Author Topic: How to reprogram a Gh60?  (Read 4574 times)
Offline snarfarlarkus
« on: Fri, 10 March 2017, 17:01:08 »
I can't seem to do it...
Re: How to reprogram a Gh60?
« Reply #1 on: Fri, 10 March 2017, 17:11:56 »
« Reply #2 on: Fri, 10 March 2017, 21:26:58 »
Any directions? Can't seem to get this working either
« Reply #3 on: Fri, 10 March 2017, 22:02:37 »
I'm getting a 'Atlibusbdfu.dll' not found error even though I am in bootloader mode and in devices manager the keyboard comes up as ATm32u4dfu... Really stuck on what to do?
Offline Tactile
« Reply #4 on: Fri, 10 March 2017, 23:35:08 »
More than likely your problem is that the driver for the controller chip is not installed. Have a look at this thread.
REΛLFORCE
« Reply #5 on: Sat, 11 March 2017, 19:11:07 »
Still no luck :(
Offline Tactile
« Reply #6 on: Sat, 11 March 2017, 19:20:32 »
Still no luck :(
Not enough information there. What goes wrong? When does it happen? What error messages are displayed? What program is displaying the error messages? Is this a GH60 Rev A or B or C? Is this a Satan GH60? Do you have a HEX file built and are just trying to flash or are you trying to build a HEX file? Or are you using EasyAVR to build the HEX file? If you're trying to build the HEX file from source using TMK or QMK, what operating system are you using?
REΛLFORCE
« Reply #7 on: Sun, 12 March 2017, 23:05:41 »
Still no luck :(
When I use Flip, it comes up with that error that I stated above. Its a GH60 rev c. I do have a hex file and eem file built. I'm running windows 10.
Offline Tactile
« Reply #8 on: Sun, 12 March 2017, 23:40:25 »
See if this video helps.
REΛLFORCE
« Reply #9 on: Mon, 13 March 2017, 03:35:22 »
Wow that video worked! Thanks a ton mate, I owe you big time.
Offline Tactile
« Reply #10 on: Mon, 13 March 2017, 09:12:30 »
I'm happy you got it working. Congratulations.
REΛLFORCE
