Author Topic: [GB]Revo&Dr.D keyboard  (Read 184907 times)
Offline MMKB
Re: [GB]Revo&Dr.D keyboard
« Reply #350 on: Sun, 26 March 2017, 01:19:20 »
Just want to say cable can be separated into 2 parts like this
You can put it into pcb after assembly and put the cases together the link the longer part of the cable.
I am not good at explaining this kind of thing,but i think you guys can get the idea.
btw, pc plate is very soft,is that right?
Hi Revo, this tenkeyless in your photos has a case that doesn't look like Dr. D. Could you confirm either way? Thanks!
Offline ihalatch
« Reply #351 on: Sun, 26 March 2017, 01:52:49 »
Where can I buy a cable like this one?
Offline RevoTeam
« Reply #352 on: Sun, 26 March 2017, 01:53:10 »
No,it's not. It's something else. A GB in China,i didn't bring everything to GH cause there are too many stuffs. I only bring the better ones imo.
Offline Moistgun
  • Slippery When Wet
« Reply #353 on: Sun, 26 March 2017, 07:18:02 »
Ayyyyeeee
Offline Moistgun
  • Slippery When Wet
« Reply #354 on: Wed, 29 March 2017, 20:34:41 »
HMU if anyone knows how to use this thing.  ;D
Computer is not recognizing the board at all.
And im not even getting started on programming it yet.
Offline Moistgun
  • Slippery When Wet
« Reply #355 on: Wed, 29 March 2017, 21:13:52 »
also
Offline RevoTeam
« Reply #356 on: Wed, 29 March 2017, 21:25:52 »
what happens when you plug it in?nothing?is there any sound or anything?
从我的 iPhone 发送,使用 Tapatalk
Offline RevoTeam
« Reply #357 on: Wed, 29 March 2017, 21:35:47 »
i flew 4 hours to anode factory yesterday and put a all nigter. I have tracking now for  90 percent of the order. Will pm tomorrow. Need to sleep for a bit. Everyone should pm ASAP if your stuff have any problem. So  i can do a change or send miss part(if there is something missing ). Revo is known for aftersales service. Cheers.
Offline smittysteve
  • Tea > Coffee. Clack > Thwock.
« Reply #358 on: Wed, 29 March 2017, 21:38:10 »
You rock, Raymond!! Thanks for the great shepherding of this gb!
Offline Moistgun
  • Slippery When Wet
« Reply #359 on: Wed, 29 March 2017, 21:43:30 »
I get the windows sound when I plug it in.
Offline Moistgun
  • Slippery When Wet
« Reply #360 on: Wed, 29 March 2017, 22:59:40 »
I assume a few of you are interested in what shipping looks like.
http://imgur.com/a/bWFVh
 :thumb:
« Reply #361 on: Wed, 29 March 2017, 23:06:50 »
 :thumb:
Man, I want a Yarbo cable.
Also, I used to have a couch just like that.
Offline kokokoy
« Reply #362 on: Wed, 29 March 2017, 23:21:17 »
Not sure if its the same thing I experienced but what i found out is the connector for the cable  on the PCB (the soldered part) gets in contact with the case. It happened 3X, I disassemble it and it works then it dies down; thought it was the PCB but then placed a little tape on the square hole to avoid contact and so far never saw the issue again.
Offline Moistgun
  • Slippery When Wet
« Reply #363 on: Thu, 30 March 2017, 00:27:48 »
Thanks for the heads up on that. I think mine had to do with ps2 drivers on my pc which fixed with a windows update!
typing on it now!
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #364 on: Thu, 30 March 2017, 17:41:25 »
Hate to be that guy.............but.............
Looking to buy one of these if anyone is looking to sell. Hmu with a PM if you dont want yours  :p
Offline Moistgun
  • Slippery When Wet
« Reply #365 on: Thu, 30 March 2017, 18:25:47 »
Better than the guy who sells their spot months before GB is meant to ship  :p
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #366 on: Thu, 30 March 2017, 20:22:51 »
At this point i wish I had bought from one of those guys
Offline Moistgun
  • Slippery When Wet
« Reply #367 on: Thu, 30 March 2017, 20:25:17 »
Photography is bad, but heres a quick dump of some angle pics so you can see what the finished product looks like.
« Reply #368 on: Thu, 30 March 2017, 21:41:04 »
It's like staring into the face of God and living.
Offline smittysteve
« Reply #369 on: Thu, 30 March 2017, 22:00:00 »
No kidding, this is a gorgeous board! Kudos Moistgun for setting the bar high on Dr. D builds!!
I need to start thinking about what to do with an orange middle in mine.
Offline Moistgun
  • Slippery When Wet
« Reply #370 on: Thu, 30 March 2017, 22:28:05 »
Thanks Guys!
The hydro is the finality of this build so the Blue and silver is really the focus.
Thats only half the build tho for the revo.
I got a second PCB and a poly carb plate.
Gonna do lubed silent blacks on the polycarb with POM for a different feel.
The bottom row might be a little weird, but its gonna be worth it to have a really soft linear board.
Offline Moistgun
  • Slippery When Wet
« Reply #371 on: Thu, 30 March 2017, 22:46:09 »
Oh. and still on the list is to figure out how to get the bootmapper client to recognize the keyboard...  :))
Offline RevoTeam
« Reply #372 on: Fri, 31 March 2017, 08:51:40 »
Try to link it with usb instead of ps2.And there are 2 mode. You should press u (don't let go) link your computer with usb port,or press p(don't let go) link your computer with ps2 port. When you using ps2,you should restart your computer. Try to programme it using usb mode. Let me know if it's still not working.
Offline RevoTeam
« Reply #373 on: Fri, 31 March 2017, 08:55:44 »
Can you show me a photo of your taped bottom case. We use xh2.54 and it's all platisc. This never happen when i assemble mine. There shouldn't be any short. And anode alu is insulated. I am a little bit confused.
Offline joey
« Reply #374 on: Fri, 31 March 2017, 08:57:00 »
Just got tracking!
Is the end of the yarbo cable xh2.54? If so, I should make my PCB use that so I can use the nice cable!
Offline Moistgun
  • Slippery When Wet
« Reply #375 on: Fri, 31 March 2017, 09:16:41 »
Well I definitely cant recommend pressing U to any one having this issue because now my keyboard has no firmware on it.
So now, not only can I not program it, I cant type on it.
Offline RevoTeam
« Reply #376 on: Fri, 31 March 2017, 09:27:00 »
Did you using the USB adaptor? If you are using it,press Q(don't let go) and then link your computer. You should be able to use bootmapper.At this point nothing can be more wrong. Or you can add my shype (raymondyy),let me see what i can do.
Offline Moistgun
  • Slippery When Wet
« Reply #377 on: Fri, 31 March 2017, 09:28:30 »
Tried P using PS2 and tried U using an adapter
Ill try Q now.
Offline Moistgun
  • Slippery When Wet
« Reply #378 on: Fri, 31 March 2017, 09:32:34 »
Q reset the keyboard so that is back up and running.
Offline RevoTeam
« Reply #379 on: Fri, 31 March 2017, 09:37:26 »
See if you can use bootmapper to programme it now. I don't really know about this if the problem is still there,i'll ask about it and get it back to you.
Offline kokokoy
« Reply #380 on: Fri, 31 March 2017, 09:40:24 »
Oh didn't know that. Then it might be another reason then. The thing is when it started not functioning back then all I need to is pull the plug disassemble plug it back without the case then it started working again. No PC restart or anything. So I thought it might be something to do with my noob soldering skills or something else.
Anyway I attached a pic of which I assume might be in contact (the 4 solder thingy), the tape would be on the case side. Can take a pic tom if you need one.
« Last Edit: Fri, 31 March 2017, 09:42:56 by kokokoy »
Offline Moistgun
  • Slippery When Wet
« Reply #381 on: Fri, 31 March 2017, 09:49:52 »
holding down Tab seems to have put it into bootloader, as each keypress registers as follows
.3,1.
.3,2.
.3,3.
.3,4.
.4,1.
.4,2.
.4,3.
Thats me typing out asdfzxc
Pressing keys will now select different cells in Bootmapper
I still cannot use the download or upload buttons in Bootmapper, nor can I flash a hex file via "options"
Offline RevoTeam
« Reply #382 on: Fri, 31 March 2017, 09:52:50 »
Tape it should fine. Dr.D is at my side,we didn't see this coming.Sorry about this.
Offline kokokoy
« Reply #383 on: Fri, 31 March 2017, 10:00:36 »
It's totally alright man. Again love the board and waiting to see if I'll like it more with an orange mid. But looking at Moistgun pics, looks like I will.  ;D
Offline MMKB
« Reply #384 on: Fri, 31 March 2017, 10:03:00 »
Hi Reymond, PM-ed you my concern about the DHL destination. It seems to be heading to my previous address which scared me a bit. Could you confirm it's heading my way? Thanks.
Offline RevoTeam
« Reply #385 on: Fri, 31 March 2017, 10:13:25 »
Just phone with shipping. will change the address tomorrow
Offline RevoTeam
« Reply #386 on: Fri, 31 March 2017, 10:24:39 »
.3,1.
.3,2.
.3,3.
.3,4.
.4,1.
.4,2.
.4,3.
I will sort out your problem tomorrow.  Dr.D and me think about everything we know and have no clue. I will ask who know tomorrow and give you the right answer :)
Offline Moistgun
  • Slippery When Wet
« Reply #387 on: Fri, 31 March 2017, 10:26:30 »
.3,1.
.3,2.
.3,3.
.3,4.
.4,1.
.4,2.
.4,3.
No rush, as long as the board has some firmware I'm cool, just wanted to get it programmed is all.  I'm happy to provide more info and screenshots if it helps troubleshooting.
« Reply #388 on: Fri, 31 March 2017, 10:30:18 »
Do you have the latest firmware?
Offline Moistgun
  • Slippery When Wet
« Reply #389 on: Fri, 31 March 2017, 14:57:19 »
How do you suggest that I confirm that
« Reply #390 on: Fri, 31 March 2017, 15:37:41 »
Download it from the WKL website. Whenever I've had a hiccup with my PCB a reflash with the newest firmware did the trick.
If you haven't found it by tonight I will look.
Offline Moistgun
  • Slippery When Wet
« Reply #391 on: Fri, 31 March 2017, 18:01:23 »
If you are referring to the latest version of Bootmapper I can check but Im almost certain I have it.
And I assume the firmware on the pcb is outdated in my situation since the bootloader button is tab as seen on past 32a bootmapper boards.
The problem with that is, whether or not the actual firmware is outdated, I still cant seem to reflash it with the newer one which has to be done in BTMppr.
Offline Moistgun
  • Slippery When Wet
« Reply #392 on: Fri, 31 March 2017, 21:44:07 »
Have you had any luck programming your keyboard?
Offline kokokoy
« Reply #393 on: Fri, 31 March 2017, 21:50:55 »
Mine was fine. Never had issue with the bootmapper.
Offline Data
« Reply #394 on: Fri, 31 March 2017, 23:08:07 »
Got my tracking number.   ;D  ;D  ;D
Offline Moistgun
  • Slippery When Wet
« Reply #395 on: Fri, 31 March 2017, 23:20:02 »
Want to offer my version of a guide for programming one of these boards.
I know the info is out there, but I dont care.
Here you go.
From all the variations I tried, the only way I was able to program the board was using the ps2 to usb converter that revo provided.
With this adapter, I had to use a USB 2.0 port, as 3.0 wouldn't work.
When I did that, windows 10 decided to finally install Ps2avrGBU on my computer.
that is when I was able to use the bootmapper client from WKL.
http://blog.winkeyless.kr/155
When you open the client, you will click download, then change that layout as you desire, toggle bootmapper, then upload.
In that order with those specifics.
After doing this, the keyboard had my custom keymap when using the ps2 adapter to usb 2.0 and 3.0.
However, I was not able to then restart my computer with PS2 and use the keyboard.
Instead I needed to reboot holding tab, and then my keymap worked through ps2
« Last Edit: Fri, 31 March 2017, 23:49:12 by Moistgun »
Offline RevoTeam
« Reply #396 on: Sat, 01 April 2017, 00:02:14 »
a little update here. My RGB 80 PCB is on the way to me now. It's a87 size so it can be use on Dr.D. Anyone in the Dr.D GB can get 10usd discount in the rgb pcb GB in the future.
Offline gadzkun
« Reply #397 on: Sat, 01 April 2017, 00:44:04 »
so you will run Dr.D R2 GB with RGB PCB? :eek:
Offline JDragon
« Reply #398 on: Sat, 01 April 2017, 04:02:49 »
I want one! Does it use SMD LEDs?
I guess I have to wait to build my board until the RGB PCB GB.
Offline Moistgun
  • Slippery When Wet
« Reply #399 on: Sun, 02 April 2017, 10:59:00 »
Finally, some nicer weather!
Bonus HWS and KWK
