Author Topic: Built-in Breathalyzer.  (Read 6229 times)
Offline Vloshko
« on: Sun, 19 March 2017, 11:30:35 »
How would one make a keyboard with a built-in breathalyzer? So this way one would have to blow in order for it to become operational?
This thing keeps happening to me while I'm drunk, where I think I have this great/hilarious Idea and I should post it on Facecrack, and then I'm wrong,  then regret sets in the next time I wake up.
Keycap Compendium
Discord: Vloshko#1327
Key Cap Wishlist
2019: Configure Optimal Audio Settings
HHKB Pro 2, Model M, Unicorn X Legend, ESPECTRO 96, SaiB CP, E8-V1.
Re: Built-in Breathalyzer.
« Reply #1 on: Sun, 19 March 2017, 12:10:26 »
I don't know, but I just wanna take this post to register how weird that is.
Good luck.
« Reply #2 on: Sun, 19 March 2017, 12:11:17 »
Stop using Facebook and post your regretful ideas to Geekhack off topic. Bam, profit.
« Reply #3 on: Sun, 19 March 2017, 12:17:45 »
TP4 would be proud
Offline FreeCopy
« Reply #4 on: Sun, 19 March 2017, 12:26:38 »
If the regret or embarrassment isn't enough to stop you from repeating, there's no stopping you.
You'll get another board, post from your phone, use a laptop, etc.
Spamming off topic here seems like the best solution next to regulating your intake.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline Vloshko
« Reply #5 on: Mon, 20 March 2017, 12:25:50 »
But this isn't off topic, I seriously want to install a breathalyzer into one of my keyboards. So it will only operate with blowing zeros. I want to make this, I thought some keyboard guru/genius could provide insight on how to actually make this work, I know they do it in vehicles so it must work with other electronics.
Keycap Compendium
Key Cap Wishlist
Offline TalkingTree
    • My projects
« Reply #6 on: Mon, 20 March 2017, 15:00:35 »
Building it into the keyboard would take either a major modification of an existing keyboard or a entirely custom PCB. Wouldn't be easier to put your analyzer in series between USB port and keyboard?
Also, this might give you something to start with.
Offline Leslieann
« Reply #7 on: Mon, 20 March 2017, 18:01:39 »
This.
Taking this as a serious question..
You aren't stopping the problem, you're only stopping a symptom of a bigger problem, and that problem is drinking.
Not a problem you say?
Tell me again about how you want to put a breathalyzer in your keyboard to stop you from drunk posting. Obviously you can't control yourself when drinking, which tells me you can't control your drinking either. Stop/reduce it while you're young, it will only get harder as you get older, not to mention the effects on your body and life.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Online Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #8 on: Mon, 20 March 2017, 18:20:05 »
This.
This, 100%. I have seen a lot of people throw away careers due to alcohol and drugs, both in the civilian job market and military.
Please seek the help you need for the underlying problem.
Offline Vloshko
« Reply #9 on: Tue, 21 March 2017, 22:51:15 »
You're taking this in a far more serious direction than my question was intended to be. I just want to hook up a breathalyzer to a keyboard in some way for my own reasons. I don't have a drinking problem and generally only drink when religiously obligated to do so. Thank you for your concern nonetheless.
« Last Edit: Tue, 21 March 2017, 22:54:57 by Vloshko »
Keycap Compendium
Key Cap Wishlist
Offline Vloshko
« Reply #10 on: Tue, 21 March 2017, 23:02:28 »
...ווען די גוי טראַכטן איך האָבן אַרויסגעבן מיט טרינקט באזירט אויף ווערטער דורך די אינטערנעט
Keycap Compendium
Key Cap Wishlist
Offline kolec94
« Reply #11 on: Thu, 23 March 2017, 10:30:32 »
arduino usb pass through module with a breathalyze should do the trick
you can take this:https://geekhack.org/index.php?topic=80421.0
and adjust it a bit and it will work
kbparadise v60 blues
« Reply #12 on: Thu, 23 March 2017, 13:58:45 »
What religion obligates you to get drunk enough to post stupid **** on social media?
« Reply #13 on: Thu, 23 March 2017, 15:52:20 »
When you haven't seen a friend in years and he wants to get wasted as a reunion
Offline Leslieann
« Reply #14 on: Thu, 23 March 2017, 18:14:28 »
As you get older you find it's far less of a requirement.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline nugglets
« Reply #15 on: Thu, 23 March 2017, 18:26:58 »
He's probably talking about Purim, which just passed a couple of weeks ago.
Though it's not actually a religious obligation, it's the common route.
« Reply #16 on: Thu, 23 March 2017, 18:38:37 »
Depends where you live, don't think anyone in northern Ontario is ever gonna not do that.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #17 on: Fri, 24 March 2017, 07:13:08 »
TIL
163830-0
Offline dantan
« Reply #18 on: Fri, 24 March 2017, 10:00:20 »
simple solution: build an alcohol fuelled keyboard.
Then you will drink less, because you will have to pour your liquor into your keyboard to keep it working!
« Reply #19 on: Fri, 24 March 2017, 14:21:40 »
Same for houghton, when winter is at least 6mo long people tend to drink more.
« Reply #20 on: Fri, 24 March 2017, 14:22:59 »
Yup. I have to not hang out with people these days, I don't want to be a drunk anymore
Offline _rubik
« Reply #21 on: Fri, 24 March 2017, 19:44:40 »
From his bio:
I'm currently studying to be a rabbi and I'm an observant Jew (no electronics during Shabbos FYI)
I'm curious what part of Judaism requires getting shwasted?
