 04 November 2016, 09:25:17 »
Would you be planning to run this special edition through your site? Also paypal works for me :)
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
Re: [Oddforge] VE.A
« Reply #484 on: Fri, 04 November 2016, 10:13:39 »
Hey guys!
B-stock is ready :)
So, quick question.
I've been checking this thread multiple times a day, ready for that B-stock. I know I signed up for the mailing list, but I still feel compelled to check here.
Paypal works perfectly for me. The non-anodized version also sounds very interesting to me. Bring it on!
Re: [Oddforge] VE.A
« Reply #485 on: Fri, 04 November 2016, 11:14:10 »
Hey guys!
B-stock is ready :)
So just to clarify, we are getting:
"Base Kit Includes
Anodized CNC aluminum case (top / bottom)
CNC poly-carbonate frame
Steel switch plate
Screws
Bump-on feet
Vergo type.T-II PCB
VE.A marking plates
SATA cable
Mini USB cable"
Offline alienman82
Re: [Oddforge] VE.A
« Reply #486 on: Fri, 04 November 2016, 11:21:41 »
removed.
« Last Edit: Thu, 01 March 2018, 13:45:58 by alienman82 »
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #487 on: Fri, 04 November 2016, 17:51:06 »
Hey guys!
B-stock is ready :)
"Base Kit Includes
Steel switch plate
Screws
Bump-on feet
Vergo type.T-II PCB
VE.A marking plates
SATA cable
Mini USB cable"
No cables included. It was a bundle deal of Massdrop.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #488 on: Sat, 05 November 2016, 09:41:03 »
B-class stock photos
Color differency
B-class marking
Dent
Scratch
Uneven surface
Dent & uneven surface
  • hackerman
Re: [Oddforge] VE.A
« Reply #489 on: Sat, 05 November 2016, 09:49:44 »
These still look great. My PayPal, and body, are ready.
Re: [Oddforge] VE.A
« Reply #490 on: Sat, 05 November 2016, 10:36:38 »
That condition looks a lot better than I expected for B-stock. My Paypal is ready and waiting!
Offline TheZissou
Re: [Oddforge] VE.A
« Reply #491 on: Sat, 05 November 2016, 10:55:26 »
These look awesome, looking forward to snagging one.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #492 on: Sat, 05 November 2016, 18:31:09 »
Announcement from team oddforge
B-class stock GB schedule & process
- We will announce exact starting time at lease 48 hours before joining form opens. (time in KST, which is UTC+9 https://www.timeanddate.com/time/zones/kst)
- We will send you invoice within 24 hours, in order of GB form application.
- We will wait payment for 48 hours.
- If 48 hours exceeds, application will be canceled and and invoice will be avoided.
- We will charge shipping cost to you.
- We will charge paypal fee (3.9% + 0.3USD including shipping cost) to you.
- Kit price will be 349USD, includes 4 Aluminium parts, 2 Polycarbonate frames, 2 nameplates, PCB, bumpons, bolts, Black-titanium-coated switch mounting plate.
- We will ship package via EMS service with tracking number.
Thanks for your interest guys!
GB will be open within a week.
We are all set.
  • hackerman
Re: [Oddforge] VE.A
« Reply #493 on: Sat, 05 November 2016, 18:46:06 »
THE HYPE IS REAL
Offline Norman_the_Owl
Re: [Oddforge] VE.A
« Reply #494 on: Sat, 05 November 2016, 21:02:25 »
I guess the PCB only option is gone now?
Re: [Oddforge] VE.A
« Reply #495 on: Sat, 05 November 2016, 21:55:47 »
We are all set.
Great, I look forward to it!
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #496 on: Sat, 05 November 2016, 23:00:14 »
PCB count is not that enough at this point.
Re: [Oddforge] VE.A
« Reply #497 on: Sun, 06 November 2016, 07:14:53 »
Offline clappingcactus
Re: [Oddforge] VE.A
« Reply #498 on: Sun, 06 November 2016, 12:02:37 »
Guess I'm in for the B-Stock group buy after all. Unless there are plans to produce more PCBs later?
Offline hkf
  • your #1 fan
Re: [Oddforge] VE.A
« Reply #499 on: Sun, 06 November 2016, 15:39:09 »
RIP
Going to get FR-300 after all :D
