Author Topic: [IC] Noxary 280 & 220  (Read 167901 times)
Re: [IC] Noxary 280 & 220 (Update!)
« Reply #200 on: Fri, 16 March 2018, 14:01:57 »
What kind of alu will be used to make the case? Will there be any chance of it being 7075?
prolly 6061 or 6063 so he can meet the target price
Offline xondat
  • i'm not a star
« Reply #201 on: Fri, 16 March 2018, 14:29:57 »
I'll be going with 6061 since I don't want to take any major changes to what works. I could do a few 7075 as part test, part GB if a few want. :p
Offline p_blaze
« Reply #202 on: Fri, 16 March 2018, 14:32:57 »
Sounds very interesting but if the price is higher as Puddsy said then I probably can't T_T
Offline xondat
  • i'm not a star
« Reply #203 on: Fri, 16 March 2018, 14:36:01 »
There are 3 versions planned, so probably shouldn't make it any more complex anyway :)) :))
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #204 on: Fri, 16 March 2018, 14:38:10 »
What are the benefits of using 7075 vs 6061 aluminum?
Offline p_blaze
« Reply #205 on: Fri, 16 March 2018, 14:45:20 »
3 versions? Regular, limited, and pad?
Offline xondat
  • i'm not a star
« Reply #206 on: Fri, 16 March 2018, 14:47:23 »
3 versions of the TKL :-X
Offline p_blaze
« Reply #207 on: Fri, 16 March 2018, 14:48:09 »
What is the third? :thinking: or is this a surprise  :p
Offline clasicks
  • Formerly KeyboardUser4
« Reply #208 on: Fri, 16 March 2018, 15:41:55 »
ONLY THE BEST DESIGN EVER
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #209 on: Fri, 16 March 2018, 17:17:49 »
Limited cerakote, limited anodized, and regular anodized ?
Offline Etherealsound
« Reply #210 on: Fri, 16 March 2018, 17:46:59 »
I might be down for that
Offline Peiweisgreat
« Reply #211 on: Fri, 16 March 2018, 19:29:51 »
No need to over complicate things for yourself, and what are the differences between the 6061/63 and 7075?
Offline p_blaze
« Reply #212 on: Fri, 16 March 2018, 19:38:35 »
7075 is very good for hard ano
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #213 on: Fri, 16 March 2018, 20:05:54 »
Does it limit color choice?
Offline p_blaze
« Reply #214 on: Fri, 16 March 2018, 20:21:20 »
No clue, but I've seen some really nice hard anos like the FMJ
« Reply #215 on: Fri, 16 March 2018, 22:42:33 »
Yeah, with 7075 the texture and finish of the alu is quite a bit better imo.
« Last Edit: Sat, 17 March 2018, 10:00:32 by Etherealsound »
« Reply #216 on: Fri, 16 March 2018, 23:02:54 »
yes, getting hard ano in colors other than black is generally very expensive and difficult to do
doing type 3 ano tints the color VERY dark, so you can't really do a lot of things you can do with type 2
« Reply #217 on: Fri, 16 March 2018, 23:09:51 »
Yes, most hard anos are usually black or a dark color but it's sort of overkill for a keyboard anyways. I think it's worth it to just go type II and have a variety of colors, namely silver  ;D.
Offline futurecrime
  • Get Zooted
« Reply #218 on: Sat, 17 March 2018, 11:04:46 »
If you're interested you can see a test Yuktsi did here: https://geekhack.org/index.php?topic=76672.0
Offline keebweeb
« Reply #219 on: Sat, 17 March 2018, 20:56:18 »
Really love the 7075's characteristic slight copper-colored tint visible in that test. It'd be cool to see more keyboards in fancier alloys like that if the extra cost isn't too excessive. Getting the anodizing colors you want might prove more difficult with the reduced aluminum content though, at least from what I've gathered reading finishing.com and various firearm forums.
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #220 on: Sat, 17 March 2018, 23:20:57 »
I’m hoping for a purple 280/220 set, so if it’s 7075 then I’ll guess I’ll have to cross my fingers for a limited edition that can get cerakoted.
Offline xondat
  • i'm not a star
« Reply #221 on: Sun, 18 March 2018, 16:48:16 »
Is there any interest in an ISO only plate? I originally made it with the files, might consider running it if a few want it. CLEAN PLATES FOR ALL!
Offline HaveAGoodDay_
« Reply #222 on: Sun, 18 March 2018, 18:09:39 »
Interested
Offline Peppermint216
« Reply #223 on: Sun, 18 March 2018, 18:22:59 »
I wanted a tight ANSI but a few of my sets don't have stepped caps, so I would need a universal (am I right thinking the fixed ANSI is stepped only?)
Offline xondat
  • i'm not a star
« Reply #224 on: Sun, 18 March 2018, 18:37:13 »
Yeah it's currently stepped only, but I may make it fit both. Takes away the point though.
Offline dr_derivative
  • Not a real doctor
    • OC Lab Discord
« Reply #225 on: Sun, 18 March 2018, 19:25:01 »
I'm interested  ;D
GH/Reddit/DT/Discord: dr_derivative | IG: dr_derivative_mk | Discord server: OC Lab
Offline nevaenuf
« Reply #226 on: Sun, 18 March 2018, 19:35:40 »
Sounds like a lot of fun.  I'm in.
Offline Theswetiyeti
« Reply #227 on: Thu, 22 March 2018, 01:42:04 »
Looks really good
Offline Pwner
  • soon™
« Reply #228 on: Thu, 22 March 2018, 06:00:12 »
BANNED!
Offline xondat
  • i'm not a star
Re: [IC] Noxary 280 & 220 (Update 3/25)
« Reply #229 on: Sun, 25 March 2018, 11:51:51 »
GB info since a lot of stuff is happening at the minute...
I still need to order the prototype, but I can't until I've decided what to do with the port placement. Should be deciding tomorrow, and have it ordered by the end of the week.
I can't run more than 2 GBs on GH so it'll be after 268 anyway. Will also show the sort of quality this will be (and judging by the parts from production I already have, it'll be 10/10).
Most likely will have a large GB window but with limit slots to hopefully fill them all. If they aren't filled, probably will get extras as the price I'm aiming for would be at the higher quantity :)
Offline p_blaze
« Reply #230 on: Sun, 25 March 2018, 11:56:04 »
H Y P E
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #231 on: Sun, 25 March 2018, 12:58:34 »
Shut up and take my money!   :))
Offline Skynet_0
« Reply #232 on: Sun, 25 March 2018, 21:46:38 »
I can't wait for this lmao
Offline xondat
  • i'm not a star
« Reply #233 on: Wed, 28 March 2018, 05:39:52 »
Finished development last night... Finally.
Had a family photo:
The main noticeable result is this:
Not much... I know :)) It's super clean though. No large cutout -- just a simple, singular hole.
Will aim for prototypes submitted this week :p
Offline thokir
« Reply #234 on: Wed, 28 March 2018, 05:47:28 »
All four look really great, nice work! Especially this color... in case the GB is gonna happen, please offer a finish + color combination which makes it look like on the renders.  Would be dope :D
Getting all four of them would give one the perfect loadout... but I already know I won't be able to afford that, sadly.
Offline futurecrime
  • Get Zooted
« Reply #235 on: Wed, 28 March 2018, 05:54:54 »
Skillz
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #236 on: Wed, 28 March 2018, 05:59:22 »
Looks great!
Offline xondat
  • i'm not a star
« Reply #238 on: Wed, 28 March 2018, 06:15:35 »
How tall is the 280 board on both sides? What's the keyboard in the middle? Looks interesting.
15mm front faces on all. Dunno about the back.
Keyboard in the middle is a 78 key, same layout as KMAC Mini. It's mainly a reference design as it's the same depth as a 60%, and same width as the TKL.
I'll say it straight away, no plans to run it yet :'(
Offline thokir
« Reply #239 on: Wed, 28 March 2018, 06:27:09 »
You make me cry :(
Offline xondat
  • i'm not a star
« Reply #240 on: Wed, 28 March 2018, 06:29:40 »
You make me cry :(
I already have 6 projects planned, so best not get too ahead :))
Offline thokir
« Reply #241 on: Wed, 28 March 2018, 06:33:16 »
Ugh, 6 projects are a lot. Do you (plan to) handle them all by yourself alone, or will you have some people to help you with them (especially shipping, quality control, talking to the companies etc)? I'd never in my life have the time to do that all alone :D
Offline ihalatch
« Reply #242 on: Wed, 28 March 2018, 06:44:17 »
I like them a lot but don't have the money to participate in your next GB :( Even if I had the money it'd be pretty difficult to get one.
Offline p_blaze
« Reply #243 on: Wed, 28 March 2018, 12:37:28 »
I like the clean cutout, I usually hate those giant holes in most boards
I can't wait to see the proto ^_^
Offline MMKB
« Reply #244 on: Wed, 28 March 2018, 13:14:34 »
Had a family photo:
I love the design language. A rectangle remains a rectangle. Reminds me of Dieter Rams and Corbusier.
Offline Cavemann6
« Reply #245 on: Wed, 28 March 2018, 14:21:15 »
Had a family photo:
Looks great  :thumb:
Offline Muffin_Smasher
« Reply #246 on: Fri, 30 March 2018, 17:02:37 »
I am super hyped to join in on this GB Xondat!   ;)
Offline xondat
  • i'm not a star
« Reply #247 on: Fri, 30 March 2018, 17:14:33 »
GH only allows members to run 2 at a time, so that's going to make it a little easier. I'm good doing everything, it isn't too complex, just a lot of time.
Well nothing should be apart from the numbered ones :'(
Thanks for all the support guys. I'm ordering the prototype next week, so should have it by the end of next month. I hope!
Offline nevaenuf
« Reply #248 on: Fri, 30 March 2018, 20:36:19 »
This buy looks like a lot of fun.  It'll be dope to build.
Offline get_weird
« Reply #249 on: Fri, 30 March 2018, 21:35:00 »
This is kinda unrelated, but will we see an x60 v2 anytime soon?
