Author Topic: switch openers  (Read 4792 times)
Offline Giorgio
switch openers
« on: Mon, 07 August 2017, 02:58:18 »
Hi, what tools do you use to open your switches? I've seen different tools to open the switch when mounted, and to open the switch when not mounted.
Thanks
175235-0
175237-1
Offline pkircher
Re: switch openers
« Reply #1 on: Mon, 07 August 2017, 07:08:02 »
2 flat screwdrivers .. no need for fancy tools - my 2 cents
Offline ctrl
Re: switch openers
« Reply #2 on: Mon, 07 August 2017, 08:13:42 »
Bent paperclips. The ultimate tools.
Offline Giorgio
Re: switch openers
« Reply #3 on: Mon, 07 August 2017, 08:36:09 »
The problem, with most tools, is that when you lift one side of the top of the switch, you need to put something in the gap, because when you lift the other side, the gap otherwise will close. I use angled pliers and a gmk uniqey clip that I put in the gap to prevent it from closing when I work on the opposite side.
Offline TalkingTree
    • My projects
Re: switch openers
« Reply #4 on: Mon, 07 August 2017, 08:45:24 »
You can make such tool by sawing, filing and bending any ready made plate available at your local hardware store.
Offline Giorgio
Re: switch openers
« Reply #5 on: Mon, 07 August 2017, 09:14:05 »
Thanks but I'm not very familiar with those operations, which require a certain precision too... I think that it is easier to just buy the already cut plates  :)
Re: switch openers
« Reply #6 on: Mon, 07 August 2017, 12:15:27 »
Mr Bishop's "trident" tools work great.
- D Trump 2026-10-24
Offline Phenix
Re: switch openers
« Reply #7 on: Mon, 07 August 2017, 12:46:18 »
where can I buy one?
Didnt he run out of stock?
Winter is coming.
Offline lordgiblite
Re: switch openers
« Reply #8 on: Mon, 07 August 2017, 12:54:30 »
I use tweezers because it was just what I had on hand that one time I opened up some switches XD.
Offline ctrl
Re: switch openers
« Reply #9 on: Mon, 07 August 2017, 15:40:00 »
When I have gotten one side up, i run a paperclip's "pin" carefully all the way through, just behind the pegs. It stays there pretty neatly and prevents it from closing again. I'll probably get a proper tool or tweezers at some point for opening the top housing, but I think I'll use this technique for keeping it open.
Offline Arallu
Re: switch openers
« Reply #10 on: Mon, 07 August 2017, 16:08:49 »
« Last Edit: Tue, 03 July 2018, 10:09:40 by Arallu »
Offline Giorgio
Re: switch openers
« Reply #11 on: Mon, 07 August 2017, 16:13:59 »
Thanks, for your suggestion, it will surely be helpful with the harder to reach keys, the stabilized ones.
Offline Leslieann
Re: switch openers
« Reply #12 on: Mon, 07 August 2017, 19:29:33 »
I just got the Mech keyboards tools, I have another set like the screen cap on the way.
I tried tweezers and they just didn't work well for me. I got along just fine with a small flathead screwdriver up until now for switches not mounted and a paperclip or dvd-drive release pin for ones that were, but that was far from elegant and I wouldn't recommend it as it deforms the housing a bit. You aren't likely to destroy them, but they may have trouble holding in a universal plate or PCB mount after. I have a few on my Race that removing the caps rips off the housing.
Spend the few bucks and buy the right tools, you will thank yourself later because while they work, even they could be better.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline 0100010
  • Not Sure
Re: switch openers
« Reply #13 on: Mon, 07 August 2017, 21:23:26 »
This is a goid tool for opening when not mounted : https://geekhack.org/index.php?topic=64115.0
Offline Giorgio
Re: switch openers
« Reply #14 on: Mon, 07 August 2017, 22:57:15 »
Interesting, but I wonder why the thread dried up.
