Author Topic: [IC] Noxary 280 & 220  (Read 167902 times)
Offline xondat
  • i'm not a star
Re: [IC] Noxary 280 & 220 (Update 3/25)
« Reply #250 on: Fri, 30 March 2018, 21:54:25 »
This is kinda unrelated, but will we see an x60 v2 anytime soon?
If this goes how I'd like it to, it'll be after ;D
Offline p_blaze
« Reply #251 on: Sat, 31 March 2018, 19:29:04 »
I just happened to wonder, where are the indicator lights going to be?
Offline xondat
  • i'm not a star
« Reply #252 on: Sat, 31 March 2018, 19:55:59 »
In your switches ;)
Offline SpectreiiI
  • Scribe
« Reply #253 on: Sat, 31 March 2018, 20:00:15 »
In your switches ;)
I designed a triple windowed stepped cap which integrates indicators, but you have to have the corresponding lights mounted on the pcb.
Offline xondat
  • i'm not a star
« Reply #254 on: Sat, 31 March 2018, 21:10:04 »
In your switches ;)
That's nice, but I'm not interested in buying your assets.
Offline SpectreiiI
  • Scribe
« Reply #255 on: Sat, 31 March 2018, 23:06:20 »
In your switches ;)
You lost me.
Offline xondat
  • i'm not a star
« Reply #256 on: Tue, 03 April 2018, 14:36:24 »
Still not a dead project :))
I went with the bottom 220 weight. The other 3 280 weights are the 3 different variants.
Just waiting to order the prototypes and then will run the buy after that. Prototypes should take 2 weeks, so maybe end of this month for GB start?
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #257 on: Tue, 03 April 2018, 14:44:26 »
I like the simple weight designs.  I'll be ready when this goes live.
Offline xondat
  • i'm not a star
« Reply #258 on: Tue, 03 April 2018, 15:36:40 »
By the way, if I think anyone is going to flip, you'll receive a special top piece :p
Offline sony
  • Formerly ultraidiot
« Reply #259 on: Tue, 03 April 2018, 21:07:33 »
I'm sold. Give me one.
Sent from my SM-G960U1 using Tapatalk
Offline xondat
  • i'm not a star
« Reply #260 on: Tue, 03 April 2018, 21:38:02 »
I've mentioned in the 208 IC, so I'll put it here too:
Noxary Discord Server
I mainly use it for group buy communication and future project communication. Some thing just aren't worth posting on GH, so they'll go here :p
Feel free to join to get those really small updates :))
Offline xondat
  • i'm not a star
« Reply #261 on: Wed, 04 April 2018, 12:13:39 »
Final final final versions.
I'm happy with it. Hope everyone else will be :)
Offline BillyTheMute
« Reply #262 on: Wed, 04 April 2018, 13:20:17 »
I love it.  :thumb:
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #263 on: Wed, 04 April 2018, 13:24:31 »
I've got a few questions:
1.  Could you clarify the differences between the 280, 280S, and 280T versions ?
2.  Will there only be a 220S?  or will un-numbered 220 numpads also be available?
3.  Will the little dolphin above the arrow cluster really be there? ( I like it personally  ;) )
Offline kevinzavier
« Reply #264 on: Wed, 04 April 2018, 13:35:05 »
So the 280 is the regular option with either wk or wkl, and plate options as well as multiple color options. 280s is a split weight and numbered edition with unlimited color options. And 280t is basically a limited version that is only wkl, red plate, 2 case colors,  and IS CHEAPER. This is what I understood from xondat
Offline xondat
  • i'm not a star
« Reply #265 on: Wed, 04 April 2018, 13:54:36 »
Might be confusing, but I think it'll be more obvious once I get the samples.
280:
  • Winkey or Winkeyless top pieces
  • Any plate variant, only restriction is red/silver for aluminum
  • One part, unnumbered weight
  • Limited to a few different colors, TBD
  • Universal PCB
  • ~$400 base price
280 S:
  • Any plate variant, no restriction on color
  • Two part, numbered weight
  • No restriction on color, probably Cerakoting offered too
  • Universal PCB
  • ~$400 base price
280 T:
  • Winkeyless top pieces
  • Red 1.5mm Aluminum plate
  • Silver or Dark Gray
  • Single layout PCB
  • ~$??? base price, a bit lower than other two
Or simply, 280 is the normal version; 280 S is the numbered, slightly more special version; and 280 T is the stripped down, focused version. If you're familiar with Porsche, look at the Carrera, Carrera S, and Carrera T. ;)
If the demand is there, I'll make 220 S and 220.
No :)) I do really like it though.
Offline eatRAMEN
  • secret society: BLANKET
« Reply #266 on: Fri, 06 April 2018, 17:19:44 »
joined the discord channel already but created an account just to ask this question: by universal PCB does this mean it supports other ones in the such as the TKL87 L3? I'm asking this in regards to the Noxary 280 :D
« Last Edit: Fri, 06 April 2018, 17:21:53 by eatRAMEN »
Offline xondat
  • i'm not a star
« Reply #267 on: Fri, 06 April 2018, 19:01:12 »
Nope, should've been more clear with that :'(
The PCB dimensions are completely new, so that it fits perfectly with the port placement on my case, and also so it fits inside.
Universal in this case refers to what layouts are supported, so meaning split backspace/left shift/right shift, stepped caps, ISO enter, 1.25u/WKL bottom row.
Offline xondat
  • i'm not a star
« Reply #268 on: Tue, 10 April 2018, 19:41:01 »
Just waiting to receive the final quotes now.
Final pricing and expected dates will follow shortly after those.
Offline bthezebra
« Reply #269 on: Tue, 10 April 2018, 19:47:23 »
Omg omg
Offline Hako
« Reply #270 on: Tue, 10 April 2018, 22:00:46 »
Any chance you'll be able to offer a silver plate in addition to/instead of a red one for the 280 T? That's the only thing stopping me from going for the T right now.
Offline xondat
  • i'm not a star
« Reply #271 on: Tue, 10 April 2018, 22:44:37 »
What's the reasoning behind wanting the T over the normal one? :p
Offline Hako
« Reply #272 on: Tue, 10 April 2018, 22:58:55 »
money  :(
Offline xondat
  • i'm not a star
« Reply #273 on: Tue, 10 April 2018, 23:03:22 »
money  :(
Oh.. I don't think the price difference will be that significant, but FWIW, I am aiming to bring the price of 280/280 T closer to $350 than $400...
Offline xondat
  • i'm not a star
« Reply #274 on: Fri, 13 April 2018, 10:33:05 »
Got the quotes for the case... Just waiting on PCB quotes now.
Unfortunately it won't be near $350, but I still think everything will be very reasonable for what the package is. :(
Offline kevinzavier
« Reply #275 on: Fri, 13 April 2018, 13:33:50 »
When are you expected to get the prototype  :cool: ?
Offline xondat
  • i'm not a star
« Reply #276 on: Fri, 13 April 2018, 13:50:20 »
If I read it right, then 10 (+2/3 ship) days after payment!
Offline xondat
  • i'm not a star
« Reply #277 on: Fri, 13 April 2018, 17:36:39 »
Spoiler?
Yeah probably got to cut a few of these
Offline Jhors2
« Reply #278 on: Fri, 13 April 2018, 19:19:09 »
Hey Xondat,
Any pictures of the plate by itself?  Just curious if you cut any extra reliefs into it for flexibility or not.  The extra plate options seem really interesting.
Duck Blackbird | Duck LSv3 | Duck Unicorn X Legend |  TX-75 | Mira SE | LZ-CP | LZ Iron | LZ Ergo | Duck Jet Fire | OTD 360 Corsa Apple Silver | TGR-910 CE
Incoming: Zeal Zephyr | Duck TC-V3 | Singa R2 | LZ GH v2 | Noxary 280 S | Noxary 220 S
Offline xondat
  • i'm not a star
« Reply #279 on: Fri, 13 April 2018, 19:38:55 »
Hey Xondat,
Best I have.
There isn't any solid research into the extra cuts, but I will be doing some, and if I think it's a massive improvement, I'll probably implement it.
Offline Jhors2
« Reply #280 on: Fri, 13 April 2018, 22:00:33 »
Hey Xondat,
Best I have.
Thank you!  I am really curious about the effect on extra reliefs especially near the mounting points to isolate the case from vibration. As well as the effect on sound/feel.  Great work on the board, looking forward to it.
Offline xondat
  • i'm not a star
« Reply #281 on: Fri, 13 April 2018, 22:15:44 »
Hey Xondat,
Best I have.
Yeah me too. I think boards that use singular layouts sound nicer than universal in my experience, and I couldn't really compare feel in a 65% anyway.
I'll be testing this (or some very close variant, definitely adding stuff for the spacebar/2.25+ keys) in the short future.
I've already worked towards isolation, but in this case between the case and the plate. Hopefully the picture shows it enough:
I'm ordering prototypes for both of these and will go with the better version :p
As for general sound/feeling improvements, I've got 15+ different concepts to try out. Very excited to start to test them, but it'll be after I start this buy, and improvements will be implemented in Series 3 :(
Offline Jhors2
« Reply #282 on: Fri, 13 April 2018, 22:23:28 »
No problem!
I am also curious in extra relief cuts immediately above/below the mount points of the plate itself.  I've seen a few OTD boards that have implemented this and it seemed interesting...Either way I'd like to get a 2 series and 3 series if anything for the sake of comparison.  Great work!  It's really refreshing to see someone thinking critically about these things.
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #283 on: Fri, 13 April 2018, 22:35:45 »
Hey Xondat,
Best I have.
Very interested in these plate cuts and other revisions to mounting etc. - this is what I'm looking for in new designs these days :thumb:
You're a smooth smoothie, you know? ~ Gaear Grimsrud
Offline xondat
  • i'm not a star
« Reply #284 on: Fri, 13 April 2018, 22:42:20 »
No problem!
Ah like on the 456GT?
I can't believe I completely missed that.
Yup, that's now another thing on my list to try. Thanks!! :))
What's the point if I'm not ;D
Offline Jhors2
« Reply #285 on: Fri, 13 April 2018, 22:53:59 »
No problem!
Yes, the 456gt is exactly what I am referencing.  It seems OTD went to great lengths to create as many cuts as possible to isolate the plate and case.  I would also assume that it makes each row of keys sound and feel more consistent with one another.
« Reply #286 on: Fri, 13 April 2018, 23:41:39 »
No problem!
You know it :thumb:
And while we're drawing inspiration from OTD, how about a 360c 'xondat 200
  • ' series logo above the nav arrows? ;)
Offline xondat
  • i'm not a star
« Reply #287 on: Sat, 14 April 2018, 10:55:58 »
I'd assume the same but only one way to find out ^-^
You know it :thumb:
Already a step ahead there :p
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #288 on: Sat, 14 April 2018, 11:09:06 »
You know it :thumb:
Definitely number only. I don't think a logo would look good there imo
Sent from my mobile using Tapatalk
Offline Wetherbee
« Reply #289 on: Sat, 14 April 2018, 21:10:09 »
Oh no  :(
Offline xondat
  • i'm not a star
« Reply #290 on: Sat, 14 April 2018, 22:02:27 »
Don't worry, it's not actually happening :cool:
Offline xondat
  • i'm not a star
Re: [IC] Noxary 280 & 220 (4/15 - Pricing Update)
« Reply #291 on: Sat, 14 April 2018, 22:43:16 »
Right. Pricing time.
Good news is also bad news.
The good news is that the initial fall of in price is pretty low (from 1 pcs to 30 pcs). The bad news is that there aren't any price breaks afterwards.
I was hoping that the price would fall off, but I think it's less than a $8 difference between 30 and 100. The quotes are what they are, and we'll have to roll with that.
The main culprit here is the massive brass weight. It'd be 30% cheaper without it, and it's seriously making me consider doing a lightweight version that's drops the weight.
Now, without rambling too much, prices:
280/280 S
  • Case - $365
  • 1.5mm Plates - $35
  • 5mm Plates - Still working on those prices
  • PCBs - $35
220/220 S
  • Case - $160
  • 1.5mm Plates - $25
  • PCBs - $25
I'll get a list up tomorrow of all the options and spec details. Small spoiler; currently got 11 280 plate options :confused:
I hope I still have everyone's support, I guess this is what happens when you refuse to compromise on a design :))
« Last Edit: Sun, 22 April 2018, 13:30:02 by xondat »
Offline Captain Shwah
« Reply #292 on: Sat, 14 April 2018, 23:04:12 »
Most definitely and I wouldn't have it any other way :thumb:
« Reply #293 on: Sat, 14 April 2018, 23:06:16 »
280 superleggera when
or i guess if you want to stay with the 911 theme, 280RS when
Offline Jhors2
« Reply #294 on: Sun, 15 April 2018, 00:32:45 »
More weight is more better.  I'm really curious what the effect of the weight + 5mm brass plate will be.  Either way the pricing for this seems quite reasonable considering the fact that it looks top tier.
« Reply #295 on: Mon, 16 April 2018, 02:39:04 »
You know it :thumb:
This guy. Too good :p
« Reply #296 on: Mon, 16 April 2018, 02:39:26 »
.. rip
« Reply #297 on: Mon, 16 April 2018, 02:43:42 »
I’d consider buying without weight and running the brass weight later so it’s less of an upfront cost. But I’m just bad at commitments so that’s just me :sigh:
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #298 on: Mon, 16 April 2018, 13:40:45 »
I'll be in for the 5mm brass plate option... I wonder if it will have enough of a weight difference to change shipping costs...  Oh well, it's only money right?
Offline xondat
  • i'm not a star
« Reply #299 on: Mon, 16 April 2018, 14:23:43 »
.. rip
The highs and lows :))
I mean to get rid of the weight entirely, including the hole for the weight.
Good point, maybe. I think it'll take it from 2.4kg to 3.2kg. It won't be much of an increase, maybe $3-5 if so.
By the way, regarding red only aluminum plates, I forgot that red won't really work with Cyan/Pink, so going to offer silver too :thumb:
