Author Topic: [IC] SA Hyperfuse and Penumbra Profile Fix-Kit  (Read 30772 times)
Offline breckstar
« on: Sat, 02 September 2017, 09:36:08 »
Howdy,
Hyperfuse is probably my favorite colorway but it has always bothered be that the SA Hyperfuse profile run by Oco was 1-2-3-3-4-4 and not 1-1-2-3-4-4.
Just looking to see how many people would be in for a "Profile Fix-Kit." It would contain the red R1 and R2 rows from the image below. (note it is the DSA image from Oco)
V1
V2
V3
52 keys for Hyperfuse and 51 keys for Penumbra.
Google Form: https://docs.google.com/forms/d/e/1FAIpQLSc-1nyBMbPCtD2eo_3k-NK_YeHYI5whv-mb8vk3T0_Kexp-3Q/viewform
Thanks to Oblotzky for the renders.
Update 12 Oct:
Current interest based on the Google form is after the kit in the quote. Please fill it out if you haven't.
Quotes are in from Melissa and are as follows:
Edit totals 18 Oct:
Hyperfuse Fix kit - 43
25 sets - $105.04 per set
50 sets - $71.68 per set
75 sets - $60.55 per set
100 sets - $54.99 per set
150 sets - $49.43 per set
200 sets - $46.65 per set
250 sets - $44.98 per set
Penumbra Fix Kit - 37
25 sets - $82.05 per set
50 sets - $57.78 per set
75 sets - $49.69 per set
100 sets - $45.64 per set
150 sets - $41.60 per set
200 sets - $39.57 per set
250 sets - $38.36 per set
Production is booked out pretty far right now in SA - these would be summertime next year...
Cheers All
GB link: https://geekhack.org/index.php?topic=93019.0
« Last Edit: Mon, 18 December 2017, 13:13:35 by breckstar »
Offline jhihguan
Re: [IC] SA Hyperfuse Profile Fix-Kit
« Reply #1 on: Sat, 02 September 2017, 09:38:21 »
I will in for this!!!
Offline DreLLin
« Reply #2 on: Sat, 02 September 2017, 11:02:45 »
Will be in!  :thumb:
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #3 on: Sat, 02 September 2017, 11:33:40 »
Would love to join, how about adding Penumbra too? At least it's mods so it can be mixed with Carbon/Godspeed to get Penumbra Solarized
Offline neon_tom
« Reply #4 on: Sat, 02 September 2017, 11:36:46 »
Agreed. I’d be in for both Hyperfuse and Penumbra.
Offline lovetree
« Reply #5 on: Sat, 02 September 2017, 11:54:34 »
Definitely in!
Offline Oblotzky
« Reply #6 on: Sat, 02 September 2017, 12:01:03 »
BTW there are also no R1 INS HOME PAGE UP (edit, these would be covered already with the fix kit) DEL END PAGE DOWN for 96key and similar. Maybe this kit could add some previously unsupported layouts? But gotta be careful not to turn this into a 100$ extension kit  :rolleyes:
« Last Edit: Sat, 02 September 2017, 12:08:18 by Oblotzky »
Offline poolside
« Reply #7 on: Sat, 02 September 2017, 12:49:34 »
The mockup in the OP is from DSA HyperFuse. The SA version shows a few more keys for 1800 layout support which need to be fixed as well:
- numpad minus which needs to be R2 (Edit: already included)
Originative currently have Solarized Penumbra on pre-order with the "fixed" profile (11 2 3 4 4). Does someone know if they have also planned to have a full SA HyperFuse with a corrected profile made?
« Last Edit: Fri, 08 September 2017, 17:02:30 by poolside »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #8 on: Sat, 02 September 2017, 14:23:24 »
In for a fix kit if it comes.
Sent from my SM-G935T using Tapatalk
Offline ullr
« Reply #9 on: Sat, 02 September 2017, 14:29:09 »
Aren’t there are unresolved ‘ownership’ issues around Hyperfuse?
Also for those talking about Penumbra
  • there are definitely unresolved ownership issues around Penumbra
  • to which sculpt would you try to correct it, standard 1‐1‐2‐3‐4‐4 or the R1 1‐2‐3‐3‐3‐4?
Offline Oblotzky
« Reply #10 on: Sat, 02 September 2017, 15:16:44 »
OP states he want's 112344, which makes the most sense
As to colorways, while I agree OCO should be keeping the 'rights' to rerun these sets, this is an option they are not offering. Plus, it does not reduce future revenue stream because this is not a full set, merely an alternative profile fix for existing and mostly sold out sets. The same way I am not offering a R4 bottom row for Oblivion. If you want to run a GB that offers an alternative bottom row, go for it!
On with the show, I guess 25 units is realistic to achieve
The RETURN keys are there because ENTER sucks. Also snuck in a FUNCTION key, CTRL already exists for that spot. Did I miss anything?
« Last Edit: Sat, 02 September 2017, 15:19:32 by Oblotzky »
Offline ullr
« Reply #11 on: Sat, 02 September 2017, 15:39:28 »
Well if we’re adding keys, a 1u blue legend FN key and 1u orange legend ‘del’ or 'backspace’ key would seal the deal for me ;)
See: my post in the GMK expansion kit thread
Would Ctrl+Alt be amenable to an expansion kit for the SA Penumbra group buy? Tentative kit:
It’s missing fewer keys, but I know I’m not the only person (not even close) who would like Solarized alphas. If you made the fourth row R3 profile and included R3 shifts (1.25×, 1.75×, two 2.25×, 2.75×) for the second round it would be compatible with both rounds.
Offline kingnestea
« Reply #12 on: Sat, 02 September 2017, 15:41:39 »
in just for that accent ISO return key :D :D
Offline Oblotzky
« Reply #13 on: Sat, 02 September 2017, 15:52:10 »
Orange 1u BACK SPACE and blue 1u FN makes sense, but orange DEL? not so much IMO. Also 1u BACK SPACE for HF then. 1u CTRL 1u ALT could also be an option, but I think we're starting to look at separating the kits then
Offline ullr
« Reply #14 on: Sat, 02 September 2017, 16:16:32 »
Yeah I really just want either/or, to support 60% split backspace layouts.
Offline Arallu
« Reply #15 on: Sat, 02 September 2017, 16:30:03 »
« Last Edit: Tue, 03 July 2018, 10:06:41 by Arallu »
Offline breckstar
« Reply #16 on: Sat, 02 September 2017, 20:35:38 »
I think you hit it pretty square on. Only thing I can think of else to be added would be accent color arrow keys.
Edit:
I'll be posting the IC on r/mm 4-5 Sept for those who don't browse GH. Assuming things go well, I'll contact SP and Oco and maybe generate an email sign up google form.
« Last Edit: Sat, 02 September 2017, 23:26:55 by breckstar »
Offline simonyunhe
« Reply #17 on: Sun, 03 September 2017, 05:10:01 »
I have both set and really need this fix-kit for sure. ;D
KeyBs:|RS96-Brown|GS-87-White|DIYer60-Red|VA68M-Brown|GS-ALT71-Blue|IKBC-108-Black|
KeyCs:|SA Carbon R1+2|SA Camping|SA Amazing Chocolatier|SA Commando 88 Ghost|SA Hyperfuse|SA Penumbra|SA Doom|SA Creamy Orange|SA Ocean Dolch|SA Lotus*72|SA Trouble Minds R2|DSA Granite|GMK TA|GMK Soware|XDA Mailstone|GM Ember|
Offline Theconejo
« Reply #18 on: Sun, 03 September 2017, 09:17:08 »
If this went through to GB I would be in and then track down a SA HF set. I never used the profile that it comes in from OCO but the one you propose here is so comfy.
Offline ghostjuggernaut
« Reply #19 on: Mon, 04 September 2017, 05:15:24 »
Although I don't disagree with most of what you are saying, BunnyLake was the one who created hyperfuse and it would be nice to let him have a cut on this decision.  I don't personally agree with people re-running sets created by others without permission, but that subject is long moot by now.  But for someone that has brought so much to this community, its common decency to at least give him the chance to say yes or no.
Offline breckstar
« Reply #20 on: Mon, 04 September 2017, 08:04:08 »
I just sent BunnyLake a pm about it and linked this thread. Hope to hear back soon.
Offline Oblotzky
« Reply #21 on: Mon, 04 September 2017, 09:02:21 »
 :thumb: lets cross our fingers
Offline imprevade
« Reply #22 on: Mon, 04 September 2017, 09:49:22 »
I'm in, 100%.
Can we please get some 1u modifiers as well? Ctrl, Alt, and Menu?
Offline breckstar
« Reply #23 on: Mon, 04 September 2017, 10:24:32 »
I'm in, 100%.
We will see :) I don't really want this kit to break the bank. Reddit has requested split backspace support as well (R2 1.5u Backspace/Delete and R1 1u \|). I'll try to figure out everything when requesting quotes from SP about $/key.
Offline Oatburner
« Reply #24 on: Mon, 04 September 2017, 10:57:25 »
Also agree that a blue 1u FN should be added to Penumbra. R1 1u backspace and R1 1u |\ would also be nice.
« Last Edit: Mon, 04 September 2017, 11:01:23 by Oatburner »
Offline imprevade
« Reply #25 on: Tue, 05 September 2017, 10:56:15 »
No problem, I'm in either way. Are you planning bundling Hyperfuse and Penumbra sets together, or will they be offered as two separate kits?
Offline breckstar
« Reply #26 on: Tue, 05 September 2017, 14:22:37 »
Depends on what SP says I'm guessing but I want separate kits run at the same time. I feel that's the best option because I'm sure there's people like me who only have one of the kits and do not need the other.
Offline jnav
  • Endgame is for quitters.
    • Macclack
Re: [IC] SA Hyperfuse and Penumbra Profile Fix-Kit
« Reply #27 on: Tue, 05 September 2017, 14:28:07 »
I'm in.
Offline breckstar
« Reply #28 on: Wed, 06 September 2017, 07:12:10 »
BunnyLake has given blessing to this :) next steps are maybe some initial quotes and then kit adjustments.
Offline Oblotzky
« Reply #29 on: Wed, 06 September 2017, 11:48:31 »
Nice, thanks Bunny!
So what did we want to change? R1 1u \| and BACK SPACE keys? 1x R4 1u ALT and 1x R4 1u CTRL?
Offline Blazestorm
« Reply #30 on: Wed, 06 September 2017, 12:15:38 »
Yay, now I'll actually buy Penumbra if I can get this kit to go with it... and Function for Capslock!
Offline breckstar
« Reply #31 on: Wed, 06 September 2017, 17:42:17 »
I think those (I prefer the 1u backspace to be an arrow) and R2 1.5u Delete? My 1.5u Delete is R3 and I think I've seen others say this as well.
The only other things I think that could be added should be voted on would be a return key in the mint on purple and accent colored arrows both mint and purple.
« Last Edit: Wed, 06 September 2017, 20:05:19 by breckstar »
Offline Oblotzky
« Reply #32 on: Fri, 08 September 2017, 00:06:41 »
Why would you want an icon among what is otherwise a text-only-mods set :/ (well apart from the arrow keys)
I'm unsure about the accent 1u ALT key in the Penumbra kit, I would say the pink 1u CTRL is RCS, but the yellow? It has a tint of green IRL, so I'm not sure if YCE that I picked here is the right one. I kinda doubt they used a custom color...
Also removed the 1u + key from numpad, that one is only needed as R3 not R2 and as such already present in the original set.
52 keys for Hyperfuse, 51 keys for Penumbra
« Last Edit: Fri, 08 September 2017, 00:12:23 by Oblotzky »
Offline ullr
« Reply #33 on: Fri, 08 September 2017, 06:42:51 »
That looks perfect.
Offline imprevade
« Reply #34 on: Fri, 08 September 2017, 08:57:05 »
Offline breckstar
« Reply #35 on: Fri, 08 September 2017, 09:13:16 »
Ah true. I've never looked at the 1u backspace besides my jukebox set which was an arrow. After looking at my other sets for 1u backspace, I kinda lean towards SA Valentine's "BKSP" for the 1u to reduce the cluttered look, but since the other 1u keys are two liners, I like the two line backspace. Sweet renders :)
« Last Edit: Fri, 08 September 2017, 09:16:04 by breckstar »
Offline breckstar
« Reply #36 on: Sun, 10 September 2017, 10:16:59 »
1u FN key with blue legend and 1u backspace with red or orange would be lovely
Got you in V3.
More accent keys would be great! I really like the arrow cluster idea
I'm going to include this in the query to SP to see the price differential. Trying to keep the set value as low as possible.
Accented ISO + Ortho support please
Accent ISO - Check
Ortho - Can be looked at when quoting to SP. Might have to been run as a separate kit as I suspect the interest would be low <10? Including it in the kit would increase the price for everyone who doesn't need it :/ We will see though. Really trying to keep the kit as low priced as possible.
Offline a_ak57
« Reply #37 on: Sun, 10 September 2017, 15:11:27 »
I know you don't have actual prices but roughly what kind of cost would we be looking at?
Offline breckstar
« Reply #38 on: Sun, 10 September 2017, 17:06:07 »
I have no idea. Completely guessing here, but I'm thinking it will be in the range of $1-1.50/key with like a 50 MOQ. So set wise, in the ballpark of $50-75. I would lean towards the higher end if anything. I'll be emailing them Monday and hopefully get some concrete numbers and have them in the OP.
Offline breckstar
« Reply #39 on: Mon, 11 September 2017, 13:15:11 »
Quoting updates:
Melissa has informed me that I need permission to run the sets from the designers. I'm trying to find out whether that is Oco or individuals like BunnyLake and whoever designed Penumbra.
We already have the go from BunnyLake, but I have not looked into Penumbras origins. Waiting on Melissas response and will reach out to Oco if needed.
Edit: looks like BunnyLake ran OG Penumbra as well on CtrlAlt.
Edit 2: getting approval through proper channels now.
« Last Edit: Mon, 11 September 2017, 13:47:50 by breckstar »
Offline xondat
  • i'm not a star
« Reply #40 on: Mon, 11 September 2017, 13:20:00 »
Ctrl Alt ran OG Penumbra; "Ryan Uber" designed/came up with the idea so best bet would be contacting bunnylake and seeing if he can talk to Ryan, because I don't think he's active?
Oco have only reran sets, they didn't design anything.
Offline Oblotzky
« Reply #41 on: Mon, 11 September 2017, 13:29:21 »
Quoting updates:
SA Penumbra was designed by Ryan Uber, BunnyLake ran the GB. Since Ryan Uber is rarely online, I think Bunny is the one in charge.
Offline breckstar
« Reply #42 on: Mon, 11 September 2017, 13:50:32 »
I've sent Bunny another pm with the updates from Melissa. She told me Bunny would be able to give permission for both.
Quoting updates:
See above quote. Bunny said if I needed any help to feel free and ask so I've asked him to contact Melissa and now we wait.
Offline funkybeat7
« Reply #43 on: Tue, 10 October 2017, 12:55:32 »
Welp, now that I have a hyperfuse set on the way I can fill out the IC form!
Offline gbchk
« Reply #45 on: Wed, 11 October 2017, 12:46:11 »
So in! Just bought Penumbra R2 and would love to have a corrected version.
Offline breckstar
« Reply #46 on: Wed, 11 October 2017, 21:38:16 »
Any progress here?
Waiting on official permission through Bunny to SP to run this. Otherwise, Melissa from SP said it will not be run without approval from the designer (Bunny).
Edit 12 Oct: Asking Melissa to contact bunny directly instead of vice versa per bunny's direction. Hopeful to hear something today or next week considering they work Monday-Thursday.
« Last Edit: Thu, 12 October 2017, 08:29:26 by breckstar »
Offline breckstar
« Reply #47 on: Thu, 12 October 2017, 16:08:30 »
Quotes have been added to OP. I will update the current interest numbers for each kit as well sometime later tonight.
Edit:
Can you add Colemak /Dvorak support?
Currently, no. Just sticking to the basic fix-kit.
What is the possible shipment date?
Summer 2018.
Can you run Non-solarized and solarized Penumbra? I bought both D:
No need to run solarized per Oco "Pre-Order: Ships March 2018. All Alphas are Grey on White instead of Yellow. Rows will be 1-1-2-3-4-4."
« Last Edit: Thu, 12 October 2017, 18:30:50 by breckstar »
Offline DreLLin
« Reply #48 on: Fri, 13 October 2017, 04:50:12 »
a bit more expensive than I thought but will be definitely in for both.
Offline breckstar
« Reply #49 on: Fri, 13 October 2017, 08:27:14 »
I feel the same. I was hoping for $50-75 range and it seems doable.
Current numbers:
35 Hyperfuse
30 Penumbra
