Author Topic: [IC] Elvish PBT SA dye-sub & Laser Engraved Keycap set UPDATE : EXTRA?  (Read 25790 times)
Offline gadzkun
Re: [IC] Elvish PBT SA dye-sub & Laser Engraved Keycap set UPDATE : EXTRA?
« Reply #50 on: Sat, 10 December 2016, 13:52:10 »
https://goo.gl/GC4NGk
Many guys want extra keys.
But due to model issue, it's not possible to support all layout as we mentioned.
But we can use limited resource to make some of them.
So there's an additional question in the form about do you want extra or not.
It might fit some keyboard but definitely not all.
We have no 4u, 6.5u, 7u space bar or bigass enter, iso enter...etc
Alpha set, modify set and extra set GB will launch when > 30 interesting
is that final? of course we want extra~
please make it happen  :p
You mean extra?
For now I think it's all we can make.
Cause we don't have iso enter, and we may not sell iso enter only in the future.
So we just remove UK extra.
But keep separate shift cause they might able to use in some custom layout keyboard I guess.
And we still provide 1.5u and 1u ctrl and alt even we don't have 6.5u and 7u space bar.
Cause sell space bar only is reasonable in my opinion.
There's too many specs for spacebar...
yeah im ok with that. its already enough for 1800 layout :p
Offline nsmechkb
« Reply #51 on: Sat, 10 December 2016, 14:14:34 »
Is it possible to include an extra 2.25u shift in the add-ons/extras pack? Then FC660 users could get in on this, too.
Looks great. Happy to see more SA PBT caps.
Offline sennin32
    • Doyu Studio
« Reply #52 on: Sat, 10 December 2016, 22:15:54 »
I think that is possible :)
We're still discuss price for the extra now.
Haven't decided what key will contain finally.
Offline nsmechkb
« Reply #53 on: Sun, 11 December 2016, 15:50:44 »
Sounds great!  Hope the 2.25u makes it in to the extras kit.
IC form submitted.  Thank you!
Offline Jubileus
« Reply #54 on: Tue, 13 December 2016, 20:57:09 »
Is the group buy already up? I saw a link in your website.
Offline e_l_tang
« Reply #56 on: Wed, 14 December 2016, 00:05:41 »
With which manufacturer are you partnering to make this keyset? Is it the same one with which jchan94 is working?
Offline sennin32
    • Doyu Studio
« Reply #57 on: Wed, 14 December 2016, 01:13:47 »
im curious too
http://shopkey.doyustudio.com/021cape01grs-b.html
already up?
Oh,
It's a testing last night.
We're going to launch it later today :)
Offline sennin32
    • Doyu Studio
« Reply #58 on: Wed, 14 December 2016, 01:22:19 »
No,
They're not.
But I also order some samples for other caps from the factory they're work with(XDA).
The only thing I'm sure is XDA's plastic and printing factory.
I'm not sure if all their caps are from the same manufacturer.
I just take a look on the 1965 GB.
They're made by Signature Plastics.
So I think they have different manufacturers.
BTW, 1965 keycap set looks really good -0-
« Last Edit: Wed, 14 December 2016, 01:53:50 by sennin32 »
Offline sennin32
    • Doyu Studio
« Reply #59 on: Wed, 14 December 2016, 02:36:59 »
We've post it in GB forum.
https://geekhack.org/index.php?topic=86395.0
Awaiting approve :)
Offline gadzkun
« Reply #60 on: Wed, 14 December 2016, 03:22:16 »
sweeet~ ordered!~
btw how much will you declare for the package? xD
Offline sennin32
    • Doyu Studio
« Reply #61 on: Wed, 14 December 2016, 04:01:12 »
sweeet~ ordered!~
If under $100, we normally claim only a little lesser or real value.
Most country will charge duty when > $100.
Offline gadzkun
« Reply #62 on: Wed, 14 December 2016, 04:07:11 »
sweeet~ ordered!~
$30-50 please~ XD
Offline sennin32
    • Doyu Studio
« Reply #63 on: Thu, 15 December 2016, 05:44:36 »
sweeet~ ordered!~
$30-50 please~ XD
Mm, I think it's possible.
Custom in korea charge duty for item over $50?
Offline gadzkun
« Reply #64 on: Thu, 15 December 2016, 09:50:40 »
sweeet~ ordered!~
$30-50 please~ XD
im from indonesia, yes its get charged if above $50 :))
btw im ordered from this site
its correct right? gb still not up, so i dont know if its right or not  :))
nvm its already up i dont check it  :))
« Last Edit: Thu, 15 December 2016, 10:48:16 by gadzkun »
Offline sennin32
    • Doyu Studio
« Reply #65 on: Thu, 15 December 2016, 16:45:49 »
The post finally approved after 24 hours -0-
