Author Topic: [GB]Revo RJ kit hhkb layout custom(waiting to ship out)  (Read 347984 times)
Offline Moistgun
  • Slippery When Wet
Re: [GB]Revo RJ kit hhkb layout custom keyboard
« Reply #100 on: Fri, 07 April 2017, 14:47:32 »
I cannot join this groupbuy but I want to wish this GB good luck and swift deliveries.
Nice work RevoTeam!
Offline Skuloth
« Reply #101 on: Fri, 07 April 2017, 14:48:38 »
What layouts to people like to use on hhkb like keyboards?
Trying to figure out how to manage modifiers.
Mirror the hhkb as close as possible. Split backspace and split right shift
Im trying to figure out my left hand mod thing currently. Especially for gaming where I end up using most of the mod keys a lot.
Planck w/ Zealios
Offline ArchDill
« Reply #102 on: Fri, 07 April 2017, 15:02:07 »
One of the things that excites me most about this is that you can make multiple boards to use with it. There is not certain mount where you have to have certain PCB and plates. I will use this case for a long long time. May be a true endgame main stay for me. I want to get a gray but I know most keysets will go with black better so I went with that.
So excited about this Raymond! This is my first Keyboard GB.
Offline Vadurr
  • Valar Morghulis
« Reply #103 on: Fri, 07 April 2017, 15:17:55 »
I know this feeling all too well... Think I'm going to go with gray though so that it can look pretty sitting next to my white and black hhkb's :]
Offline robbles
« Reply #104 on: Fri, 07 April 2017, 15:35:32 »
This is great logic. The case is compatible with other 60% plates though? The cutouts on the bottom row won't get in the way? If not, having a few PCB, swtich, plate sandwiches laying around to throw in this thing would be delicious.
How does one become so interested in a thing like keyboards? When you realize you use a keyboard more than any other tool in your life.
Offline Unforgivable
« Reply #105 on: Fri, 07 April 2017, 15:41:13 »
I really want to see those color samples! Hopefully soon!
Keep in mind guys, you can have whatever layout you want. The PCB is easily reprogramable! Have fun with it! :)
Offline sth
  • 2 girls 1 cuprubber
« Reply #106 on: Fri, 07 April 2017, 15:42:04 »
if you are located in the US or Canada, this will be the link people should use!
https://originative.co/products/revo-hhkb-rj-kit
Limit of 50!
if i am planning on waiting a week to order and you happen to get 50 orders before i can make mine, what should i do?
I read the OP wrong. It's a MOQ of 50!
sweet. if i do end up getting in on this i'll order through you sherry!
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #107 on: Fri, 07 April 2017, 15:42:27 »
looks outstanding
have a fantastic buy
Offline ArchDill
« Reply #108 on: Fri, 07 April 2017, 15:50:40 »
I THINK. Looking at the screw location, it seems to be standard Poker screw whole.
Can you confirm Raymond?
« Reply #109 on: Fri, 07 April 2017, 15:58:25 »
He said any standard 60% can be used. Any plate as well. Be careful about the plate though! Not sure if a Pok3r style plate would work 100%. Most are universal anyway.
Offline Kafka
  • i like clean things
« Reply #110 on: Fri, 07 April 2017, 16:29:34 »
Its tray mount so no issues with the blockers! Any 60 plate should work.
Offline RevoTeam
« Reply #111 on: Fri, 07 April 2017, 17:29:48 »
Nice work RevoTeam!
Thanks my friend. Wish you all the best!
Offline RevoTeam
« Reply #112 on: Fri, 07 April 2017, 17:33:09 »
I think it is. But what kind of Pcb  you want to use? I mean it's fixed on the spacebar row.Nothing can be changed there. Can't really get a poker inside of this baby.
Offline RevoTeam
« Reply #113 on: Fri, 07 April 2017, 17:37:14 »
looks outstanding
Thank you sir. Have a good one :thumb:
Offline RevoTeam
« Reply #114 on: Fri, 07 April 2017, 17:40:42 »
Hi guy since this is tray mount. You guys don't necessarily need a plate. Any PCB like GH60 will work in this. So PCB is something easily replaced.
Offline Skuloth
« Reply #115 on: Fri, 07 April 2017, 17:49:08 »
Ideally a zeal 60 pcb is the plan :P
Planck w/ Zealios
Offline RevoTeam
« Reply #116 on: Fri, 07 April 2017, 17:57:26 »
If it can be used in a poker case. it should be fine.
Offline RevoTeam
« Reply #117 on: Fri, 07 April 2017, 18:01:30 »
Just invoiced everyone who filled in the form. If you are ordering from originative,you can just ignore it.
BTW,The PCB is a custom made. ESC led will face north,and the rest of the leds will face south. This way,it's better for resin keycaps you put in the ESC spot.
Offline johnthedong
« Reply #118 on: Fri, 07 April 2017, 18:11:31 »
Sounds good - with the current LED orientation gmk caps can be used right?
Offline Kafka
« Reply #119 on: Fri, 07 April 2017, 18:14:21 »
Thank god for south facing leds.
Offline johnthedong
« Reply #120 on: Fri, 07 April 2017, 18:23:37 »
Googled, south facing LED's work well with GMK. It's the other way that doesn't work well with GMK/thicker caps. Yay!
Offline gnmar2723
« Reply #121 on: Fri, 07 April 2017, 18:29:26 »
I have a couple more q's --
What color will the pcb be?
Is the diffuser removable, or is is necessary to have it in for the case to work properly?
I'll have to shuffle around some finances real quick, but I am so hyped for this!!  :p
Offline johnthedong
« Reply #122 on: Fri, 07 April 2017, 18:30:26 »
The diffuser is removable as per discussion in the IC thread/here. :) Personally I'm probably going to go with a non-diffuser build.
Offline RevoTeam
« Reply #123 on: Fri, 07 April 2017, 18:30:52 »
You don't have to use diffuser. For the pcb the color is black/gold
Offline johnthedong
« Reply #124 on: Fri, 07 April 2017, 18:34:33 »
Damn, a black/gold PCB would look great when paired with the black option. Just wishing there was a black aluminum version for the plate too now for the all-black look  ;D
Offline gnmar2723
« Reply #125 on: Fri, 07 April 2017, 19:51:42 »
Thanks! I know the IC and GB threads have been moving fast lately; I must have missed it. You could always pick up a LeandreN plate... :D
Offline ArchDill
« Reply #126 on: Fri, 07 April 2017, 20:00:11 »
If I am understanding right, you can use most plates with this case right?
Offline ArchDill
« Reply #127 on: Fri, 07 April 2017, 20:01:59 »
Not wanting to use a Poker. I have a GH60 with a SS plate that I will most likely use until I can get my full kit built.
Offline RevoTeam
« Reply #128 on: Fri, 07 April 2017, 20:08:49 »
Yep, if that's a hhkb-like layout. it has to be 1 1.5 7 1.5 1 on the spacebar row.
Offline johnthedong
« Reply #129 on: Fri, 07 April 2017, 22:15:14 »
Interesting, looking around for full-black aluminum plates now I guess.
Offline bthezebra
« Reply #131 on: Fri, 07 April 2017, 23:02:16 »
Is the grey colour the same as the camp c225 titanium?
I asked him earlier and he said it would be about the same.
Sent from the love gun.
Offline RevoTeam
« Reply #132 on: Sat, 08 April 2017, 00:06:10 »
Yep,it's almost the same.
Offline johnthedong
« Reply #133 on: Sat, 08 April 2017, 00:22:42 »
Hopefully there's more photos soon!  ;D
Offline Vadurr
  • Valar Morghulis
« Reply #134 on: Sat, 08 April 2017, 03:43:13 »
Who's getting a red plate?! Can't decide which color combos to go with...
Offline theillumedpanda
  • Don't point that gun at me - I'm an unpaid intern!
« Reply #135 on: Sat, 08 April 2017, 03:57:50 »
Just out of curiousity: why did you go with tray mount? Some folks over on reddit say that it would have been better to choose something similar like a Duck Viper, because tray mount feels very rigid and not that good.
Offline RevoTeam
« Reply #136 on: Sat, 08 April 2017, 05:48:03 »
I know people want to have a soft type feeling. Still tray mount is not that bad and it's easy to replace. You don't need a plate.After all i am quite happy with mine. With the vintage black everything is good. ;D ;D ;D
Offline RevoTeam
« Reply #137 on: Sat, 08 April 2017, 05:49:49 »
Personally, i think silver plate can't be wrong with anything. Red plate also great. That's why i am this two colors.
Offline RevoTeam
« Reply #138 on: Sat, 08 April 2017, 05:54:22 »
I am waiting for delivery,man. But my photo taking skill just so bad. My friend always say that they lose their desire to buy the stuff by looking at the photo i take for the product.
Anyhow,ill do my best :D :D
Offline Latin00032
« Reply #139 on: Sat, 08 April 2017, 13:32:52 »
What if I already have a pcb, plate, stabs, etc... And I just want the top and bottom case parts?
Offline ArchDill
« Reply #140 on: Sat, 08 April 2017, 13:55:34 »
I PM'ed him and he is not doing the case alone. Only the kit.
Offline Kafka
« Reply #141 on: Sat, 08 April 2017, 17:03:14 »
Just ordered my pink one, phew that was a chunk of change. Super excited though :D
Offline ArchDill
« Reply #142 on: Sat, 08 April 2017, 18:44:37 »
Yeah I debated on it for a day but I know I would regret not getting it when the after market prices kick in haha
« Last Edit: Sat, 08 April 2017, 21:51:28 by ArchDill »
Offline ArchDill
« Reply #143 on: Sat, 08 April 2017, 21:51:12 »
Alright everyone... I am in for a black but I kind of want a gray. Financially, this will be my last board for the year and I will pair it with my last keyset for the year.. GMK Terminal.
What are your opinions on Black vs Gray case for GMK Terminal? I have always wanted a gray case but black is more safe.
Offline Vadurr
  • Valar Morghulis
« Reply #144 on: Sat, 08 April 2017, 22:03:38 »
Definitely go with the black for Terminal.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #145 on: Sat, 08 April 2017, 22:52:44 »
It's hard to go wrong with black.  Pairs well with nearly everything.  Having a black board for your rotation is great and something I am sorely missing...definitely considering switching from the pink...
But pink is so <3
Offline RevoTeam
« Reply #146 on: Sat, 08 April 2017, 23:10:40 »
But pink is so <3
Totally agreed. Black is easy to pair,it can never go wrong. But with terminal,gray can also fit in perfectly. I think the base color of terminal is kind of gray isn't it? ;) ;)
Also pink is so good make everyone want it. Don't change it.
Offline Kafka
« Reply #148 on: Sat, 08 April 2017, 23:14:02 »
Have we hit moq yet?
Offline RevoTeam
« Reply #149 on: Sat, 08 April 2017, 23:21:32 »
Yes,we have. No need to worries about that now.
