Author Topic: [Oddforge] VE.A  (Read 338166 times)
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #500 on: Mon, 07 November 2016, 00:54:45 »
Announcement from oddforge
B-stock GB will be starts at November 9, 02:00 PM KST
Korea Standard Time, KST   November 09, 2016 14:00
Pacific Standard Time, PST   November 08, 2016 21:00
Central Standard Time, CST   November 08, 2016 23:00
Eastern Standard Time, EST   November 09, 2016 00:00
Mountain Standard Time, MST   November 08, 2016 22:00
Western European Time, WET   November 09, 2016 05:00
Central European Time, CET   November 09, 2016 06:00
Time converter
http://ko.thetimenow.com/time-zone-converter.php
GB Application form URL
https://goo.gl/forms/3vMzfTmYTQvxG3zq1
Thanks for your high interests on our keyboard.
ZeFyr "Vermillion" J.
Vergo type.T / alpetit / alpetit II / VE.A with Vergo type.T-II
Offline Gatix
  • #!/bin/sh
  • console.log
Re: [Oddforge] VE.A
« Reply #501 on: Mon, 07 November 2016, 02:56:14 »
I didn't expect it to be this early. Now panic selling my keyboards so I can get one
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
Re: [Oddforge] VE.A
« Reply #502 on: Mon, 07 November 2016, 08:40:50 »
I look forward to picking up a B-stock kit tomorrow night.
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
Re: [Oddforge] VE.A
« Reply #503 on: Mon, 07 November 2016, 11:22:19 »
What kind of defects can we expect to see on the B-Stock versions?
Offline RobotMalcolmX
  • hackerman
Re: [Oddforge] VE.A
« Reply #504 on: Mon, 07 November 2016, 11:30:34 »
There are some photos on the last page that illustrate what's to be expected.
Offline Saiph
Re: [Oddforge] VE.A
« Reply #505 on: Mon, 07 November 2016, 11:33:29 »
Does the converted US times in the email take into account daylight savings?
EDIT: Also, what have people been using for spacebars on cherry profile keysets?
« Last Edit: Mon, 07 November 2016, 11:38:39 by Saiph »
Offline krisst
Re: [Oddforge] VE.A
« Reply #506 on: Mon, 07 November 2016, 11:59:54 »
A full-size keyboard keycap set with additional 1.75u rightshift key should fit VE.A. Cherry profile 2.75u right shiftkey and 2u numpad 0 key should fit well as spacebars.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #507 on: Mon, 07 November 2016, 20:13:01 »
I have no idea about daylight saving offset.
How about try convert it?
Exact time will be "Nov 9 14:00 KST" that's all.
Re: [Oddforge] VE.A
« Reply #508 on: Tue, 08 November 2016, 22:03:56 »
Just filled the form, though it would not let me put 0 down for the Gray option (I just wanted 1 Silver kit). I left a note stating that I only want one B-stock kit and prefer silver to gray. If silver is unavailable, however, I'll take the gray (or black, if gray is also gone).
  • hackerman
Re: [Oddforge] VE.A
« Reply #509 on: Tue, 08 November 2016, 22:08:02 »
I think they only wanted you to fill in the ones you wanted, not a 0 for those you don't want. Or at least I hope as that's what I did too with the black one :D
Re: [Oddforge] VE.A
« Reply #510 on: Tue, 08 November 2016, 22:10:03 »
Ah, I was not sure. I hope it is clear enough on the form. I'm sending zefyr a PM right now just in case. Also glad that the form came in an hour earlier than expected, likely due to Daylight Savings, because I have to get up for work tomorrow.
Offline alienman82
Re: [Oddforge] VE.A
« Reply #511 on: Tue, 08 November 2016, 22:12:37 »
removed.
« Last Edit: Thu, 01 March 2018, 13:42:58 by alienman82 »
  • hackerman
Re: [Oddforge] VE.A
« Reply #512 on: Tue, 08 November 2016, 22:27:22 »
Offline alienman82
Re: [Oddforge] VE.A
« Reply #513 on: Tue, 08 November 2016, 22:29:13 »
removed.
« Last Edit: Thu, 01 March 2018, 13:42:56 by alienman82 »
  • hackerman
Re: [Oddforge] VE.A
« Reply #514 on: Tue, 08 November 2016, 22:30:41 »
who is gonna do alps?
Nope.
cherry?
Possibly, may have some vintage clears or something. Kind of unsure what I'll actually use.
Re: [Oddforge] VE.A
« Reply #515 on: Tue, 08 November 2016, 22:33:55 »
Pretty sure I'm going Cherry, just need to decide on switch. Kinda interested in those Panda switches, though I'd want to try them out on something else first. Might go tactile.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #516 on: Tue, 08 November 2016, 22:40:09 »
That form was open by accident.
That's why that form act like that.
I don't know why google form opened before trigger run.
We will accept your application, and your request about color option is confirmed.
Thanks for your high interest.
  • hackerman
Re: [Oddforge] VE.A
« Reply #517 on: Tue, 08 November 2016, 22:44:31 »
So to clarify, if we submitted we do not need to submit again, even though the form opened when it should not have?
Offline MandrewDavis
  • Chasin' That Neon Rainbow
Re: [Oddforge] VE.A
« Reply #518 on: Tue, 08 November 2016, 22:47:07 »
I'm doing Cherry MX 'Yellow'. Cap selection was the main factor. Will probably go Alps if Oddforge does another GB and Wingpad's keyset gets off the ground.
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #519 on: Tue, 08 November 2016, 22:52:38 »
Yes, unless you want to change your option or quantity.
(Yours will be processed as silver as you noted)
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #520 on: Tue, 08 November 2016, 22:55:06 »
Form will open in FIVE minutes.
Re: [Oddforge] VE.A
« Reply #521 on: Tue, 08 November 2016, 22:56:28 »
Ah, did not realize that the form was not supposed to open an hour early. I was thinking it had to do with Daylight Savings, so I just did the form as soon as it opened.
Thank you for honoring the submission even with the early opening and accepting the color request.
Re: [Oddforge] VE.A
« Reply #522 on: Tue, 08 November 2016, 22:57:34 »
I already have a PCB.  Should I make an acrylic case for it, or purchase B-Stock and have the ability to swap between Alps and Cherry MX?
  • hackerman
Re: [Oddforge] VE.A
« Reply #523 on: Tue, 08 November 2016, 22:58:20 »
I think you have me confused with Slash Emperor, he requested silver and I requested black when the form opened previously.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #524 on: Tue, 08 November 2016, 22:59:50 »
Nope, yours is black.
  • hackerman
Re: [Oddforge] VE.A
« Reply #525 on: Tue, 08 November 2016, 23:01:17 »
Oh good :)
Offline clappingcactus
Re: [Oddforge] VE.A
« Reply #526 on: Tue, 08 November 2016, 23:02:41 »
Well I submitted. Kind of upset that I'm here on time but people got access early. :(
Hope I still get what I want.
Offline JDragon
Re: [Oddforge] VE.A
« Reply #527 on: Tue, 08 November 2016, 23:03:23 »
Submitted form for silver (but will be ok with any color), hope I get in, thanks!
  • hackerman
Re: [Oddforge] VE.A
« Reply #528 on: Tue, 08 November 2016, 23:12:17 »
To be fair, I think it was only two of us that stumbled in early and got lucky.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #529 on: Tue, 08 November 2016, 23:16:11 »
I don't think it is fair.
It was accident, and we are very uncomfortable with our mistake.
We organized this for a long time.
I really don't know why that form opened earlier than I scheduled.
Re: [Oddforge] VE.A
« Reply #530 on: Tue, 08 November 2016, 23:18:59 »
I'm okay with that. You two were around and checking a whole hour early. I'm sure you two would have submitted your forms before I did.
To say otherwise would be to be petty.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #531 on: Tue, 08 November 2016, 23:28:20 »
Please, do not make this worse...
We are really sorry about our mistake.
Application count is halted now.
There's many stocks left.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #532 on: Tue, 08 November 2016, 23:37:53 »
Stock left at 14:37 KST
Black 11
Gray 4
Silver 1
Re: [Oddforge] VE.A
« Reply #533 on: Tue, 08 November 2016, 23:48:54 »
I'm not making it worse. :P
I was saying I'm okay with all outcomes. :)
Including this one.
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #534 on: Tue, 08 November 2016, 23:51:20 »
Including this one.
Ah, I was so embarrassed for that.
Thanks for kind words.
Offline Gatix
  • #!/bin/sh
  • console.log
Re: [Oddforge] VE.A
« Reply #535 on: Wed, 09 November 2016, 00:11:57 »
Filled in my entry :D
Offline slickmamba
Re: [Oddforge] VE.A
« Reply #536 on: Wed, 09 November 2016, 00:15:07 »
guess its luck how bad yours ends up =/
Hi :)
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #537 on: Wed, 09 November 2016, 00:21:54 »
Silver out of stock.
If you apply for silver, you will be on queue.
Stock
Black 11
Gray 3
Re: [Oddforge] VE.A
« Reply #538 on: Wed, 09 November 2016, 00:27:58 »
Just put in one for a gray one! Hope I did it all correctly! Looking forward to it.
Offline JDragon
Re: [Oddforge] VE.A
« Reply #539 on: Wed, 09 November 2016, 02:46:40 »
Will we only know if we made it when the invoice comes?
Offline zefyr
  • Oddforge
Re: [Oddforge] VE.A
« Reply #540 on: Wed, 09 November 2016, 02:53:50 »
All application will be accepted so far.
Stock count is enough.
Except silver it is OOS now, however, JDragon you are in.
Re: [Oddforge] VE.A
« Reply #541 on: Wed, 09 November 2016, 10:01:17 »
I still have not gotten a PayPal invoice? I just wanted to check and be sure that I am in line for one of these!
  • hackerman
Re: [Oddforge] VE.A
« Reply #542 on: Wed, 09 November 2016, 10:24:52 »
"We will send you invoice within 24 hours, in order of GB form application."
It's also 1:30 AM in Korea right now, so I wouldn't expect an invoice for the next little bit anyway.
Re: [Oddforge] VE.A
« Reply #543 on: Wed, 09 November 2016, 12:04:44 »
Ah! I misread the initial post, I thought I had 24 hours to pay, and was getting worried that that window was halfway over without an invoice. I see now that the max turn-around time would be about 3 days, with the 24hr request window and the 48hr completion window.
Offline JDragon
Re: [Oddforge] VE.A
« Reply #544 on: Wed, 09 November 2016, 18:32:12 »
 :eek:
<3
Can't wait :D
Offline litster
  • rare caps?! THAT'S A SMILIN
Re: [Oddforge] VE.A
« Reply #545 on: Wed, 09 November 2016, 18:40:12 »
Thanks for making B stock available.  though I am surprised it is not sold out immediately, given so many people missed the original drop.
Re: [Oddforge] VE.A
« Reply #546 on: Wed, 09 November 2016, 19:18:07 »
It was run very nicely too! The two day warning meant no unknown opening date or need to endlessly F5.
Re: [Oddforge] VE.A
« Reply #547 on: Wed, 09 November 2016, 19:21:52 »
I want one so bad I can taste it, but I can't make the ≈$400 happen no matter how I slice it =( Congrats to those lucky few of you that are picking these up! Can't wait to see your pictures
  • hackerman
Re: [Oddforge] VE.A
« Reply #548 on: Wed, 09 November 2016, 19:51:25 »
Invoice received and paid, thanks Oddforge team!
Offline hkf
  • your #1 fan
Re: [Oddforge] VE.A
« Reply #549 on: Wed, 09 November 2016, 19:59:31 »
Guess I have to wait till all the housings are sold before I get word whether I can get a pcb/plate?
