Author Topic: [IC] GMK TA 90 (GB will start June 24!)  (Read 66432 times)
Offline intelli78
Re: [IC] GMK OG TA
« Reply #100 on: Thu, 10 May 2018, 02:03:02 »
Very nice! Are you going to send in your caps for color matching, or use Pantone color chips?
Definitely would've done some things differently in retrospect.
Offline thelaughingman
  • Simultaneously the most starry-eyed idealist and t
Re: [IC] GMK OG TA
« Reply #101 on: Thu, 10 May 2018, 04:32:38 »
Just dropping in to say I'm interested. I have a GMK TA set stashing away and it will always be special to me (1) it's the first GMK set that I could look up and wanted to have (the original MD drop happened before I was into mechkey); and (2) full R5 support - no other GMK sets do it since, at least the ones that I was interested in and/or bought.
Keep it up!  :thumb:
Offline Drclick
  • aka 鸡巴博士
Re: [IC] GMK OG TA
« Reply #102 on: Fri, 11 May 2018, 12:18:11 »
I plan to send my caps to GMK ;D
Offline Drclick
  • aka 鸡巴博士
Re: [IC] GMK OG TA
« Reply #103 on: Fri, 11 May 2018, 12:51:43 »
Many of you want icon mods, how about an icon kit like gmk yuri? It could be compatible with more layouts.
And I have contacted to vendor, price was a little more than I expected.
Offline ideus
  • Björkö.
Re: [IC] GMK OG TA
« Reply #104 on: Fri, 11 May 2018, 14:39:34 »
+1 in for a modi kit.
Offline Vigrith
Re: [IC] GMK OG TA
« Reply #105 on: Fri, 11 May 2018, 16:24:44 »
I would really like that. A lot.
Offline xondat
  • i'm not a star
Re: [IC] GMK OG TA
« Reply #106 on: Fri, 11 May 2018, 16:46:44 »
As long as it's a kit, sure, as I'm not keen on the bottom row.
Offline wholypantalones
  • text and icon mods plz.
Re: [IC] GMK OG TA
« Reply #107 on: Fri, 11 May 2018, 16:46:51 »
does it have to have the odd bottom row symbols? I'd prefer to not have them honestly, it would be cheaper too.
Offline enrique.aliaga
Re: [IC] GMK OG TA
« Reply #108 on: Fri, 11 May 2018, 16:51:55 »
I second that. Skipping those weird looking bottom row icons would make the set cheaper. Unless there’s huge demand for them. Personally, I don’t find them that nice.
Re: [IC] GMK OG TA
« Reply #109 on: Fri, 11 May 2018, 19:07:16 »
Don't think GMK has R5 icon mod moulds already and if so, this is exactly my sentiment LOL
Offline Mcnos
    • GMK Fuyu
Re: [IC] GMK OG TA
« Reply #110 on: Sat, 12 May 2018, 18:56:44 »
Is there an update on this? I'm pretty interested
Offline Drclick
  • aka 鸡巴博士
Re: [IC] GMK OG TA (Update :May 23)
« Reply #111 on: Tue, 22 May 2018, 14:20:14 »
Updated.
Add some kits.
Who can tell me what's difference between  "|" and "¦"?
« Reply #112 on: Tue, 22 May 2018, 14:21:32 »
Updated.
Add some kits.
They’re the same. The “pipe” symbol.
Offline clasicks
  • Formerly KeyboardUser4
« Reply #113 on: Tue, 22 May 2018, 14:22:18 »
very cool, i would be interested!
In terms of the backslash/pipe key, do what the OG board has edit: i see now it was an iso board, but the key has the split pipe down by the left shift.
Dealers choice!
Offline Drclick
  • aka 鸡巴博士
« Reply #114 on: Tue, 22 May 2018, 14:37:19 »
But some OG HAD keyboards have both of them.
« Reply #115 on: Tue, 22 May 2018, 14:39:48 »
Updated.
Add some kits.
The vertical bar vs. parted rule or broken bar. ANSI vs ISO.
https://en.wikipedia.org/wiki/Vertical_bar#Solid_vertical_bar_vs_broken_bar
« Reply #116 on: Tue, 22 May 2018, 14:58:10 »
Rather than reading the entire thread, I'm going to ask for the sake of being lazy:
Will the alphas have the more yellowed look, or will it be similar to intelli's GMK TA?
Either way I'm fine, but for this new iteration I'm kinda hoping for the more yellowed look.
Offline oh_chesteroni
« Reply #117 on: Tue, 22 May 2018, 16:20:32 »
First pic in op. Looks to be more beige than yellow.
Edit: or at least that's what is being aimed for.
« Reply #118 on: Tue, 22 May 2018, 16:37:07 »
That's what I thought, but I wasn't sure if that was just a render thing.
« Reply #119 on: Tue, 22 May 2018, 21:04:02 »
nice update! looking at the Icon kit now, it's not for me, I'm fine with the standard mods as they are. I'll get the spacebar kit for sure, it's got everything  :thumb:
Offline smoian
« Reply #120 on: Tue, 22 May 2018, 21:55:53 »
Glad to see movement on this project. Any ETA on GB timing?
Offline Drclick
  • aka 鸡巴博士
« Reply #121 on: Tue, 22 May 2018, 23:12:28 »
Alpha color will be light gray, the same as original Cherry set.
If you want a yellowed look, you could try to do something to yellow this set.
Offline Drclick
  • aka 鸡巴博士
« Reply #122 on: Tue, 22 May 2018, 23:22:41 »
Updated.
Add some kits.
Thanks for the info!
« Reply #123 on: Tue, 22 May 2018, 23:38:08 »
So darker from intelli's GMK TA, yes?
Sorry, I missed which Uniqey codes this will use.
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
« Reply #124 on: Wed, 23 May 2018, 00:45:54 »
Just a thought, 1.5u bottom row only in R5 kinda ruins the set for layouts like 65/75/96key that can use 3x1.25u left of space and 2x1.5u right of space next to arrows.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #125 on: Wed, 23 May 2018, 00:56:26 »
"Ruins" probably isn't the right word to use here.
If I recall correctly GMK does not have molds for R5 keys in different bottom row sizes other than the ones specified. 1u, 1.5u, 2u, Numpad Enter.
If you want to use the set for other layouts, just use R4 bottom row, which is provided.
Sent from my mobile using Tapatalk
Offline donutcat
    • Donut Cables
« Reply #126 on: Wed, 23 May 2018, 01:18:24 »
No, I mean you have to use the 1.5u keys in R5 whether the rest of the bottom is or not due to the layout. You're stuck with either the 1.5u being the only R5 keys on the bottom or the 1.25u keys being the only R4 keys on the bottom. I'd say that does sorta ruin the bottom row if you have any of these pretty popular layouts.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #127 on: Wed, 23 May 2018, 01:23:53 »
You should consider adding R4 1.5u controls and alts along with the various other R4 1u keys as it is fairly common on the many 65%, 75%, 96-key, and 1800 style layouts to use a mix of 1.25u, 1.5u, or 1u keys. I could imagine it might be awkward mixing R4 and R5 bottom row keys for these cases.
Other than than, I’m definitely in! Have always loved the OG TA colorway, but the original GMK run left a lot to be desired.
I prefer using R5 bottom row, I will consider using R4 bottom row or adding additional R4 row.
So I need some more feedback! :D
Valid point, donut. It seems to have been suggested here. OP should take it into account.
Offline Petch
« Reply #128 on: Wed, 23 May 2018, 03:58:23 »
Leave it out in the sun
Offline ideus
  • Björkö.
« Reply #129 on: Wed, 23 May 2018, 09:41:41 »
Is this going to be run by small vendors or MD?
Offline Brannan
« Reply #130 on: Wed, 23 May 2018, 16:54:10 »
I hope it's not MD ;0
Offline amnesia0287
  • Formerly Amnesia
« Reply #131 on: Wed, 23 May 2018, 23:07:06 »
I agree on the R5 stuff, if it were me I’d include the r4 versions to the base kit and r5 to the r0 kit. That way you keep the base kit down, but still have the option if it sells well. I also am not a big fan of how it looks in photos even if I do enjoy typing on r5. So I could see wanting both.
Regardless, the way it is now greatly hurts compatibility with any non traditional bottom row board which isn’t exactly a rarity these days. Plus, from my understanding r5 keys cost more and for compatibility this set is adding an entire second bottom row to the base.
Offline Drclick
  • aka 鸡巴博士
« Reply #132 on: Thu, 24 May 2018, 07:01:47 »
Yes, there is no similar color in Uniqey codes, so this set will use custom colors.
Offline Drclick
  • aka 鸡巴博士
« Reply #133 on: Thu, 24 May 2018, 07:19:59 »
Not decided yet. I don't know why but it seems people here don't like MD.
MD could offer a cheaper price and we can hit a higher MOQ.
Offline dgneo
  • Supervillain
« Reply #134 on: Thu, 24 May 2018, 07:23:15 »
+1 to R5 bottom row
looks great
« Reply #135 on: Thu, 24 May 2018, 08:09:37 »
+1 to R5 bottom row
looks great
This.
Row 5 both looks and feels great.
Offline ideus
  • Björkö.
« Reply #136 on: Thu, 24 May 2018, 16:38:13 »
MD is not bad price-wise for ConUS; but, it does not ship to some countries and for Europeans final total cost may be too high.
Offline pikku-allu
  • IG: @kinnalek
« Reply #137 on: Fri, 25 May 2018, 09:29:33 »
The spacebar kit could offer much better compatibility for split spacebar boards by simply adding a 1.25u blank.
Offline ideus
  • Björkö.
« Reply #138 on: Sun, 27 May 2018, 14:34:09 »
I think this Norde's key would be better in its DE version:
Offline Denonic
« Reply #139 on: Wed, 06 June 2018, 08:41:54 »
+1. Definitely keen on that top R0.
Offline lumpofunworth
  • I’m a guy, that does stuff, with things, for fun.
« Reply #140 on: Thu, 07 June 2018, 08:26:27 »
I see the appeal, this isn’t the set for me, but I know it will be for a lot of people! Good luck with everything!
I like keyboards like I like people... I like keyboards a bit more come to think of it... nvm
Offline RobotRogue
  • No.
« Reply #141 on: Thu, 07 June 2018, 10:48:26 »
At first I was thinking this should have a blue spacebar option, but now that I look at it more, that would be overkill.
Offline ideus
  • Björkö.
« Reply #142 on: Thu, 07 June 2018, 15:27:07 »
reminds me of a brighter gmk hydro! would fit white cases a little better.
Truth be told, comparing this to hydro is like comparing a toy with a professional tool. Too many features that back the comment to enumerate them here.
« Reply #143 on: Thu, 07 June 2018, 17:25:56 »
True! Never compare a playful set with something as elegant and professional as Hydro!
Offline ideus
  • Björkö.
« Reply #144 on: Thu, 07 June 2018, 17:40:29 »
Good try my friend. But the intrinsic  elegance of OG sets speaks louder.
« Reply #145 on: Thu, 07 June 2018, 17:50:23 »
So you're saying TA is louder?!
Edit:
I'm just pulling your leg, ideus. I'm a big fan of Hydro, but TA was my first GMK set and it's definitely really elegant and beautiful in its simplicity.
I'm just baffled that someone tried to compared the two in the first place!
« Last Edit: Thu, 07 June 2018, 22:21:51 by romevi »
Offline flameray
« Reply #146 on: Thu, 07 June 2018, 20:14:35 »
Really hope this IC goes through. This GMK set got me into keebs  :D
Offline hyperlite218
« Reply #147 on: Thu, 07 June 2018, 20:17:15 »
This ic would push yuri off of my board. I want it!
Offline Drclick
  • aka 鸡巴博士
« Reply #148 on: Sat, 09 June 2018, 22:20:36 »
Updated! Thanks for your suggestions :thumb:
Offline Drclick
  • aka 鸡巴博士
« Reply #149 on: Fri, 15 June 2018, 15:26:23 »
It seems that all the TA keyboards were made in 1990(Cherry date code C), so I would like to name this set "GMK TA 90".
What do you guys think?
GMK TA OG?
GMK TA Retro?
GMK TA Origin?
Barring accidents, GB will start next week!
