Author Topic: Throwing a teensy inside a dell quietkey  (Read 1881 times)
Offline QuincyJones
« on: Mon, 13 June 2016, 22:20:00 »
I'm thinking about doing this, mainly to give me a function layer but never done anything like this before. Would I simply wire up the connectors where the membrane matrix meets the board to the teensy?
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline Darkshado
Re: Throwing a teensy inside a dell quietkey
« Reply #1 on: Mon, 13 June 2016, 23:07:19 »
Easier: make a PS/2 to USB converter with that Teensy / other suitable dev board.
You need to solder the PS/2 connectors according to your fimware's instructions. You could do this internally and install the board permanently inside, or use a PS/2 connector and have a removeable adapter that'll work on all of your PS/2 boards.
Check out Soarer's and TMK as good starting points.
N.B. I haven't done this specific project myself yet.
Offline QuincyJones
« Reply #2 on: Tue, 14 June 2016, 05:16:46 »
I suppose that's an idea - thanks! there's some space inside but not sure whether there'll be enough! Teensy's are so expensive in the UK though sadface
« Last Edit: Tue, 14 June 2016, 05:21:14 by QuincyJones »
(please like me)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #3 on: Tue, 14 June 2016, 05:26:22 »
ProMicro from eBay is quite cheap.
« Reply #4 on: Tue, 14 June 2016, 08:00:31 »
- D Trump 2026-10-24
