Author Topic: [IC] Noxary 280 & 220  (Read 167936 times)
Offline xondat
  • i'm not a star
Re: [IC] Noxary 280 & 220 (4/15 - Pricing Update)
« Reply #300 on: Tue, 17 April 2018, 08:30:29 »
Here are the current plates I'm working with... I need to cut some, what goes? :p
  • Fixed Red Aluminum
  • Fixed Silver Aluminum
  • Fixed Brass
  • Fixed Polycarbonate
  • Universal Red Aluminum
  • Universal Silver Aluminum
  • Universal Brass
  • Universal Polycarbonate
  • Partial Red Aluminum
  • Partial Silver Aluminum
  • Partial Polycarbonate
  • 5mm Red Aluminum
  • 5mm Silver Aluminum
  • 5mm Brass
  • 5mm Polycarbonate
I (rather annoyingly) can justify every single option, but I am thinking of cutting a few if they go unmentioned. I think 7-8 options would be best.
« Last Edit: Tue, 17 April 2018, 08:41:40 by xondat »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #301 on: Tue, 17 April 2018, 08:37:42 »
  • Fixed Brass
  • Universal Brass
  • 5mm Red Aluminum
  • 5mm Brass
  • 5mm Polycarbonate
Fixed brass
Fixed PC
Universal alu silver
Universal brass
Partial poly
5mm red alu
5mm brass
5mm poly
Sent from my mobile using Tapatalk
Offline Choppersuey
« Reply #302 on: Tue, 17 April 2018, 08:45:22 »
You could make a google form with these options and allow like max. 2 picks and the 7-8 plates with the most votes will be offered.
Also, what about steel?  :))
Offline xondat
  • i'm not a star
Re: [IC] Noxary 280 & 220 (4/17 - Plate Update)
« Reply #303 on: Tue, 17 April 2018, 08:52:58 »
There's nothing better than votes :))
Steel feels awful, so no, sorry!
PLEASE CHOOSE WHICH PLATES YOU'LL GET!
« Last Edit: Tue, 17 April 2018, 08:55:27 by xondat »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #304 on: Tue, 17 April 2018, 09:01:54 »
 I like steel :(
Offline Choppersuey
« Reply #305 on: Tue, 17 April 2018, 09:02:42 »
I see, no worries, brass is fine, too  :)
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #306 on: Tue, 17 April 2018, 09:15:50 »
Yikes, that's a lot of choices...  Is there somewhere I can read about the different characteristics ( pros/cons ) of the different plate materials?
Offline xondat
  • i'm not a star
« Reply #307 on: Tue, 17 April 2018, 09:23:57 »
I can only go from my typing experiences with 268 but:
  • Aluminum - Slightly harder bottom out feel, more crisp feeling compared to Brass. Slightly higher pitched noise. Nothing bad, great baseline.
  • Brass - Slightly softer bottom out feel, less crisp, more "blunt" compared to Alu. Slightly lower pitched noise. Overall a tiny bit softer.
  • Polycarbonate - Softer, cushiony, not very crisp. You can tell when you bottom out, but not nearly as much as Alu/Brass imo. Nicest sounding since there isn't a metallic sound.
It's hard finding the right words to describe the feelings.
No one has given their opinion on 5mm plates, so anything said will be guess work until I get the samples.
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #308 on: Tue, 17 April 2018, 15:16:43 »
I feel that you’d only need one 5mm option, say brass, because it is primarily for maximising weight and rigidity, right?
As for me, a fixed poly plate is all I need :D
You're a smooth smoothie, you know? ~ Gaear Grimsrud
Offline xondat
  • i'm not a star
« Reply #309 on: Tue, 17 April 2018, 15:39:01 »
No idea.
Polycarbonate is the best since it's beautiful :p
Offline megaforce
« Reply #310 on: Tue, 17 April 2018, 16:32:38 »
fixed 5mm brass pls
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline futurecrime
  • Get Zooted
« Reply #311 on: Tue, 17 April 2018, 17:01:23 »
« Reply #312 on: Tue, 17 April 2018, 17:52:51 »
No idea.
Polycarbonate is the best full stop :p
Offline wholypantalones
  • text and icon mods plz.
« Reply #313 on: Tue, 17 April 2018, 20:09:19 »
I'm liking brass these days, aluminium is good too.
« Last Edit: Tue, 17 April 2018, 20:11:25 by wholypantalones »
Offline xondat
  • i'm not a star
« Reply #314 on: Tue, 17 April 2018, 20:58:08 »
  • Fixed Brass
  • Universal Brass
  • 5mm Red Aluminum
  • 5mm Brass
  • 5mm Polycarbonate
I think we're down to 7.
  • Fixed Brass
  • Universal Brass
  • 5mm Brass
  • 5mm Polycarbonate
Based on the form and logic, I think these may be the 7 available.
Offline amnesia0287
  • Formerly Amnesia
« Reply #315 on: Tue, 17 April 2018, 21:09:19 »
  • Fixed Brass
  • Universal Brass
  • 5mm Red Aluminum
  • 5mm Brass
  • 5mm Polycarbonate
  • Fixed Brass
  • Universal Brass
  • 5mm Brass
  • 5mm Polycarbonate
No universal alu :O. Thats a bummer as I love alu plates most.
I really wish there were more with the layout support of the 5mm. I don't think I can deal with anything that doesn't support split right shift, and I greatly prefer full touch caps for ctrl. Now i dunno what to do since the only brass plate is the one I'd never user.
The main advantage of the 5mm plate support is that you don't really see anything visibly different from offering split backspace or right shift, i guess you MIGHT be able to see that it supports both caps, but for the most part the look when assembled into the same layout as fixed should be identical. No massive iso gaps and stuff.
Offline Pwner
  • soon™
« Reply #316 on: Wed, 18 April 2018, 05:12:48 »
5mm supports split right shift and both caps options.
Offline xondat
  • i'm not a star
« Reply #317 on: Wed, 18 April 2018, 13:12:14 »
280/280 S/280 T
  • Case - $365
  • PCBs - $35
  • Fixed Red Aluminum - $35
  • Fixed Brass - $35
  • Universal Brass - $35
  • Partial Polycarbonate - $60
  • 5mm Brass - $120*
  • 5mm Polycarbonate - $85
220/220 S
  • Case - $160
  • PCBs - $25
  • Universal Brass - $25
* Price may come down, quotes pending.
Should be it for changes. Hopefully it's a straight line to the start now :p
« Reply #318 on: Wed, 18 April 2018, 15:17:06 »
280/280 S/280 T
  • Case - $365
  • PCBs - $35
  • Fixed Brass - $35
  • 5mm Brass - $120*
220/220 S
  • Case - $160
  • PCBs - $25
Where'd fixed poly plate go  :eek:
Offline xondat
  • i'm not a star
« Reply #319 on: Wed, 18 April 2018, 15:21:08 »
280/280 S/280 T
  • Case - $365
  • PCBs - $35
  • Fixed Brass - $35
  • 5mm Brass - $120*
220/220 S
  • Case - $160
  • PCBs - $25
I doubt it'd 1) hit MOQ, and 2) especially at $75 :(
« Reply #320 on: Wed, 18 April 2018, 16:02:52 »
280/280 S/280 T
  • Case - $365
  • PCBs - $35
  • Fixed Brass - $35
  • 5mm Brass - $120*
220/220 S
  • Case - $160
  • PCBs - $25
:( I think you’re right. But also, $75?? Whew lad.
Offline xondat
  • i'm not a star
« Reply #321 on: Wed, 18 April 2018, 16:13:40 »
280/280 S/280 T
  • Case - $365
  • PCBs - $35
  • Fixed Brass - $35
  • 5mm Brass - $120*
220/220 S
  • Case - $160
  • PCBs - $25
Yeah it sucks. CNC + UV coating + complex switch cutouts = death.
Offline Jedi
« Reply #322 on: Wed, 18 April 2018, 23:44:20 »
Dumb question but is the 5mm plate interchangeable with say the fixed red aluminum?
Offline Choppersuey
« Reply #323 on: Thu, 19 April 2018, 06:11:27 »
Since you're shipping from the UK: there won't be any import taxes within the EU (or specifically Germany), right?
Offline hansichen
« Reply #324 on: Thu, 19 April 2018, 07:16:51 »
That depends on how fast this GB is fulfilled and if there are other weird decisions by the UK government
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #325 on: Thu, 19 April 2018, 07:51:03 »
This. As long as they don't Brexit before fulfillment, you're looking at paying postage only.
Offline Choppersuey
« Reply #326 on: Thu, 19 April 2018, 08:17:40 »
I see, thx both  :thumb:
Edit: @xondat
Ah, got it, thx for explaining. Hope it's the latter
« Last Edit: Thu, 19 April 2018, 12:20:48 by Choppersuey »
Offline xondat
  • i'm not a star
« Reply #327 on: Thu, 19 April 2018, 11:39:16 »
All plates are exchangeable and work with the same chassis.
Not sure at the minute.
If the parts are declared full value, then they'll be made VAT exempt as I'm reshipping (in short terms), and any custom charges will be independent to each package.
If they aren't, and they're low enough to not make a fuss, then it'll save us all money (apart from me, but I could work this into overall costs, not sure).
Offline p_blaze
« Reply #328 on: Mon, 23 April 2018, 20:58:09 »
Any updates? I can't wait to see the prototype :D
Offline xondat
  • i'm not a star
« Reply #329 on: Mon, 23 April 2018, 21:48:11 »
Well I sent the files over to the middleman to place the order on the 9th of April, and I haven’t had confirmation (or communication really). I’m pretty much in the dark right now.
If I don’t see any progress then I’ll have to go direct.
Offline xondat
  • i'm not a star
Re: [IC] Noxary 280 & 220 (4/25 - Samples Ordered)
« Reply #330 on: Wed, 25 April 2018, 08:30:55 »
Samples ordered last night. Estimate was 10 days, will get a solid date in the coming days.
Also got a special thing on the way that'll be a surprise :p
Offline itskuroi
« Reply #331 on: Wed, 25 April 2018, 10:13:58 »
need 280s for cerakote white pls ahhh.
Offline lunr
« Reply #332 on: Thu, 26 April 2018, 13:48:24 »
No other plate option for 220/220 S?
Offline xondat
  • i'm not a star
« Reply #333 on: Thu, 26 April 2018, 14:53:01 »
Still considering it.
It would be hard to meet sufficient numbers when there are considerably less cases.
Offline maxf
« Reply #334 on: Sun, 29 April 2018, 18:45:55 »
looks soooo good!
Offline Etherealsound
« Reply #335 on: Wed, 02 May 2018, 08:53:23 »
So has the aluminum type being used for this project been finalized? Crossing my fingers for the option to have 7075.
Offline Captainbuttmonkey
« Reply #336 on: Wed, 02 May 2018, 14:06:49 »
Actually that's not quite correct, currently a 'transition period' of 21 months from 29th March 2019 has been agreed whereby businesses/people/etc have time to prepare for new rules between the UK and EU to begin whilst all current laws/agreements stay the same as they are currently. Of course this could all change, though I would suggest if it does it will only be extended.
TL;DR: I wouldn't worry about import costs UK>EU until 1st Jan 2021 at the very earliest. More than likely it will get pushed back as a result of government cluelessness/incompetence. Hey if we are really lucky who knows, it may never happen!
Offline xondat
  • i'm not a star
« Reply #337 on: Wed, 02 May 2018, 14:08:05 »
6061, but if you and a few others really want it, happy to try other alloys.
Offline clasicks
  • Formerly KeyboardUser4
« Reply #338 on: Wed, 02 May 2018, 14:11:41 »
Isn't there a healthy price difference in material costs and mfg process with the harder alloy?
6061 is a perfectly good mix for our purposes.
Offline xondat
  • i'm not a star
« Reply #339 on: Wed, 02 May 2018, 14:22:35 »
Yeah 6061 is absolutely fine for this use, but happy to offer more bespoke options for the people that want something different :p
Offline p_blaze
« Reply #340 on: Wed, 02 May 2018, 18:08:22 »
I'd be down if we can get good colors and the price isnt crazy
Offline xondat
  • i'm not a star
« Reply #341 on: Wed, 02 May 2018, 18:13:48 »
If say 5 people wanted 7075, and they're all the same color, I'm happy to make it happen.
Basically, as long as the effort isn't wasted, it's fine.
Offline Oblotzky
« Reply #342 on: Wed, 02 May 2018, 18:18:14 »
Looking for 4 fellow people who want 6063 in dark gray  :cool:
Offline p_blaze
« Reply #343 on: Wed, 02 May 2018, 18:45:01 »
« Last Edit: Wed, 02 May 2018, 19:06:49 by p_blaze »
Offline kevinzavier
« Reply #344 on: Wed, 02 May 2018, 18:53:49 »
Do you mean 7075 in dark gray haha?
Offline kevinzavier
« Reply #345 on: Wed, 02 May 2018, 18:56:07 »
Oh nvmd, no idea what 6063 is
Offline p_blaze
« Reply #346 on: Wed, 02 May 2018, 19:06:33 »
I just saw the Cinque in the project page, those bezels are perfect
I think I'm going to wait for that, so sorry if I don't jump on the 280 xondat :-[
Offline xondat
  • i'm not a star
« Reply #347 on: Wed, 02 May 2018, 19:19:24 »
That probably won't even be this year :'(
Offline p_blaze
« Reply #348 on: Wed, 02 May 2018, 20:44:34 »
I love the design though; this is something I'd wait a year for especially with the quality of the 268. The layout with arrow keys stepped in and blocker above the right arrow key is one of my ultimate keyboard fetishes, and the only thing I would personally change is to block off the 2 keys in the row above the top arrow key like a TKL (would be awesome as an option in the eventual GB or something).
All said, this is as endgame as it gets for me, so I might as well wait for it ;D
Offline xondat
  • i'm not a star
« Reply #349 on: Wed, 02 May 2018, 21:07:39 »
Well I won't spoil too much, but it'll likely be a one layout deal as it is a modernized G80-5000.
Still figuring out what to use instead of the original bottom row, it's impossible to source 3.5u Cherry spacebars :(
