Author Topic: [GB] Noxary X60 R (Complete)  (Read 189323 times)
Offline dyrdevil
Re: [GB] Noxary X60 R (Opens 1/20)
« Reply #50 on: Fri, 19 January 2018, 22:41:26 »
xondat,
2 questions if you have time :
1) will the brass plate be mirror finish only?  I really like the look of the brass plate from the previous run.
2) do you have any pics you could post of the dark grey and silver finishes next to each other? Or maybe of the silver next to a classic beige/9009 colorway?
  • Which brass plates are you referring to? I've only done brass for 268 and they're mirror (the same as this).
  • Dark gray with 9009 below. I don't have a silver case to compare, but there are many on Google etc.
Thanks.  I thought the following was a brass plate, sorry if I’m misinformed
Also thanks for the pic. I thought that may have been silver.  The dark grey seems super dark in some pics, and almost silver in others depending on lighting.
finally got mine built. some quick pics:
Offline lunr
« Reply #51 on: Fri, 19 January 2018, 23:03:39 »
Just wondering you mentioned polycarb plate in the IC. Are you still going to offer that as a plate material?
Offline xondat
  • i'm not a star
« Reply #52 on: Fri, 19 January 2018, 23:13:36 »
Oh I see. It's the gold aluminum plate, they came out pretty close to rose golden.
I've asked for the dark gray to be darker in the 268 run, and will keep the same thing going with these. X60 dark gray was super nice, so should be closer to that than the sample.
I did? Probably didn't mean to. I doubt I will unless there is suddenly significant interest.
Mounting will stay the same for when I release X60 V2, so plates with more variety will be available then.
Offline Vadurr
  • Valar Morghulis
« Reply #53 on: Sat, 20 January 2018, 01:01:52 »
A darker gray...Now I'm torn between black or dark gray :eek:
Offline dyrdevil
« Reply #54 on: Sat, 20 January 2018, 10:54:35 »
Will pcb be white b.face?
Offline xondat
  • i'm not a star
« Reply #55 on: Sat, 20 January 2018, 11:04:12 »
No, will be like this:
Offline Captainbuttmonkey
« Reply #56 on: Sat, 20 January 2018, 11:17:21 »
Just noticed in the OP I think you may have accidentally linked the supported layouts for the 268 by mistake
Offline xondat
  • i'm not a star
« Reply #57 on: Sat, 20 January 2018, 11:20:33 »
Haha thanks. Just organizing everything :))
« Reply #58 on: Sat, 20 January 2018, 11:23:23 »
No worries  :p, not that I'm eagerly counting down till 7 or anything even though it's a raffle haha
Offline Vadurr
  • Valar Morghulis
« Reply #59 on: Sat, 20 January 2018, 11:59:37 »
Oh man! A thick acrylic plate would make this look extra bombdiggity!
Offline xondat
  • i'm not a star
Re: [GB] Noxary X60 R (Open)
« Reply #60 on: Sat, 20 January 2018, 13:02:08 »
Offline ns90
« Reply #61 on: Sat, 20 January 2018, 13:08:35 »
I think the KLE link is a bit borked.
Offline xondat
  • i'm not a star
« Reply #62 on: Sat, 20 January 2018, 13:11:09 »
Yeah my bad, seemed to work some times and then it didn't. Try incognito, otherwise just make one from scratch :)
Offline kekstee
« Reply #63 on: Sat, 20 January 2018, 13:11:27 »
Had to use chromium for that one.
Oh well, here's hoping. Good deal inside EU.
Offline ns90
« Reply #64 on: Sat, 20 January 2018, 13:12:41 »
Thanks! Incognito did the trick.
Offline xosk
« Reply #65 on: Sat, 20 January 2018, 13:16:40 »
Raffle form:
https://goo.gl/forms/w6jyzgMtB2i6WsB82
Heh, can we just out "Exactly like Topre HHKB" for KLE?   ^-^
« Reply #66 on: Sat, 20 January 2018, 13:16:55 »
Seemed to work perfectly if copy and pasted but not if clicked =S
Offline Spaghetti
« Reply #67 on: Sat, 20 January 2018, 13:17:50 »
Fingers crossed...
Offline ns90
« Reply #68 on: Sat, 20 January 2018, 13:18:26 »
Yeah I had tried that to no avail. But it did work when I pasted it in incognito.
Offline kekstee
« Reply #69 on: Sat, 20 January 2018, 13:19:10 »
If I think about it I would drop regular shift/bs in case this turns out to be HHKB only.
Offline amnesia0287
  • Formerly Amnesia
« Reply #70 on: Sat, 20 January 2018, 13:20:59 »
Regular backspace is life.
Offline MMKB
« Reply #71 on: Sat, 20 January 2018, 13:24:19 »
Submitted one for a black HHKB case!  :thumb:  For those who don't want to fiddle with KLE:
Offline xondat
  • i'm not a star
« Reply #72 on: Sat, 20 January 2018, 13:24:39 »
Would like to make this clear here, and I will in the form:
YOU NEED AT LEAST 1 PLATE.
If you have chosen no plates, redo your form. Your responses have been deleted.
Offline DreLLin
« Reply #73 on: Sat, 20 January 2018, 13:28:26 »
Entered for a dark grey 60%. Good luck everyone  ;D
Offline ctzn_voyager
« Reply #74 on: Sat, 20 January 2018, 17:03:16 »
Anyone have an imgur link for WKL? The form is not accepting any of my links.
NVM, had to get the direct link rather than a share link.
« Last Edit: Sat, 20 January 2018, 17:14:03 by ctzn_voyager »
Offline boxfrommoon
« Reply #75 on: Sat, 20 January 2018, 17:11:18 »
Anyone have this for WKL? I've been out with the my family all day and couldn't make a ****ing entire layout on my phone walking around, thought there would be default options.
NVM, the form wouldn't even accept my imgur link so I'm ****ed anyway.
Try this one: https://i.imgur.com/0DoD6XS.jpg
« Reply #76 on: Sat, 20 January 2018, 17:15:06 »
Thanks, I figured it out (I think) but I'm not sure my layout is entirely correct. Appreciate the quick help!
Offline xondat
  • i'm not a star
Re: [GB] Noxary X60 R (Open - Last 30 Minutes)
« Reply #77 on: Sat, 20 January 2018, 18:31:29 »
Open for the final 30 minutes, make sure not to miss it if you want a chance :thumb:
Offline xondat
  • i'm not a star
Re: [GB] Noxary X60 R (Closed - Invoices Going Out)
« Reply #78 on: Sat, 20 January 2018, 19:07:10 »
Closed!
Thanks for all the submissions. I'm going to start sending invoices out. :-*
Offline alveeno
« Reply #79 on: Sat, 20 January 2018, 19:13:15 »
Can we get some stats? How many people entered? :)
Offline regionfree
« Reply #80 on: Sat, 20 January 2018, 19:15:03 »
Made it in, I hope :D
« Reply #81 on: Sat, 20 January 2018, 19:38:20 »
Paid!
Offline amnesia0287
  • Formerly Amnesia
Re: [GB] Noxary X60 R (All Invoices Out - 48 Hours To Pay)
« Reply #82 on: Sat, 20 January 2018, 19:42:41 »
No soup for me. I am both sad and relieved :P
Offline ___q
« Reply #83 on: Sat, 20 January 2018, 19:45:27 »
In and paid :thumb:
Offline regionfree
« Reply #84 on: Sat, 20 January 2018, 19:46:03 »
good god, I had mixed reactions when I got the invoice, as I asked for extra plates, stabs, and pcbs. but still settled it, nonetheless :D very happy I got in! WKL 60, here we go!
Offline MMKB
« Reply #85 on: Sat, 20 January 2018, 19:47:27 »
Paid!
Paid! Hope I'm right about the color choice. Your black X60 R1 is stunning.
Offline xondat
  • i'm not a star
« Reply #86 on: Sat, 20 January 2018, 19:48:57 »
All invoices are now out. I hope you got lucky! If not, then I can only apologize.
Everyone has 48 hours to pay their invoices. I'll be cancelling and re-raffling if any go unpaid.
Generally don't but why not.
  • 59 people entered - just under a 1 in 3 chance of winning.
  • 50% went for Dark Gray, 33% went for Silver, and the rest went for Black.
  • 56% for HHKB, 25% for WKL, and 19% for 60%.
  • Brass plates were the most popular, with 45. Stainless Steel with 11, and 23 for Aluminum.
  • 3 people managed to get the last question completely wrong, and 2 people put Prag (maybe a translation thing?)
Offline regionfree
« Reply #87 on: Sat, 20 January 2018, 19:56:30 »
This is the first time i've won a slot in GB raffle :D
Offline kekstee
« Reply #88 on: Sat, 20 January 2018, 19:58:23 »
Whew, slipped in. Went with the dark grey brass HHKB majority it seems.
Did we manage to kill ISO enter btw? (and split left shift)
Prag would be the German variant of Prague.
Offline DreLLin
« Reply #89 on: Sat, 20 January 2018, 20:02:39 »
Invoice paid  :thumb:
Took 60% with ISO layout so you can blame me everytime looking at your plate  ;D
Offline kekstee
« Reply #90 on: Sat, 20 January 2018, 20:04:55 »
Curse you dreLLin. I might drop a brass weight near your foot at the next ffm meetup. ;)
Offline boxfrommoon
« Reply #91 on: Sun, 21 January 2018, 07:35:36 »
Congratulations everyone who won! Sadly I had no luck this time..
xondat any estimations when are you going to be running the V2? And is it also going to be in raffle format?
Offline kmba
  • Formerly tameone
« Reply #92 on: Sun, 21 January 2018, 09:08:07 »
Really DreLLin? Like... Really???? :-\
keyboards.
Offline xondat
  • i'm not a star
« Reply #93 on: Sun, 21 January 2018, 09:17:52 »
Maybe next time ;)
After 280/220, which is after 268... So June/July seems about right.
He's not the only person to ruin the plates :'(
Offline Vadurr
  • Valar Morghulis
« Reply #94 on: Sun, 21 January 2018, 10:28:45 »
Just to clarify, will this dark gray be the same as the previous run, or darker?
Offline xondat
  • i'm not a star
« Reply #95 on: Sun, 21 January 2018, 11:33:38 »
I want it as close to X60 V1 as possible :)
Offline dyrdevil
« Reply #96 on: Sun, 21 January 2018, 12:18:11 »
Paid! There goes my PayPal balance  :-X.
Super happy for this beautiful board to be my first custom after several years of salivating over high end boards.
In for a silver HHKB , brass plate.. gonna stick GMK 9009 on it.
Offline MMKB
« Reply #97 on: Sun, 21 January 2018, 13:11:29 »
Wow, would you drop a hint of the 280 and 220?
Also, speaking of the surface of the case, the R1 X60 has a rather reflective and smooth surface which is cool. A more matte finish is also nice and reflects the light more uniformly. (https://imgur.com/a/gG0Yu X60 vs Viper) Since this is a new factory, do you have any specific preference?
Offline amnesia0287
  • Formerly Amnesia
« Reply #98 on: Sun, 21 January 2018, 13:17:32 »
280/220 is TKL/Numpad
Offline amnesia0287
  • Formerly Amnesia
« Reply #99 on: Sun, 21 January 2018, 13:18:12 »
Grats and good choice, that's what I wanted too ;P
