Author Topic: [Build Log] The Still Unamed Split TKL - Status: Building  (Read 12306 times)
Offline infiniti
  • I <3 KB
  • Bob was here
« on: Tue, 31 January 2017, 09:18:47 »
Ever since I switched to mechanical keyboards, the one thing I kinda missed was the split of my Microsoft Natural Multimedia Keyboard and Natural Ergonomic Keyboard 4000.  I wasn't sure if I'd like it so I couldn't commit to buying an LZ ErGO or a VE.A...so I decided to build one and try it out!
Considerations in design were:
  • it had to be TKL form factor
    • I use the arrows a lot in my day-to-day computing
    • moving down from a fullsize keyboard and losing the numeric pad was a small price to pay to alleviate my neck and shoulder pains; I can always get a dedicated numeric pad should the need arise
  • it had to split but join together to look like a TKL
  • the layout as close to ANSI as possible save for the split space bar
    • something about an old dog and new layouts
    • all my key sets support ANSI
I ended up with this design...
159112-0
...and this layout:
159114-1
I've been reading, planning, designing, and gathering parts since May / June 2016.
Quick rundown of parts:
  • The case was cut from clear acrylic (still has the backing paper):
    159116-2 159118-3
  • plastic hexagon spacers with m3 threading to build the sandwich case
    159126-4 159128-5
  • Cherry MX Clear switches with MX Blue springs and transparent abostudio switch top covers
    159120-6
  • Transparent stabilizers from a local bro
    159122-7
  • Enablers from TechKeys
    159124-8
  • m3 rivet nuts like this to mount the feet to the bottom of the case
  • m3 socket button head screws
  • ribbon cable for wiring
  • Teensy 2.0
So far I've:
  • soldered all the diodes to the enablers
  • soldered the enablers to the switches
  • added resistors and LEDs to the Caps Lock and Scroll Lock switches
    159130-9 159132-10
  • hot glued the switches to the plate layers
    159134-11
To do next:
Edit: fixed image sizes
« Last Edit: Tue, 31 January 2017, 09:28:35 by infiniti »
Offline infiniti
  • I <3 KB
  • Bob was here
Re: [Build Log] The Still Unamed Split TKL - Status: Building
« Reply #1 on: Tue, 31 January 2017, 09:19:25 »
Reserved for final assembly pictures.
Offline joey
« Reply #2 on: Tue, 31 January 2017, 09:21:52 »
Good work so far! Look forward to the final thing :thumb:
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #3 on: Tue, 31 January 2017, 09:32:15 »
Thanks, joey!
Oh yeah this "thing" is still unnamed but I have a list going for possible names:
  • ErgoDivorce
  • Diforce
  • D.Vorce
  • The Banana...coz it splits!
« Last Edit: Tue, 31 January 2017, 20:01:05 by infiniti »
Offline Cocopah
  • Lurker Extraordinaire
« Reply #4 on: Tue, 31 January 2017, 09:56:18 »
Looking good. Thats alot of FN's. :))
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #5 on: Wed, 01 February 2017, 01:49:47 »
There may have been easier ways to go about this but I didn't want to have to bake my own firmware and I've already used the Easy AVR GUI for my KMAC2.
Anyway, I poked around the config files of Easy AVR and added a layout to the phantom config for the The Still Unamed Split TKL:
159176-0
Loading it came out like this:
159178-1
Fixed the key map on the Normal layer:
159180-2
Work-in-progress FN layer:
159182-3
Work-in-progress FN2 layer:
159184-4
I took note of the row and columns that Easy AVR was expecting from the keys and ended up with this diagram for rows and columns (note to self, add wiring):
159186-5
To Do:
- transcribe the matrix row and columns in reverse since when I do the soldering, I will be looking at the keyboard from the bottom
« Last Edit: Wed, 01 February 2017, 01:52:49 by infiniti »
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #6 on: Wed, 01 February 2017, 01:53:36 »
I needs to be functional brah! :))
Offline chintimin
« Reply #7 on: Fri, 20 April 2018, 19:42:12 »
I find this super-interesting, as I am a die-hard on both the things this satisfies, from split ergonomics and also F row and nav cluster and not having a numpad there to run into your  mouse hand. If you want, I can show you my two-keyboard setup which I emulate what you're doing here with - I really want to see how this turns out. I've seen a ton of NEARLY-normal split TKL designs, but they always gotta screw with stuff. If I can ever buy a metal plate-split-TKL, I will be on it in a heartbeat. I may take a couple of ebay keyboards and a jigsaw and do a handwire. Yours will still be nicer. <3
Offline TD22057
« Reply #8 on: Fri, 20 April 2018, 22:23:12 »
Looks fantastic.  Would you mind posting the case CAD files?
Thanks,
TD
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #9 on: Tue, 07 August 2018, 09:03:36 »
Revive!
The switches wouldn't hold so I tried hot glue which didn't hold and then moved on to the kragle (super glue).  I regret using superglue since it bled between the plate layers and left a white haze.  Then I soldered up the matrix.
Next steps:
  • figure out where the cable joining the halves will go...probably out the top so I don't have to worry about tucking them into the case when the halves are joined
  • solder the matrix to the teensy
  • assemble the case
I'd love to see your setup!  A metal plate-split-TKL?  With enough time and funds...soontm :triangle:
Thanks,
TD
Pardon the late reply, Here's the cutting files.  Please let me know if you need them in any other format.
201474-0
Note: The bottom 6mm layer needs to be adjusted for the ribbon cable between the two halves
* 2018-08-07a ALL LAYERS - X12.cdr (37.1 kB - downloaded 137 times.)
* 2018-08-07a ALL LAYERS - X18.cdr (587.97 kB - downloaded 127 times.)
* 2018-08-07a ALL LAYERS.dxf (1220.5 kB - downloaded 141 times.)
* 2018-08-07a ALL LAYERS.svg (40.07 kB - downloaded 160 times.)
Offline nachie
    • KapCave
« Reply #10 on: Mon, 24 September 2018, 14:22:02 »
Very cool project. I don't think I have seen a split TKL before :)
AHKB | GSKT-00 | Arya | Båge | Paladin64
Offline MatchstickMan
  • CAD Jockey - YOLO Enthusiast
« Reply #11 on: Mon, 24 September 2018, 15:41:09 »
I can't believe I haven't seen this yet!
If you put a num pad on the left side, you'll have exactly the layout I'm shooting for! How are you getting the two halves to talk to each other? My project is on hold currently due to life happening, but that was one of the big unknowns I didn't have answered yet. Though, I was mostly ignoring it because I didn't see a real need for layers when you've got a Full Sized board, so I was just planning to have separate USB cables for each half.
Current Projects:
- SouthPad -- Left-handed Numpad
- Full Split (Currently on hold)
Offline Nlight
« Reply #12 on: Wed, 26 September 2018, 13:24:13 »
Well, teh easiet way is to use an hdmi breakout board, as HDMI has enough pins to allow direct connection. The other method is to use I believe an I/O extender chip from Microchip, the extender chip is linked to the controller through 2 wire cable, so a mini jack cable and connectors are enough , it uses the I2C protocol. I don't know anything more about it.
« Reply #13 on: Wed, 26 September 2018, 13:32:27 »
Right. I've seen a lot of the smaller boards use I2C to talk to each other. I'm just not sure if that scales to a full-sized 104 key board or not, let alone that I don't have a solid grasp on how it really works. But you're right, the other alternative would be an HDMI cable and just wire everything back to a big-ass Teensy controller or something like that.
I've got a pair of ProMicros that I could also use and just flash them individually, but I wanted something a bit more elegant than that. Haha...
Current Projects:
Offline thesiscamper
    • Keyrenders
« Reply #14 on: Fri, 05 April 2019, 21:24:06 »
216700-0
216702-1
216704-2
"haters are confused admirers"
Offline infiniti
  • I <3 KB
  • Bob was here
Current Projects:
    • Keyrenders
« Reply #17 on: Sun, 07 April 2019, 16:43:15 »
216791-0
216793-1
216795-2
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #18 on: Thu, 31 October 2019, 07:02:50 »
REVIVE!!!
A little after thesiscamper completed the renders, my interest in the split TKL was renewed and I finally finished the prototype!
229153-0
The horror that is my handwiring and makeshift case lies within...you have been warned >:D
229157-2
229159-3
Regardless of how it looks...IT WORKED!  That is until it stopped working. :)) When giving it a technical hit (banging on it) no longer worked...I knew it was time to move on to the next step:
229161-4
Custom PCB designed by u/natecastillo
WOOHOO :cool:
Edit: image EXIF blah blah
« Last Edit: Thu, 31 October 2019, 07:06:17 by infiniti »
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #19 on: Sat, 02 November 2019, 11:27:15 »
Nice to see this making progress! Looks great.
