Author Topic: [IC] MAXKEY Flamingo (GB starts now!)  (Read 31839 times)
Offline hoq
    • wolfmark.work
« on: Mon, 28 August 2017, 06:34:47 »
Renders and layout  pics updated again!
3D render (1U zero missed, sorry)
Inspired by the following photos:
« Last Edit: Wed, 22 November 2017, 18:29:58 by hoq »
Offline hoq
    • wolfmark.work
Re: MAXKEY Flamingo
« Reply #1 on: Mon, 28 August 2017, 06:37:50 »
Temp
Offline The_Boom_Boy
Re: MAXKEY Flamingo
« Reply #2 on: Mon, 28 August 2017, 06:38:23 »
Interesting set
Offline jihadu
Re: MAXKEY Flamingo
« Reply #3 on: Mon, 28 August 2017, 06:46:55 »
Looks interesting
Offline Minha
  • I Don't Want To Die Like Cobain
Re: MAXKEY Flamingo
« Reply #4 on: Mon, 28 August 2017, 07:00:12 »
I love it so much, wished it was SA tho :thumb:
Offline FoC_Tow
  • Brokehlicious
Re: MAXKEY Flamingo
« Reply #5 on: Mon, 28 August 2017, 07:13:17 »
Dat Case O_O
Does the board from the renders exist? Did I miss something?
Offline fishpod
Re: MAXKEY Flamingo
« Reply #6 on: Mon, 28 August 2017, 07:24:16 »
Dat Case O_O
that case actually exists! it was CA66 and they had a GB running in China like a month or two ago with Taobao
And, great work! hoq, would love to see more novelties tho :thumb:
Offline hoq
    • wolfmark.work
Re: MAXKEY Flamingo
« Reply #7 on: Mon, 28 August 2017, 07:34:51 »
I love SA too, but ,due to the busy production schedule of SP, I don't think it's easy to make a SA keycaps now.
Maxkey is also good enough for daily use!
Offline iskalamberge
Re: MAXKEY Flamingo
« Reply #8 on: Mon, 28 August 2017, 07:41:31 »
This looks nice. What profile are you going to be using?
Offline hoq
    • wolfmark.work
Re: MAXKEY Flamingo
« Reply #9 on: Mon, 28 August 2017, 07:44:53 »
I'm planning to use Maxkey, a SA-like high profile which made in China.
Offline hoq
    • wolfmark.work
Re: MAXKEY Flamingo
« Reply #10 on: Mon, 28 August 2017, 08:37:40 »
Dat Case O_O
Yes, I'll make more novelties after I got more ideas.
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
Re: [IC] MAXKEY Flamingo
« Reply #11 on: Mon, 28 August 2017, 08:38:22 »
Very interesting set, would prefer GMK is SA is impossible :thumb:
Offline lovetree
« Reply #12 on: Mon, 28 August 2017, 09:39:28 »
Love this kit!
Hope to proceed to GB in earlier time    :thumb:
Offline tacahiroy
« Reply #13 on: Wed, 30 August 2017, 10:28:10 »
Love this colour way. ED / Planck kit would be preferable :)))
Offline bkw1209
« Reply #14 on: Wed, 30 August 2017, 11:24:49 »
I like it.
Offline zumwalt
« Reply #15 on: Wed, 30 August 2017, 15:51:24 »
Love this.
Offline jesssmithsup
« Reply #16 on: Wed, 30 August 2017, 15:56:20 »
 :thumb: I need this keyboard in my life
Offline hoq
    • wolfmark.work
« Reply #17 on: Fri, 01 September 2017, 08:01:40 »
It's hard to adapt planck with MAXKEY profile I think, unless more 1u keys add. :blank:
Offline aptivaboy
« Reply #18 on: Sat, 02 September 2017, 01:41:37 »
I really like it, although the brown might be a tad too dark compared to the rest of the colorway. It stands out a bit too much. Maybe lighten it just a bit?
Offline hoq
    • wolfmark.work
« Reply #19 on: Sat, 02 September 2017, 04:34:53 »
Ok,I'll change to a lighter color for adapters. I have to think about what is better. a lighter brown or a darker pink?or some other colors....
Offline clappingcactus
« Reply #20 on: Sat, 02 September 2017, 07:35:44 »
I thought the brown was perfect... :(
Offline tacahiroy
« Reply #21 on: Sat, 02 September 2017, 11:24:11 »
Yeah that's fine even if it's blanks
« Reply #22 on: Mon, 04 September 2017, 12:21:21 »
Hi, any update as to when this will go live maybe?
Offline Pentax+Contax
« Reply #23 on: Fri, 08 September 2017, 02:06:46 »
Offline hoq
    • wolfmark.work
« Reply #24 on: Fri, 08 September 2017, 02:08:27 »
I will update some thing later.
As I got from Maxkey, this set will probably run after some other key sets such as : Lime, CalmDepth, Berserk.....
Offline hoq
    • wolfmark.work
« Reply #25 on: Mon, 11 September 2017, 09:05:05 »
Hi, Since some people don't like that deep brown color of adapters, I change it to a light blue color, it makes the whole key set looks a little bit low contrast and feminine, but looks soft in color.
How about it?
Offline mogo
« Reply #26 on: Mon, 11 September 2017, 09:14:25 »
I favor the colorway of the header post at the moment, with the black accent. Black like the beak! Lovely :)
Offline tacahiroy
« Reply #27 on: Mon, 11 September 2017, 09:25:12 »
I prefer Brown one, blue one is kinda ok though
« Reply #28 on: Mon, 11 September 2017, 09:39:18 »
The brown is better.
Offline hoq
    • wolfmark.work
« Reply #29 on: Mon, 11 September 2017, 10:06:15 »
That's the deep brown color ,not black, haha.
Offline mogo
« Reply #30 on: Mon, 11 September 2017, 20:36:53 »
"Black C" is brown? I mean... are you sure? It looks pretty much black on both of my monitors. Alright. ¯\_(ツ)_/¯
Offline hoq
    • wolfmark.work
« Reply #31 on: Mon, 11 September 2017, 21:03:13 »
It's just a Pantone color called "Black C", In fact, it's a deep brown color.......
may be I should keep the brown tone and just make it little bit lighter.
Offline bkw1209
« Reply #32 on: Mon, 11 September 2017, 22:13:17 »
When start gb?
Offline hoq
    • wolfmark.work
« Reply #33 on: Mon, 11 September 2017, 23:50:02 »
When start gb?
Maybe OCT. or later. Maykey is busy in handling some other key sets now.
Offline bkw1209
« Reply #34 on: Tue, 12 September 2017, 10:27:33 »
When start gb?
Thanks
Offline lovetree
« Reply #35 on: Tue, 12 September 2017, 10:28:24 »
I agree with you keeping the brown. But would like to suggest keeping Black C of original color way.
I think Blue was error and Brighter one also would lack of impact.
Hope the GB for this keyset to run ASAP.
Offline mgsickler
« Reply #36 on: Tue, 12 September 2017, 15:35:23 »
Hmm. I think I like the blue one better. Both look pretty good.
Offline hoq
    • wolfmark.work
« Reply #37 on: Wed, 13 September 2017, 02:56:47 »
Ok, it will run in Oct. or later.
Offline midnightrun
« Reply #38 on: Thu, 14 September 2017, 10:41:06 »
Totally in the GB so count me in :)
Offline bluesclera
« Reply #39 on: Thu, 14 September 2017, 16:24:47 »
Can we please have as set of Function keys that match the modifiers. I cant be the only one that dislike the alternating Fn colors.
Offline hoq
    • wolfmark.work
« Reply #40 on: Fri, 15 September 2017, 10:44:54 »
Hi. Do you mean that F1~F4, and F9~F12 are the same color with modifiers?
Offline bluesclera
« Reply #41 on: Fri, 15 September 2017, 10:49:45 »
Yes PLEASE!
Offline tototoru
« Reply #42 on: Fri, 15 September 2017, 18:36:12 »
Is Maxkey able to manufacture non-standard kits like Ergodox ?
Offline hoq
    • wolfmark.work
« Reply #43 on: Fri, 15 September 2017, 23:45:49 »
Yes PLEASE!
OK,I make a mockup to have a look.
From My iPhone 9.99
Offline hoq
    • wolfmark.work
« Reply #44 on: Fri, 15 September 2017, 23:58:23 »
No, they said they can not provide any other keys except 127 keys default base, only they can make some additional novelties.
From My iPhone 9.99
Offline lordgiblite
« Reply #45 on: Sat, 16 September 2017, 10:15:33 »
Interesting choice to have the flamingo novelty on both the win key and the esc key, any reason why?
Offline hoq
    • wolfmark.work
« Reply #46 on: Sun, 17 September 2017, 01:26:51 »
At first, I just put 2 1U flamingo novelties randomly there, because I saw some of the Maxkey keysets put cherry novelies  there,
I thought those cherry novelties can be replaced easily by designers request
But, today, I asked Maxkey , they told me their default Base layout always have those cherry novelties, just like this :
So I have to think about to add some novelties keys and special keys for a additional kit now.
I will revise the layout later.
Offline midnightrun
« Reply #47 on: Sun, 17 September 2017, 16:02:19 »
What about Palms for those keys :)
Offline hoq
    • wolfmark.work
« Reply #48 on: Sun, 17 September 2017, 20:15:35 »
Yes, espesially the second palms. Thanks so much.
Offline hoq
    • wolfmark.work
Re: [IC] MAXKEY Flamingo (update)
« Reply #49 on: Mon, 18 September 2017, 08:26:34 »
I updated the basic layout and added some novelties.
