Author Topic: Atmel Flip programmer & Java  (Read 2746 times)
Offline Tactile
« on: Sat, 26 November 2016, 12:25:06 »
I'm setting up a Win 10 install here & about to install the Atmel Flip programmer. As you all know, the install requires Java. Is there a way to install Java for just this program? I don't want or need Java to reach its tentacles into my computer or my web browsers, I don't need or want Java to run whenever I boot my computer. I just need it for this one program.
How can I restrict Java from everything except Flip?
REΛLFORCE
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: Atmel Flip programmer & Java
« Reply #1 on: Wed, 30 November 2016, 03:12:21 »
AFAIK you can't specify the Java directory in FLIP, it will use the one from the environment variable. You could create a bat file to temporarily append the Java path every time you start the FLIP programmer.
If you are only using it to program FLIP, you could give dfu-programmer a go as well.
