Author Topic: Some PCB help for a Keypad  (Read 2436 times)
Offline tee-eye
« on: Thu, 30 June 2016, 04:30:23 »
So, I am working on my first DIY project... and also my first PCB.
I think I have everything done properly, but if anyone knows their stuff, does this blueprint look right?
The first one I do, I am going to just make at home to see if I can. If it works well, I plan on cleaning it up some more and possibly getting some made to send to friends.
anyway... A PDF of my design is below.
I plan on using a Pro Micro just to try and keep it more reasonably priced. *poor college student*
seems like a pretty basic set up... Idk.
Offline joey
Re: Some PCB help for a Keypad
« Reply #1 on: Thu, 30 June 2016, 04:49:38 »
Looks fine to me!
Offline kolec94
« Reply #2 on: Thu, 30 June 2016, 17:53:56 »
looks good as long as your not doing a single sided board
kbparadise v60 blues
Offline tee-eye
« Reply #3 on: Thu, 30 June 2016, 23:13:47 »
Definitely double sided.  I think I will probably redo the routing a couple more times until it is really clean and then go from there.
Thanks for the responses! :)USB
Offline kingyachan
« Reply #4 on: Fri, 01 July 2016, 00:53:47 »
I know it's a bit off topic but I'm looking at making my first PCB as well but I'm a bit lost, could you tell me where you started and what resources you used? Thanks!
Also yours looks pretty sweet!
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #5 on: Fri, 01 July 2016, 07:02:42 »
Offline kolec94
« Reply #6 on: Fri, 01 July 2016, 08:22:09 »
is thier a reason not to run the row altogether until the go their separate ways?
Offline tee-eye
« Reply #7 on: Fri, 01 July 2016, 20:07:34 »
I was just trying to keep it as compact as possible and splitting them like that just seemed less cramped and didnt go beyond the switch outlines. :)
