Author Topic: [IC] Time TKL (updated photos of the prototype on Oct 25 )  (Read 106822 times)
Offline senter
Re: [IC] Time TKL - 2nd Project of Fox Lab
« Reply #50 on: Mon, 18 September 2017, 14:18:08 »
I really like this concept but I worry about that intricate ornamentation being too fragile and making production difficult in general. Perhaps a sundial instead of moving clock arms? Less moving/delicate parts could reduce potential problems down the road.
These gears and clock pointers are not movable on the current design. This will be a solid board.
Offline alveeno
« Reply #51 on: Mon, 18 September 2017, 14:34:10 »
I'd love split backspace. Will the Gb be limited?
Offline senter
« Reply #52 on: Mon, 18 September 2017, 15:02:56 »
Is there anyway you'd do a 75% or something besides TKL? The design is stunning but there are just too many TKL's out already, I think doing something besides TKL would take this superb design to the next level.
TKL was our original plan. The design is almost finished.
I also found multiple people asked about the 75% version. Now I need to discuss with my partners about our plan.
Offline vtachkov
« Reply #53 on: Mon, 18 September 2017, 15:07:20 »
I'm so in. Will you support both winkey and winkeyless or only winkeyless?
Offline maximm
« Reply #54 on: Mon, 18 September 2017, 15:16:07 »
Go with the TKL, it is way more popular than 75%!
« Reply #55 on: Mon, 18 September 2017, 15:18:25 »
75% this an I won't need another 75%, probably ever.
Sent from my SM-G955W using Tapatalk
Offline HotRoderX
« Reply #56 on: Mon, 18 September 2017, 16:07:00 »
This is case only? I am still totally in just want to figure out what else I would need. I look at that and am shocked! Showed a friend think there in shock also! I want it so badly.
Offline Rodde
« Reply #57 on: Mon, 18 September 2017, 16:31:40 »
It might be easy to assume that, based on the amount of people asking for the 75% version,  the majority would prefer that. Just wanted to add a voice saying that I love it as is, and the people who do are likely busy gushing over the build instead of asking for it to remain the same!
Offline KetchyKech
« Reply #58 on: Mon, 18 September 2017, 16:53:28 »
I don't need another keyboard ---
but your last GB left me so satisfied (speed, quality, communication)
----that I'm absolutely IN
Huge fan of your brand  :-*
Offline KaosJ
« Reply #59 on: Mon, 18 September 2017, 17:16:16 »
YES Please make it 75%, the endgame of the endgames!   I actually really like the design but i doubt I will join if it will be TKL again.
Or why not, make everyone happy and make 2 versions in this GB, TKL and 75%.  At the end only the case will be bigger/smaller, while the Time weights that should be the most important and difficult part will be the same for the 2 versions :D
Idk i would probably be in for anything that is a 75% or a 96-layout
« Last Edit: Mon, 18 September 2017, 17:20:32 by KaosJ »
Offline avid
« Reply #60 on: Mon, 18 September 2017, 18:06:25 »
Beautiful!
Is it possible to have the pcb/plate be top-mounted?
Offline 1905ChelseaBlues
« Reply #61 on: Mon, 18 September 2017, 19:47:36 »
What a beautiful design. Definitely interested in this!
Offline gt1989
« Reply #62 on: Mon, 18 September 2017, 19:54:32 »
Looks amazing, I'll most likely join this if it's a TKL or 75% board. Keep up the great work.  :thumb:
Offline mypainishurt
« Reply #63 on: Mon, 18 September 2017, 20:03:15 »
Im in.
Offline bkw1209
« Reply #64 on: Mon, 18 September 2017, 20:05:30 »
I'm in.
« Reply #65 on: Mon, 18 September 2017, 20:38:57 »
Any chance a Filco PCB + Plate fits this case?
doubtful
i'm hoping for tx87, not phantom
We're considering to support some popular TKL bare-bones, but we don't have their measurements currently.
Message kin25 on telegram, he'll help you with those measurements.
Offline o3okevin
« Reply #66 on: Mon, 18 September 2017, 21:52:24 »
I'm so in
Offline PotatoTM
« Reply #67 on: Mon, 18 September 2017, 22:22:35 »
Any chance for a with windows key version? :)
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #68 on: Tue, 19 September 2017, 00:32:40 »
$1000 founders edition with a functional clock?
I would buy it
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #69 on: Tue, 19 September 2017, 00:53:42 »
Really digging the pastel colored render
Offline HotRoderX
« Reply #70 on: Tue, 19 September 2017, 00:55:26 »
I am just thinking out lout but perhaps TKL would be the way to go? My thinking is better keycap compatibility.. also you just don't see that many TKL boards out there least I don't Seems most customs are 40/60/75 or something unique thats not staggered.
« Reply #71 on: Tue, 19 September 2017, 00:57:51 »
Reddit is pretty much the only community that doesn't use TKL.
China/VN especially use almost nothing but WKL TKL.
Offline senter
« Reply #72 on: Tue, 19 September 2017, 01:08:08 »
I would buy it
You're always joking ;) ;). It doesn't need to be that expensive. It's just a little more expensive than orange .
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #73 on: Tue, 19 September 2017, 01:10:15 »
I would buy it
I would still buy one with a real clock, it wouldn't be that hard to add a battery operated wall clock movement, and an acrylic/glass cover to protect the hands
Offline senter
« Reply #74 on: Tue, 19 September 2017, 01:23:43 »
I would buy it
It's not a clock. It's just decoration. The gears and the pointer are fixed
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #75 on: Tue, 19 September 2017, 01:28:11 »
I would buy it
I guess I'll try to modify it myself
Offline yasintahir
  • Formerly silentreader
« Reply #76 on: Tue, 19 September 2017, 02:01:09 »
PLS DON't MAKE IT RAFFLE OR FCFS I NEED THIS
their last GB was totally open/unlimited
Ikr.. i hope he still do the same for this time
« Reply #77 on: Tue, 19 September 2017, 02:06:23 »
I would buy it
simon pls
Offline ozan6661
« Reply #78 on: Tue, 19 September 2017, 02:14:52 »
+1
luar biasa oh oh oh, hope they do the same
Offline [Lewynlight]
  • Formerly Dymloslouire
« Reply #79 on: Tue, 19 September 2017, 02:16:16 »
I would buy it
simon pls
simon pls (2)
it's like you'd flip the bottom all the time to check the time tho  :))
TGR Jane V1 CE - TGR Jane V2 CE Black Ano - TGR 910 R1 - TGR 910 RE Polycarbonate - TGR 910v3 Prototype - TGR Tris - RS60 - RS65 "Internet Yamero" - RS TKL
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
« Reply #80 on: Tue, 19 September 2017, 03:14:02 »
Im 200% in, this is the next lv sh*t :eek:
Offline KaosJ
« Reply #81 on: Tue, 19 September 2017, 03:16:07 »
I would buy it
simon pls
simon pls (2)
simon pls (3)
But why stopping at a fully functional clock? I think that time travel would be suitable for this keyboard  :thumb:
Offline TeHao
« Reply #82 on: Tue, 19 September 2017, 04:06:38 »
So beautiful. I can't wait for GB.
Offline Vigrith
« Reply #83 on: Tue, 19 September 2017, 09:43:53 »
If this actually ends up being true and the board is only a little more expensive than Orange, I foresee a very, very successful future ahead of you - as well as many happy customers, myself included.
Offline senter
« Reply #84 on: Tue, 19 September 2017, 09:48:07 »
No.
Offline senter
« Reply #85 on: Tue, 19 September 2017, 09:51:12 »
We will have three options, winkey and two types of winkeyless
Offline avid
« Reply #86 on: Tue, 19 September 2017, 09:52:18 »
Is there any estimates when GB will run?
Offline senter
« Reply #87 on: Tue, 19 September 2017, 09:54:19 »
Not just case, it's a keyboard kit. You still need to buy switches, keycaps, cable, stabs.
Another option is to use our assemble service. Then you only need to install your keycaps on it and the board is ready to use.
Offline senter
« Reply #88 on: Tue, 19 September 2017, 09:56:55 »
Beautiful!
Yes the plate will be top mounted.
Offline senter
« Reply #89 on: Tue, 19 September 2017, 09:58:00 »
doubtful
Thanks Puddsy
Offline senter
« Reply #90 on: Tue, 19 September 2017, 10:02:13 »
Thanks Vigrith. We were not trying to design a super expensive board. We actually were balancing the design and cost all the time.
Offline senter
« Reply #91 on: Tue, 19 September 2017, 10:03:04 »
Hopefully the GB will start next month.
Offline Hamel
  • KBDLAB
« Reply #92 on: Tue, 19 September 2017, 10:06:17 »
This looks great.
I'm def interested as long as the design is durable.
나의 SM-G950N 의 Tapatalk에서 보냄
Offline bkw1209
« Reply #93 on: Tue, 19 September 2017, 10:20:30 »
When start gb?
Offline Vigrith
« Reply #94 on: Tue, 19 September 2017, 10:47:49 »
When start gb?
Read 2 posts above yours.
Offline clasicks
  • Formerly KeyboardUser4
« Reply #95 on: Tue, 19 September 2017, 11:58:54 »
i will buy the clock if the time is 4:20  :cool:
Offline Nonster
  • Lo-Ki Studios
« Reply #96 on: Tue, 19 September 2017, 12:32:48 »
This is really awesome, beautiful case design. I'll definitely join once GB begins.
Offline Muiju
« Reply #97 on: Tue, 19 September 2017, 13:10:17 »
count me in
its yo girl
LZ CLSm | mech27v2 | DC60 | E7-V1 |  x1.1
lubed filmed Tealios <3
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #98 on: Tue, 19 September 2017, 13:24:05 »
How am I supposed to type on it when I just want it upside-down all the time?
Offline aspenc4
« Reply #99 on: Tue, 19 September 2017, 14:15:35 »
I adore this; gotta have one.
One comment I'm seeing regularly (as I'm sure you're aware) is that the design is on the bottom, so you won't see it unless you're picking it up constantly. Got me thinking...
Is a matching case or cover possible? I'm in either way but man, that would really make this thing even more special than it already is. If not now, maybe a future group buy? Just a thought.
