Author Topic: [IC] FJELL 60% High Profile Keyboard Case  (Read 56664 times)
Offline Jokrik
Re: [IC] FJELL 60% High Profile Keyboard Case
« Reply #100 on: Wed, 04 January 2017, 07:37:59 »
Hello!
I been talking to the factory about what tolerances I have for these cases. The prototypes were very good, with some small flaws that would go unnoticed by most people, but I still want to make these better so that we get the highest possible quality out from the situation.
We had:
Some "stripes" on the side of the case, from the machining
Scratches on the brass weight(difficult to work with in this shape)
Some of the corners were not machined correctly.
We have been going through these small problems, and hopefully they have improved by our next prototype. The factory is very cooperative and they delivered an amazing products aside from these very small, almost unnoticeable flaws.
Shipping:
I am prepared to pay over 700$ in shipping to get these to me after I have placed the GB order, these are super heavy cases. From me, I will set up a solution with tracked shipping for everyone.
I am also figuring out some good options to include, and extras.
Thanks for reading, hopefully we will have some excellent prototypes so we can start this GB ASAP.
Very interesting updates
really can't wait for the GB :), all the best for the next proto
Offline Jedi
« Reply #101 on: Wed, 04 January 2017, 09:50:19 »
Throw us a weight figure on these boys.  My Round5 order could sure use this when it arrives.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #102 on: Wed, 04 January 2017, 09:59:03 »
Looks like a are going to hit the 2KG mark.
Offline hervuli
« Reply #103 on: Wed, 04 January 2017, 10:57:09 »
Wow. I was already interested, now I definitely want one! :)
JD40v2 MX Grey | HHKB BKE Heavy | E6-V2 78g Tealios | ZealX60 72g MX Zilent | TGR 910 RE 78g MX Zilent | Singa Vintage MX Black | Octagon V2 MX Grey | Orion V2 MX Clear | Novatouch BKE Extreme
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #104 on: Wed, 04 January 2017, 11:29:32 »
Fantastic, thanks for teh feedback!
Offline bbmathlvr
« Reply #105 on: Wed, 04 January 2017, 20:36:50 »
Holy crap! I think that's a good thing, but I'm a little worried for my desk at that weight :P
Probably TeX'ing right now.
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #106 on: Wed, 04 January 2017, 22:57:32 »
What is your desk made of?
Offline Saiph
« Reply #107 on: Wed, 04 January 2017, 23:01:02 »
Origami, is that not normal?
« Reply #108 on: Thu, 05 January 2017, 00:25:29 »
I don't know if it's been mentioned, have the colors been determined?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #109 on: Thu, 05 January 2017, 00:49:16 »
Not yet, still trying some different options to see what will fit best as options.
« Reply #110 on: Thu, 05 January 2017, 00:50:41 »
Ok great, looking forward to see what you choose :)
Offline exanile_tabasco
  • settling down
« Reply #111 on: Thu, 05 January 2017, 02:47:22 »
This is going to be a wonderful hipro case! I need this in my life.
Posting so I won't forget about this. I love what you've done with the centre screw post; most weighted hipros don't have it due to the position of the weight.
Offline E3E
« Reply #112 on: Thu, 05 January 2017, 07:19:41 »
Watching this topic over here too.  ^-^
Offline KHAANNN
« Reply #113 on: Thu, 05 January 2017, 07:31:04 »
I wonder how much higher are the bottom row keycaps compared to an 60% with a TEX case
Like everyone points out, it's an incredible product, would want to join If I can still type while my palm is on the desk
  • settling down
« Reply #114 on: Thu, 05 January 2017, 14:56:25 »
If you want to live the hipro life, you should probably have either a wrist rest or good posture (wrist suspended while typing). Otherwise it's going to hurt. If it's anything like FMJ or Hammer, bottom row (assuming regular R4 Cherry mods, not R5) will be a few mm higher than in a Tex case.
By the way @Leandren, I'm a little concerned now about the corners. If they're really rounded, is there any chance that the corners of bottom row Cherry caps will rub against the case? Have had this issue with some other hipro cases. I see that you like Skidata a lot so perhaps you could test it out for us GMK users? To me it looks like V2 is going to be tight around the edges, and V1 has a little more wiggle room for the board.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #115 on: Thu, 05 January 2017, 14:58:44 »
Yeah it is true. It doesn't scratch at the normal position now, but it is awfully close. We will reduce the roundness by .5mm to make sure.
Offline bbmathlvr
« Reply #116 on: Fri, 06 January 2017, 22:17:49 »
It's solid cherry.
Offline ArchDill
« Reply #117 on: Fri, 06 January 2017, 22:25:17 »
I need the gray case for GMK Terminal.
Offline alveeno
« Reply #118 on: Fri, 06 January 2017, 23:32:15 »
So no hhkb blockers?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #119 on: Sat, 07 January 2017, 03:53:03 »
That is impossible with this design, sorry.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #120 on: Sat, 07 January 2017, 03:53:31 »
Me too!
Offline GreyAmbience
  • I can stop when ever I want
« Reply #121 on: Sat, 07 January 2017, 04:12:56 »
Me too!
Soon™?
Sent from my microwave oven using alternating current
Offline rabbitfire
« Reply #122 on: Sat, 07 January 2017, 04:46:42 »
Looks so great. Interested!
Offline LDobler
« Reply #123 on: Sat, 07 January 2017, 04:49:33 »
This case looks real nice  :eek:
Will we have the option to order a PCB with the case when the GB is live?
Also, good work Leandren!  :thumb:
Offline menuhin
« Reply #124 on: Sat, 07 January 2017, 05:29:44 »
I always wonder if any maker creates switch blockers (like those sold on Pimpmykeyboard) but in aluminum. As a separate kit, two 1.5u aluminium switch blockers (with matching height and color) at the corner can kind of transform a high profile 60% case to a HHKB style case.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline venjiang
« Reply #125 on: Sat, 07 January 2017, 08:50:47 »
Cool
从我的 iPhone 发送,使用 Tapatalk
Offline xondat
  • i'm not a star
« Reply #126 on: Sat, 07 January 2017, 09:05:19 »
It's been done before, but there is a problem. It looks wank.
Offline menuhin
« Reply #127 on: Sat, 07 January 2017, 09:32:57 »
It doesn't look good when there are too many of them on a board.
I am suggesting two things:
- As I read from a few TaoBao listings that their alu blockers are screwed into the PCB, unlike those Pimpmykeyboard blockers where one can just snap them in. Snap-in blockers will be better.
- A pair of 1.5u blockers and a pair of 1u blockers can turn a 60% into the HHKB style and the Winkeyles style in a few second and it doesn't look half bad:
Of course these low cost addons are not as elegant as running another Groupbuy and spending another few hundred dollars on a specialized HHKB case and then also on a Winkeyless case.
(I know that LeandreN offers Winkeyless plate option and HHKB plate option)
« Last Edit: Sat, 07 January 2017, 10:14:06 by menuhin »
IBM M13 black
HHKB Pro 2 HasuBT
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #128 on: Sat, 07 January 2017, 09:53:07 »
Offline Jokrik
« Reply #129 on: Sat, 07 January 2017, 10:23:31 »
pls stop
my life feels miserable without one
Offline ArchDill
« Reply #130 on: Sat, 07 January 2017, 10:40:15 »
Offline kmba
  • Formerly tameone
« Reply #131 on: Sat, 07 January 2017, 13:12:46 »
Quote from: menuhin
What case is that?
keyboards.
Offline kmba
  • Formerly tameone
« Reply #132 on: Sat, 07 January 2017, 13:16:14 »
Me too!
I think the problem with trying to match a gray case with gray keycap sets is the grays will never be the same color unless manufactured to match.   I think two dark grays together, but different shades, is a little silly looking  :p  That's why I'm putting terminal on a board with a black case! heh.
Based on your color option renders above.. I miiiight try to get in for a blue case, but I'll probably wuss out and go with silver.
keyboards.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #133 on: Sat, 07 January 2017, 16:32:14 »
https://mekanisk.co/products/fjell?variant=36234901255
Here you can test different combinations.
The colours are a bit off in the renders, hope to fix that soon, but you should get a general idea.
  • settling down
« Reply #134 on: Sat, 07 January 2017, 16:43:25 »
Cool idea putting in renders for both the brass and steel weights  :thumb:
But what is this at the top? It only shows on the Fjell page. I thought you said it wouldn't start until R5 ended?
157033-0
Also, the "Enter the raffle" button on the Project C page has been broken for some time because the link is the page itself.
EDIT: something to do with the products page. Once you go on the products page, the banner disappears. I feel like an idiot for getting all worried.
« Last Edit: Sat, 07 January 2017, 16:48:36 by exanile_tabasco »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #135 on: Sat, 07 January 2017, 16:50:13 »
It's purposely broken. It's just an old site, I will update it.
I will not start before I have a 100% plan for R5. So that will be posted to R5 thread first.
We are waiting for a package over there.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #136 on: Sat, 07 January 2017, 16:52:25 »
Colors look great. When you do the GB will you also have plates of matching colors available?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #137 on: Sat, 07 January 2017, 16:54:59 »
I need to clear things ups in that regard, but I might offer that, or/also brass plates
« Reply #138 on: Sat, 07 January 2017, 17:00:45 »
Ohhhh, that orange looks good!
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #139 on: Sat, 07 January 2017, 17:12:35 »
The reason I ask is because I'd like to redo my purple build, so I'd like to get a purple plate to go along with the case.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #140 on: Sat, 07 January 2017, 17:17:10 »
That is totally understandable. I will try my best to get it available.
Offline IneffableTao
« Reply #141 on: Sat, 07 January 2017, 18:49:32 »
+1 for brass plate <3
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #142 on: Sat, 07 January 2017, 20:23:07 »
Thank you. Also, the purple with the brass weight looks dope!
Offline ticktwo
  • -kbdfan
« Reply #143 on: Sun, 08 January 2017, 01:52:25 »
that purple case so awesome!
Sent from my SM-G935F using Tapatalk
HHKB | Leopold FC750R | Mech27 (soon) | TX-75 (soon)
Offline ehmlis
« Reply #144 on: Sun, 08 January 2017, 11:58:33 »
Ooh, a matching brass plate! I would love that. +1
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #145 on: Sun, 08 January 2017, 12:45:34 »
First post? Welcome to Geekhack!
Offline ehmlis
« Reply #146 on: Sun, 08 January 2017, 13:12:43 »
Thank you. I'm a long time non-registered lurker though :) (Also, I'm oknytt on DT.)
Will the silver case be so light in colour that it's almost white? I mean with the name and all, a snowclad "fjell" would be beautiful.
« Last Edit: Sun, 08 January 2017, 13:14:14 by ehmlis »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #147 on: Sun, 08 January 2017, 13:13:31 »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #148 on: Sun, 08 January 2017, 13:16:43 »
Unfortunately it is not white, just silver. I hope to get some sample pics next week.
  • settling down
« Reply #149 on: Sun, 08 January 2017, 13:19:53 »
OMGOMGOMGOMG FINALLY
