Author Topic: [IC] 60% PCB with arrow cluster NEW Layout (GB thread link inside!)  (Read 43738 times)
Offline FoC_Tow
  • Brokehlicious
Re: [IC] 60% PCB with arrow cluster NEW Layout (Taking poll | please help vote!)
« Reply #100 on: Thu, 02 February 2017, 01:31:38 »
Guys this is 6 option what i got from leeku
but consider to result poll i ask leeku if he could change
1.25 - 1.25 - 1.25 - 1.25 - 3u spacebar - 1.25 - 1.25 -arrow cluster
with
1.5 - 1.5 -  6.25u spacebar - 1.25 - arrow cluster
but so far this 6 option from leeku i think it's fair enough to covered in 1 PCB  ;)
Lookin good,
glad the 6u version made the list! =)
1.5 1.5 6.25 1.25 arrows would be an awesome adition tho, since it seems to be one of the most popular choices.
Offline cumwagondeluxe
« Reply #101 on: Thu, 02 February 2017, 01:55:01 »
Is it possible to do a split spacebar layout with this PCB but with no key in between the two spacebars? (instead of 2.25 - 1.25 - 2.75, have e.g 3.25 - 3 or 3 - 3.25)
Offline yasintahir
  • Formerly silentreader
« Reply #102 on: Thu, 02 February 2017, 06:19:38 »
If we can make this fit most standard 60% cases, this would be tits!
Congrats! it would be fit 60% universal case, just miss 1 bottom screw for some layout  :p
Lookin good,
from what i see it's should be fit 1.5-1.5-6.25-1.25-arrow, my finger still cross for 8 option btw  :))
mmm not sure about this layout... especially where u can find 3.25u spacebar?
Offline yasintahir
« Reply #103 on: Thu, 02 February 2017, 21:03:13 »
we have good news guys... leeku already done with checking layout and it's will cover all 8 layout :yay:
i will preparing for gb thread and if i dont have any trouble it will be up on monday
Offline ideus
  • Björkö.
« Reply #104 on: Thu, 02 February 2017, 21:09:00 »
Wow! Great job.
Edit: Does the 6u bottom row feature the classic Cherry off centered switch position? If not it will not take any six units GMK space bar.
« Last Edit: Fri, 03 February 2017, 09:13:21 by ideus »
Offline FoC_Tow
  • Brokehlicious
« Reply #105 on: Sat, 04 February 2017, 04:53:59 »
GB Hype!
Offline Vadurr
  • Valar Morghulis
« Reply #106 on: Sat, 04 February 2017, 17:45:56 »
super stoked for this!
Offline yasintahir
« Reply #107 on: Sun, 05 February 2017, 00:20:00 »
Wow! Great job.
for 6u spacebar i will make it center and off stem option
------- update -----
i'm already talk with leeku about change 1 layout 1.25-1-1-1.25-3-1-1-1-arrow with 1.25-1-1-1.25-3-1.5-1.5-arrow to make it better with bottom hole screw for 60% universal case
Sent from my 2014811 using Tapatalk
Offline yasintahir
« Reply #108 on: Sun, 05 February 2017, 00:20:15 »
Wow! Great job.
Offline gadzkun
« Reply #109 on: Sun, 05 February 2017, 10:21:36 »
Wow! Great job.
NOOOOOOOOOOOOOOOOOOOOOOOOOOOO
RIP DREAMS
Offline yasintahir
Re: [IC] 60% PCB with arrow cluster NEW Layout (Preparing for GB Thread!)
« Reply #110 on: Tue, 07 February 2017, 08:38:34 »
already post GB thread, now wait for approval   :))
Don't forget to vote pcb color and plate option  :p
https://goo.gl/forms/VWoRxca2NuBCtyAB2
Offline ideus
  • Björkö.
« Reply #111 on: Tue, 07 February 2017, 09:35:04 »
Would this layout worth trying? Not sure if I should go the ISO route, this time. I may try it with Ergo Clears.
Offline yasintahir
« Reply #112 on: Tue, 07 February 2017, 09:46:08 »
sure ;D look at this 3rd option
Offline InfiniteMan
« Reply #113 on: Tue, 07 February 2017, 12:17:16 »
Is there an option for PCB mount(without a plate)?
Thanks.
Offline menuhin
« Reply #114 on: Tue, 07 February 2017, 12:25:29 »
Thanks.
I think it depends on the switches, doesn't it?
The 5-legged (1 center stud, 2 plastic legs and 2 metal pins) version of MX switches can be PCB mounted while the 3-legged (1 center stud and 2 metal pins only) can only be mounted to a plate. All Alps switches need a mounting plate to be installed.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline yasintahir
« Reply #115 on: Tue, 07 February 2017, 16:13:09 »
Thanks.
sure... but your enemy when you use PCB mount is 0.75 blocker on bottom both side
Offline FoC_Tow
  • Brokehlicious
Re: [IC] 60% PCB with arrow cluster NEW Layout (Waiting approval GB Thread!)
« Reply #116 on: Wed, 08 February 2017, 12:19:59 »
Sooo stoked! It's happening Ö_Ö
Offline JasonH
« Reply #117 on: Wed, 08 February 2017, 16:09:32 »
Already got a spare case for it. Very excited.
Offline lunr
« Reply #118 on: Wed, 08 February 2017, 18:11:45 »
i was looking for a 60% with arrow keys the other day. this is a good option since i was looking for a kit.
is this mac os compatible?
Offline yasintahir
« Reply #119 on: Wed, 08 February 2017, 21:18:17 »
Let's hope moderator not to long for approve GB thread  :D
i never used mac os before, but it should be ok i think
Offline yasintahir
« Reply #120 on: Thu, 09 February 2017, 00:41:25 »
https://geekhack.org/index.php?topic=87511.0
GB Thread is up guys.... HYPEEEEEE~
Offline SNReloaded
Re: [IC] 60% PCB with arrow cluster NEW Layout (GB thread link inside!)
« Reply #121 on: Fri, 12 May 2017, 00:37:27 »
---UPDATE 3---
GB THREAD :
---UPDATE 2---
So guys after talk to leeku here's the final layout for this pcb and it will be support universal 60% case but some layout lose 1 bottom screw
PCB will be designed by leeku
-Fully programmable
-Underglow Led
-controller use Atmega 32a
-Use L3 firmware like other leeku PCB
Price for PCB $55 (presoldered)
Plate $30 for alu/ss and $35 or $40 for brass
--- UPDATE 1---
after i contacted leeku to check if he can do 8 bottom combination r5 option, he said still working on it and not be sure until he arrange it... so to make plan B if he can't put 8 option R5 in this PCB i'm taking poll to see which bottom option you interest for this PCB. It will help me to see which option with most interest for this pcb, so that option with most interest will be put in plan B. And for people who want make it mx/alps PCB sure it will help with less option to make mx/alps PCB.
So please vote which option you're interest :)
link poll : https://goo.gl/forms/NmB30XCIWQNjRDWY2
Just got around to seeing this now, but I really like this layout. I'd totally look at purchasing if you ever did a round 2
