Author Topic: Rama Works M60-A [SHIPPED]  (Read 448488 times)
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« on: Sun, 25 March 2018, 07:18:32 »
Missed out? Join the waiting list here: http://m60.iwantrama.works
M60-A
The M60-A represents the benchmark and equilibrium between function and design for us at Rama Works. The gently exaggerated design of the frame is not understated, but rather provocative. Inspiration and evolution from previous models are evident in the beautifully articulated design and the well defined aesthetic, the fingerprint of our ‘Industrial Modern’ designs. The M60-A offers a unique contender in the traditional 60% form factor.
Expertly milled down from a single piece of solid brass & aluminium to it's final shape, hand polished to a mirror finish & beadblasted to a high grit finish, then PVD coated or anodized to the perfect color.
In an effort to provide the best end-user experience available, this board requires no soldering to construct with any Cherry MX-compatible switches. The M60-A offers a USB-C connection attached to the USB Extension PCB. There will be additional PCBs also available for individual sale. The board includes in-switch RGB LEDs under the PCB, which require no installation. PCB design by Wilba.
There is also an optional interior weight for extra heft. The optional interior weight is a beadblasted brass weight which has been PVD coated. The weight adds some extra stability to the exceptionally solid build of the M60-A weighing altogether close to 2.3kg (1.6kg without the additional weight)
There's a slideshow on the info page of the M60-A with various sets & colors :)
What's included?
1 x Top Enclosure (Aluminium)
1 x Base Enclosure (Aluminium)
1 x Back Weight (PVD Mirror-Polished Brass)
2 x Custom Moulded Foot (Silicone - Black)
1 x Polishing Cloth
8 x SS M2 Fixtures
4 x SS M4 Fixtures
4 x SS M3 Fixtures
1 x M60-A PCB with Kailh Switch Sockets (designed by Wilba)
1 x U1-C PCB (USB-C Interface board)
1 x U1-C to M60-A PCB CABLE
1 x USB-C to USB-A cable (USB 3.0)
1 x HEX tool for base fixtures
Various Packaging
OPTIONAL EXTRAS
STARTER KIT w/ STABS + NOVELKEYS BOX ROYAL
INTERNAL WEIGHT KIT + 775 grams (roughly)
PREORDER NOW
https://rama.works/m60-a
Preorder closes April 30th
« Last Edit: Tue, 04 December 2018, 04:38:43 by KingRama »
Didn't notice my personal messages have been disabled for those thinking you have been blocked - to contact please reach out through Facebook messages or support email!
WEB: https://rama.works/
STORE: https://ramaworks.store/
INSTA: @ramaworks
FB: ramaworks
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: Rama Works M60-A
« Reply #1 on: Sun, 25 March 2018, 07:57:59 »
Approved!
Offline Vigrith
« Reply #2 on: Sun, 25 March 2018, 08:24:09 »
Board of the year.
Offline Lisinge
« Reply #3 on: Sun, 25 March 2018, 08:31:57 »
F yeah. I'm so pumped!
In for two dark grey and interior weights. The other colors looks great but i want to be able to freely match with keycaps.
What colors did you guys get?
« Last Edit: Sun, 25 March 2018, 09:20:16 by Lisinge »
Offline clochette
« Reply #4 on: Sun, 25 March 2018, 09:08:09 »
which keycap set is this? would certainly like to get the exact same configuration!
Offline Lisinge
« Reply #5 on: Sun, 25 March 2018, 09:18:56 »
GMK Olivia! https://geekhack.org/index.php?topic=94386.0
Offline clochette
« Reply #6 on: Sun, 25 March 2018, 09:26:15 »
awesome, thanks!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #7 on: Sun, 25 March 2018, 10:58:16 »
So dope. I can't wait.
Sent from my mobile using Tapatalk
Offline MMKB
« Reply #8 on: Sun, 25 March 2018, 11:27:06 »
Joined! How does typing sound without soldering the switches? Could you upload a recording of typing with GMK keycaps and any linear switches?
Offline stxfreak
« Reply #9 on: Sun, 25 March 2018, 12:23:32 »
I think he is still waiting for the pcb, he mentioned several times elsewhere that he'll do stuff like that once he has it!
TGR Jane V2
Offline pixelpusher
« Reply #10 on: Sun, 25 March 2018, 12:27:07 »
More and more people have been reporting issues with the pcb on their M65-a boards.  My best guess is that it is related to the other thing people are reporting. Static shock.
I was convinced it was because of the nylon base causing buildup quickly, and it might be.  But what about the silicone feet?   I was reading that rubber silicon can be conductive or not depending on how it’s made.
Just wish there was a better answer for how to not fry you $400 keyboard other than remember to discharge before you sit down or run a humidifier
This is not isolated to Rama’s projects.  It happens with all of my aluminum boards.  It just happens more with my m65-a
« Last Edit: Sun, 25 March 2018, 12:29:03 by reececonrad »
Offline BongoUnicorns
« Reply #11 on: Sun, 25 March 2018, 12:42:10 »
Would using tiny rubber gaskets to stand off the plate from the top case do anything to prevent the ESD from ruining the PCB?
Offline up-in
« Reply #12 on: Sun, 25 March 2018, 13:31:38 »
Awesome! but need more render for the Lake color.
Offline Peppermint216
« Reply #13 on: Sun, 25 March 2018, 13:50:17 »
Would imagine you need them on both sides of the plate to not conduct through the screws. If so you wouldn't be able plug the USB seen as its hole is cut tight.
Offline mago
« Reply #14 on: Sun, 25 March 2018, 14:24:13 »
Amazing board, can't wait to have it on my desk :thumb:
Offline beekey
« Reply #15 on: Sun, 25 March 2018, 14:25:15 »
So beautiful, would love this as a WKL, instand buy. HHKB is just not for me.
Offline tanvir175
« Reply #16 on: Sun, 25 March 2018, 17:15:21 »
Joined for a Lake!
Offline Brannan
« Reply #17 on: Sun, 25 March 2018, 17:19:26 »
Got in on the silver! So hyped ;D
Offline metalliccharles
« Reply #18 on: Sun, 25 March 2018, 17:37:09 »
This is the best looking board I've ever seen.  Joined as soon as the buy went up!  Is this a possibility for the weight??? :eek: :eek:
Offline tanvir175
« Reply #19 on: Sun, 25 March 2018, 17:50:06 »
Offline l0uie
« Reply #20 on: Sun, 25 March 2018, 19:37:11 »
Would like to see more Lake pictures!
« Last Edit: Mon, 26 March 2018, 00:51:31 by l0uie »
Offline Solotov
« Reply #21 on: Sun, 25 March 2018, 21:16:40 »
Went for Sage (dark green). But I still can't design which keyset would look good on it. Any idea guys?
Flex is love, flex is life.
Offline p_blaze
« Reply #22 on: Sun, 25 March 2018, 21:19:40 »
GMK royal alpha or beige with green text and sublegends
Offline Midori
  • Formerly loktrevor
  • c:
« Reply #23 on: Sun, 25 March 2018, 21:20:13 »
Maybe one of the green sets like Camping or Coniferous. Or you could go with something more muted like 9009, Classic Retro, or Muted.
TGR Jane v2 | Vulcan Pro | Matrix 8X v2.0 | Bean | hbcp | froge | hype hen
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #24 on: Sun, 25 March 2018, 21:20:23 »
Waiting for a typing test. Not sold on Integrated plates.
Offline romeo
« Reply #25 on: Sun, 25 March 2018, 21:21:41 »
i'm so tempted by this, but i'm fully booked for now :(
Offline midnight2903
« Reply #26 on: Sun, 25 March 2018, 21:31:09 »
Hellz YEAAAA
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #27 on: Sun, 25 March 2018, 22:20:25 »
Haven't heard of any issues with Wilba's PCB's (who designed the M60 PCB) - including the Planck's with metal enclosures :)
Oh man, it sounds amazing - even without the PCB - but just waiting on until I get the full kit w/ PCB to post a typing video so all the proper resonance is there - will be tweaking internals if need be :)
Thanks so much!
That weight is actually the gold weight with a purple light reflecting on it :P
INSTA: @ramaworks
FB: ramaworks
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #28 on: Sun, 25 March 2018, 22:23:21 »
What this man said!
9009
Terminal
Camping
INSTA: @ramaworks
FB: ramaworks
Offline xondat
  • i'm not a star
« Reply #29 on: Sun, 25 March 2018, 22:24:03 »
There is also an optional interior weight for extra heft and resonance.
I'm confused by this :eek: :eek:
Are you trying to increase the resonance?
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #30 on: Sun, 25 March 2018, 22:26:55 »
I'm confused by this :o :o
Sorry, that should be reduced - as there is less air-room - not that it makes a ton of difference - still need to get the mic out and record a through samples with/without
INSTA: @ramaworks
FB: ramaworks
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #31 on: Sun, 25 March 2018, 23:04:01 »
is it possible to have an optional carrying case for this?
Offline stxfreak
« Reply #32 on: Mon, 26 March 2018, 02:33:13 »
I dont know if Rama has some himself, but there was a post on reddit last week, from guys who are making carrying cases. They follow the new releases and you can ask them weather the keyboards will fit, for example the m60-a would fit the 65% as it’s a little too big for the 60%.
https://www.etsy.com/de/shop/ModernCoupCases
Sorry for off topic.
TGR Jane V2
Offline gutsack
« Reply #33 on: Mon, 26 March 2018, 14:55:23 »
In for two. So excited.
Offline Vadurr
  • Valar Morghulis
« Reply #34 on: Mon, 26 March 2018, 17:23:43 »
Anyone see or know of some good renders of Dusk with some keysets?
« Reply #35 on: Mon, 26 March 2018, 17:37:13 »
i summon rama
he's been spamming renders in IC threads, so i'm sure he'll be happy to make some more
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #36 on: Mon, 26 March 2018, 19:48:36 »
Not at this point unfortunately - but there's a lot of cool artisan made sleeves like the ones stxfreak posted!
Here are some dimensions useful for getting a sleeve made:
Any keysets you're interested in seeing specifically? :)
There's a few on the main rama.works site (in the slideshow)
GMK PLUM
GMK RED SAMURAI
GMK 9009 w/ the new VIM kit
Here's how the colour looks next to Lake:
And next to Moon:
DUAL WIELD !  :eek:
i summon rama
100% let me know requests!
INSTA: @ramaworks
FB: ramaworks
Offline p_blaze
« Reply #37 on: Mon, 26 March 2018, 20:12:48 »
Kuro, moon, and mist with sanctuary dcs if you really want to kill some time :P
Was hoping for a lunar red tho
Offline Vadurr
  • Valar Morghulis
« Reply #38 on: Mon, 26 March 2018, 20:39:35 »
GMK PLUM
GMK RED SAMURAI
And next to Moon:
DUAL WIELD !  :eek:
i summon rama
These are hot! I'd like to see Olivia, Muted, and HF Origins if possible :)
Offline ihalatch
« Reply #39 on: Mon, 26 March 2018, 20:42:37 »
This is such an aesthetically pleasing board. I'm in. I guess we've got another 3 or 4 weeks to order? Are these available in limited numbers?
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #40 on: Mon, 26 March 2018, 20:49:35 »
IIRC Unlimited number and GB closes 20th April
Offline tanvir175
« Reply #41 on: Mon, 26 March 2018, 21:27:45 »
GMK RED SAMURAI
  :eek: If Red Samurai wasn't for the Dark Red CA66, I would have had to reconsider buying Lake.
Offline Muffin_Smasher
« Reply #42 on: Tue, 27 March 2018, 00:45:09 »
So that Moon looks quite dark grey from the color sample, i like it a lot!
Offline up-in
« Reply #43 on: Tue, 27 March 2018, 03:58:02 »
I have some questions, does the felt lining as shown on the early render on Instagram gonna be there? It's very nice add. And does the extra weight really matter? I've never used a keyboard that weights more than 800g (1.7lbs), I read that M60-A weights 1,5kg without the weight so it's heavy enough but i don't know, the extra wight seems nice to fill the chamber.
Offline Vadurr
  • Valar Morghulis
« Reply #44 on: Tue, 27 March 2018, 04:11:23 »
I believe the felt lining has been removed since it hasn't proven to make much of a difference. The weight is completely optional and up to you. I personally like more heft so I'll be opting for the weight!
Offline kmba
  • Formerly tameone
« Reply #45 on: Tue, 27 March 2018, 05:03:22 »
It will be heavy enough without the additional weight.
keyboards.
Offline audax989
  • NOM NOM NOM
« Reply #46 on: Tue, 27 March 2018, 05:53:21 »
M60-A Sleeve it is. :)
Offline notflipperdan420
  • dalla dalla
« Reply #47 on: Tue, 27 March 2018, 06:07:41 »
looks good  ;)
356L *2 | 356CL Gunmetal *3 | 356CL Black | 356.2 | 356CL DGE SE | 356mini v1 Military | 356mini v1 Black *2 | 356mini v1 Red *2 | 356mini v2 Red | 356N MK2 Silver *2 | 356N MK2 Red | 456GT Pink *3 | 356 Pad *2 | Brass Koala | Koala WK Black | FE Whale WKL | Whale v1 WKL Gunmetal | HHKB Type-S |  G80-5000HAMUS | G80-1838HPU NIB | G81-3000SAT NIB
Current Rotation: HeoK Dolch, HHKB Type-S, 456GT Pink
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #48 on: Tue, 27 March 2018, 08:11:34 »
Kuro, moon, and mist with sanctuary dcs if you really want to kill some time :p
Here you go!
Agree'd! We had a custom bath made up for our grey :D Super happy with how it came out
We have to do some further testing once the PCB comes in, but without we've found no difference as the sound with the 4.5MM integrated already sounds really great - but if necessary it will be included if a difference can be deduced :)
Yep! The extra weight is for people who need that something more, without it it's still decently hefty!
INSTA: @ramaworks
FB: ramaworks
Offline garbo
« Reply #49 on: Tue, 27 March 2018, 08:18:17 »
Since I can’t seem to see it mentioned anywhere, does anyone know if there’s a projected timeline for manufacturing and shipping? Would something like the end of the year be a fair estimate?
