Author Topic: [GB] MIRA SE - Custom 80% Keyboard (CLOSED)  (Read 3125886 times)
0 Members and 6 Guests are viewing this topic.
Offline megaforce
Re: [GB] MIRA SE - Custom 80% Keyboard
« Reply #150 on: Wed, 01 February 2017, 18:49:59 »
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline techmattr
« Reply #151 on: Wed, 01 February 2017, 19:12:12 »
  • Is there a limit to how many each person can buy?
  • How do we buy more than one?
  • Can the first 57 have the engraving on more than one?
Logic would suggest:
  • No.
  • 1 form = 1 keyboard, submit more forms.
  • What's the point of having two (for example) 3/57s? Of course you can't.
I doubt the answer you'd receive from anyone else would be different; I'll be very surprised if they are.
Thanks. I guess I was looking at the # question as having more than one weight so you could have one brass and one ss. But yeah I guess that doesn't really make sense in the overall scheme.
Offline Photoelectric
« Reply #152 on: Wed, 01 February 2017, 19:20:34 »
1. I don't think there's a limit, within reason.  If you're looking to get like 10, ask ninja directly.
2. submit the order form more than once.
3. No, you only get one numbered weight period (your primary selected weight), even if you order extra weights.
Offline Vala
  • :smork:
    • Vala Supply
« Reply #153 on: Wed, 01 February 2017, 19:55:59 »
Does the PCB support n-key rollover? It's a necessity for my rhythm games  :)
Offline E3E
« Reply #154 on: Wed, 01 February 2017, 20:30:22 »
The PCB supports 6KRO over USB.
Offline Baddy126
« Reply #155 on: Wed, 01 February 2017, 22:01:54 »
Will the blue version get the "Mira SE" engraved on the back?
Yes.
hell yeah
Anyone for a render or pic of how it looks?
Offline loud_asian
Offline iArson
« Reply #157 on: Wed, 01 February 2017, 22:09:57 »
Yes.
Is only he blue getting an engraving?
Offline Baddy126
« Reply #159 on: Wed, 01 February 2017, 22:34:04 »
Yes.
Why would you think that :)
Offline iArson
« Reply #160 on: Wed, 01 February 2017, 22:43:04 »
Yes.
:thumb:
Offline Baddy126
« Reply #161 on: Thu, 02 February 2017, 10:27:56 »
Does the lunar grey have the option to not get diffuser as shown in the pictures?
Also, any word on lowering the amount for customs?
« Reply #162 on: Thu, 02 February 2017, 10:42:43 »
The diffuser is part of the MIRA SE case design, the aluminum is cut to include it, so if you don't insert the diffuser, there'll be a gap in the case.
Offline ninjadoc
« Reply #163 on: Thu, 02 February 2017, 14:16:49 »
The grey board is from the Chinese Group Buy. Once the manufacturer returns from celebrating the Chines New Year I will ask about either an aluminum or stainless spacer.
Offline iArson
« Reply #164 on: Thu, 02 February 2017, 14:19:21 »
Awesome thanks. With that being said would be be able to buy both an acrylic and aluminum spacer if it's available?
Offline roostrc0gburn
  • its just plastic
« Reply #165 on: Thu, 02 February 2017, 15:05:34 »
I would love to buy an acrylic diffuser and a stainless steel spacer. that would be awesome if the manufacturer can do it!
Offline Baddy126
« Reply #166 on: Thu, 02 February 2017, 15:24:49 »
+3
Offline Vala
  • :smork:
    • Vala Supply
« Reply #167 on: Thu, 02 February 2017, 15:32:46 »
Oh crap, is there any way to get around that? I've heard about PS/2, but not sure about the logistics of using it.
Offline E3E
« Reply #168 on: Thu, 02 February 2017, 15:49:32 »
I've heard of this too, but I'm actually not sure how it works on many of the modern PCBs as almost everyone uses USB. Only a few PCBs support NKRO over USB, despite supporting it in the matrix.
I heard a while back that converting it to PS2 and then back to USB can do it, but that sounds kind of sketchy and dubious.
Offline Sissy
« Reply #169 on: Thu, 02 February 2017, 18:42:39 »
I'm still kinda new to this whole soldering and buying parts thing. just wondering what LED do I need for switches and best site to buy them from.
« Reply #170 on: Thu, 02 February 2017, 18:47:56 »
Here's a thread with some LED photos:
https://geekhack.org/index.php?topic=54702.0
Generally used are 2x3x4 rectangular LEDs and 1.8mm small LEDs (down the first page for photos and description).  Either of those work.
I believe most get them from eBay (or Aliexpress).
Offline alienman82
« Reply #171 on: Thu, 02 February 2017, 19:48:47 »
removed.
« Last Edit: Thu, 01 March 2018, 13:11:25 by alienman82 »
Offline arid_tare
« Reply #172 on: Thu, 02 February 2017, 20:07:30 »
just get 1,8mm.  the 234 size isn't compatible with all caps.
I believe 2x3x4 LEDs interfere with row 3 of cherry profile, in particular.
« Reply #173 on: Thu, 02 February 2017, 21:15:17 »
I use 2x3x4 and exclusively vintage Cherry and new GMK caps--no interference that I've noticed.
Offline alienman82
« Reply #174 on: Thu, 02 February 2017, 21:18:33 »
removed.
« Last Edit: Thu, 01 March 2018, 13:11:20 by alienman82 »
« Reply #175 on: Thu, 02 February 2017, 21:26:20 »
I have and  used OG Dolch caps too without issues with rectangular LEDs.  Have you made sure the LEDs are fitted neatly and pushed all the way in?  (All of my LEDs are in SIP sockets anyway).
Offline alienman82
« Reply #176 on: Thu, 02 February 2017, 21:33:30 »
removed.
« Last Edit: Thu, 01 March 2018, 13:11:17 by alienman82 »
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #177 on: Thu, 02 February 2017, 21:38:08 »
I've had issues with gmk and original dyesubs rubbing against 2x3x4.
Offline E3E
« Reply #178 on: Fri, 03 February 2017, 08:16:58 »
Yeah, I'd recommend 1.8mm LEDs for the most hassle-free experience when it comes to issues you might run into with cap clearance.
Offline rotciveel
  • Fugu Curator Extraordinaire
« Reply #179 on: Fri, 03 February 2017, 08:19:26 »
Is this interstellar black with stainless steel weight?
Offline E3E
« Reply #180 on: Fri, 03 February 2017, 08:32:31 »
That looks like brass to me.
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #181 on: Fri, 03 February 2017, 08:34:04 »
before I order,
Who all are the reputable US based keyboard assemblers?
Need a bonafide, trustworthy person.
Trying to avoid another TheChemist disappearing with $800+ of my gear.
Thanks
Ninjadoc and I were talking about this a few nights ago. He'll finalize the assembler list soon.
Whoever it will be though, the goal is to keep things consistent. IE: all assemblers using the same solder - I advocate for Kester 44 - ultimately it's ninjadoc's call though.
« Last Edit: Fri, 03 February 2017, 08:35:51 by limitz »
Mmm... machined aluminum
Offline doclong
« Reply #182 on: Fri, 03 February 2017, 08:39:32 »
_Will you commit to quality?
_Do you have QA to check product before packaging and shipping?
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #183 on: Fri, 03 February 2017, 10:41:57 »
I haven't been following the threads too much, but just want to make sure if I can assemble the keyboard WITHOUT the acrylic diffurer.
I'm almost sure it can but just wanted a 100% confirmation  ;)
Offline limitz
« Reply #184 on: Fri, 03 February 2017, 10:44:45 »
This is not possible. The diffuser/bottom half was made to be integral.
« Reply #185 on: Fri, 03 February 2017, 10:45:03 »
Hmm, strange that I haven't had the same issues.  In any event, 1.8mm LEDs seem like a good idea... if they come in colors one wants.  I only see them in fairly standard colors, unfortunately.  I have a few different 2x3x4 cyans and interesting warm pink ones that I love.  But for standard colors, 1.8mm is the way to go now, especially if they fit switches with SIP sockets without falling out easily (I like how 2x3x4 fit tightly into the bottom stem mold).
« Last Edit: Fri, 03 February 2017, 10:49:04 by Photoelectric »
Offline E3E
« Reply #186 on: Fri, 03 February 2017, 10:58:16 »
http://www.ebay.com/itm/10Lights-200PCS-1-8mm-Water-Clear-LED-Diodes-White-Red-Orange-Purple-Mix-Kits-/121785459094?hash=item1c5afaa196:g:HBcAAOSw8-tWV-vM
They come in a pretty nice selection. In my experience, they also fit flush and snug in SIP sockets and the LED recesses for Cherry switches. I myself bought quite a few 2x3x4mm varieties and encountered the clearance issues described with Gateron PBT blanks, doubleshot OG Cherry caps, and OG Dyesubs.
Offline ninjadoc
updates
« Reply #187 on: Fri, 03 February 2017, 13:06:13 »
There are updates on shipping and quality check procedure in the second post
Offline limitz
« Reply #188 on: Fri, 03 February 2017, 15:54:25 »
Changing to a new number
Number 57/57 is up for grabs
Will not be FCFS. PM me please.
Edit: Gone to Xondat.
« Last Edit: Sat, 04 February 2017, 13:09:39 by limitz »
Offline alienman82
« Reply #189 on: Fri, 03 February 2017, 17:15:10 »
removed.
« Last Edit: Thu, 01 March 2018, 13:11:10 by alienman82 »
Offline E3E
« Reply #190 on: Fri, 03 February 2017, 17:27:19 »
is 57 some special number for the Mira? Or just a cutoff?
Dr.HubbleAWOL probably knows the answer.
  • its just plastic
« Reply #191 on: Fri, 03 February 2017, 17:30:42 »
when hubbs started the project, NASA had been around (officially) 57 years. perhaps that means the number of engraved keyboards should be increased to 58?
check out the "Facts about the potential group buy" section from this post -
https://geekhack.org/index.php?topic=70149.msg1687506#msg1687506
Offline poolside
« Reply #192 on: Fri, 03 February 2017, 17:44:02 »
Will the rectangular top side of the weight (engraved or not) be polished as well?
Any hints on what the engraving will look like? Just curious, as I am not in the first 57 list.
Offline asgeirtj
« Reply #193 on: Fri, 03 February 2017, 18:49:42 »
Is there a picture somewhere where I can see the board from the top?  I'm deciding on this one or the LZ CLS and I will buy the board which has the thinner bezels.  Is anyone here able to make a judgement on that?  I have the lz-rv and I think it has quite the fat bezels which is not my preference, it seems to me that the cls has the same width, probably something standard on all lz boards.
Kind of hard to see:
ps: could someone enlighten me why anyone would want to buy the steel weight if it is lighter and more expensive?  Just curious.
« Last Edit: Fri, 03 February 2017, 18:52:23 by asgeirtj »
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline eksuen
  • Ambassador of explosions.
« Reply #194 on: Fri, 03 February 2017, 18:54:07 »
They like the way it looks and they can afford it?
Offline MrRooks
  • Always be knolling
« Reply #195 on: Fri, 03 February 2017, 19:13:11 »
Check the IC thread linked in the first post. There are a bunch of good shots that should show you what you're looking for.  :thumb:
Offline loud_asian
« Reply #196 on: Fri, 03 February 2017, 19:15:32 »
Here's more pictures of the mira https://bbs.wstx.com/forum.php?mod=viewthread&tid=700766&page=1&extra=#pid8857629
I chose steel cause it looks better.
brass with the blue case looks ugly
Offline Rayoui
« Reply #197 on: Fri, 03 February 2017, 19:40:24 »
Keep in mind the brass will look much different after it ages a bit.
Mira SE  |  Clueboard  |   B.face  |  HHKB Type-S
Offline nevaenuf
« Reply #198 on: Fri, 03 February 2017, 20:23:04 »
This is killin me guys. I've trying to pare down my collection and to stop buying expensive boards. But I love this board! :(
Let's talk about how cool it isn't and how I don't need it.
Let me know if you find an excuse. I'm trying to find one since the IC has started and failed miserably so far.
Don't find an excuse! :)
Please buy one!
Guys, this article describes me.  This board may be my last for a while.  I get so happy when a new board comes in that I get to customize.  I've got problems.
http://www.pcgamer.com/confessions-of-a-custom-mechanical-keyboard-obsessive/
Offline beamingrobot
  • もうけい
    • monokei
« Reply #199 on: Fri, 03 February 2017, 20:48:10 »
damn it i shouldn't have seen those pictures...
« Last Edit: Fri, 03 February 2017, 20:52:17 by beamingrobot »
http://monokei.co
Jane v2 | Jane v2 CE | Police | EXENT | KFE | KFE CE | Singa R1 | Jaguar | HHKB | Custom G80-3000 | Dalco 959mini | Haus | Kei | Hiro | Hidari | Tomo | Neko | Prophet | MXSS | TKL One | RS
