Author Topic: the Norbaforce: after-market housing for RealForce TKL keyboards — SHIPPED  (Read 379518 times)
Offline norbauer
  • Plz email shop@norbauer.com; I miss PMs sometimes
    • Ryan Norbauer's personal site
norbauer might have answered this before but not sure can't remember. Do you know if the non powder coated board's will ship earlier then the powder coated ones?
He said that they would in the most recent update above.
Indeed. I generally ship anodized stuff right out within a few days of when it arrives to me—just however long it takes me to personally inspect, pack, and ship each one individually and then batch them up into a big pile for UPS/USPS/DHL to come pick up. But I've gotten pretty fast at the process. :)
Offline HotRoderX
very sweet I am excited to get my hands on the case and rebuild my Topre board. I am hoping I have the money to buy into your FC660C design.. won't lie I am not thrilled with the color choices but at the same time.. this buy's been amazing and my FC660C deserves a nice home also!
Offline Petch
R2 when?  :D
Offline shadow
Hey,
Really looking forward to getting the case as well :D In your typing test video I see you used some foam inserts, and in a post a while back, you mentioned you might make such inserts available around the time when the cases are ready to ship.
Do you think you will be able to do this? I'd be very interested in such foam inserts :)
Offline norbauer
Oh, that’s a good question. I had entirely forgotten about this! I’ll investigate and see what’s possible. :)
Offline avid
Can't wait for this!
Question about euro orders, will they be shipped out altogether when the powder coatings are done or is there sufficient EU orders that there will be more than one deliveries?
Offline salvanipour
I’d like to see those brass plates come to fruition if at all possible.
Offline richard912
Any updates as to when this will ship?
Offline norbauer
Hey Richard. Since you got an anodized case, I'd say that July is a good guess. The boxes and printed enclosure are going to be the last thing completed in the whole Norbaforce assembly and as a result are unfortunately holding everything else up a bit, but we should still fall roughly within my originally envisaged timeline.
Powder cases will take longer. In the past, this has meant from one to multiple months, but I'm currently working hard to shorten my lead times on those by working with a new shop that has faster turnaround times and can do bigger volumes at once. I've had good results in small tests with them, but this has yet to be put to the test with a big batch so far. ;)
Offline Choobies
Will this housing fit the Realforce 91U?  Item # NG0100.  Thinking about picking one up..
Offline xondat
  • i'm not a star
It should do.
Offline shadow
Sounds good! :)
Offline richard912
Thanks for the update, Ryan. July, should give me sufficient time to mod out my RF87.
Offline idlemao
To those who got the WKL version but have the 87u, how would you mod the board so that it fit into the case?
Offline xondat
  • i'm not a star
No, you'd just block the menu key.
« Last Edit: Sat, 12 May 2018, 16:34:44 by xondat »
Offline HotRoderX
There are modifications required, I looked into the wkl option my self.
Basically you have to remove the switch housing from the plate/board for the Win key's. I found a video on doing this that looked sorta simple like they might should just snap off but honestly not 100% sure. Since it was the only video ever found and it is gone now! Hopefully someone else can give you a better more complete answer with step by steps.
Offline idlemao
So just take out the dome/spring on the menu key basically?
Offline xondat
  • i'm not a star
Remove the housing. The dome and spring can stay.
Basically the housings are held in by two small protruding plastic parts on the housing. It's kind of like MX, but you could better compare it to the sliders and how they have a singular bit of plastic sticking out -- it's like that basically.
How do you remove the housing? Same way as sliders. Push it out. You'll deform the plastic sticking out, but not enough so that it won't stick back in next time. I reckon you could put a housing in/out 5-6 times.
Offline HotRoderX
Nice I knew it was something like that not overly complicated but not super simple either. I would assume it takes a gentle touch to get them off with out completely mangling them.
Offline xondat
  • i'm not a star
You do need a little force :))
Offline norbauer
Thanks for sharing all your modding wisdom, xondat! You have a lot more experience in that domain than I do.
Offline xondat
  • i'm not a star
Happy to help where I can :-*
Offline shadow
Did you find out anything yet? :)
Thank you!
Offline norbauer
Thank you!
Yes, we'd have to get a custom die made and, looking at the various MOQs for factories willing to do that, I think it might just make more sense to point people to buy the SilverStone foam on Amazon and cut it down to size themselves. ;)
Instead of the custom-cut foam, I've decided to look into another request, which is PVD-coated upgrade back-plates. I actually just sent out the specs and RFQ for that earlier today and will report back when I know something solid.
Offline le_wraith
I for one am totally fine cutting my own silverstone foam and have plenty lying around.
Offline Mr_BeastQuake
    • Reddit
Thank you!
Anything to drive the Topre game further is a worthy cause.
Offline hayt
****, I love my Realforce so much I don't want to discard the original case. It's time to get another one for this build :)
IMO the Realforce TKL series (87u, 86, etc) is a near perfect keyboard design. Hence why I own two of them :)
Offline ihalatch
Absolutely agree with this, it's amazing out of the box as it is. I'm new to topre but I must admit IMO it's superior to almost anything else except the vintage blacks and some alps :) maybe.
Offline child
The design may be perfect, but the stock case is not. It is squeaky (especially after it's opened and closed again), tends to warp (I had to bend mine right after I got it to get all feet touch the desk), feets are garbage... After a year and a bit the case texture below the bottom row is completely gone for me (btw. the texture on the keys is completely fine, which shows the difference between the material of the two).
So for me Norbaforce is hopefully a huge upgrade to the worst element of the keyboard, which is otherwise great  :thumb:
Offline YouGotRioted
Also bought another one in anticipation of this case. Also, it's like a backup PCB in case they stop production of this model (in favor of Realforce R2).
Offline Kerasan
in my opinion the worst part of realforce is not the case but the plate, after 1 year already shows signs of oxidation.
KMK Labs.
Offline thelaughingman
  • Simultaneously the most starry-eyed idealist and t
This is so cuteeeeeeeeeeeee!
196379-0
Offline Luna
Any chance on this group buy happening again or any unsold cases?
Enigma Gray would look fabulous on my 87U Anniversary!
R2 is unlikely but R1 extras will probs be available late summer. Your best bet is to subscribe to Norbauer's mailing list (https://shop.norbauer.com/) to know when there is extra.
Offline haydoselefantes
Over in hasu's thread, I saw MandrewDavis do a cool mod putting hasu's controller directly into the stock 87u case.
Obviously, it's way too late for this GB, but it would be really cool for a future round!
Offline MajorKoos
  • 1 life please. Extra large.
I have have a pair of these lined up in anticipation.
They work great.
Offline shadow
Thank you!
Ok cool thanks for checking (sorry for my late reply) :) Could you share what the exact dimensions of the foam should be to fit in the case? Also I believe the Silverstone foam has some adhesive on the back, but can you just put it loose in there or should it stick to the back plate or something?
Thank you!
Offline letze
  • Here I am~
Good day
Any update real picture on case  :D
HHKB Professional 2 Type S Stock | Topre RF 87U + Norbaforce + Mix BKE Heavy 60g/ Stock 55g + Silencing ring + Slight lubed with [Krytox GPL 105 housing] & [Krytox GPL 205 stab]
Offline forstsiven
I have a one-off powder coat color: Should I expect closer to October-Dec for shipping?
Offline salvanipour
Any update on the brass/pvd backing plates? I'd love to get in on the ground level for one of those.
Offline norbauer
Oh, god, I hope it won't take that long, but with these powder places it's hard to say with any absolute certainty. Assuming these arrive late July, I'm really hoping I won't still be dealing with shipping out powder cases as late of October. I should have a better sense at the end of, say, August of what the turnaround rate is on the RF cases from the new shop. This one is actually a little easier/faster than the Cooler Master cases because it's only three parts (upper housing and two risers) instead of four.
Offline norbauer
I'm waiting on my Heavy-6 sample in PVD steel to come back to see how we all like the finish on that. If it's good, I'll happily get a quote for an upgrade backplate. One-off prototypes in stainless with PVD coating are so insanely expensive, I just didn't want to get both made at the same time on the chance that the result isn't satisfactory—would have been a lot of wasted money. :S
Offline norbauer
Hey all. Quick update: the first Norbaforce has actually shipped to a group buy participant!
Don't get too excited, however. That one person happened to live in Shenzhen, the same city in which the cases were machined, inspected, and packed, so I had his case sent to him directly rather than making the absurd trip across the Pacific to California and then directly back to Shenzhen. (Another participant in the same city will have to endure that absurdity, however, because he chose a powder coating finish, which is applied here in Silicon Valley.)
Anyway, the cases have all been inspected and are on their way to me as of tomorrow. The stated delivery time window given to me by the freight forwarder is ridiculously wide (26-43 calendar days), but even on the long end of that we're still looking at arrival to me in July.
In the meantime, I'm working on stuff like video assembly instructions and the printed package enclosure, a portion of the artwork for which was teased above by thelaughingman, and which I think you will all really enjoy. While the housings make their slow trip across the ocean, I'll also be working on the rather tedious task of putting together the hardware packets that go with each box and figuring out all the shipping supplies and such that I need to order. :)
Offline hayt
Thank you for the update! I can't wait!!
Offline Burt Macklin
Wonderful news, thanks for the update!
  :thumb:
Offline richard912
The end is nigh ! ! Thanks for the update
Offline Lansky
  • Realest motherthocker
Dis gon' be gud!  :cool:
good update
