Author Topic: [IC] Clueboard CNC'd Aluminum Case  (Read 28101 times)
Offline skullydazed
  • Had to turn PM's off. Email info@clueboard.co!
    • Clueboard
« on: Tue, 21 June 2016, 02:38:43 »
Imgur Album: http://imgur.com/gallery/YOwqL
This is two of the Clueboard Aluminum Case prototypes. The case is two solid pieces of Aluminum that have been CNC milled.
The plate is integrated into the case for an extremely sturdy and rigid design. There is no flex or pinging on these cases.
We made several changes and improvements to the design based on the prototypes. Most are not visible changes (like increasing the amount of room inside for the PCB through several tweaks) but one of the prominent changes is increasing the lip around the edge. From most angles switches will no longer be visible, while still allowing for even the largest SA caps.
Interest Form
To gauge interest and figure out what colors should be produced I've put together this form, please fill it out if you want to buy a case: https://docs.google.com/forms/d/16bAnQ7ygDPMfOg0luyiKC4aZFabileAtbzfDeoJfK-M/viewform
« Last Edit: Fri, 23 September 2016, 00:33:12 by skullydazed »
Offline loud_asian
Re: Clueboard CNC'd Aluminum Case
« Reply #2 on: Tue, 21 June 2016, 03:07:19 »
My interest is piqued, might pick up a case if the price is right :D
Offline joey
« Reply #3 on: Tue, 21 June 2016, 03:25:32 »
Dope! :thumb: Almost tempting.. :P
Offline smart5088
« Reply #4 on: Tue, 21 June 2016, 04:09:39 »
interest. keyboard is what pcb ?
this is leopold 660 lay out ? and leopold 660 pcb ?
Offline joey
« Reply #5 on: Tue, 21 June 2016, 04:15:15 »
The PCB would be a clueboard PCB (designed by skully), http://clueboard.co
Offline Jokrik
« Reply #6 on: Tue, 21 June 2016, 04:19:56 »
Can I assume this will support the alps pcb? :)
Offline kiwi99
  • that's a gnarly dookie
« Reply #7 on: Tue, 21 June 2016, 04:26:59 »
Good stuff skully, it looks amazing and unique :)
Offline Auxo
  • Formerly CJD_Anthony
« Reply #8 on: Tue, 21 June 2016, 07:02:29 »
hng
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #9 on: Tue, 21 June 2016, 07:14:02 »
That's a very a nice looking case, I'm not into the Clueboard layout, but if I ever design a case for my own projects, sure will take a few cues from this.
Well done!
Offline xondat
  • i'm not a star
« Reply #10 on: Tue, 21 June 2016, 07:22:53 »
Interested to try the layout but the cases never did it for me - this one does. I love the idea of combining the plate and top piece, it looks amazing.
Offline chuckdee
« Reply #11 on: Tue, 21 June 2016, 10:49:48 »
Interested.  would like to see the color for purple... and black if you decide to make it available.
Offline SixtyLife
« Reply #12 on: Tue, 21 June 2016, 10:53:20 »
this looks slick
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline eyedrop
« Reply #13 on: Tue, 21 June 2016, 11:40:17 »
That looks really good.  Will keep an eye out for sure.  I filled out the IC form also.
Offline Data
« Reply #14 on: Tue, 21 June 2016, 12:19:36 »
Very clean.  I like the bevel around the top edge.
Offline theXavier89
« Reply #15 on: Tue, 21 June 2016, 14:58:16 »
I'd totally buy these.
One in black and one in red. I have to have options for my Deadpool build.
Before you ask, yes I name all of my keyboards.
       Betty                    Lucy            Elizabeth (Cluebard)
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #16 on: Tue, 21 June 2016, 17:50:35 »
Really cool looking case. If only I had a clueboard... and wasn't about to start 3 other projects.
It'd be awesome to see this case design on another form factor like a 60%.
Offline murkey
    • murkey's alpaca farm
« Reply #17 on: Sat, 25 June 2016, 00:27:46 »
Interested!
Offline SBJ
  • Tactile pls
« Reply #18 on: Sun, 26 June 2016, 08:45:40 »
Filled out the form, and am definitely interested. I was disapointed to find it it wasn't a Leopold FC660C that it was for, but I guess a Clueboard with Zealios will do  :p
Offline braidn
« Reply #19 on: Tue, 28 June 2016, 18:52:10 »
Filled out and co platelets psyched for this. Love it Skully
Offline misconceit
« Reply #20 on: Wed, 29 June 2016, 11:05:39 »
Makes me want to build one with Zealios 62g as well :p
HHKB Pro 2 Type-S
HHKB Pro 2
Offline duynguyenle
  • Personal text? What personal text???
« Reply #21 on: Fri, 01 July 2016, 12:03:28 »
I'm in! Extra credits if it can support Alps too!
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline braidn
« Reply #22 on: Tue, 19 July 2016, 22:49:52 »
Any updates here Skully? Super excited about this!
Offline Chedda7
« Reply #23 on: Thu, 21 July 2016, 01:09:03 »
The renders look great!
Offline Erysichthon
« Reply #24 on: Wed, 03 August 2016, 21:35:56 »
I'd love one if blue is a chosen color!
Offline sony
  • Formerly ultraidiot
« Reply #25 on: Wed, 10 August 2016, 23:48:21 »
I'm in if it supports alps. One for my white and one for my blue alps.
« Reply #26 on: Thu, 11 August 2016, 00:09:27 »
Any updates on progress? Specifically, if Alps are supported?  ;)
Offline Wannabe
  • Independent Adjudicator
« Reply #27 on: Thu, 11 August 2016, 09:27:37 »
Interested in a purple one.
I liek keyboards
Offline Bucky
« Reply #28 on: Fri, 26 August 2016, 11:40:39 »
Depending on when this comes out I may be interested.
Offline KHAANNN
« Reply #29 on: Fri, 26 August 2016, 14:21:31 »
Wow. Amazing
Out of curiosity, why are the inner borders rounded, while the keyboard design itself is pretty sharp
On the pro side, it's a lot like Cherry keycaps, where they have sharp bottoms, yet the top of the keycaps are rounded, similarly this keyboard has pretty sharp bottoms, but the gaps are rounded
I just wonder whether an all-sharp keyboard could look more appealing, with GMK keycaps (or other Cherry keycaps)
Offline skullydazed
    • Clueboard
« Reply #30 on: Fri, 26 August 2016, 18:15:06 »
Wow. Amazing
Mostly that has to do with CNC tooling. The smallest corner you can make is the radius of your cutting tool, and it would be prohibitively expensive to cut those with sharp corners.
Production costs aside, I think you have an interesting idea. It could look pretty good to have sharp GMK caps with nice crisp corners.
Offline skullydazed
    • Clueboard
« Reply #31 on: Fri, 26 August 2016, 18:16:56 »
New Renders!
Offline xondat
  • i'm not a star
« Reply #32 on: Fri, 26 August 2016, 18:25:01 »
New Renders!
Still pretty. I need those caps in my library soon though.
How many screw holes now?
Offline KHAANNN
« Reply #33 on: Fri, 26 August 2016, 18:35:03 »
Thanks, It's like a dream/obsession of mine :]
I thought about designing a keyboard that's just drilled into a solid block of aluminium, so keyboard's frame and plate would be one, but it requires too much dedication and time
In the meantime, this version of the Clueboard is just incredible
I really like the looks of the WASD keyboard, apart from the plastics, they are just spectacular, the sides of the Clueboard has the same vibe
When the time comes, I would love to own one or two of these
Offline xondat
  • i'm not a star
« Reply #34 on: Fri, 26 August 2016, 18:39:46 »
Not possible unless you had a hole somewhere to slot the PCB in :-* wouldn't be too hard to design imo (with previous experience).
Offline jchan94
  • Keyclack Inc
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
« Reply #35 on: Fri, 26 August 2016, 18:40:54 »
New Renders!
New Renders!
Love it! The edgy look matches my 2016 Prius (no regrets with 55 smiles per gallon)
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline KHAANNN
« Reply #36 on: Fri, 26 August 2016, 18:47:55 »
I don't know the limitations of the CNC processes, so first I would need to learn these processes
But basically, the bottom is empty, when the build is completed, you close the bottom part of the keyboard with a plate (which has the feet attached) - so unless you flip the keyboard, all you see is a block of aluminium
Not sure how good it would look tho, I personally prefer the looks of the Clueboard (this case) style keyboards, where the switches are recessed, however, since my layout is: http://www.keyboard-layout-editor.com/#/gists/e981a31e8654ca60b7c8 - and all my layouts have gaps, It seems like the best option for me
« Last Edit: Fri, 26 August 2016, 19:01:27 by KHAANNN »
Offline Bucky
« Reply #37 on: Fri, 26 August 2016, 20:56:01 »
Was there ever a discussion of a diffuser to utilize the under mounted LEDs?
Offline Jumie
« Reply #38 on: Sat, 27 August 2016, 01:51:46 »
Will this be compatible with fc660m pcb?
Offline skullydazed
    • Clueboard
« Reply #39 on: Sat, 27 August 2016, 14:00:16 »
No, we had to add a second mounting post on the left that the fc660m pcb doesn't have. It makes the board really strong and only a few people would do that anyway.
I've looked into it, but for now that's not an option.
Offline Bucky
« Reply #40 on: Sat, 27 August 2016, 21:47:11 »
Alright, well maybe just a thought as an add on for the future. Looking good!
Offline KHAANNN
« Reply #41 on: Sat, 27 August 2016, 21:53:02 »
Filled the form, Dark Grey, Silver, Dark Grey.
When are we going to have this beauty by the way?
A rough ETA would be nice :)
Offline B1G_B1RD
« Reply #42 on: Tue, 06 September 2016, 14:34:51 »
Thats a great looking case. I wish i had a clueboard now.
Offline nateth
« Reply #43 on: Thu, 08 September 2016, 02:19:44 »
I'm all in for the Alps model down the pipe.
« Last Edit: Sun, 11 September 2016, 17:13:37 by nateth »
« Reply #44 on: Mon, 12 September 2016, 21:27:57 »
Same.
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #45 on: Tue, 13 September 2016, 14:14:59 »
What kind of ballpark pricing would we be looking at for a case like this?
Offline ntw
« Reply #46 on: Tue, 13 September 2016, 14:26:17 »
^ asking the important question
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #47 on: Sat, 17 September 2016, 22:13:34 »
Maybe this is asking too much, but I would buy two if there was a future case revision to support some type of an AEK-esque Alps layout.
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline skullydazed
    • Clueboard
« Reply #48 on: Fri, 23 September 2016, 00:26:01 »
We got the manufacturing samples back! The grey needs to be reworked (it didn't match the first sample,) but the Silver and the Orange look fantastic! They fit together well and everything feels nice and solid.
If you're gonna be at the KiiboHD meetup on Saturday you'll have a chance to handle one of these yourself. They're pretty hefty boards, and very solid.
We've decided on pricing. Retail price for this will be $149.99 for the case alone. I've been talking to Massdrop about running this, and depending on the number of people in the drop we should be able to get the price down quite a lot from there.
I've also been working on acrylic inserts for the case. The underlight reflects pretty well on the silver case (less well on the orange) and so far I really like either clear or transparent cobalt blue. You can see the cobalt blue on my instagram:
https://www.instagram.com/p/BKrZ8z0h790/
I can't say anything about timing this update, but we're drawing ever closer!
Offline loud_asian
Re: [IC] Clueboard CNC'd Aluminum Case
« Reply #49 on: Fri, 23 September 2016, 00:36:17 »
unf.. thanks for the update
gonna need more pics tho
