Author Topic: [GB] DSA LightCycle (again) - Shipping 100% complete  (Read 186244 times)
Offline bmmcwhirt
    • KB9YEN
Re: [IC] DSA LightCycle (again)
« Reply #50 on: Mon, 23 January 2017, 15:11:57 »
I am eagerly waiting on this one but have a question, can we get the plastic color codes listed? I know that HTML RGB Color don't match up exactly and I'd like to get a better idea. I'm asking mostly because I'm color coordinating a custom case and cable to match for when I get the keys.
Offline evangs
  • TheVan
« Reply #51 on: Tue, 24 January 2017, 11:22:41 »
the color codes are GX, GY, and BFQ
Offline bmmcwhirt
    • KB9YEN
« Reply #52 on: Tue, 24 January 2017, 13:02:45 »
Thank you.
Now the long dark wait till the end of May.
Offline FearsomeCubedWarrior
  •  Post Reporting Timeout
« Reply #53 on: Tue, 24 January 2017, 13:25:48 »
« Last Edit: Mon, 15 April 2024, 18:24:32 by FearsomeCubedWarrior »
Offline smithyithy
  • a l p s
« Reply #54 on: Tue, 24 January 2017, 15:47:37 »
You okay with people buying multiple sets evangs?
I've seen some group buys where it's not allowed, but I figured as you're also offering Alps it might be worth at least buying a set of each stem type..
KBD75; Alps64 trio; some other stuff
Offline zslane
« Reply #55 on: Tue, 24 January 2017, 16:03:40 »
That's what I'm likely to do, assuming it is allowed.
Offline evangs
  • TheVan
« Reply #56 on: Tue, 24 January 2017, 16:06:29 »
I never limit anyone on what they purchase.  :thumb:
Offline evangs
  • TheVan
« Reply #57 on: Tue, 24 January 2017, 16:06:53 »
it is allowed, and encouraged. helps meet those MOQs
Offline smithyithy
  • a l p s
« Reply #58 on: Wed, 25 January 2017, 04:38:53 »
That's good to hear. It's not like I'm buying them to flip anyway - I literally need a set of each  :D
« Last Edit: Sun, 29 January 2017, 17:11:31 by smithyithy »
Offline daaawooo
« Reply #59 on: Wed, 25 January 2017, 17:55:10 »
nice to see the reboot.
but price to fill my ergodox went quite hefty up from 150 to 270 ... damn.
Perixx PX-5200 BR, KBP-V60-MTS-Q, SS 6G V2
Offline zslane
« Reply #60 on: Wed, 25 January 2017, 19:47:47 »
Think of it this way: your ErgoDox was only half a keyboard without the right keycaps. It is only natural to spend another $100-150 on the other half...
Offline pixelpusher
« Reply #61 on: Thu, 26 January 2017, 22:17:01 »
Could you provide a photo of the V60 mini in the Pok3r case, but viewed from the bottom? I'm curious what the 6-DIP switch block looks like given the small size of the window provided on the Pok3r case.
Sorry it took me so long to respond.  I didn't get a photo but I stuck it in there to check and it looks like it blocks off the #1 DIP switch :(
Tex case fits fine though
Offline zslane
« Reply #62 on: Sun, 29 January 2017, 12:23:58 »
Does the blocked DIP switch prevent the case from fitting onto the board though? Once I have the switches set, I don't really need access to them again, so I'm not concerned about one of them being blocked. I only care that I can fit the board into the Lambo case properly and securely.
Offline pixelpusher
« Reply #63 on: Sun, 29 January 2017, 15:26:00 »
It fits, yes.  I don't know about the Lambo case because it depends on how deep of a pocket is under the PCB, right?  If it was designed to fit very close to the bottom with the dip switches protruding way out, it would be an issue.  But the poker case has a bit of room so that the dip switches don't make contact with the case (or if they do it was unnoticeable and still fit perfectly).  I figure with the height and angle of the lambo there will be plenty of room.
Offline Jedi
« Reply #64 on: Sun, 29 January 2017, 22:36:15 »
I'm in regardless to support the fam :thumb:
Offline SunshineGrrrl
« Reply #65 on: Thu, 09 February 2017, 17:36:04 »
In for MX stems. Glad I decided to check back on this today! ^_^
Offline child
« Reply #66 on: Fri, 10 February 2017, 01:28:49 »
In for MX stems as well.
Offline kawasaki161
« Reply #67 on: Sat, 11 February 2017, 09:04:12 »
I was wondering, which stabs do the ALPS caps use?
Offline arhetue
« Reply #68 on: Sat, 11 February 2017, 13:06:38 »
In for MX stems. thanks for bringing this back on line!  :thumb:
Offline eksuen
  • Ambassador of explosions.
« Reply #69 on: Sat, 11 February 2017, 22:24:45 »
These will be made by SP so they'll use Cherry cruciform stab inserts.
Offline arhetue
« Reply #70 on: Thu, 16 February 2017, 14:03:03 »
These are abs correct? I would love it even more if it were pbt...
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #71 on: Thu, 16 February 2017, 14:16:32 »
Can't currently dyesub lighter colors onto darker bases, unfortunately, and SA isn't set up for doubleshot PBT as far as I know.
Offline spanyam
  • Enjoy the gift of life!
« Reply #72 on: Thu, 16 February 2017, 14:44:06 »
Abso-****ing-lutely in for ALPS stems!
SKCM Orange ALPS on Infinity 60% bent-metal case w/ hasu ALPS64 PCB and PBT blank DSA caps | KBP V60 w/ Matias Quiet Linears | IBM Model M | QFR w/ MX Blues
Offline pixelpusher
« Reply #73 on: Thu, 16 February 2017, 16:29:41 »
If 5-sided inverse dye sub (dying a lighter cap on all sides and leaving the legend un-dyed) looks good, I think this may no longer be an issue.  However, I haven't see the end result of this process yet.  I think MC Rebirth (modifiers) will be the first mainstream run out there.  Also there was the Green SA clone set being produced in China with the process (the infamous SCOROLL LOCK key set!)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #74 on: Wed, 22 February 2017, 21:03:18 »
Yes! I'm in like Sam and Kevin Flynn!
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline dante
« Reply #75 on: Thu, 23 February 2017, 08:24:29 »
Best Pinball graphics ever:
« Last Edit: Thu, 23 February 2017, 08:27:28 by dante »
Offline 00zeRO
« Reply #76 on: Thu, 23 February 2017, 09:28:49 »
I love me some pinball...always wanted my own machine, but I gots nowheres to put it
Offline hhkbp2
« Reply #78 on: Fri, 24 February 2017, 07:15:38 »
In for MX
Offline 00zeRO
« Reply #79 on: Fri, 24 February 2017, 08:53:37 »
Hey OP, pardon me if this has been addressed already, but what is the production time frame on this once the GB closes?
Offline CampAsAChamp
  • Absolutely Nasty
« Reply #80 on: Fri, 24 February 2017, 12:49:03 »
10 weeks after GB closes. Then it should be shipping to us around May 31st, if everything goes smoothly.
https://thevankeyboards.com/products/lightcycle-keycap-set?variant=34315776526
« Last Edit: Fri, 24 February 2017, 12:51:23 by CampAsAChamp »
Offline 00zeRO
« Reply #81 on: Fri, 24 February 2017, 12:55:34 »
Not to be 'that guy' but is there any way to get extra 1x1u blanks along with an order?
Offline 00zeRO
« Reply #82 on: Fri, 24 February 2017, 12:55:58 »
Thanks.
Offline bmmcwhirt
    • KB9YEN
« Reply #83 on: Tue, 28 February 2017, 15:09:20 »
We are hours away from this opening. I have to confess, I'm excited. This will be my first GB outside of Mass or Kickstart and it's my first foray into keycaps. Is there a max that will be able to be produced? I plan on getting in as soon as it opens so I shouldn't miss out but I was curious.
Offline mustardgreens
« Reply #84 on: Tue, 28 February 2017, 23:06:45 »
It's happening!   :D
Please guys if you're interested please support the Alps set -- they don't come around too often!  Minimum MOQ is 50 pcs, let's make it happen.
  • Absolutely Nasty
« Reply #85 on: Tue, 28 February 2017, 23:10:19 »
SUPER EXCITED, can't wait to get my set.
Just wondering if there are gonna be any price drops for MOQ on this set?
I'm still gonna pick up a set anyways but might pick up two sets if there is a price drop.
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #86 on: Wed, 01 March 2017, 00:12:50 »
No, I wish there was
https://www.reddit.com/r/MechanicalKeyboards/comments/5wsybi/buying_the_mcp_must_be_destroyed_lightcycle_is/decuv7s/
Offline bmmcwhirt
    • KB9YEN
« Reply #88 on: Wed, 01 March 2017, 01:38:20 »
Base/MX order placed!
We also need to make sure this gets added to the list of currently running so it's as visible as possible.
« Last Edit: Wed, 01 March 2017, 01:40:21 by bmmcwhirt »
Offline evangs
  • TheVan
« Reply #89 on: Wed, 01 March 2017, 09:06:48 »
Offline kawasaki161
« Reply #90 on: Wed, 01 March 2017, 10:01:43 »
Whoah, you, sir, are great at scheduling these gbs that don't work too well for me :)). I'll get in this time though, I hope I don't sleep through the deadline.
« Reply #91 on: Wed, 01 March 2017, 13:30:38 »
« Last Edit: Mon, 15 April 2024, 18:26:11 by FearsomeCubedWarrior »
Offline evangs
  • TheVan
« Reply #92 on: Wed, 01 March 2017, 22:45:14 »
Pretty good numbers today
Offline bmmcwhirt
    • KB9YEN
« Reply #93 on: Wed, 01 March 2017, 23:09:49 »
Wow, I was hoping for better numbers on day one, but this also has no post in the actual GroupBuy forum and hasn't been listed on the currently running list which might put it in the eyes of a few more buyers, and Friday is yet to come, which is when most get paid so there is still hope.
Offline pixelpusher
« Reply #94 on: Wed, 01 March 2017, 23:41:37 »
Also, I don't see anything posted for the new group buy on r/MechanicalKeyboards or r/mechmarket
Gotta get Alps to 50!
Offline bmmcwhirt
    • KB9YEN
« Reply #95 on: Thu, 02 March 2017, 02:34:05 »
You just missed it, it's on reddit.  https://www.reddit.com/r/MechanicalKeyboards/comments/5ojgd6/news_dsa_lightcycle_group_buy_starting_march_1st/?ref=search_posts
There just haven't ben any recent posts so I posted that it is live.
Offline 00zeRO
« Reply #96 on: Thu, 02 March 2017, 07:23:21 »
I will be adding to the score once I get my DSA Raindop set sold...
Offline pixelpusher
« Reply #97 on: Thu, 02 March 2017, 07:27:07 »
Evangs, did you get any complaints in R1 about the double shot implementation?
From this thread:
https://geekhack.org/index.php?topic=87816.msg2374448#msg2374448
Quote:
My only experience with dsa alps was the lightcycle set that came with my minivan - and it was delicate as can be. I ripped a couple stems off just trying to remove a cap from the switch and from what I could tell, the doubleshot did not adhere like it should to both colors. Wouldn't be a problem with blanks though if i'm correct in diagnosing the problem but i'd definitely be weary of buying more sets especially if they were SP priced.
My V80 has some kinda costar type stabs but with out normal mounts. It definitely is a standards problem getting a mod set that works for everyone.
« Last Edit: Thu, 02 March 2017, 07:30:02 by reececonrad »
Offline evangs
  • TheVan
« Reply #98 on: Thu, 02 March 2017, 08:39:40 »
From this thread:
I got a couple complaints, but there were a lot of people who didn't complain. I have yet to get a set myself so I can't actually speak to it myself. A friend of mine got the alps MiniVan and he reported no issues, so I don't know if people were just new to alps tightness or if there is actually an issue.
Offline zslane
« Reply #99 on: Thu, 02 March 2017, 12:41:51 »
Well, I think it would be alarming to anyone to learn that it is even possible for the two shots to become separated simply from pulling force while trying to remove keycaps from switch sliders (Alps or otherwise).
