Author Topic: Need feedbacks on Gateron Clear.  (Read 14182 times)
Offline Capmerica
« on: Mon, 25 July 2016, 09:34:55 »
Hello guys, I have just followed the whitefox groupbuy. I decided to pick the Gateron Clear switches to go with the keyboard. I would like to know what is ur opinion about these gateron clear switches. Which one is better for gaming Gateron Clear or Cherry Red? Thanks.
Offline xondat
  • i'm not a star
Re: Need feedbacks on Gateron Clear.
« Reply #1 on: Mon, 25 July 2016, 09:41:07 »
It depends which you like the most - no one here can tell you what you like.
Offline redbanshee
  • actually Dade Murphy
« Reply #2 on: Mon, 25 July 2016, 10:08:50 »
The gateron clears actuate SUPER easy. I made a board with them and had a little bit of trouble with accidental actuation with just resting my hand on the keyboard. Personally I would pick the Cherry reds over the gateron clears after that experience. You may not end up having any problems tho /shrug
Offline jenggo
« Reply #3 on: Mon, 25 July 2016, 10:10:06 »
prefer cherry red, that gateron clear too light. i accidentaly press the button with that switch
Filcos | JD40 | Planck | FJELL | Jetfire | Weaven | GON 60 | BWU | DasKeyboard | PokerII | Strafe | Octagon v2 | TX 1800 | TXCP | Realforce 104UB | KMAC 1 | TXPad | DC60 | Ergos
Offline Capmerica
« Reply #4 on: Mon, 25 July 2016, 10:27:10 »
Is gateron red any different than the cherry counter part?
« Reply #5 on: Mon, 25 July 2016, 10:28:25 »
I'd say a little smoother.
I've used gateron clears they are too light with their stock springs.
I also use cherry reds at work daily and gateron reds at home.
Offline Proyoyo
« Reply #6 on: Mon, 25 July 2016, 10:29:29 »
I prefer cherry red as well. Gateron clear feels way too light in my opinion.
Offline Capmerica
« Reply #7 on: Mon, 25 July 2016, 10:39:22 »
Thanks for feedbacks guys.
Offline SKD
« Reply #8 on: Mon, 25 July 2016, 12:11:59 »
Oddly I prefer Gateron clears to Cherry reds. I love the light actuation on the clears. I just replaced a numpad with clears and in the middle of building a 60% with clears too. The clears feel smoother than cherry reds too.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #9 on: Tue, 26 July 2016, 00:26:15 »
Like others have said, clears frankly are just too light for most people. Especially on stabilized switches, the slider's return feels slow.
Offline nmur
  • ಠ_ಠ
« Reply #10 on: Tue, 26 July 2016, 00:30:10 »
i ran with Gateron Clears for about 4 months
i thought they were great for a while, however i began to notice just how easy they were to actuate accidentally
i really noticed this once i started playing Overwatch, where i'd sometimes press Q (for ultimate) accidentally...
i quickly spring swapped to 62g bottom out weighted springs
Offline jcoffin1981
« Reply #11 on: Tue, 26 July 2016, 02:46:20 »
I generally prefer tactile switches.  Therefore I have not used Cherry Reds with any length of time.  However, I now that the Gateron clears are  extremely light and even resting your hands on the home row can result in accidental keystrokes.  However, the Cherry Reds I have tried have been extremely scratchy.  It's almost like the springs of a mattress that make the sound of "eeek eerrrr eeeeekk  errrr," when shifting your weight or bouncing up and down.  The Cherry's will  provide a little more resitance, but the Gaterons will be smoother.  These are all things to consider when making your decision.  Good luck.
Offline Magna224
« Reply #12 on: Tue, 26 July 2016, 02:55:39 »
Gateron clear take less force (theyre really light) but have a slower rebound. They are a bit smoother than cherry switches too. I would probably choose gateron clears just because they are more interesting than MX reds. But its all about what you like and you wont know until you try them.
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
Offline iichigoz
« Reply #13 on: Tue, 26 July 2016, 21:40:50 »
I was on gateron clears for awhile and it was too light for me. Now using cherry clears. Haha
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #14 on: Tue, 26 July 2016, 21:53:35 »
I would suggest going with the Gateron Reds over Cherry reds and the clears. Gaterons are generally smoother and the Whitefox plate supports switch-top opening so you could always swap the springs later.
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline blighty
« Reply #15 on: Wed, 03 August 2016, 08:56:35 »
I just built up a mx-mini pcb with gateron clears (with a red as spacebar).  Feels great, similar to the Plum 35g topre-clone.  The bottom out is a bit different, of course, even with o-rings on the clears, but the fingers just fly over the keys.  If you like light linear switches, clears could work for you.  Using MX blacks now almost feels like exercise...
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline chuckdee
« Reply #16 on: Wed, 03 August 2016, 10:14:54 »
Are gateron clears tactile?  I thought that they were going to be like MX Clears, but they feel nothing like that.  As others have said, they're really light.  And I didn't feel anything tactile about them at all.
Offline Spopepro
« Reply #17 on: Wed, 03 August 2016, 10:22:32 »
Nope, gateron clears are linear. I use them on a number of my keyboards for modifiers, and my pinkies love them. However even just resting your finger tip on them will cause actuation. They are nearly too light to use.
Offline chuckdee
« Reply #18 on: Wed, 03 August 2016, 10:29:42 »
Ah... so my fault on my research on that, or I'd not have gotten them.  I think I just assumed if it was named after a switch already in production, they'd have been similar to that.  Well, at least there's a drop on MD for Gats going on.  I tried them, and was glad that I'd not put them into a board first.
Offline blighty
« Reply #19 on: Wed, 03 August 2016, 10:33:01 »
Hmm, i touch my keys but generally don't push down when on the home row, so I rarely get random key presses.   They are just a light, smooth switch.  If you are heavy handed, the switches may not be for you.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #20 on: Wed, 03 August 2016, 16:55:02 »
oops. I made this mistake as well... glad I found this thread before that white fox drop ended. Just edited my order to cherry mx clear instead.
Phew!
-Dana
« Reply #21 on: Wed, 03 August 2016, 23:49:42 »
Phew!
There actually are 67g Gateron tactile clears, but they are only available through Winkeyless.kr . I have heard the feel is almost indistinguishable from 67g Zealios.
« Last Edit: Thu, 04 August 2016, 03:18:20 by MandrewDavis »
Offline SBJ
  • Tactile pls
« Reply #22 on: Thu, 04 August 2016, 02:22:41 »
There actually are 67g Gateron tactile clears, but they are only available through Winkeyless.kr . I have heard the in feel is almost indistinguishable from 67g Zealios.
Oooh very interesting. I'll have to try these out!
Offline Capmerica
« Reply #23 on: Thu, 04 August 2016, 05:39:38 »
I have tried Gateron Red recently. I did feel light, maybe I will go with black.
