Author Topic: [GB]Revo RJ kit hhkb layout custom(waiting to ship out)  (Read 347988 times)
Offline RevoTeam
Re: [GB]Revo RJ kit hhkb layout custom(MOQ reached, invoicing)
« Reply #250 on: Thu, 13 April 2017, 08:21:03 »
I'm about to pay but I don't know if silver is the way to go. D: PAID
You can send a pm to change color if you are ordering with me. ;D ;D ;D
Offline RevoTeam
« Reply #251 on: Thu, 13 April 2017, 08:22:50 »
submitted for gray!
my first hhkb style board. can't wait!
You are not gonna regret this!!
Offline gnmar2723
« Reply #252 on: Thu, 13 April 2017, 10:22:22 »
Could you take a quick photo without the diffuser? I'd like to see what the top and bottom look like without the diffuser :)
Offline RevoTeam
« Reply #253 on: Thu, 13 April 2017, 10:48:43 »
You can see it in the 1st page of this thread. I think it shows pretty clear.
Offline midnight2903
« Reply #254 on: Thu, 13 April 2017, 11:18:48 »
submitted for gray!
I wish I don't screw up my first soldering job on a keyboard tho D:
Offline RevoTeam
« Reply #255 on: Thu, 13 April 2017, 12:03:34 »
Don't worry too much about it. We always do ENIG on our pcb,it's not easy to be broke. Anyway,i can always sell you new PCBs. LOL
« Last Edit: Thu, 13 April 2017, 12:32:08 by RevoTeam »
Offline TelFiRE
« Reply #256 on: Thu, 13 April 2017, 20:40:52 »
I will definitely keep my eye out for more of your designs. As much as I love it, I think TKL is the life for me.
KBD75 GMK Terminal          XD84 DSA Black on GSF + Hana Matcha + Serum
Offline Kafka
  • i like clean things
« Reply #257 on: Thu, 13 April 2017, 20:41:41 »
Did you see Revo's Dr. D tkl?
Offline TelFiRE
« Reply #258 on: Thu, 13 April 2017, 20:43:15 »
Yeah I saw, but I really like the diffused RBG LED element of this one
Offline ArchDill
« Reply #259 on: Thu, 13 April 2017, 21:38:33 »
Last part arrived. Just take some quick pictures for you guys. No PS
So, will the diffuser make the board set up higher when installed or will it replace a part that is aluminum?
Offline onlinelife
« Reply #260 on: Thu, 13 April 2017, 22:27:39 »
Ohh man can't decide on colour. Grey or Silver?
Is the grey like the space grey on apple products?
Offline loud_asian
« Reply #261 on: Thu, 13 April 2017, 22:35:46 »
it will make the board thicker
Offline RevoTeam
« Reply #262 on: Fri, 14 April 2017, 00:14:04 »
It will make it higher. No replacement. :p :p :p
Offline RevoTeam
« Reply #263 on: Fri, 14 April 2017, 00:14:54 »
Not like apple space grey. You can see it in the color chip picture in the first page of this thread.
« Reply #264 on: Fri, 14 April 2017, 08:43:06 »
Is it just me or does the front of the case look very tall? Seems like it would need a wrist rest to type comfortably.
Offline RevoTeam
« Reply #265 on: Fri, 14 April 2017, 09:20:19 »
I think that depends. I never use a wrist and i feel very comfortable. You may need a wrist. But hey i always use cherry profile keycaps. Must use a wrist if you are using SA. :D :D :D
Offline LDobler
« Reply #266 on: Fri, 14 April 2017, 09:23:36 »
How high is it compared to a HHKB pro2? 🤔
« Reply #267 on: Fri, 14 April 2017, 09:30:33 »
Ok then it should be fine, I use cherry profile also.
Offline RevoTeam
« Reply #268 on: Fri, 14 April 2017, 09:34:10 »
Just measure it. It's 21 mm thick in the front. 37 in the back make it 8 degree slope.  Hope this can help you. :thumb: :thumb: :thumb:
Offline LDobler
« Reply #269 on: Fri, 14 April 2017, 09:36:17 »
Thanks! :thumb:
Offline johnthedong
« Reply #270 on: Fri, 14 April 2017, 09:57:15 »
Thanks! :thumb:
Anyone know how thick is a HHKB? I left mine at home, otherwise I'd measure it.  :D
Offline johnthedong
« Reply #271 on: Fri, 14 April 2017, 10:14:20 »
Thanks! :thumb:
Google says the hhkb is about 40mm thick (probably at the thickest point), so I guess the revo is slightly thinner overall.
Offline LDobler
« Reply #272 on: Fri, 14 April 2017, 10:15:46 »
Thanks for the research mate! I was also curious since I no longer own a HHKB  :thumb:
« Reply #273 on: Fri, 14 April 2017, 10:23:43 »
That sounds pretty comfy, thanks  :thumb:
Offline xondat
  • i'm not a star
« Reply #274 on: Fri, 14 April 2017, 12:26:45 »
Thanks! :thumb:
I just measured and it's 16/32mm front/back.
Offline RevoTeam
« Reply #275 on: Fri, 14 April 2017, 13:16:27 »
Thanks! :thumb:
thanks mate.looks like RJ will be a little bit thick.
从我的 iPhone 发送,使用 Tapatalk
« Reply #276 on: Fri, 14 April 2017, 13:16:55 »
Thanks! :thumb:
Can confirm, it's about 17/31
« Last Edit: Sat, 15 April 2017, 01:42:34 by midnight2903 »
Offline mintyfruits
« Reply #277 on: Fri, 14 April 2017, 23:29:21 »
Joined! Very excited to see this finally happening.
Offline johnthedong
« Reply #278 on: Fri, 14 April 2017, 23:30:37 »
Thanks! :thumb:
Welp, thanks for the heads up. Just confirmed with mine too, I guess google wasn't that accurate lol.
Offline ArchDill
« Reply #279 on: Fri, 14 April 2017, 23:44:10 »
Thanks! :thumb:
Anyone know what the Duck Viper is?
Offline johnthedong
« Reply #280 on: Fri, 14 April 2017, 23:47:06 »
Thanks! :thumb:
11 degrees
« Reply #281 on: Sat, 15 April 2017, 01:42:51 »
Are there any pics of the PCB?
Also, is it possible to get another PCB?  :p
Offline ArchDill
« Reply #282 on: Sat, 15 April 2017, 01:56:24 »
He mentioned that it was black and gold but I do not think he has a pic yet. Not sure if he has the proto in hand yet.
Offline RevoTeam
« Reply #283 on: Sat, 15 April 2017, 02:31:49 »
I post in IC thread before. It will be like this:
165886-0
You can also see it in Dr.D GB.
 :p :p :p :p
Offline RevoTeam
« Reply #284 on: Sat, 15 April 2017, 02:33:25 »
I have to order PCB after the GB is finished,so i won't have a picture before GB ends. It will be like the one i did in Dr.D's tkl GB.
 :D :D :D
« Reply #285 on: Sat, 15 April 2017, 02:56:11 »
 :p :p :p :p
omg that looks amazing, can i get another one?  ;)
Offline RevoTeam
« Reply #286 on: Sat, 15 April 2017, 04:20:56 »
Sorry, Don't want to give that option cause it bring me too much workload. Didn't work well last time. Anyway,there are some that don't want a PCB or plate i think you can get another one easily. :thumb: :thumb: :thumb:
Offline futurecrime
  • Get Zooted
« Reply #287 on: Sat, 15 April 2017, 08:39:26 »
I'm waiting on the Lightsaver GB to go live but really want one of these as well. And there's no guarantee of even getting a lightsaver...  It's fine to just buy one with the excuse that it'll be worth more aftermarket (even though I'd have no intention of selling it) right? And it's fine to buy one having never tried HHKB layout right? I've been considering getting an HHKB but I guess this is just gonna be way nicer anyway.
I mean, my hands would look so good on that pink...
Offline RevoTeam
« Reply #288 on: Sat, 15 April 2017, 08:48:38 »
Hi,
Lightsaver is a great board, can't argue with that. I think it's fine you try this layout for the first time. Anyway,it's programmable so i think everyone can get used to this layout.
Oh, there is no way to guarantee it will worth more. I just try to do the best i can. If i did a good job and people like it,the price would certainly go up.
Pink is really good and i am getting one myself. :thumb: :thumb: :thumb:
« Reply #289 on: Sat, 15 April 2017, 08:53:31 »
No probs, if anyone wanna let go of their PCB please PM me.
@Revo, if someone wanna give me their PCB is it possible to arrange it at your side, so there's no need for further shipping  :p
Offline Skuloth
« Reply #290 on: Sat, 15 April 2017, 09:52:41 »
I'll get in touch.
I plan on using a zeal60 pcb with the case so someone is more than welcome to buy my pcb and potentially plate off of me.
Planck w/ Zealios
« Reply #291 on: Sat, 15 April 2017, 10:35:12 »
I'll get in touch.
Would getting it from oco be different in this case? I'm getting it directly from Revo so I'm not sure how the inner procedures work.
Offline mintyfruits
« Reply #292 on: Sat, 15 April 2017, 10:44:09 »
Revo, this may have been answered already, but I didn't see it anywhere: does the PCB support PCB mount switches, or will we need plate mount switches?
Offline RevoTeam
« Reply #293 on: Sat, 15 April 2017, 10:46:17 »
It support PCB mount switches. Btw, you are the first one asked about this.LOL :p :p :p
Offline RevoTeam
« Reply #294 on: Sat, 15 April 2017, 10:51:03 »
No, it won't be any different. I mean you could buy it from him. I will pack each kit the same way,this can make thing much easier for me.Cause you know, i don't want to put 2 pcbs in one box. I always missing something for someone. Anyhow,i think one pcb is enough for you. If you want more later on you can always pm me. And i think lots of people are trying to sell their PCB. :thumb: :thumb: :thumb:
Offline mintyfruits
« Reply #295 on: Sat, 15 April 2017, 12:29:44 »
Great! I am sitting on some PCB mount Zealios, so I will save them for this. :)
« Reply #296 on: Sun, 16 April 2017, 08:29:27 »
How's the MOQ for this? Might have to get stabs myself if it's not reached :(
Offline RevoTeam
« Reply #297 on: Sun, 16 April 2017, 09:58:00 »
We are no there yet. But good news is i may bring the free stabs anyway. Still working on it but ill try my best. :thumb: :thumb: :thumb:
« Reply #298 on: Sun, 16 April 2017, 10:33:30 »
Thanks Revo :)
Offline Kafka
« Reply #299 on: Sun, 16 April 2017, 11:02:36 »
So should I use my Zeal stabs or the Revo stabs?
